    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      A Former User last edited by
      ich habe ein Problem beim auslösen von "Start clima for the vehicle" bei meinem IONIQ5 MY23 mit aktuellstem Softwarestand.
      Ich bekomme diese Meldung:
      2023-01-07 07:45:08.488 - info: bluelink.0 (718839) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.21.1, js-controller: 4.0.24
      2023-01-07 07:45:08.526 - info: bluelink.0 (718839) Login to api
      2023-01-07 07:45:13.277 - info: bluelink.0 (718839) 1 Vehicles found
      2023-01-07 07:45:49.481 - info: bluelink.0 (718839) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
      2023-01-07 07:45:49.527 - info: bluelink.0 (718839) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
      2023-01-07 07:45:49.575 - info: bluelink.0 (718839) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
      2023-01-07 07:45:49.623 - info: bluelink.0 (718839) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
      2023-01-07 07:45:49.688 - info: bluelink.0 (718839) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
      2023-01-07 07:48:53.904 - info: admin.0 (718326) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2023-01-07 07:49:25.198 - info: bluelink.0 (718839) Starting clima for vehicle
      2023-01-07 07:49:25.663 - error: bluelink.0 (718839) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-01-07 07:49:25.664 - error: bluelink.0 (718839) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"99e90977-880c-4738-ade3-fef32aa3a1ee"}
      2023-01-07 07:49:25.666 - error: bluelink.0 (718839) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"99e90977-880c-4738-ade3-fef32aa3a1ee"}
      at U (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:11700)
      at G. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
      at Generator.throw ()
      at a (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
      at runMicrotasks ()
      at processTicksAndRejections (internal/process/task_queues.js:95:5)
      2023-01-07 07:49:25.667 - error: bluelink.0 (718839) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"99e90977-880c-4738-ade3-fef32aa3a1ee"}
      2023-01-07 07:49:25.702 - info: bluelink.0 (718839) Adapter bluelink cleaned up everything...
      2023-01-07 07:49:25.703 - info: bluelink.0 (718839) terminating
      2023-01-07 07:49:25.705 - warn: bluelink.0 (718839) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-01-07 07:49:26.268 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-01-07 07:49:26.274 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
      2023-01-07 07:49:56.372 - info: host.raspberrypi instance system.adapter.bluelink.0 started with pid 719096
      2023-01-07 07:49:58.346 - info: bluelink.0 (719096) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.21.1, js-controller: 4.0.24
      2023-01-07 07:49:58.383 - info: bluelink.0 (719096) Login to api
      2023-01-07 07:50:02.535 - info: bluelink.0 (719096) 1 Vehicles found
      2023-01-07 07:50:35.672 - info: bluelink.0 (719096) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
      2023-01-07 07:50:35.719 - info: bluelink.0 (719096) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
      2023-01-07 07:50:35.767 - info: bluelink.0 (719096) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
      2023-01-07 07:50:35.815 - info: bluelink.0 (719096) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
      2023-01-07 07:50:35.882 - info: bluelink.0 (719096) State value to set for "bluelink.0.KMHKR81xxxxxxxxxx.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
      2023-01-07 07:50:49.720 - info: admin.0 (718326) <== Disconnect system.user.admin from ::ffff:192.168.178.37 javascript
      2023-01-07 07:49:25.198 - drückte ich den "button"
      Hat jemand eine Idee, was hier schief läuft?
      M ? 2 Replies Last reply Reply Quote 0
        Michaelnorge @Guest last edited by
        @williwilliwilli Das Problem kenne ich auch. Ich habe bisher nicht herausgefunden wieso das passiert, allerdings geht es wenn man den Button "jqui-icon toggle" benutzt.
