    4. Awattar - die billigsten Strom-Stunden nutzen
      paul53 @Doom.86 last edited by paul53
      @doom-86 sagte: Es würde somit auch reichen, wenn erst um 18 Uhr getriggert wird.
      Dann schau mal diese Lösung mit Trigger um 17:59 Uhr an:
       <variables>
         <variable id="slzz5)!d0O#p:CL?^k@l">tibber</variable>
         <variable id="I=q`=kgBC10=WtmP[C@G">end1h</variable>
         <variable id="y[G=0ms17p|S*%p]+B~p">preise</variable>
         <variable id="A*CzK[pG.x4^B]b*|c[1">end3h</variable>
         <variable id="L`VRA5|#^N/oI[|LjJqy">i</variable>
         <variable id="ES`I}6lM2ZNSuk*`6Bt`">id</variable>
         <variable id="6)]2##_Z9.w~~.^]:M*W">min1</variable>
         <variable id="bpynY%@fDWCdbC?Xv*s1">min3</variable>
         <variable id="5_aI@Kq-?t,56cb.j893">preis1</variable>
         <variable id="FAiYO^Ty$^^g*F@vG:~j">start1h</variable>
         <variable id="a4m{kvJ}{$=rv(H9#1J_">preis3</variable>
         <variable id="ud88TKb=*)[?(!NqiOoj">start3h</variable>
         <variable type="cron" id="schedule1">schedule1</variable>
         <variable type="cron" id="schedule2">schedule2</variable>
         <variable type="cron" id="schedule3">schedule3</variable>
         <variable type="cron" id="schedule4">schedule4</variable>
       </variables>
       <block type="variables_set" id="yCwl;0ySJ|1}Q!2s=yK]" x="87" y="-87">
         <field name="VAR" id="slzz5)!d0O#p:CL?^k@l">tibber</field>
           <block type="text" id="Dg:|cO}z^{]x$/g4fe`1">
             <field name="TEXT">tibberconnect.0.Homes.ef9611f1-6e89-47ae-8966-ce359e21b819.</field>
           <block type="schedule" id="tt0v29t$v3Fc|sH*~qV_">
             <field name="SCHEDULE">59 17 * * *</field>
               <block type="controls_if" id="+g*^w|33kRI[#2ilg+zf">
                   <block type="logic_compare" id="%kEM[O!*NkR1bxYxj}La">
                     <field name="OP">EQ</field>
                       <block type="variables_get" id="*RrNBWBfa}4YV^EFey:|">
                         <field name="VAR" id="I=q`=kgBC10=WtmP[C@G">end1h</field>
                       <block type="math_number" id="M7U.jytRxX6d-BmPUg@*">
                         <field name="NUM">18</field>
                   <block type="control" id="*B_t6szZgS!H$Znz$|)#">
                       <block type="logic_boolean" id="j]D))tVtr,r_ZAC_dAY+">
                   <block type="controls_if" id="a0!D]L2`|I(._P{MjZn]">
                       <block type="logic_compare" id="X.N)Nh`lCo83t,M=g0`*">
                           <block type="variables_get" id="yf%,Pvwz(hBDganu|},t">
                             <field name="VAR" id="A*CzK[pG.x4^B]b*|c[1">end3h</field>
                           <block type="math_number" id="O1R{)2/9M(-.8L{6@P~P">
                       <block type="control" id="c7{0Rrpn|)lA{HL$PE:`">
                           <block type="logic_boolean" id="u2(so==`PrHNt$t,/XT#">
                       <block type="variables_set" id=".T%gExb0x3kzS0QkPh4_">
                         <field name="VAR" id="y[G=0ms17p|S*%p]+B~p">preise</field>
                           <block type="lists_create_with" id="9_QV!ty3GA(vG,y+f$PM">
                           <block type="controls_for" id="0EMe,uPv?5mH[^}O)k`i">
                             <field name="VAR" id="L`VRA5|#^N/oI[|LjJqy">i</field>
                             <value name="FROM">
                               <shadow type="math_number" id="CD]PeRYFc[XnhEs5CJ#x">
                             <value name="TO">
                               <shadow type="math_number" id="qYc{.jy$roEsQ,Nt8vyr">
                                 <field name="NUM">23</field>
                             <value name="BY">
                               <shadow type="math_number" id="03:P%];Y-P#yi{L-}LKp">
                                 <field name="NUM">1</field>
