    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • JohGre
      JohGre last edited by
      Bei mir funktioniert der Adapter seit gestern Nachmittag nicht mehr. Auch aus dem Log ist nicht wirklich was ersichtlich. Ist da was bekannt.
      2022-03-30 09:48:00.435 - debug: vofo-speedtest.0 (5218) Redis Objects: Use Redis connection: 10.0.0.227:9001
      2022-03-30 09:48:00.462 - debug: vofo-speedtest.0 (5218) Objects client ready ... initialize now
      2022-03-30 09:48:00.464 - debug: vofo-speedtest.0 (5218) Objects create System PubSub Client
      2022-03-30 09:48:00.465 - debug: vofo-speedtest.0 (5218) Objects create User PubSub Client
      2022-03-30 09:48:00.499 - debug: vofo-speedtest.0 (5218) Objects client initialize lua scripts
      2022-03-30 09:48:00.504 - debug: vofo-speedtest.0 (5218) Objects connected to redis: 10.0.0.227:9001
      2022-03-30 09:48:00.505 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.system.user.*
      2022-03-30 09:48:00.525 - silly: vofo-speedtest.0 (5218) redis psubscribe cfg.o.enum.*
      2022-03-30 09:48:00.527 - silly: vofo-speedtest.0 (5218) objectDB connected
      2022-03-30 09:48:00.528 - debug: vofo-speedtest.0 (5218) Redis States: Use Redis connection: 10.0.0.227:9000
      2022-03-30 09:48:00.543 - debug: vofo-speedtest.0 (5218) States create System PubSub Client
      2022-03-30 09:48:00.544 - debug: vofo-speedtest.0 (5218) States create User PubSub Client
      2022-03-30 09:48:00.570 - debug: vofo-speedtest.0 (5218) States connected to redis: 10.0.0.227:9000
      2022-03-30 09:48:00.571 - silly: vofo-speedtest.0 (5218) statesDB connected
      2022-03-30 09:48:00.664 - debug: vofo-speedtest.0 (5218) Plugin sentry Initialize Plugin (enabled=true)
      2022-03-30 09:48:00.941 - info: vofo-speedtest.0 (5218) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v14.19.1, js-controller: 4.0.21
      2022-03-30 09:48:00.998 - silly: vofo-speedtest.0 (5218) States system redis pmessage system.adapter.vofo-speedtest.0.logLevel/system.adapter.vofo-speedtest.0.logLevel:{"val":"silly","ack":true,"ts":1648626480968,"q":0,"from":"system.adapter.vofo-speedtest.0","lc":1648626480968}
      2022-03-30 10:03:00.003 - warn: host.VM-Slave instance system.adapter.vofo-speedtest.0 already running with pid 5218
      dontobi Thomas Braun RK62 3 Replies Last reply Reply Quote 0
      • dontobi
        dontobi @JohGre last edited by
        @johgre Die Entwicklung des Adapters würde entweder eingestellt oder geschieht sehr schleppend. Schade.
        Aber daher habe ich mich vor einiger Zeit nach einer Alternative umgesehen. Ich bin dann auf den Docker Container SpeedFlux gestoßen. Jedoch gab es diesen nicht für ARM Geräte. Daher habe ich den Container so angepasst und unter SpeedFlux.rpi veröffentlicht. Vielleicht wäre das was für den ein oder anderen.
        https://github.com/dontobi/SpeedFlux.rpi
          Thomas Braun Most Active @JohGre last edited by
          @johgre
          Oder das Skript von @SKB verwenden.
          Findest du über die Suchfunktion:
          Kreyenborg
          als Suchbegriff.
          • SKB
            SKB Developer Most Active last edited by SKB
            ... oder direkt als Link 🙂
            https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
            Gruß,
            Stephan
            • RK62
              RK62 @JohGre last edited by
              @johgre Ich hatte diesen Docker-Container mal getestet, der arbeitet recht zuverlässig und ist optisch auch nett aufgemacht: https://github.com/henrywhitaker3/Speedtest-Tracker
              Mittlerweile habe ich den ookla-Speedtest in eine eigene Docker-Maschine gelegt, die dann regelmäßig ein Testergebnis für den ioBroker bereit stellt und dort dann visualisiert wird.
