    • Armilar
      Armilar Most Active Forum Testing @carlos last edited by
      @carlos Was wird in den Datenpunkt geschrieben? Zeig mal das JSON
      • Armilar
        Armilar Most Active Forum Testing @c3b last edited by Armilar
        @c3b
        Kann daran liegen, dass in der Config nicht mehr alle Konstanten enthalten sind. Sende mal die Config.
        Es gab weitere Änderungen mit der 3.7.0
        https://forum.iobroker.net/post/915335
        Bei Anpassungen im neuen Script, dürfte ja kein Dimmode mehr gewesen sein...Vermute du hast einfach deine Config 1:1 wieder reinkopiert.
          carlos @Armilar last edited by
          @armilar
          10.1.2023, 10:04:14.443	[info ]: javascript.0 (361) Start javascript script.js.NSPanels.PowerCard
          10.1.2023, 10:04:14.454	[info ]: javascript.0 (361) script.js.NSPanels.PowerCard: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          10.1.2023, 10:04:16.583	[info ]: javascript.0 (361) script.js.NSPanels.PowerCard: [{ "id" : 0, "value": "", "unit": "" , "icon" : "home" , "iconColor" : 0}, { "id" : 1, "value": 3, "unit": "kW" , "direction" :  "out" , "icon" : "battery-charging-60" , "iconColor" : 10 , "speed" : 3}, { "id" : 2, "value": 524, "unit": "kW" , "direction" :  "out" , "icon" : "solar-power-variant" , "iconColor" : -739 , "speed" : 250}, { "id" : 3, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "wind-turbine" , "iconColor" : 10 , "speed" : 0}, { "id" : 4, "value": 905.1, "unit": "kW" , "direction" :  "out" , "icon" : "shape" , "iconColor" : 10 , "speed" : 3}, { "id" : 5, "value": 378.1, "unit": "kW" , "direction" :  "out" , "icon" : "transmission-tower" , "iconColor" : 10 , "speed" : -2}, { "id" : 6, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "car" , "iconColor" : 0 , "speed" : 3}]
          10.1.2023, 10:04:16.587	[info ]: javascript.0 (361) script.js.NSPanels.PowerCard: [{ "id" : 0, "value": "", "unit": "" , "icon" : "home" , "iconColor" : 0}, { "id" : 1, "value": 3, "unit": "kW" , "direction" :  "out" , "icon" : "battery-charging-60" , "iconColor" : 10 , "speed" : 3}, { "id" : 2, "value": 524, "unit": "kW" , "direction" :  "out" , "icon" : "solar-power-variant" , "iconColor" : -739 , "speed" : 250}, { "id" : 3, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "wind-turbine" , "iconColor" : 10 , "speed" : 0}, { "id" : 4, "value": 903.2, "unit": "kW" , "direction" :  "out" , "icon" : "shape" , "iconColor" : 10 , "speed" : 3}, { "id" : 5, "value": 376.2, "unit": "kW" , "direction" :  "out" , "icon" : "transmission-tower" , "iconColor" : 10 , "speed" : -2}, { "id" : 6, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "car" , "iconColor" : 0 , "speed" : 3}]
          10.1.2023, 10:04:16.591	[info ]: javascript.0 (361) script.js.NSPanels.PowerCard: [{ "id" : 0, "value": "", "unit": "" , "icon" : "home" , "iconColor" : 0}, { "id" : 1, "value": 3, "unit": "kW" , "direction" :  "out" , "icon" : "battery-charging-60" , "iconColor" : 10 , "speed" : 3}, { "id" : 2, "value": 524, "unit": "kW" , "direction" :  "out" , "icon" : "solar-power-variant" , "iconColor" : -739 , "speed" : 250}, { "id" : 3, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "wind-turbine" , "iconColor" : 10 , "speed" : 0}, { "id" : 4, "value": 903.2, "unit": "kW" , "direction" :  "out" , "icon" : "shape" , "iconColor" : 10 , "speed" : 3}, { "id" : 5, "value": 376.2, "unit": "kW" , "direction" :  "out" , "icon" : "transmission-tower" , "iconColor" : 10 , "speed" : -2}, { "id" : 6, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "car" , "iconColor" : 0 , "speed" : 3}]
          • Armilar
            @carlos
            nicht das Log, sondern das was dein Blockly in den Datenpunkt für das Panel schreibt. Möchte mal sehen, ob da noch Fehler sind.