                             <statement name="DO">
                               <block type="variables_set" id="@3TC[[E?2tnNxQ*fd~Q{">
                                 <field name="VAR" id="ES`I}6lM2ZNSuk*`6Bt`">id</field>
                                   <block type="text_join" id="N:w]#x6G+8Bmx~)$;f8}" inline="true">
                                     <mutation items="4"></mutation>
                                     <value name="ADD0">
                                       <block type="variables_get" id="LzVIIv*{^;~R(2@Lv;{E">
                                     <value name="ADD1">
                                       <block type="text" id="N@bdq$^6yP}vR4yYmF.x">
                                         <field name="TEXT">PricesToday.</field>
                                     <value name="ADD2">
                                       <block type="variables_get" id="IcZwEk?;*^(U.C8Sj,7|">
                                     <value name="ADD3">
                                       <block type="text" id="e!Oo*|9/;z$t6##==xXm">
                                         <field name="TEXT">.total</field>
                                   <block type="lists_setIndex" id="mz72D6xxndyuAarOJ^Rh">
                                     <mutation at="false"></mutation>
                                     <field name="WHERE">LAST</field>
                                     <value name="LIST">
                                       <block type="variables_get" id="IWq=s?THie/h/[7iiV}{">
                                     <value name="TO">
                                       <block type="get_value_var" id="GGwox!C;I%E_l1R0DqiG">
                                         <value name="OID">
                                           <shadow type="text" id="MyJGi(n/]qv_!IYhxy=H">
                                             <field name="TEXT"></field>
                                           <block type="variables_get" id="ks=U5X[R.:5N=z(giPmt">
                               <block type="controls_for" id="#IcemZu7(wpeg8hlUr;:">
                                 <value name="FROM">
                                   <shadow type="math_number" id="XqH@jx{57kMGD#DNVXEe">
                                     <field name="NUM">0</field>
                                 <value name="TO">
                                   <shadow type="math_number" id="Rof~CHCPfRE}Q?+NC.R_">
                                     <field name="NUM">17</field>
                                 <value name="BY">
                                   <shadow type="math_number" id="^[nSkD;0r.fX)=GB;P5=">
                                   <block type="variables_set" id=",140@$+*?5Q!6phadh*E">
                                       <block type="text_join" id="f;8DEi_aVP:k8Mo2{[xZ" inline="true">
                                         <value name="ADD0">
                                           <block type="variables_get" id="FU7z:,?Q@2]@;WxPq8-H">
                                         <value name="ADD1">
                                           <block type="text" id="W5b%W`21-HBX(uY$3G|/">
                                             <field name="TEXT">PricesTomorrow.</field>
                                         <value name="ADD2">
                                           <block type="variables_get" id="y91uc$|ujM0al,!9q-Xv">
                                         <value name="ADD3">
                                           <block type="text" id="00Ae^StCs9ZJQ]7.FgN5">
                                       <block type="lists_setIndex" id="C_rGEL-3J#BKOo`X4[dK">
                                         <value name="LIST">
                                           <block type="variables_get" id="~9N?Q5}62w)Sy!mAO)k}">
                                         <value name="TO">
