    4. jarvis v3.1.x - just another remarkable vis
    • Michael Sauer
      Michael Sauer last edited by
      @mcu sagte in jarvis v3.1.0-beta - just another remarkable vis:
      @michael-sauer
      Dann müsste man dies anpassen?
      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./v3-systemprogramme/setdropdown
      Das obige Bild kommt aus VIS? Oder eine andere?
      Hab mir das Script angepasst:
      // setDropDown v1.0.0
      // Copyright ©MCU
      // Dieses Programm setzt in einem oder mehreren festgelegten Device mit deviceId und
      // bestimmtem stateKey eine vorgefertige DropDownListe
      let devicesDP = '0_userdata.0.jarvis.setDropDown';
      let deviceIDJarvisArrDP = devicesDP + '.jarvisDeviceIDArr';
      let dropDownListFolderDP = devicesDP + '.dropDownLists'; // Ordner
      let setDeviceDP = devicesDP + '.set';
      let setInstanceDP = devicesDP + '.instance';
      let loggingDP =  devicesDP + '.logging'; // boolean
      let setDevicesDP = devicesDP + '.devicesSET';
      let deviceIDJarvisArray = [
              "id": "3294002f-c8e2-49b5-bfcb-098a54a31554",
              "statekey": "Raum",
              "dropDownListKey" : "UsedRooms"
      let version = 'v1.0.0';
      log('Script "' + scriptName + '" wurde für setDropDown '+version+' gestartet!');
      createStateAsync(deviceIDJarvisArrDP, {read: true, write: true, name: 'Jarvis Device ID Array with stateKey' , type: "string", role: "", def: JSON.stringify([])});
      createStateAsync(loggingDP, {read: true, write: true, name: 'Logging On' , type: "boolean", role: "", def: true });
      createStateAsync(setDevicesDP, {read: true, write: true, name: 'Devices ändern On' , type: "boolean", role: "", def: false });
      createStateAsync(setDeviceDP, {read: true, write: true, name: 'Set Devices with DevStates' , type: "boolean", role: "button", def: false });
      createStateAsync(setInstanceDP, {read: true, write: true, name: 'Instance of jarvis' , type: "string", role: "", def: "0" });
      createStateAsync(dropDownListFolderDP, {read: true, write: true, name: 'DropDownListe' , type: "", role: "", def: "" });
      //setDevice([{"id":"5210cf66-e17e-4353-bd77-aeced4dc1d94","statekey":"progNo"},{"id":"5210cf66-e17e-4353-bd77-aeced4dc1d94","statekey":"IR_Steuerung"}],JSON.parse(dropDownList));
      on({id: setDeviceDP, change: "any"}, function (obj) {
          let value = obj.state.val;
          let logging = getState(loggingDP).val;
          let deviceIdArray = [];
          if (value){
              log('SetDropDown wurde ausgelöst');
              //let dropDownList = JSON.parse(getState(dropDownListDP).val);
              if (typeof deviceIDJarvisArray === 'undefined'){
                  deviceIdArray = JSON.parse(getState(deviceIDJarvisArrDP).val);
              }else{
                  deviceIdArray = deviceIDJarvisArray;
              if (logging){
                  //log('SetDropDown - DropDownListe: ' + JSON.stringify(dropDownList));
                  log('SetDropDown - DeviceIDArray: ' + JSON.stringify(deviceIdArray));
              setDevices(deviceIdArray,dropDownListFolderDP);
              setState(setDeviceDP,false,false);
      function setDevices(deviceIdArr, dropDownListFolderDP){
          let instance = getState(setInstanceDP).val;
          let newSet = getState(setDevicesDP).val;
          let devices = getState('jarvis.'+ instance +'.devices').val;
          let devicesAll = JSON.parse(devices);
          devices = JSON.parse(devices).devices;
          //log(deviceIdArr);
          //log(dropDownList);
          for ( let key in devices){
              let deviceIdArr_key  = inDeviceArr(deviceIdArr,key)
              if (deviceIdArr_key !== false){
                  let dropDownListKey = deviceIdArr[deviceIdArr_key].dropDownListKey;
                  let dropDownList = JSON.parse(getState(dropDownListFolderDP+'.'+dropDownListKey).val);
                  // log('Key: ' + key + ' Device[key]: '+JSON.stringify(devices[key]));
                  // let statekeyId = getStateKeyFromDeviceArr(deviceIdArr,key);
                  // log('StateKey: ' + statekeyId);
                  // if (logging){
                  //     log('States Before: '+ JSON.stringify(devices[key].states));