              • JohGre
                Danke an alle und @SKB für das Script werde es nun mal etwas testen
                  Thomas Braun Most Active @JohGre last edited by Thomas Braun
                  @johgre
                  Hier hab ich noch ein paar Ergänzungen zum Skript aufgeschrieben:
                  https://forum.iobroker.net/topic/48700/speedtest-skript-von-kreyenborg-koeln-für-kabel-gigabit
                  Da wird u. a. die speedtest binairy sauberer im System installiert.
                  JohGre 1 Reply Last reply Reply Quote 1
                  • JohGre
                    JohGre @Thomas Braun last edited by
                    @thomas-braun Super, danke für den Link und läuft schon. Ich musste aber noch in die sudoers.d von iobroker den Pfad zu speedtest eintragen damits dann wirklich lief.
                    sudo nano /etc/sudoers.d/iobroker
                    iobroker ALL=(ALL) NOPASSWD: /usr/bin/speedtest
                      @johgre sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                      Musste ich nicht. Warum auch?
                      echad@chet:~ $ which speedtest
                      /usr/bin/speedtest
                      echad@chet:~ $ ls -l /usr/bin/speedtest
                      -rwxr-xr-x 1 root root 2471896 Nov 17 23:26 /usr/bin/speedtest
                      echad@chet:~ $
                        Bongo last edited by
                        Habe ich nun auch installiert. Funktioniert! Danke.
                        Was ist der Unterschied zu den Datenpunkten download_Mb und download_Mb_calc?
                          mx-driver last edited by
                          Im Moment bekomme ich den Fehler:
                          instance system.adapter.vofo-speedtest.0 already running with pid 21677
                          Immer wenn er einen Speedtest machen sollte.
                          Hat das sonst noch jemand?
                          • Knallochse
                            Knallochse last edited by
                            Installation unter Node Version 18.15.0 nicht mehr möglich
                            $ iobroker add vofo-speedtest auto --host buanet-iobroker1 --debug
                            NPM version: 9.5.0
                            Installing iobroker.vofo-speedtest@0.0.13... (System call)
                            npm ERR! code 1
                            npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/.cache/node-gyp/18.15.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/18.15.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/18.15.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Could not run curl-config, please make sure libcurl dev package is installed.
                            npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2023-04-04T09_56_47_982Z-debug-0.log
                            host.buanet-iobroker1 Cannot install iobroker.vofo-speedtest@0.0.13: 1
                            ERROR: Process exited with code 25
                            Github Issues dazu
                            • wendy2702
                              wendy2702 @Knallochse last edited by
                              @knallochse sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                              Mal hier gschaut: https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2
                                Thomas Braun Most Active @wendy2702 last edited by
                                @wendy2702
                                Du bist zu spät. Wurde schon gelöst:
                                Kein Issue mit nodejs, da fehlen dev-packages.
                                sudo apt update
                                apt policy libcurl4-gnutls-dev libcurl4-nss-dev libcurl4-openssl-dev
                                • wendy2702
                                  wendy2702 @Thomas Braun last edited by
                                  @thomas-braun Ups...
                                  OK.
                                    PatrickFro last edited by
                                    Moin,
                                    ich habe den Adapter gerade erst gefunden und installiert. So wie es scheint wird er ja nun doch weiterentwickelt, zumindest gab es einige Änderungen im letzten Monat.
                                    Ich verstehe die Ergebnisse jedoch noch nicht:
                                    9b7898b3-a51f-4574-92ba-4dd798486539-image.png im Vergleich zu baeddd3f-17c8-40c9-8d9c-148a2baf8fc2-image.png
                                    Schaue ich mir die Downloadraten an, sehe ich über die Webseite vom Speedtest 269 Mbit/s, über den Adapter eine Minute vor der Messung per Webseite 55,842 MB/s.
                                    Wenn ich die verschiedenen Werte richtig zuordnete, müsste ich bei MB/s x 8,25 rechnen um auf Mbit/s zu kommen. Das aber ergäbe 470 Mbit/s. Wo ist hier mein Denkfehler?
                                    • wollerosekaufe
                                      wollerosekaufe last edited by wollerosekaufe
                                      verstehe es auch nicht so ganz.
                                      auf npm ist version 1.0.1, aber nur dependencies aktualisiert und kein release.
                                      haben wir noch chancen dass der adapter gefixt wird? @Bluefox @peterbaumert 🙂
                                      anyway, der adapter läuft bei mir nicht. habe ebenso das problem von @PatrickFro mit VIEL zu niedrigen DL rates.
