    4. Adapter LightControl 0.4.x Stable
      sigi234 Forum Testing Most Active @Schmakus last edited by
      @schmakus
      Läuft. 👍
      lightcontrol.0
      2022-12-23 20:45:01.144	info	Reaching powerOnAfterCare for Group="Büro" bri="100" ct="3300" color="#FFFFFF"
      lightcontrol.0
      2022-12-23 20:45:00.953	info	SimpleGroupPowerOnOff => Normales ausschalten ohne Ramping für Group="Büro"
      lightcontrol.0
      2022-12-23 20:45:00.766	info	Reaching Controller, Group="Büro" Property="power" NewVal="false", OldVal="true"
      lightcontrol.0
      2022-12-23 20:43:48.064	info	Reaching powerOnAfterCare for Group="Büro" bri="100" ct="3300" color="#FFFFFF"
      lightcontrol.0
      2022-12-23 20:43:48.003	info	Reaching Controller, Group="Büro" Property="power" NewVal="true", OldVal="false"
      lightcontrol.0
      2022-12-23 20:43:42.139	info	Reaching Controller, Group="Büro" Property="rampOn.time" NewVal="20", OldVal=""
      lightcontrol.0
      2022-12-23 20:43:27.233	info	Reaching powerOnAfterCare for Group="Büro" bri="100" ct="3300" color="#FFFFFF"
      lightcontrol.0
      2022-12-23 20:43:27.150	info	SimpleGroupPowerOnOff => Normales ausschalten ohne Ramping für Group="Büro"
      lightcontrol.0
      2022-12-23 20:43:27.146	info	Reaching Controller, Group="Büro" Property="power" NewVal="false", OldVal="true"
      lightcontrol.0
      2022-12-23 20:43:17.331	info	Reaching Controller, Group="Büro" Property="rampOn.enabled" NewVal="true", OldVal=""
      lightcontrol.0
      2022-12-23 20:42:20.264	info	Now setting bri to 100% for Group="Büro"
      lightcontrol.0
      2022-12-23 20:42:20.263	info	Reaching powerOnAfterCare for Group="Büro" bri="100" ct="3300" color="#FFFFFF"
      lightcontrol.0
      2022-12-23 20:42:20.176	info	SimpleGroupPowerOnOff => Normales anschalten ohne Ramping für Group="Büro"
      lightcontrol.0
      2022-12-23 20:42:20.175	info	Reaching Controller, Group="Büro" Property="power" NewVal="true", OldVal="false"
      lightcontrol.0
      2022-12-23 20:39:19.481	info	Successfully activated LightControl for 3 of 3 states, will do my Job until you stop me!
      lightcontrol.0
      2022-12-23 20:39:19.479	info	InitCustomStates => Initialization of hue.0.Philips_hue.Büro.level successfully
      lightcontrol.0
      2022-12-23 20:39:19.477	info	InitCustomStates => Initialization of hue.0.Philips_hue.Büro.bri successfully
      lightcontrol.0
      2022-12-23 20:39:19.474	info	InitCustomStates => Initialization of hue.0.Philips_hue.Büro.on successfully
      lightcontrol.0
      2022-12-23 20:39:19.471	info	Found 3 LightControl enabled states
      lightcontrol.0
      2022-12-23 20:39:19.380	info	starting. Version 0.0.4 (non-npm: Schmakus/ioBroker.lightcontrol#be97df7583927c1bc8f6dd1ff80c70ca56e3c31f) in C:/ioBroker/node_modules/iobroker.lightcontrol, node: v16.19.0, js-controller: 4.0.24
      lightcontrol.0
      2022-12-23 20:39:15.061	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      lightcontrol.0
      2022-12-23 20:39:15.060	info	terminating
      lightcontrol.0
      2022-12-23 20:39:15.059	info	Got terminate signal TERMINATE_YOURSELF
        spike2 @Schmakus last edited by
        @schmakus bei mir auch 🙂
        Schmakus 1 Reply Last reply Reply Quote 0
        • Schmakus
          Schmakus Developer @spike2 last edited by
          @spike2 @sigi234 Bitte sofort bei jeder Fehlfunktion oder Warnung/Error im log ein Issue auf GitHub aufmachen.
          Hab selbst schon paar Sachen gefunden und Issues erstellt. Werden dann zwischen den Jahren gefixt.
            sigi234 Forum Testing Most Active @Schmakus last edited by sigi234
            @schmakus sagte in Test Adapter LightControl 0.0.x GitHub:
            Jupp, das mit den Gruppenname anklicken funktioniert noch nicht.
            @spike2 bei Dir?
            S Schmakus 2 Replies Last reply Reply Quote 0
              spike2 @sigi234 last edited by
              @sigi234 Nein, das funktioniert leider bei mir auch nicht.
              Laut Doku steht drin: Um eine Gruppe zu bearbeiten, klickt man auf den Gruppennamen. Es öffnet sich ein weiteres Menü. Hier lassen sich die jeweiligen Lampen und Sensoren konfigurieren.
              Öffnet sich nichts bei mir 😉
              • Schmakus
                Schmakus Developer @sigi234 last edited by Schmakus
                @sigi234 Habe die Doku geändert. War noch eine alte Passage drin.
                In den Instant-Einstellungen kann man nur den Gruppennamen und den individuellen LuxSensor festlegen. Die Lampen und Sensoren werden ausschließlich über ihre eigenen Datenpunkte definiert
                  Ok, jetzt ist alles klar.