                  for (let statekey in devices[key].states){
                      //log(statekey);
                      if (getStateKeyFromDeviceArr(deviceIdArr,key,statekey)){
                          // before
                          //log('Before: '+ JSON.stringify(devices[key].states[stateKEY]));
                          let stateKeyVar = devices[key].states[statekey];
                          if (logging){
                              log('StateKey: '+stateKeyVar.stateKey);
                              log('Old display: '+ JSON.stringify(stateKeyVar.display));
                          if (stateKeyVar.display == null || stateKeyVar.display == undefined){
                              // Neu anlegen
                              stateKeyVar.display = dropDownList;
                              //stateKeyVar.actionElement = 'DropDownAction';
                              //stateKeyVar.DropDownActionConfig = {};
                          }else{
                              if (dropDownList == '' || dropDownList == null || dropDownList == undefined){
                                  dropDownList = {};
                          if (logging){
                              log('New display: '+ JSON.stringify(stateKeyVar.display));
                          devices[key].states[statekey] = stateKeyVar;
                  if (logging){
                      log('States After: '+ JSON.stringify(devices[key].states));
                  //break;
          // log('Fertig');
          if (newSet){
              devicesAll.devices = devices;
              setState('jarvis.'+ instance +'.devices',JSON.stringify(devicesAll),false);
      function inDeviceArr(deviceIdArr,deviceId){
          for (let i = 0; i<deviceIdArr.length;i++){
              if (deviceId == deviceIdArr[i].id){
                  return i;
          return false;
      function getStateKeyFromDeviceArr(deviceIdArr,deviceId,statekey){
              if (deviceId == deviceIdArr[i].id && statekey == deviceIdArr[i].statekey){
                  return true;
          return false;
      @Dominik-F Und das ist mein Script um die Datenpunkte aus dem VIS Adapter des Heating Controll Adapter zu konvertieren.
      let userdata = "0_userdata.0.jarvis.setDropDown.dropDownLists.",
          ObjectArray_Heatingcontrol = [
                  "JarvisDatenpunkt":{id:'UsedRooms', initial: 0, forceCreation: false, common: { read: true, write: true, name: "Raeume Json", type: "string",role: "", def: JSON.stringify({}) }},
                  "HeatingcontrolDatenpunkt_Text":"heatingcontrol.0.info.UsedRooms",
                  "HeatingcontrolDatenpunkt_Value":"heatingcontrol.0.info.UsedRooms"
                  "JarvisDatenpunkt":{id:'OverrideTempValueList', initial: 0, forceCreation: false, common: { read: true, write: true, name: "OverrideTemp", type: "string",role: "", def: JSON.stringify({}) }},
                  "HeatingcontrolDatenpunkt_Text":"heatingcontrol.0.vis.OverrideTempValueListText",
                  "HeatingcontrolDatenpunkt_Value":"heatingcontrol.0.vis.OverrideTempValueListValue"
      CreateJarvisJson_Heatingcontroller();
      function CreateJarvisJson_Heatingcontroller(){
          ObjectArray_Heatingcontrol.forEach(function(Datenpunkt){
              CreateDPObject(Datenpunkt.JarvisDatenpunkt, function(){
                  let temp_Array = {};
                  let HeatingcontrolDatenpunkt_Value__Array = getState(Datenpunkt.HeatingcontrolDatenpunkt_Value).val.split(/;/);
                  getState(Datenpunkt.HeatingcontrolDatenpunkt_Text).val.split(/;/).forEach(function(dat,index){
                      //console.log(HeatingcontrolDatenpunkt_Value__Array[index]);
                      if(dat !== ""){
                          temp_Array[HeatingcontrolDatenpunkt_Value__Array[index]] = dat;
                  setState(
                      userdata+Datenpunkt.JarvisDatenpunkt.id,
                      JSON.stringify(temp_Array),
                      true
      function CreateDPObject(DP_state,init){
          createState(userdata+DP_state.id, DP_state.initial, DP_state.forceCreation, DP_state.common, function () {
                  //console.log('Datenpunkte sind angelegt');
                  init();
      Dominik F. M 2 Replies Last reply Reply Quote 0
      • Dominik F.
