    4. [SourceAnalytix 0.4.8-Final] Released !
      crunchip Forum Testing Most Active @tugsi last edited by
      @tugsi ok
      • David G.
        ich habe Probleme mit einem Datenpunkt.
        Der Zähler wurde denke resettet (kommt dort leider recht oft vor).
        sourceanalytix.0
        2023-01-03 07:54:58.784	error	Initialization of alias.0.Netzwerk.Internet.Modem.Daten_empfangen failed, check warn messages !
        sourceanalytix.0
        2023-01-03 07:54:58.783	error	Cannot handle calculations for alias.0.Netzwerk.Internet.Modem.Daten_empfangen, check log messages and adjust settings!
        sourceanalytix.0
        2023-01-03 07:54:58.783	error	Troubleshoot Data alias.0.Netzwerk.Internet.Modem.Daten_empfangen custom Data : {"type":"state","common":{"name":"Daten_empfagen","role":"state.argument.out","type":"number","read":true,"write":true,"alias":{"id":"upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived","read":"Math.round((val / 1000000000)* 10) / 10"},"unit":"GB","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","start_day":18.02069216104943,"start_week":0,"start_month":18.02069216104943,"start_quarter":18.02069216104943,"start_year":18.02069216104943,"alias":"Internet_Daten_empfangen","selectedPrice":"Strom","consumption":true,"valueAtDeviceReset":37.58226645215021,"valueAtDeviceInit":0,"cumulativeValue":18.02069216104943}}},"_id":"alias.0.Netzwerk.Internet.Modem.Daten_empfangen","native":{},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1672596752394}
        sourceanalytix.0
        2023-01-03 07:54:58.782	error	Check settings for alias.0.Netzwerk.Internet.Modem.Daten_empfangen ! Known valueAtDeviceReset : (37.58226645215021) > known cumulative value (35.68226645405021) cannot proceed
        Eine Idee wie ich den wieder ans laufen bekomme?
          arnold last edited by
          ich habe SA gestoppt ,dann die Werte eingetragen (01.01.2023)
          "cumulativeValue" komplett gelöscht
          Datenpunkt cumulativeReading eingetragen 1034.02
          jetzt steht dort
          und so sehen die daten punkte aus
          soll aber 1.7kwh stehen (statt 0.177 kWh) wieso kommen da minus Werte
          Adapter läuft schon 5 Tage, wo mache ich Fehler
          R crunchip 2 Replies Last reply Reply Quote 0
            ReverZ @arnold last edited by ReverZ
            Bei mir ist es so, dass bei fast allen Datenpunkten 2023er Unterverzeichnisse angelegt wurden aber nicht für den Volkszähler.
            Ich hab den Adapter bereits mehrmals neu gestartet aber er bleibt er hartnäckig bei 2022.
            Hat jemand noch eine Idee, wie ich sourceanalytix dazu überreden kann, den Jahreswechsel zu 2023 zu vollziehen?
              crunchip Forum Testing Most Active @arnold last edited by
              @arnold sagte in [SourceAnalytix 0.4.8-Final] Released !:
              weil ein device reset erkannt wurde
              wo?
              wo?
                crunchip Forum Testing Most Active @ReverZ last edited by
                @reverz sagte in [SourceAnalytix 0.4.8-Final] Released !:
                selbiges wie https://forum.iobroker.net/post/920443 ?
                  ReverZ @crunchip last edited by
                  @crunchip
                  Ja ähnlich. Mit dem Unterschied, dass er gar nichts für das Jahr 2023 angelegt hat.
                  Die Werte der Smartmeter-Datenpunkte selbst werden munter aktualisiert nur sourceanalytix will hier das Jahr 2023 nicht einläuten.
                    crunchip Forum Testing Most Active @ReverZ last edited by crunchip
                    und das loggen für diesen Datenpunkt ist auch noch aktiv?
                    zeig mal das RAW vom original Datenpunkt(Zähler)
                      @crunchip
                      Das ist einer der beiden Datenpunkte:
                        "_id": "sonoff.0.Volkszaehler.Strom_energy",
                        "common": {
                          "role": "value",
                          "read": true,
                          "write": false,
                          "type": "number",
                          "name": "Volkszaehler Strom  energy",
                          "custom": {
                            "influxdb.0": {
                              "enabled": true,
                              "storageType": "",
                              "aliasId": "Hausstromzaehler_energie",
                              "debounceTime": 0,
                              "blockTime": 0,
                              "changesOnly": true,
                              "changesRelogInterval": 0,
                              "changesMinDelta": 0,
                              "ignoreBelowNumber": "",
                              "disableSkippedValueLogging": false,
                              "enableDebugLogs": false,
                              "debounce": 1000,
                              "ignoreZero": true
                            "sourceanalytix.0": {
                              "enabled": true,
                              "selectedUnit": "Detect automatically",
                              "deviceResetLogicEnabled": true,
                              "threshold": 1,
                              "start_day": 0,
                              "start_week": 0,
                              "start_month": 0,
                              "start_quarter": 0,
                              "start_year": 0,
                              "alias": "hausstrom_energie",
                              "selectedPrice": "ElectricityDay",
                              "costs": true,
                              "consumption": true,
                              "basicRate": true,
                              "meter_values": true
                        "native": {},
                        "type": "state",
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                          "owner": "system.user.admin",
                        "user": "system.user.admin",
                        "ts": 1673278782290
                      Und die grafische sourceanalytix-Konfiguration:
                        "start_day": 0, "start_week": 0, "start_month": 0, "start_quarter": 0, "start_year": 0,
                        hast du diese selbst eingetragen?