          A Former User @Guest last edited by
          @williwilliwilli sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          Hier hast du die genaue Antwort:
          da war einfach die API nicht erreichbar.. das kann passieren.. einfach nochmal versuchen.. klappt das dauerhaft nicht, und auch nicht per APP dann das Boardsystem mal resetten (kleines rundes Loch unten rechts)
            @ilovegym
            danke für die schnelle Antwort
            Ich verstehe, dass es so aussieht als wäre die API grade nicht da, ich habe das Problem aber immer. Ich habe es sofort danach per Blue Link App probiert und es funktionierte ohne Probleme:
            Ich habe es auch jetzt nochmal getestet, das Problem bleibt bestehen:
            2023-01-07 17:18:26.698 - info: bluelink.0 (746776) Login to api
            2023-01-07 17:18:30.898 - info: bluelink.0 (746776) 1 Vehicles found
            2023-01-07 17:18:53.526 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
            2023-01-07 17:18:53.575 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
            2023-01-07 17:18:53.623 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
            2023-01-07 17:18:53.671 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
            2023-01-07 17:18:53.740 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
            2023-01-07 17:19:30.685 - info: bluelink.0 (746776) Starting clima for vehicle
            2023-01-07 17:19:30.868 - error: bluelink.0 (746776) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-01-07 17:19:30.869 - error: bluelink.0 (746776) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
            2023-01-07 17:19:30.870 - error: bluelink.0 (746776) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
            2023-01-07 17:19:30.871 - error: bluelink.0 (746776) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
            2023-01-07 17:19:30.882 - info: bluelink.0 (746776) Adapter bluelink cleaned up everything...
            2023-01-07 17:19:30.883 - info: bluelink.0 (746776) terminating
            2023-01-07 17:19:30.885 - warn: bluelink.0 (746776) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-01-07 17:19:31.433 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-01-07 17:19:31.434 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
            @Michaelnorge Wo finde ich den Button "jqui-icon toggle" 😃 ?
            Ich klicke mich fleißig durch das iobroker UI, finde ihn aber nicht.
            ? arteck 2 Replies Last reply Reply Quote 0
              @williwilliwilli
              Hast du die aktuelle Version von Git gezogen? Es gab mal eine mit so einem Fehler, aber @arteck hatte das gefixed…
                arteck Developer Most Active @Guest last edited by
                @williwilliwilli
                installier bitte die GIT version.. du scheinst was älteres da zu haben
                  stefan.cloer last edited by
                  Hallo zusammen, wenn ich manuell auf die letzte GIT Version update funktioniert bei mir der Adapter leider gar nicht mehr. In der Instanz-Liste wird nur noch folgendes angezeigt
                  Im LOG ist vom Bluelink Adapter gar nichts zu sehen nur der Host Adapter spukt folgendes aus
                  Kann mir jemand sagen wo das Problem liegen könnte?
                  tugsi 1 Reply Last reply Reply Quote 0
                  • tugsi
                    tugsi @stefan.cloer last edited by
                    @stefan-cloer sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                    Merkwürdig, hast Du einen alten JS-Controller installiert?
                      stefan.cloer @tugsi last edited by
                      Nein, der Javascript Controller ist Version 6.1.4
                        arteck Developer Most Active @stefan.cloer last edited by
                        @stefan-cloer was hat den javascript mit dem js-controller zu un ??
                        bitte die ausgabe von
                        iob diag
                          ich habe eine version zum testen da ich es nicht kann auf GIT
                          https://github.com/Newan/ioBroker.bluelink/tarball/heating_number
                          unter heating sollten jetzt zahlen eingebbar sein
                          und dann schauen obs tut
                          evtl. Datenpunkt löschen der wird dann neu erzeugt
                          in zuge dessen auch die Temperatur.. irgendwie hab ich das geühl das es F ist und nicht C
                          ? 3 Replies Last reply Reply Quote 0
                            A Former User @arteck last edited by
                            @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            Guten Morgen,
                            startet bei mir leider nicht:
                            2023-01-11 09:17:34.239  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3666387
                            2023-01-11 09:17:34.366  - error: host.iobrokerS Caught by controller[0]: /opt/iobroker/node_modules/iobroker.bluelink/main.js:99
                            2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:                     let airTempF = (airTempC.val × 9/5) + 32;
                            2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]: SyntaxError: Invalid or unexpected token
                            2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at Object.compileFunction (node:vm:360:18)
                            2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                            2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1129:27)
                            2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32)
                            2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                            2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at node:internal/main/run_main_module:22:47
                            2023-01-11 09:17:34.368  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            2023-01-11 09:17:34.369  - info: host.iobrokerS Restart adapter system.adapter.bluelink.0 because enabled
                            2023-01-11 09:17:37.395  - info: tuya.0 (3639062) bf51aaad135aa1ced0dhmw: Error on Reconnect (3): connect EHOSTUNREACH 10.1.12.101:6668
                            2023-01-11 09:17:42.722  - info: host.iobrokerS "system.adapter.bluelink.0" disabled
                              @arteck die Temp ist im Original von der bluelinkapp diese 02H0 die im Adapter irgendwo umgerechnet werden..
                                @ilovegym jetzt, guck nochmal
                                  @arteck nee haengt jetzt in ner rebuild-schleife, versucht es 3x, bricht dann ab.