                                           <block type="get_value_var" id="{16RqU$HDR4jR|aQ0q3%">
                                             <value name="OID">
                                               <shadow type="text">
                                               <block type="variables_get" id="l2^WVBo)dq?Syx.w5F%!">
                                   <block type="variables_set" id="I%E4f01C`g;3p|DcmUku">
                                     <field name="VAR" id="6)]2##_Z9.w~~.^]:M*W">min1</field>
                                       <block type="math_number" id="3KuHw0^#,p*_2M/QP?uO">
                                         <field name="NUM">3</field>
                                       <block type="variables_set" id="Dt_:-3vN.ADYN1pT.7-z">
                                         <field name="VAR" id="bpynY%@fDWCdbC?Xv*s1">min3</field>
                                           <block type="math_number" id="?gi`V*!@#+iuu8K3*`5L">
                                             <field name="NUM">9</field>
                                           <block type="controls_for" id="W3SFx!cp:%wcO#wjjI({">
                                             <value name="FROM">
                                               <shadow type="math_number" id="?VS9n{p5)Sbybdj_MorR">
                                             <value name="TO">
                                               <shadow type="math_number" id="68B!zjKn/MASC]R;y}k1">
                                                 <field name="NUM">10</field>
                                               <block type="lists_length" id="t9HYB^`KjiNfq$x*IH,f">
                                                   <block type="variables_get" id="fUVVK_^CL_)k4*5C*l|7">
                                             <value name="BY">
                                               <shadow type="math_number" id="tP+sIGUb[Wn]d+!$C*mL">
                                               <block type="variables_set" id="L:[PGOztTsy}k$t*7|oA">
                                                 <field name="VAR" id="5_aI@Kq-?t,56cb.j893">preis1</field>
                                                   <block type="lists_getIndex" id=".LJVQeHz5,l}n%R[%6~}">
                                                       <block type="variables_get" id="ZFC/#M0fU1Fj@?y8i98Y">
                                                     <value name="AT">
                                                       <block type="variables_get" id="Wq(#HzHm(]G]PaXwu4B*">
                                                   <block type="controls_if" id="Ozsx73!acF65Yh8[fRS[">
                                                       <block type="logic_compare" id="]XZHpA3}P5iN%Ip1UoLZ">
                                                         <field name="OP">LT</field>
                                                           <block type="variables_get" id="5}g:it%7kl(5?9x*p~Gy">
                                                           <block type="variables_get" id="AvX)nL76,z(TOD-f#;AR">
                                                       <block type="variables_set" id="L4nG!:}Bi%*B9bD|U$[z">
                                                           <block type="variables_get" id="FY@GQkmRYO[;W6rM[ayJ">
                                                           <block type="variables_set" id="b*cBRJ-9AMXYQ*U;ncQs">
                                                             <field name="VAR" id="FAiYO^Ty$^^g*F@vG:~j">start1h</field>
                                                               <block type="logic_ternary" id="AIR,$Z?!9$xfowz)flFt" inline="true">
        <value name="IF">
        <block type="logic_compare" id="Ij$Y[Y=A[:chL7VA%8SU">
        <block type="variables_get" id="D9Qw)FPc9e9^JDF*{dlj">
        <block type="math_number" id="UE*pCLL]21,C{0nywlC9">