              @armilar
              [{ "id" : 0, "value": "", "unit": "" , "icon" : "home" , "iconColor" : 0}, { "id" : 1, "value": 3, "unit": "kW" , "direction" :  "out" , "icon" : "battery-charging-60" , "iconColor" : 10 , "speed" : 3}, { "id" : 2, "value": 593, "unit": "kW" , "direction" :  "out" , "icon" : "solar-power-variant" , "iconColor" : -837 , "speed" : 282}, { "id" : 3, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "wind-turbine" , "iconColor" : 10 , "speed" : 0}, { "id" : 4, "value": 873.3, "unit": "kW" , "direction" :  "out" , "icon" : "shape" , "iconColor" : 10 , "speed" : 3}, { "id" : 5, "value": 277.3, "unit": "kW" , "direction" :  "out" , "icon" : "transmission-tower" , "iconColor" : 10 , "speed" : -2}, { "id" : 6, "value": 0, "unit": "kW" , "direction" :  "out" , "icon" : "car" , "iconColor" : 0 , "speed" : 3}]
              Armilar D 2 Replies Last reply Reply Quote 0
              • Armilar
                Armilar Most Active Forum Testing @carlos last edited by Armilar
                @carlos
                Sieht bei mir so aus, wenn ich 2 Werte verändere:
                In der id: 2 steht für die Icon Farbe eine -837. Farben sind von 0-10 erlaubt. Auch der Speed (Gibt an, mit welcher Geschwindigkeit, der Slider sich bewegt; Bei negativen Vorzeichen wird die Richtung gedreht) ist mit 282 zu hoch.
                    "id": 2,
                    "value": 593,
                    "unit": "kW",
                    "direction": "out",
                    "icon": "solar-power-variant",
                    "iconColor": -837,
                    "speed": 282
                Wenn die Bilanz irgendwann stimmen soll, solltest du für den Anfang die Umrechnung so vornehmen, dass nicht W und kW im gleichen Diagramm sind
                C 1 Reply Last reply Reply Quote 1
                  @armilar
                  Ok, dann stimmt wohl was mit dem blockly nicht.
                  Ich mach mich mal auf die Suche.
                    danny_v1 @carlos last edited by
                    @Armilar
                    Hi, hier kommt man ja kaum noch nach mit updaten, so schnell wie ihr das ganze Projekt weiter entwickelt, echt top eure Arbeit und das ganze Projekt!!! Da braucht man ja bald keine andere Visu mehr! 🙂
                    Besteht die Möglichkeit das Skript in zwei Skripte aufzuteilen, einem in dem das ganze individuelle Zeugs, also die Seiten und alles drin sind und der anderen Teil aus dem was von euch weiter entwickelt wird. Das macht das ganze updaten für viele sicher einfacher und spart auch viele Fragen hier, die sich immer mal wieder stellen und zum Teil sehr ähnlich sind.
                    Und eine zweite Frage: besteht die Möglichkeit Parameter wie zB die Namen, Icon oder Color der Items variabel also per Datenpunkt zu übergeben?
                    • Armilar
                      Armilar Most Active Forum Testing @danny_v1 last edited by Armilar
                      @danny_v1
                      War damit angefangen und habe es sein lassen nachdem ich gesehen habe, dass der Aufwand und das Verständnis für ein Update zu Umfangreich für den Enduser wird. Mit anderen Worten: Es wird danach nicht besser sondern schlimmer.
                      Grund: Es gibt keine elegante Lösung, die Konstanten und Variablen sauber zwischen den Scripten zu tauschen, ohne individuelle und exorbitante Anpassungen durch jeden einzelnen User zu machen. Das macht es dann auch nicht mehr supportfähig... Vielleicht denke ich zu kompliziert und die Lösung ist einfach. Habe aber keine gefunden.
                      Ich dachte auch daran, ein globales Script zu nutzen. Da sich aber alle globalen Scripte vor das TS-Script setzten, lässt sich das nur mit absoluter Eindeutigkeit der Variablennamen lösen. Wer wird das garantieren können, ohne copy/paste eine absolute Eindeutigkeit für n-Panel zu erzeugen.
