    4. [Neuer Adapter] EuSec
      Thomas Braun Most Active @Ben 1 last edited by
      @ben-1 sagte in [Neuer Adapter] EuSec:
      Welches OS läuft da mit welcher Version von ffmpeg/libav-tools?
        Ben 1 @Thomas Braun last edited by
        Debian 11 (bullseye)
        pi@raspberrypi:~ $ ffmpeg
        ffmpeg version 4.3.5-0+deb11u1+rpt2 Copyright (c) 2000-2022 the FFmpeg developers
        built with gcc 10 (Debian 10.2.1-6)
        configuration: --prefix=/usr --extra-version=0+deb11u1+rpt2 --toolchain=hardened --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-mmal --enable-neon --enable-v4l2-request --enable-libudev --enable-epoxy --enable-sand --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-vout-drm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
        libavutil 56. 51.100 / 56. 51.100
        libavcodec 58. 91.100 / 58. 91.100
        libavformat 58. 45.100 / 58. 45.100
        libavdevice 58. 10.100 / 58. 10.100
        libavfilter 7. 85.100 / 7. 85.100
        libavresample 4. 0. 0 / 4. 0. 0
        libswscale 5. 7.100 / 5. 7.100
        libswresample 3. 7.100 / 3. 7.100
        libpostproc 55. 7.100 / 55. 7.100
        Hyper fast Audio and Video encoder
        usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
          mading @Ben 1 last edited by mading
          Kann ich den RTSP stream im VIS darstellen ?
          Mit welchem widget zeige ich das last event Bild in VIS an?
          Ich habe mir ein MotionEye Docker image aufgesetzt und lasse den Stream so darstellen. Direkt RTSP geht m.E. nicht.
          Edith: gibt einen Adapter: https://github.com/dbweb-ch/ioBroker.rtspStream. Musst aber auch was auf dem iobroker im OS installieren. Hab den Adapter aber nicht getestet
          Uli977 1 Reply Last reply Reply Quote 0
            leider werden die Bilder fehlerhaft erstellt weil irgendwas mit dem ffmpef nicht stimmt 😞
              Nun bekomme ich den Fehler:
              saveImage(): Error: TypeError [ERR_INVALID_URL]: Invalid URL: T8010N2321160982~/media/mmcblk0p1/video/20230113104520_c01.jpg - url: T8010N2321160982~/media/mmcblk0p1/video/20230113104520_c01.jpg
              • Uli977
                Uli977 @mading last edited by
                @mading MotionEye klappt bei mir nicht mit meiner EufyCam 2C... welche nutzt du?
                  mading @Uli977 last edited by
                  @uli977 ich habe eine indoor cam pan& tilt.
                  Deine liefert aber schon einen rtsp stream?
                  • Uli977
                    @mading ja, den bietet die cam an. Jedoch bekomme ich machmal nur kurz ein bild in motionEye und meistens ist es aber einfach nur ein graues bild, wobei es irgendwie scheint als wenn die Verbindung vorhanden ist....
                      Ist ja auch 'irgendwas', aber mit Sicherheit nicht der korrekte Pfad zu der Datei.
                        @uli977 teste mal mit vlc player ob der stream überhaupt geht. Bei mir hat die cam ziemlich gezickt
                        Uli977 2 Replies Last reply Reply Quote 0
                        • Uli977
                          Uli977 @Thomas Braun last edited by
                          ich habe bei Last Camera Picture URL auch folgendes...
                          T8010N2320530012~/media/mmcblk0p1/video/20230113170826_c01.jpg
                          • Uli977
                            @mading
                            Für VLC muss ich die Cam aber nicht in MotionEye eingerichtet haben, oder?
                            VLC ging soeben auch nicht, aber vielleicht muss ich in den Einstellungen der Cam noch was ändern.
                              Thomas Braun Most Active @Uli977 last edited by Thomas Braun
                              @uli977
                              Die Tilde ist eigentlich der Platzhalter für das Home-Verzeichnis eines Users und absolute Pfade beginnen bei Linux immer mit /
                              • Uli977
                                Uli977 @mading last edited by Uli977
                                @mading
                                Aus VLC gib es jetzt 5x hintereinander über den rtsp stream und dann plötzlich wieder nicht mehr
                                Jetzt geht es wieder in VLC und auch MotionEye
                                Und dann auf einmal wieder so
                                Muss vielleicht eine Bewegung stattgefunden haben, damit die Cam ein Bild über den Stream liefert?
                                Da wird man ja verrückt...
                                Das sind die Fehlermeldungen aus dem VLC Fehlerprotokoll
                                Failed to connect with rtsp://192.168.1.104:554/live2
                                Failed to setup RTSP session
                                read error: Connection reset by peer
                                Cseq mismatch, got 1, assumed 0
                                only real/helix rtsp servers supported for now
                                Could not download device description! Fetching data from http://192.168.1.100:10293/upnp/desc.html failed: UPNP_E_SOCKET_CONNECT
                                Die ip-Adresse ist vom ioBroker
                                Marc Berg M 2 Replies Last reply Reply Quote 0
                                • Marc Berg
                                  Marc Berg Most Active @Uli977 last edited by
                                  @uli977
                                  Ich glaube nicht , dass du aus dieser Akku-Cam einen verlässlichen Stream herausbekommen wirst. Meine Versuche dazu waren allesamt nicht erfolgreich.
                                  Abgesehen davon, sieht man auf den Bildern deine Mail-Adresse. 🙂
                                  • Uli977
                                    Uli977 @Marc Berg last edited by
                                    @marc-berg ok, das mag sein...
                                    Kannst mir ja eine Mail schreiben 😊
                                      @uli977 da war was….
                                      Hast du im rtsp fortlaufende Aufzeichnung aktiviert?
                                      • Uli977
                                        @mading
                                        Das habe ich gar nicht...
                                        Ist deine Cam auch mit Akku über WLAN?
                                          @uli977 nein, deswegen gehts wohl mit der nicht
                                          • Uli977
                                            @mading hmm, schade!
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            458026