                        wie sehen die Ordner/letzten Werte in 2022 aus?
                          @crunchip
                          Nein, an den Werten war ich nicht dran.
                          Jetzt hab ich nochmal den Adapter neu gestartet und jetzt kamen auch Fehlermeldungen, mit denen ich etwas anfangen konnte. Hat vielleicht was damit zu tun, dass ich den Smartmeter mal durchgestartet hab.
                          Es sieht so aus, dass er mit der Einstellung "Detect Automatically" für "Select Unit" im Fall des Smartmeters nicht klargekommen ist. Erst nachdem ich die Einheiten für die beiden Datenpunkte explizit ausgewählt hab, wurde das 2023-Verzeichnis angelegt.
                          Wenn ich mich recht erinnere, hatte ich den MQTT-Topic Mitte Dezember geändert und die Logging-Einstellungen für den neuen Objekt-Baum entsprechend neu gesetzt. Vermutlich hatte ich "Detect Automatically" wie für die anderen Datenpunkte ausgewählt und seit dem streikt der Adapter bezüglich des Smartmeters.
                          Es ist also kein Jahreswechsel-Problem sondern es ist die Einheit, die Schwierigkeiten macht.
                            tja, mit dieser Info wäre womöglich das Problem schneller gefunden. Aber gut das es jetzt behoben ist
                              arnold @crunchip last edited by
                              @crunchip
                              wo? im RAW (X-----rot markiert)
                              wo? RAW
                              obiekt startet jeden Tag mit 0,09kWh
                                @arnold und was hat dein Zähler aktuell als Wert?
                                cumulativeValue
                                sollte deinem Zählerwert entsprechen und auch drin stehen. das valueDeviceReset sollte 0 sein
                                  @crunchip
                                  10.01.2023 Gestern Zähler 1035,79kWh
                                  SA gestoppt
                                  noch ändern Datenpunkt
                                  cumulativeReading 1035,79 (geschrieben)
                                  in RAW geschrieben
                                  muss hier auch ändern ??? (habe auch geändert)
                                  SA gestartet
                                  11.01.2023 Heute Zähler 1036,66kWh
                                  cumulativeReading 1036.172
                                  currentMonth ist heute gestartet mit 1,85kWh (bin sicher morgen auch mit 1,85)
                                  Datenpunkte jetzt
                                  heute ein minus wert soll 0,4kWh stehen
                                    das sind doch die Werte die im Raw stehen
                                    du hast am 10.01. ein device reset stehen 1035.79(möglicherweise war dann wohl der Zählerstand schon höher, als das was du eingetragen hast
                                    probier es so https://forum.iobroker.net/post/738686
                                      @crunchip
                                      Habe SA gestoppt ,experten Modus ein
                                      in RAW schreibe
                                      "cumulativeValue": 1036.81 (mein aktuelle Zähler Wert)
                                      beide gelöscht(Komplett )
                                      valueAtDeviceReset
                                      valueAtDeviceInit
                                      im Datenpunkt cumulativeReading ändere ich gar nicht
                                      SA starten
                                      bekomme ich
                                        den korrekten Wert trägst du unmittelbar bevor du SA wieder startest, ein. Der darf nicht kleiner als der tatsächliche sein.
                                        Dein Zähler läuft ja weiter, wenn du natürlich zu lange brauchst, hat sich der Wert ja schon wieder verändert, folglich bekommst du wieder ein device reset
                                        L A 2 Replies Last reply Reply Quote 0
                                          lucky51179 @crunchip last edited by lucky51179
                                          ich habe auch zwei Punkte ich möchte den Verbrauch von meinen Shelley 3EM aufzeichnen.
                                          Leider wirft es mir immer wieder die Berechnung durcheinander.
                                          Warum schreibt er mir nach einiger Zeit hier
                                          "valueAtDeviceInit": -0.003,
                                          "valueAtDeviceReset": 19611.127200000003,
                                          immer einen Wert rein ? Lösche ich die Zeilen stimmt die Berechnung wieder.
                                          Abfrage Punkt
                                            "type": "state",
                                            "common": {
                                              "name": "Total Energy",
                                              "type": "number",
                                              "role": "value.power.consumption",
                                              "read": true,
                                              "write": false,
                                              "def": 0,
                                              "unit": "Wh",
                                              "custom": {
                                                  "enabled": true,
                                                  "selectedUnit": "wh",
                                                  "threshold": 1,
                                                  "start_day": 6529.0452000000005,
                                                  "start_week": 1611.24,
                                                  "start_month": 1557.2,
                                                  "start_quarter": 1557.2,
                                                  "start_year": 1557.2,
                                                  "alias": "BezugTotal",
                                                  "meter_values": false,
                                                  "cumulativeValue": 1634326.4
                                            "native": {},
                                            "_id": "shelly.0.SHEM-3#BCFF4DFD1016#1.Total.ConsumedPower",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                            "from": "system.adapter.sourceanalytix.0",
                                            "ts": 1673527497250
                                            crunchip Forum Testing Most Active @lucky51179 last edited by
                                            @lucky51179 habe zwar keinen 3EM, allerdings frage ich mich woher die vielen Nachkomma Stellen sind
                                            2302
                                            1156009