                      Mein Fazit: Es wird eher schlechter als besser bei Auslagerung der Variablen...
                      Du würdest die ebenfalls als z.B. JSON importieren wollen? Könnte man ggfs machen, wenn der ALIAS zur "id" einen weiteren DP zu einem validen Ziel erhält. Ähnlich der cardPower. Macht es für die meisten User denke ich auch nicht viel einfacher - aber möglich. Könnte aber auch als Alternative einfließen.
                      Aber ich finde es faktisch auch nicht wirklich schlimm mit einem Script je Panel zu arbeiten. Der unterer Teil sollte eh nicht angefasst werden müssen und ist bei Copy/Paste innerhalb kürzester Zeit bei einem normalen Releasewechsel ohne "Breaking Changes im oberen Bereich") schnell ausgetauscht.
                      • Armilar
                        @carlos
                        Falls dir das zu komplex mit der Schleife ist, kannst du die Blöcke id 1-6 auch untereinander setzen:
                        und ohne Listen arbeiten. Dann kannst du da auch Datenpunkte einsetzten.
                        Wichtig ist nur, dass das JSON (und das ist im Prinzip ja auch nur Text) korrekt erzeugt wird.
                        Zwischen den Blöcken müsste dann nur noch ein zusätzliches Komma gesetzt werden "},"
                          @armilar
                          habe jetzt einfachbeim setzen der dpvalues durch 1000 dividiert um kW zu bekommen.
                          So siehts gut aus.
                          Danke dir, jetzt geht auch blockly etwas besser.👍
                            danny_v1 @Armilar last edited by
                            @armilar Ok hätte nicht gedacht das das so aufwändig ist. War auch nur so eine Idee.
                            In der zweiten Frage mit den variablen Parametern gings mir eher darum um zB auf einer Status Seite die Anzahl offener Fenster oder angeschalteten Lampen anzuzeigen.
                            • Armilar
                              @danny_v1
                              Für eine Statusseite (interpretiere ich mal als card Grid oder cardEntities oder eher Info-Seite) können jederzeit Info-Aliase mit einem Wert aus einem Datenpunkt (externes Blockly ermittelt die Anzahl generisch) angezeigt werden.
                              bei der cardGrid wäre es zusätzlich der Parameter im pageItem: useValue: true. Dann würde der numerische Wert im Info-Element stehen. Die cardEntities hat doch eh hinten den Wert mit Einheit.
                              name: "Anzahl offene Fenster"
                              • Armilar
                                @carlos
                                Habe jetzt mal ein neues Blocky-Beispiel für die cardPower zum spielen und ausprobieren gebaut.
                                "cardPower simple example"
                                Das Blockly:
                                https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/Blockly/cardPower_simple_example.xml
                                Beim ersten Aufruf sollte die card so aussehen:
                                Die restlichen Variablen können analog der id: 1 verändert werden, oder durch Datenpunkte mit echter Logik ersetzt werden.
                                Ich denke das wird dem allgemeinen Verständnis helfen...