                                  2023-01-11 09:41:52.409  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3696947
                                  2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
                                  2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       throw err;
                                  2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       ^
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
                                  2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                  2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                  2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
                                  2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                  2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/package.json',
                                  2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
                                  2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]: }
                                  2023-01-11 09:41:52.907  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  2023-01-11 09:41:52.907  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  hab dann im Verzeichnis node_modules/iobroker.bluelink das manuell angestossen:
                                  ilovegym@iobrokerS /opt/iobroker/node_modules/iobroker.bluelink $ npm install --production
                                  npm WARN config production Use `--omit=dev` instead.
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  added 137 packages, and audited 138 packages in 20s
                                  6 packages are looking for funding
                                    run `npm fund` for details
                                  2 moderate severity vulnerabilities
                                  Some issues need review, and may require choosing
                                  a different dependency.
                                  Run `npm audit` for details.
                                  mikeal created this issue in request/request
                                  open Request’s Past, Present and Future #3142
                                    @ilovegym
                                    nochmal bitte
                                      @ilovegym
                                      nochmal bitte
                                      jetzt kommt das:
                                      2023-01-11 10:10:17.367  - info: host.iobrokerS "system.adapter.bluelink.0" enabled
                                      2023-01-11 10:10:17.416  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3730679
                                      2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
                                      2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]:       throw err;
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:       ^
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                      2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/bluelinky/package.json',
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]: }
                                      2023-01-11 10:10:17.867  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2023-01-11 10:10:17.867  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                      2023-01-11 10:10:18.662  - info: lightcontrol.0 (3668) [ Controller ] Reaching, Group="BueroOGB" Property="actualLux" NewVal="5", OldVal="5"
                                      2023-01-11 10:10:23.419  - info: host.iobrokerS "system.adapter.bluelink.0" disabled
                                        @ilovegym ok nimm wieder das orginal
                                        muss ich später schauen
                                          A Former User @arteck last edited by A Former User
                                          @arteck ok kein thema!
                                          der ging auch nicht, kam auch dieser Fehler, musste erst den Adapter komplett loeschen, dann aus dem latest installieren, der wollte starten, kam aber immer der Fehler dass die Sprache DE nicht unterstuetzt wird, obwohl ich EN eingestellt habe... ?
                                          2023-01-11 10:33:07.025  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3758144
                                          2023-01-11 10:33:07.806  - debug: bluelink.0 (3758144) Redis Objects: Use Redis connection: 10.10.2.10:6379
                                          2023-01-11 10:33:07.826  - debug: bluelink.0 (3758144) Objects client ready ... initialize now
                                          2023-01-11 10:33:07.828  - debug: bluelink.0 (3758144) Objects create System PubSub Client
                                          2023-01-11 10:33:07.829  - debug: bluelink.0 (3758144) Objects create User PubSub Client
                                          2023-01-11 10:33:08.245  - debug: bluelink.0 (3758144) Objects client initialize lua scripts
                                          2023-01-11 10:33:08.249  - debug: bluelink.0 (3758144) Objects connected to redis: 10.10.2.10:6379
                                          2023-01-11 10:33:08.300  - debug: bluelink.0 (3758144) Redis States: Use Redis connection: 10.10.2.10:6379
                                          2023-01-11 10:33:08.306  - debug: bluelink.0 (3758144) States create System PubSub Client
                                          2023-01-11 10:33:08.307  - debug: bluelink.0 (3758144) States create User PubSub Client
                                          2023-01-11 10:33:08.317  - debug: bluelink.0 (3758144) States connected to redis: 10.10.2.10:6379
                                          2023-01-11 10:33:08.470  - info: bluelink.0 (3758144) starting. Version 2.2.6 (non-npm: Newan/ioBroker.bluelink#heating_number) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.0, js-controller: 4.0.24
                                          2023-01-11 10:33:08.496  - info: bluelink.0 (3758144) Login to api
                                          2023-01-11 10:33:08.498  - error: bluelink.0 (3758144) Error in login/on function
                                          2023-01-11 10:33:08.499  - error: bluelink.0 (3758144) The language code DE is not managed. Only cs, da, nl, en, fi, fr, de, it, pl, hu, no, sk, es, sv are.
                                          Bin dann auf den letzten Snapshot zurueck, hatte ja vorher einen gemacht..
                                            @ilovegym
                                            ahh sehr gut
                                            kannst nochmal schauen
                                            2264
                                            846624