                                      dazu klappt der UL test erst gar nicht, der adapter stoppt einfach "ohne fehlermeldung", vofo-speedtest.0.Results.upload_MB etc. bleibt alles leer.
                                      host.iobroker
                                      	2023-11-17 22:57:39.204	info	instance system.adapter.vofo-speedtest.0 terminated with code 0 (NO_ERROR)
                                      vofo-speedtest.0
                                      	2023-11-17 22:57:38.631	info	Terminated (NO_ERROR): Without reason
                                      vofo-speedtest.0
                                      	2023-11-17 22:57:38.577	info	cleaned everything up...
                                      vofo-speedtest.0
                                      	2023-11-17 22:57:38.576	info	starting cleanup...
                                      vofo-speedtest.0
                                      	2023-11-17 22:57:38.563	info	Vofo-Speedtest finished with 184.013mbit download speed and 0mbit upload speed.
                                      vofo-speedtest.0
                                      	2023-11-17 22:57:04.317	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                                      host.iobroker
                                      	2023-11-17 22:57:00.080	info	instance system.adapter.vofo-speedtest.0 started with pid 509363
                                      mit CURL ist das ganze noch schlimmer, da crasht der adapter mit UNCAUGHT_EXCEPTION:
                                      host.iobroker
                                      	2023-11-17 23:01:44.523	error	instance system.adapter.vofo-speedtest.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.944	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.941	info	terminating
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.938	info	cleaned everything up...
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.937	info	starting cleanup...
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.799	error	Curl handle is closed.
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.798	error	Error: Curl handle is closed. at Curl.close (/opt/iobroker/node_modules/node-libcurl/dist/Curl.js:588:21) at VofoSpeedtest.stopDownloadTest (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:824:29) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.vofo-speedtest/main.js:540:39) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                      vofo-speedtest.0
                                      	2023-11-17 23:01:43.787	error	uncaught exception: Curl handle is closed.
                                      vofo-speedtest.0
                                      	2023-11-17 23:00:03.861	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.vofo-speedtest, node: v18.18.2, js-controller: 5.0.16
                                      host.iobroker
                                      	2023-11-17 23:00:00.125	info	instance system.adapter.vofo-speedtest.0 started with pid 509581
                                      iobroker läuft auf buanet/docker mit libcurl4-openssl-dev package
                                      btw: bei mir wird die config nicht richtig aktualisiert, daher meldet npm permanent die alte version. alle anderen dateien werden sauber von 1.0.1 geladen, code auf dem iobroker entspricht den neuen github files - das update klappt also. adapter mehrmals de- und neu installiert, hilft nichts. hab die config nun manuell angepasst damit die update-meldung nicht nervt.
                                        @wollerosekaufe
                                        Ich hatte meinen buanet/Docker Container upgegradet. Dabei wurde auch ein Upgrade von node 16 auf 18 gemacht. Darauf hin kam unter anderem JS_CONTROLLER_STOPPED.
                                        Ich habe dann die Version v0.0.13 über Github auf v1.0.1 gebracht. Jetzt gibt es keine Fehlermeldung mehr. Download passt aber Upload war immer 0.
                                        Dann habe ich CURL aktiviert. Dann war der Upload wieder korrekt.
                                        Hilft dir vermutlich nicht weiter aber bei mir funktioniert wieder alles.
                                        Von welcher Config sprichst du?
                                        wollerosekaufe 1 Reply Last reply Reply Quote 0
                                        • wollerosekaufe
                                          wollerosekaufe @Bongo last edited by
                                          @bongo said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                          bei mir wird die io-package.json scheinbar nicht geladen, alles andere wie gesagt schon. aus der datei holt sich iobroker/npm dann wohl die version zum update-abgleich. hab da manuell 1.0.1 hinterlegt:
                                          cat io-package.json
                                            "common": {
                                              "name": "vofo-speedtest",
                                              "version": "1.0.1",
                                              "news": {
                                                "0.0.13": {
                                                  "en": "some more \"already running\" fixes",
                                          über github bekomme ich auch nur die alte version, die 1.0.1 ist da nicht released.
                                            Bongo @wollerosekaufe last edited by
                                            @wollerosekaufe sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                            Ich habe die 1.0.1 über die Katze installiert. In der Instanz wird zwar die alte Version angezeigt aber wenn das Programm startet sieht man im Protokoll die 1.0.1.
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25308