        <field name="NUM">7</field>
        <value name="THEN">
        <block type="math_arithmetic" id="S(4~b~~Os#gW;Ae+7b2~">
        <field name="OP">ADD</field>
        <shadow type="math_number" id="A0|ecpGucnJ;c=5R)QPu">
        <block type="variables_get" id="VP9|C5G+m?+[S%h+L$SK">
        <shadow type="math_number" id="fRyfZ2ugekFxSbGw+|2.">
        <value name="ELSE">
        <block type="math_arithmetic" id="}?gMK^#aT.Dg?Kq[_3gU">
        <shadow type="math_number">
        <block type="variables_get" id=",m0S.DIN-i.W4qB1DKY0">
        <shadow type="math_number" id="+2H~`?hnFXE?Tue#??m[">
                                                       <block type="controls_if" id="z4sy3v]0;aHg8?:Gj]1q">
                                                           <block type="logic_compare" id="`T=HLgrMIevH#=#3ri^+">
                                                             <field name="OP">LTE</field>
                                                               <block type="variables_get" id="A+Gquk7s3kdja^=WzWZi">
                                                               <block type="math_arithmetic" id="~!H6ix/juSb1QKizjMEg">
        <shadow type="math_number" id="edjc~ni75,)^-MW2eAD!">
        <block type="lists_length" id="Ff!`(-2!7M#^)_WymPfp">
        <block type="variables_get" id="[13^ih^yUx~]zvixT(k1">
        <shadow type="math_number" id="pV;){(|(_g39fTA$QoY?">
        <field name="NUM">2</field>
                                                           <block type="variables_set" id="93e2%SRJrBGkHVT|JK+t">
                                                             <field name="VAR" id="a4m{kvJ}{$=rv(H9#1J_">preis3</field>
                                                               <block type="math_arithmetic" id="Iqe~^Y]R4f5e1ZRlkTN?">
        <shadow type="math_number" id="UnCxpTSlndDmHwzJ9z]s">
        <block type="variables_get" id="_#!qO(*2{1]q[,:OVuVg">
        <shadow type="math_number" id="==NQWZ*VKKYvKR1H*PsY">
        <block type="math_arithmetic" id="2x[l_Q)nTYh8XdvcpT6," inline="false">
        <shadow type="math_number" id=")}0`5kIav:jNy+PjDAPX">
        <block type="lists_getIndex" id="2:cxr7AvKukN|oxJ|8$s">
        <block type="variables_get" id="|QJ7IXv.fGbKjXZ:t,T0">
        <value name="AT">
        <block type="math_arithmetic" id=")9M=+:!*`t3:^kK@6v.U">
        <shadow type="math_number" id="d6Vs9+DCL~OyRs+WT^)b">
        <block type="variables_get" id=",mdfVY1y#7OJ/LpoXugr">
        <shadow type="math_number" id=":Azb.knUscU0Y6Y$$x~x">
        <shadow type="math_number" id="AsHxB2um+5RUQtu^VH~c">
        <block type="lists_getIndex" id="{7#Y1kmCjSzA6zDM(~ec">
        <block type="variables_get" id="9Hwt/#|)CcMAry7lid|2">
        <value name="AT">
        <block type="math_arithmetic" id="q4sI9mLMEDuS-_`@~mqj">
        <block type="variables_get" id="7f^QF_uPBzFEWj#..]P#">
        <shadow type="math_number" id="mRg/SS2z*!,s(Aza6^@9">
                                                               <block type="controls_if" id="n1n2P:qtW6Q-lfm{Abp%">
        <block type="logic_compare" id="f07U,rk3tE3W/q0ofM08">
        <block type="variables_get" id="YfYeRF{7,Wn2lwJtGrgG">
        <block type="variables_get" id="mDAJ1@=qgN$rBT_Ke}mg">
        <block type="variables_set" id="V:[20QemZnhU63-|yYW;">
        <block type="variables_get" id="!8=qf*1+^mU_ZbC/vWo3">
        <block type="variables_set" id="S~xa|f9t2Zn~XZXlbJh?">
        <field name="VAR" id="ud88TKb=*)[?(!NqiOoj">start3h</field>
        <block type="logic_ternary" id="jS-NU~7A8yY,1}|^_*,f" inline="true">
        <value name="IF">
        <block type="logic_compare" id="75?f-Y9K1`uISWR.Pr19">
        <block type="variables_get" id="IRj[~IFnc?`x7/@YGbm)">
        <block type="math_number" id="(V~PXIre~J(0|6y@Y;`{">
        <value name="THEN">