        Dominik F. @Michael Sauer last edited by
        @michael-sauer
        und das müsste ich für jede einzelne DropdownListe anpassen?
        Michael Sauer 1 Reply Last reply Reply Quote 0
          MCU @Michael Sauer last edited by
          @michael-sauer Kannst du bitte Deine Veränderungen kennzeichnen, damit ich die dann auch in der Doku beschreiben kann. Danke.
          • Michael Sauer
            Michael Sauer @Dominik F. last edited by
            @dominik-f sagte in jarvis v3.1.0-beta - just another remarkable vis:
            @michael-sauer
            so ist es.
            • Michael Sauer
              Habe das Problem das bei dem "HTMLTable" Widget die höhe des DIV Container falsch berechnet wird und ein unnötiger Scroll Balken entsteht.
              Bei 9h mit 490px
              werden im äußeren DIV Container nur 489px geschrieben und der innere wieder mit 490px was den unschönen Scroll Balken verursacht.
                sigi234 Forum Testing Most Active @Zefau last edited by sigi234
                @zefau
                Hallo, habe einen Volume-Slider angelegt, funktioniert , aber die Anzeige geht beim betätigen der Slider immer zurück?
                  MCU @sigi234 last edited by MCU
                  @sigi234 Die Werte sind auch negativ in ioBroker?
                  Nimm mal
                  {"min":-40,"max":0}
                  Und statt val -> value
                    sigi234 Forum Testing Most Active @MCU last edited by
                    Ja
                      @sigi234 Wo ich Dich grad dran hab, kannst du mir die Standard DPs für das Volume vom Musiccast geben.
                      Gibt es da bei der Auswahl mehrere Boxen oder sowas?
                        sigi234 Forum Testing Most Active @MCU last edited by sigi234
                          "type": "state",
                          "common": {
                            "name": "Actual Volume db",
                            "type": "number",
                            "min": -80.5,
                            "max": 16.5,
                            "read": true,
                            "write": true,
                            "role": "level.volume",
                            "desc": "State and Control of Volume db"
                          "native": {},
                          "from": "system.adapter.musiccast.0",
                          "user": "system.user.admin",
                          "ts": 1654774962942,
                          "_id": "musiccast.0.RX-V481_08125F03.main.act_vol_val",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                          @sigi234 Die ObjektId lautet dann für das Volume?
                          Gibt es da mehrere Boxen zur Auswahl links?
                            Nur bei Musiccast, ich habe den vom Yamaha genommen:
                              "type": "state",
                              "common": {
                                "name": "VOL",
                                "type": "number",
                                "role": "state"
                              "native": {},
                              "_id": "yamaha.0.Realtime.MAIN.VOL",
                              "from": "system.adapter.yamaha.0",
                              "ts": 1654705019795,
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            Nein
                                @sigi234 Funktioniert der LevelBody mit den neuen Einstellungen?
                                  Teste gerade, muss da aufpassen, er darf nicht über 0 dB gehen. Sonst sind meine Boxen kaputt, hatte ich schon mal.
                                  Überlege noch ob ich den von Yamaha oder Musiccast nehmen soll.
                                  Wenn ich den Volume Regler am Yamaha stelle, dann sind es immer 0,5 dB Schritte und deswegen kommt der Level Slider durcheinander?
                                    @sigi234 Du kannst ja in den LevelBody-Einstellungen die Schrittweite vorgeben.
                                      Ja, aber 0,5 ?
                                        @sigi234
                                        0.5
                                          @sigi234
                                          0.5
                                          Nimmt er nicht an.
                                            @sigi234 Er macht aus 0.5 ->0,5
                                            Läuft bei mir
                                            81.1k
                                            92
                                            1847
                                            708715