                                PS.:
                                • direction wurde im Script noch nie abgefragt und ist deshalb im Beispiel auch nicht mehr enthalten
                                • speed_id_1-6 kann auch negative Werte enthalten und kehrt somit die Laufrichtung des Punktes um (Empfehlung -5 bis +5)
                                • Der mittlere größere Block hat kein Speed
                                • Ich habe einen Timer eingebaut, der jede Minute das JSONzusammenbaut und in den Datenpunkt schreibt. Bei Bedarf die Zeit ändern oder durch einen Trigger ersetzten
                                • Die Farben gehen von 0=weiß, 1=grün bis 10=rot
                                H J 3 Replies Last reply Reply Quote 1
                                  ronny130286 @Armilar last edited by ronny130286
                                  @armilar said in SONOFF NSPanel mit Lovelace UI:
                                  @ronny130286
                                  Versuch mal das:
                                              UnsubscribeWatcher();
                                              if (existsState(pageItem.id + '.GET')) {
                                                  val = getState(pageItem.id + '.GET').val;
                                                  RegisterEntityWatcher(pageItem.id + '.GET');
                                              if (existsState(pageItem.id + ".STATE")) {
                                                  val = getState(pageItem.id + ".STATE").val;
                                                  RegisterEntityWatcher(pageItem.id + ".STATE");
                                              if (existsState(pageItem.id + '.SET') && !existsState(pageItem.id + ".STATE")) {
                                                  val = getState(pageItem.id + '.SET').val;
                                                  RegisterEntityWatcher(pageItem.id + '.SET');
                                              if (existsState(pageItem.id + '.ACTUAL')) {
                                                  val = getState(pageItem.id + '.ACTUAL').val;
                                                  RegisterEntityWatcher(pageItem.id + '.ACTUAL');
                                              if (existsState(pageItem.id + '.ON_ACTUAL')) {
                                                  val = getState(pageItem.id + '.ON_ACTUAL').val;
                                                  RegisterEntityWatcher(pageItem.id + '.ON_ACTUAL');
                                              if (existsState(pageItem.id + '.ON_SET')) {
                                                  val = getState(pageItem.id + '.ON_SET').val;
                                                  RegisterEntityWatcher(pageItem.id + '.ON_SET');
                                              if (existsState(pageItem.id + '.ON')) {
                                                  val = getState(pageItem.id + '.ON').val;
                                                  RegisterEntityWatcher(pageItem.id + '.ON');
                                  Das sieht super aus 🙂 so funktionieren bei mir jetzt alle Versionen 🙂
                                  EDIT: Aber er setzt jetzt das Icon nicht mehr auf on/off, es bleibt jetzt immer off => betrifft scheinbar nur die "cardEntities" , auf der "cardGrid" geht es.
                                  @Armilar => das ist aber wie schon geschrieben scheinbar nur Kosmetik, der Funktion tut es nichts ab 😉
                                  Armilar 2 Replies Last reply Reply Quote 0
                                  • Armilar
                                    Armilar Most Active Forum Testing @ronny130286 last edited by
                                    @ronny130286
                                    Sehe ich auch so
                                    • egal
                                      egal @egal last edited by
                                      @egal
                                      bevor ich das vergesse, die letzten Erweiterungen zum Volumio Media-Player,
                                      Repeat-Button ergänzt, Tracklist-Generierung verschoben, so das auch extern erstellte Tracklisten/Queues erfaßt werden:
                                      function GenerateMediaPage(page: PageMedia): Payload[] {
                                                  //InSel Tracklist
                                                  let trackListString: string = '~~~~~~'
                                                  let trackListIconCol = rgb_dec565(HMIOff);
                                      +            if (v2Adapter == 'volumio') { /* Volumio: get queue */
                                      +                setTimeout(async function () {
                                      +                    request({ url: `${getState(vInstance+'info.host').val}/api/getQueue`, headers: {'User-Agent': 'ioBroker'} },
                                      +                            async (error, response, result) => {
                                      +                                try {
                                      +                                    const QUEUELIST = JSON.parse(result);
                                      +                                    page.items[0].globalTracklist = QUEUELIST.queue;
                                      +                                    if (Debug) { for (let i_index in QUEUELIST.queue) console.log(QUEUELIST.queue[i_index]); }
                                      +                                } catch (err) {
                                      +                                    console.log('get_volumio-queue: ' + err.message);
                                      +                    }, 2000);
                                      +                globalTracklist = page.items[0].globalTracklist;
                                                  //Repeat Control Button
                                      +            } else if (v2Adapter == 'volumio') { /* Volumio: only Repeat true/false with API */
                                      +                if (getState(id + '.REPEAT').val == true) {
                                      +                    repeatIcon = Icons.GetIcon('repeat-variant');