        <block type="math_arithmetic" id="gfg!EF#W,kt7-PIe.]jO">
        <block type="variables_get" id="D*3tr1la5PYprIfcC:=O">
        <shadow type="math_number" id="-ES^l3#}PjLG+jjuRA@g">
        <value name="ELSE">
        <block type="math_arithmetic" id="sii*:2njz!9TiOuc[aZe">
        <block type="variables_get" id="KO$U?pP9#m.LJ8a]/ig;">
        <shadow type="math_number" id="lK$A8CNUSB8wmH)GEuTW">
                                               <block type="variables_set" id="?VZnr9+1^FL]flg:=39f">
                                                   <block type="logic_ternary" id="5hVu~,$5hYC=+)77ZnvF" inline="true">
                                                     <value name="IF">
                                                       <block type="logic_compare" id="{#nKoiS0A2!ds]4A_9PD">
                                                           <block type="math_arithmetic" id="LjTp=sImVPb6`ULLeIb7">
                                                               <shadow type="math_number" id="_J95g6~#:F9sj2VjM}Qh">
                                                               <block type="variables_get" id="pr_)NjZ{/P{9T#`IDLZh">
                                                               <shadow type="math_number" id="#?$Un~ak7axxfE;{o{Qv">
                                                           <block type="math_number" id="oiAIF1yfSH/#|RKsezHr">
                                                             <field name="NUM">24</field>
                                                     <value name="THEN">
                                                       <block type="math_arithmetic" id="ly`80HF+P.9J8snCEGac">
                                                           <block type="variables_get" id="dR!V{Hse^.`K;6fXm*rL">
                                                           <shadow type="math_number" id="i]Rfsocfn@5O57aFe3dP">
                                                     <value name="ELSE">
                                                       <block type="math_number" id="MGCtCd`Yt=6@{n*~Kn]h">
                                                   <block type="variables_set" id="`yJ*RF3RXBzDcYoUf]V$">
                                                       <block type="logic_ternary" id="@-:I|ewU=ypMKe5?#.GV" inline="true">
                                                         <value name="IF">
                                                           <block type="logic_compare" id="Ry;||rCNv.1Euw*UJP]M">
                                                               <block type="math_arithmetic" id="p^@+.p)y{v5o}0C}m0.y">
        <block type="variables_get" id="xH;g#MI35+/3yJQ:qQG)">
        <shadow type="math_number" id="Ok}tH`Br~A_24Nrf=sM/">
                                                               <block type="math_number" id="-3@U3~j%$|hdAj[)pfB/">
                                                         <value name="THEN">
                                                           <block type="math_arithmetic" id="EUg_wq,2_Af/q7Dwldp=">
                                                               <block type="variables_get" id="nXXAXel6/+px~(.P;Xd*">
                                                               <shadow type="math_number" id="N,vEBOefnhveJ:1*]DFC">
                                                         <value name="ELSE">
                                                           <block type="math_arithmetic" id="c29R^iU`sijcK83l%^E|">
                                                               <block type="variables_get" id="d#z|7LYA@:|^q)WTo,L#">
                                                               <shadow type="math_number" id=".Q9)T9Rp|iH%:,Xvcv6O">
        <field name="NUM">21</field>
                                                       <block type="schedule_clear" id="iM7,/Ko=JX57Y0yu?-6q">