                  • Neuschwansteini
                    Neuschwansteini @Schmakus last edited by
                    @schmakus
                    Erstmal vielen Dank fuer den tollen Adapter!
                    Hast ja wirklich viele Szenarien eingebaut, ist ne tolle Hilfe und ersetzt auf Anhieb zig Scripte!
                    • FredF
                      FredF Most Active Forum Testing last edited by
                      @Schmakus Finde den Adapter auch super!
                      ch90045 1 Reply Last reply Reply Quote 0
                      • ch90045
                        ch90045 @FredF last edited by ch90045
                        @Schmakus Top, macht das Erstellen der Gruppen viel einfacher. Finde die Doku bzgl. "Wie füge ich Geräte hinzu" missvervständlich.
                        Ich habe hier zuerst in den DPs der Lichtgruppe gesucht und natürlich nichts gefunden.
                        Eine Formulierung wie " .... Um ein Licht/Sensor hinzufügen muss bei dem entsprechenden Datenpunkt des Licht/Sensor über das Zahnrad dieses Datenpunkt für den Adapter aktiviert werden und entsprechend der Funktion der Lichtgruppe hinzugefügt werden. ...."
                        Hat man erst einmal den richtigen Datenpunkt gefunden, dann ist es ganz einfach!
                        ch90045 Schmakus 2 Replies Last reply Reply Quote 0
                        • ch90045
                          ch90045 @ch90045 last edited by ch90045
                          Entfernt, weil nicht reproduzierbar
                          • Schmakus
                            Schmakus Developer @ch90045 last edited by
                            @ch90045 Hallo, danke für das Feedback! Werde die Doku entsprechend aktualisieren, damit es verständlicher wird.
                            • FredF
                              FredF Most Active Forum Testing last edited by FredF
                              @Schmakus
                              Kannst du mir den Unterschied/Funktion von dailyLock und enabled erklären?
                              autoOnLux: Automatisch Licht ein bei Lux
                              enabled: Aktivieren/Deaktivieren
                              dailyLock: Bei false wird AutoOnLux nicht ausgeführt
                              Soll das bei autoOnLux nicht "angehen" statt "ausgehen" heißen?
                              operator: Vergleich ob Licht über oder unter minLux ausgehen soll (z.B. > / < / >= / <=)
                              Edit: Beim Datenpunkt lightcontrol.0.xxx.autoOnLux.operator gibt es bei Eingabe des Operators < oder > eine Fehlermeldung:
                              [ Controller ] Error, unknown or missing property: "autoOnLux.operator"
                                Solear last edited by
                                Ich probiere den Adapter auch gerade aus.
                                Gegeben: 4 Hue-Lampen und 1 Hue Wandschalter (Taster), eingebunden über den Adapter Zigbee2mqtt.
                                Die Hue-Lampen bekomme ich über Lightcontrol gruppiert und auch über das Objekt bei der Gruppe via Zustandsänderung per Handeintragung ein/ausgeschaltet.
                                Aber den Wandschalter (Taster) als Trigger bekomme ich nicht eingebunden. Er ist als "Sensor" definiert und der Gruppe zugeordnet.
                                Ich erwarte irgendwo das Verhalten, dass der Taster die Gruppe on/off toggelt - habe ich einen Denkfehler?
                                • Schmakus
                                  Schmakus Developer @Solear last edited by
                                  @solear Schalter, Taster und Buttons werden vom Adapter aktuell nicht unterstützt. D.h. können nicht einfach als Sensor definiert werden. Sensoren sind ausschließlich BWMs, Lichtschranken oder ähnliches, welche für den Modus "AutoOnMotion" zuständig sind.
                                  BTW: Du kannst temporär einen Taster oder Schalter als Sensor definieren, musst aber dann den Modus "AutoOnMotion" aktivieren.
                                  • Schmakus
                                    Schmakus Developer @FredF last edited by
                                    @fredf sagte in Adapter LightControl 0.1.x GitHub:
                                    @Schmakus
                                    enabled: Hier wird die Funktion grundsätzlich aktiviert
                                    dailyLock: ist eine interne Sperre (nicht änderbar durch User), Ausreisserschutz wenns am morgen kurz mal dunkler wird (5x muss es heller werden, damit dailyLock zurückgesetzt wird.
                                    Klar, werde ich ändern. Danke für's Feedback! 🙂
                                    Könntest du hierzu bitte ein Issue auf GitHub aufmachen?! Danke! Hier wird aktuell der Wert nicht in den internen Speicher übernommen.
                                    • ch90045
                                      ch90045 @Schmakus last edited by
                                      @schmakus Mal ne Frage, wie wird der Adapter "upgedated" - entfernen und neu installieren ist ja blöd, da werden ja alle DPs gelöscht.
                                        A Former User @ch90045 last edited by
                                        @ch90045 einfach drüber installieren. 🙂
                                        • ch90045
                                          ch90045 @Guest last edited by
                                          @ciddi89
                                          schon versucht:
                                           npm i iobroker.lightcontrol
                                          up to date, audited 6 packages in 992ms
                                          No Luck!
                                            A Former User @ch90045 last edited by A Former User
                                            @ch90045 der adapter ist noch nicht im stable. Dann musst du über bei Adapter auf Experten Einstellungen und dann auf die Katze, unter dem tab benutzerdefiniert den GitHub link vom adapter einfügen.
                                            https://github.com/Schmakus/ioBroker.lightcontrol
                                            31.7k
                                            79.8k
                                            light light control lightcontrol motion motion detection
                                            18
                                            117
                                            11143