                                      +                    repeatIconCol = rgb_dec565(colMediaIcon);
                                      -            if (v2Adapter == 'spotify-premium' || v2Adapter == 'alexa2' || v2Adapter == 'sonos') {
                                      +            if (v2Adapter == 'spotify-premium' || v2Adapter == 'alexa2' || v2Adapter == 'sonos' || v2Adapter == 'volumio') {
                                      function HandleButtonEvent(words): void {
                                              switch (buttonAction) {
                                                  case 'button':
                                                              case 'media':
        if (tempid[1] == 'repeat') {
        switch (deviceAdapterRP) {
                                      +                                    case 'volumio':
                                      +                                        request({ url:`${getState(adapterInstanceRepeat+'info.host').val}/api/commands/?cmd=repeat`, headers: {'User-Agent': 'ioBroker'} },
                                      +                                            async (error, response, result)=>{}); /* nothing todo @ error */
                                      +                                        break;
                                      // + die Tracklistgenerierung unten entfernt:
                                                  case 'mode-playlist':
                                                          case 'volumio':
                                                              let strDevicePL = pageItemPL.playList[words[4]];
                                                              request({ url:`${getState(adapterInstancePL+'info.host').val}/api/commands/?cmd=playplaylist&name=${strDevicePL}`, headers: {'User-Agent': 'ioBroker'} },
                                      -                       /*setTimeout(async function () {
                                      -                            request({ url: `${getState(adapterInstancePL+'info.host').val}/api/getQueue`, headers: {'User-Agent': 'ioBroker'} },
                                      -                                async (error, response, result) => {
                                      -                                    try {
                                      -                                        const QUEUELIST = JSON.parse(result);
                                      -                                        pageItemPL.globalTracklist = QUEUELIST.queue;
                                      -                                        if (Debug) { for (let i_index in QUEUELIST.queue) console.log(QUEUELIST.queue[i_index]); }
                                      -                                    } catch (err) {
                                      -                                        console.log('get_volumio-queue: ' + err.message);
                                      -                        }, 2000); */
                                                              break;
                                      Armilar 1 Reply Last reply Reply Quote 1
                                      • Armilar
                                        @ronny130286
                                        Etwas verfeinert... Teste mal
                                                       unsubscribe(pageItem.id + '.GET');
                                                       unsubscribe(pageItem.id + '.STATE');
                                                       //unsubscribe(pageItem.id + '.ACTUAL');
                                                       //unsubscribe(pageItem.id + '.SET');
                                                       unsubscribe(pageItem.id + '.ON_ACTUAL');
                                                       unsubscribe(pageItem.id + '.ON_SET');
                                                       unsubscribe(pageItem.id + '.ON');
                                        • Armilar
                                          Armilar Most Active Forum Testing @egal last edited by
                                          @egal
                                          baue ich mit ein
                                          • ravenst0ne
                                            ravenst0ne last edited by
                                            Hallo, mir ist aufgefallen, dass sich das Icon meiner RGB Lampen nicht ändert, wenn ich diese ein-/ausschalte.
                                            Müsste in der Funktion CreateEntity() nicht auch der false state von val behandelt werden?
                                                           case 'rgbSingle':
        type = 'light';
        iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon('lightbulb');
        optVal = '0';
        if (val === true || val === 'true') {
        optVal = '1'
        iconColor = GetIconColor(pageItem, existsState(pageItem.id + '.DIMMER') ? 100 - getState(pageItem.id + '.DIMMER').val : true, useColors);
        if (existsState(pageItem.id + '.RGB')) {
        if (getState(pageItem.id + '.RGB').val != null) {
        let hex = getState(pageItem.id + '.RGB').val;
        let hexRed = parseInt(hex[1] + hex[2], 16);
        let hexGreen = parseInt(hex[3] + hex[4], 16);
        let hexBlue = parseInt(hex[5] + hex[6], 16);
        let rgb = <RGB>{ red: Math.round(hexRed), green: Math.round(hexGreen), blue: Math.round(hexBlue) };
        iconColor = rgb_dec565(pageItem.interpolateColor !== undefined ? rgb : config.defaultOnColor);
        } else {
        iconColor = GetIconColor(pageItem, false, useColors);
                                            Analog dann zu 'hue', 'rgb', etc.
                                            Auch springe ich immer wieder zu der Hauptseite zurück, wenn ich das Popup für die RGB Lampen schließe, nicht zur vorherigen Subpage. Könnte aber auch ein Konfigurationsfehler bei mir sein
                                            Armilar 2 Replies Last reply Reply Quote 1
                                            lovelace ui nspanel sonoff
                                            270
                                            7695
                                            6529198