                                                         <field name="NAME">schedule1</field>
                                                           <block type="schedule_clear" id="7ci5R#wHLXk]I]Erriip">
                                                             <field name="NAME">schedule2</field>
                                                               <block type="schedule_clear" id="4]Ps(*w%jE%aa@U26}mw">
        <field name="NAME">schedule3</field>
        <block type="schedule_clear" id="$ceBK{ys|)xS*f~_Z;Rp">
        <field name="NAME">schedule4</field>
        <block type="schedule_create" id="C@%7o,Ekc,|!/a6{MkUS">
        <value name="SCHEDULE">
        <shadow type="field_cron" id="-$VctMxjGv=4)zq9N4Y0">
        <field name="CRON">* * * * *</field>
        <block type="cron_builder" id="8y]GZ`$%m4$NTYjf,#_4" inline="true">
        <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
        <field name="LINE">TRUE</field>
        <field name="WITH_SECONDS">FALSE</field>
        <value name="DOW">
        <shadow type="text" id="5BeD0bHLs:^x0RqW5}$x">
        <field name="TEXT">*</field>
        <value name="MONTHS">
        <shadow type="text" id="lg{qvknu8,?D++21hEpf">
        <value name="DAYS">
        <shadow type="text" id="*Fw,YPls30y1W{.)Z]Zp">
        <value name="HOURS">
        <shadow type="text" id="w+jm9ay~fdBT)SuxS|y9">
        <block type="variables_get" id="o(.aJHIKtOGz3%n2lxYM">
        <value name="MINUTES">
        <shadow type="text" id="HLI#3VJ/f!FRNZQ:n4O%">
        <field name="TEXT">0</field>
        <block type="control" id="R|GS:n7ms%A-8wutDCq[">
        <block type="logic_boolean" id="UYDo5xpjr03Z[HC]JciX">
        <block type="schedule_create" id="lmx|uwrCVvUbx-C09[94">
        <shadow type="field_cron">
        <block type="cron_builder" id="aEX/56JjlSBU/[ipuQ8X" inline="true">
        <value name="DOW">
        <shadow type="text" id="lMH4V)Vtf+IcFdjRXkaW">
        <shadow type="text" id="AjkR{~Onh=VHFT!@jluL">
        <value name="DAYS">
        <shadow type="text" id="gX*GvSQe~+EV$/I$O,j%">
        <block type="variables_get" id="~}v=cY[KUbaMt@pI}8{e">
        <shadow type="text" id="ijLCMJgY]v$y@,?zSo9+">
        <block type="control" id="F[A)xVutBB$1Yv9wQJMg">
        <block type="logic_boolean" id="Q7bdR}]i^c*s6c46-O@o">
        <block type="schedule_create" id="Uz3Pj9N9)62!ppFx*s`-">
        <block type="cron_builder" id="}`t[hS]2+i@W$Kw@C;2L" inline="true">
        <value name="DOW">
        <shadow type="text" id="b:oN*ACawmZv{JQR0m7q">
        <shadow type="text" id="Ur]myA9.G$]jH22=!nx]">
        <value name="DAYS">
        <shadow type="text" id="%@r2eu#Cv7rs2*|n.0ol">
        <block type="variables_get" id="p81|d/F,bF2}O`(qGaGH">
        <shadow type="text" id="lMv%?#YLF`haS{qw}3W!">
        <block type="control" id="JMt*g^rD+x|@pHw3p:5,">
        <block type="logic_boolean" id=":`WAU[k;h[|V+Pt[9W%W">
        <block type="schedule_create" id="Xu`urAC!r/9e%8Yc3?(r">
        <block type="cron_builder" id="TKfvJ_4r93bJ7La7-=46" inline="true">
        <value name="DOW">
        <shadow type="text" id="A{ANH/W|%b,aS!(QRvhv">
        <shadow type="text" id="tTX%wAllx+SDy:.xMIt6">
        <value name="DAYS">
        <shadow type="text" id=".z=ARDX,g[O6@RX-8CRq">
        <block type="variables_get" id="^qx9D%(sDw*tT~.|n]fE">
        <shadow type="text" id="%I_F`(NE8{I)Pd8.+*ZY">
        <block type="control" id=":Y?k,t=+Ug:-h!aRb+e~">
        <block type="logic_boolean" id="E%~He2eg5q}_wNkv%Fro">
      Für ein Bild ist es zu umfangreich.
      Der erste Teil schaltet aus, wenn vor einem Tag als Endzeit 18:00 Uhr ermittelt wurde und es werden die Preise ab 18:00 Uhr bis morgen 17:00 chronologisch sortiert in ein Array geschrieben.
      Im zweiten Teil werden die Startzeiten für 1 Stunde und 3 Stunden Dauer ermittelt.
      Im letzten Teil werden die Endzeiten ermittelt, die laufenden Zeitpläne gestoppt und die neuen Zeitpläne erstellt.
        Doom.86 @paul53 last edited by Doom.86
        @paul53 ich sage erstmal vielen lieben Dank für deine Mühe. Ich schaue es mir an, sobald ich zuhause bin und werde dann Rückmeldung geben.
        Edit: hab ich es an den Bildern übersehen, wo trage ich die id von Warmwasser bzw FBH ein? Dort reicht es, wenn preis günstig erhöhe aktuellen Wert zb. Um 4 nach Ablauf der Zeit veringere diesen Wert wieder um 4.
          @doom-86 sagte: wo trage ich die id von Warmwasser bzw FBH ein?
          Dort, wo die Blöcke "steuere" sitzen: FBH bei end3h, schedule3 und schedule4.
            @paul53 ach, gleich in der dritten zeile von dem ersten screenshot?
            Und dahinter dann den wert mit erhöhe um 4?
            Ich probier es nachher zu hause aus. Übers handy ließ er mich nicht mal den Code kopieren.
              @doom-86 sagte: gleich in der dritten zeile von dem ersten screenshot?
              Stattdessen: Verringere den Wert um 4.
              Und unten:
                @paul53 So schaut es jetzt bei mir aus.
                ich hoffe das passt so?
                Einzige was mir unter Protokolle ausgewurfen wurde ist:
                2023-01-10 23:10:19.125 warn State "javascript.1.scriptEnabled.Heizung_Nacht_Tibber" has no existing object, this might lead to an error in future versions
                naja, ich hab jetzt die Zwei Werte der Heizung in die History aufgenommen. so sollte ich die Tage sehen, ob es funktioniert.
                Edit: Die Meldung aus dem Protokoll kam jetzt nur einmal, beim ersten Start des Skripts. Als ich es gestoppt habe und nochmals gestartet, kam diese Meldung nicht mehr.
                  @doom-86 sagte: ich hoffe das passt so?
                  Das muss oben (Ausschalten um 17:59 Uhr) genauso gehandhabt werden wie unten
                  Es genügt, den WW-Sollwert um 4 K zu verringern?
                    @paul53 sagte in Awattar - die billigsten Strom-Stunden nutzen:
                    Ich möchte ja ein überheizen. somit muss doch die WW Temp und die Raumtemperatur erhöht werden? oder habe ich jetzt einen Denkfehler?
                    Wenn ich aktuell zB. 44°C als WW-Temperatur eingestellt habe, möchte dann in der Nacht wenn der Strom günstig ist, die WW-Temperatur auf 48°C erhöhen, dann muss ich doch +4 und nach der 1 Stunde des Zeitplans wieder -4, damit ich wieder auf meine Anfangs 44°C komme?
                    EDIT: Ich habe eben gesehen, dass die Preise in dem Tibber Adapter von Morgen nicht gelöscht werden. Jetzt stehen bei heute und morgen die Identischen Preise drinnen.
                      @doom-86 sagte: Jetzt stehen bei heute und morgen die Identischen Preise drinnen.
                      Hauptsache, die Preise stimmen um 17:59 Uhr.
                      @doom-86 sagte in Awattar - die billigsten Strom-Stunden nutzen:
                      Wenn im Laufe des Tages die WW-Temperatur von 48°C auf 44°C sinkt - was nicht viel ist, schaltet der interne Regler die Heizung unabhängig vom Strompreis ein.
                        Richtig aktuell hab ich die Anlage im tagbetrieb und über einen Zeitplan gesteuert. Tagsüber ww-soll 40°C in der Nacht WW-Soll 48°C. Durch die hysterese heizt die wärmepumpe auf ca. 50 - 51°C auf. Tagsüber fällt die Temperatur je nach Verbrauch langsam oder schneller ab. Wenn diese am Tag auf 38°C abfällt, läuft die wärmepumpe an und heizt mit hysterese auf ca 42°C auf.
                        Nächste bzw spätestens übernächste woche wird mein wärmepumpen Zähler ausgebaut, dann läuft diese auch über tibber.
                        Daher auch die Steuerung.
                          @paul53 jetzt wurde das ganze eben ausgeführt. Nun die Frage, liegen die Fehlermeldungen daran. Dass tibber aktuell Probleme hat? Bekomme keine live Daten mehr in iobroker. Die heutigen und morgigen preise wurden allerdings noch richtig gesetzt.
                            @doom-86
                            Nicht lesbar: Bitte in Code tags posten!
                            Den String der Variablen tibber hast Du für Deinen Account angepasst?
                              @paul53 geht es so?
                              2023-01-11 17:59:00.130 - warn: javascript.0 (11927) getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926bXXXXPricesTomorrow.16.total" not found (3)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:19:17)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
                              2023-01-11 17:59:00.131 - warn: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
                              2023-01-11 17:59:00.132 - warn: javascript.0 (11927) getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926bXXXXPricesTomorrow.17.total" not found (3)
                              2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:19:17)
                              2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                              2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                              2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                              2023-01-11 17:59:00.136 - warn: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                              2023-01-11 17:59:00.137 - warn: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
                              2023-01-11 17:59:00.137 - warn: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
                              2023-01-11 17:59:00.143 - error: javascript.0 (11927) script.js.Heizung_Nacht_Tibber: TypeError: Cannot read properties of undefined (reading 'toString')
                              2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Object. (script.js.Heizung_Nacht_Tibber:54:62)
                              2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                              2023-01-11 17:59:00.144 - error: javascript.0 (11927) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                              2023-01-11 17:59:00.145 - error: javascript.0 (11927) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                              2023-01-11 17:59:00.145 - error: javascript.0 (11927) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                              2023-01-11 17:59:00.145 - error: javascript.0 (11927) at listOnTimeout (node:internal/timers:559:17)
                              2023-01-11 17:59:00.145 - error: javascript.0 (11927) at processTimers (node:internal/timers:502:7)
                              Das zieht sich so weiter. Und tibber hat wie gesagt scheinbar Probleme heute.
                                @doom-86 sagte:
                                getState "tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926b4a69PricesTomorrow.16.total" not found
                                Am Ende des Strings der Variablen tibber fehlt ein Punkt! Richtig:
                                tibberconnect.1.Homes.9aefe294-bfba-4283-a708-c12c926b4a69.PricesTomorrow.16.total
                                  @paul53 ah. Alles klar. Vielen Dank. Dann morgen auf einen neuen Versuch. Vorausgesetzt tibber bringt ihr Zeug auch wieder auf die Reihe. Bekomme aktuell keine Daten mehr. Auf ihrer Homepage steht etwas mit Problemen.
                                    @paul53 Hallo Paul. Es funktioniert. alles so weit. Vielen Dank für deine mühe.
                                    Eine kleine Frage habe ich noch, lassen sich die Zeiten evtl in einem Datenpunkt auswerten, um diese für andere Dinge zu nutzen oder zur kontrolle, welche Uhrzeiten er berechnet hat?
                                      @doom-86 sagte: lassen sich die Zeiten evtl in einem Datenpunkt auswerten
                                      Welche Zeiten? start1h, start3h? Die lassen sich nach der Ermittlung in Datenpunkte schreiben ("aktualisiere").
                                        @paul53 genau die meinte ich. Wie setze ich die dann am besten ein?
                                          @doom-86 sagte: Wie setze ich die dann am besten ein?
                                          Z.B. ganz unten im Trigger (vor oder nach den Zeitplänen).
                                            @paul53 perfekt. Vielen lieben Dank dafür nochmals.
                                            Jetzt verstehe ich wenigsten schon ein wenig mehr von dem ganzen.
                                            82
                                            8581
