    4. [Neuer Adapter] Life360
      Rushmed Most Active last edited by
      Hallo und ein gesundes Neues!
      Seit einigen Tagen habe ich auch solche Meldungen von wegen Credentials.
      life360.0
      2023-01-01 20:20:29.239	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      life360.0
      2023-01-01 20:20:29.238	info	terminating
      life360.0
      2023-01-01 20:20:29.238	info	cleaned everything up...
      life360.0
      2023-01-01 20:20:29.238	info	Disabled polling.
      life360.0
      2023-01-01 20:20:29.236	info	Got terminate signal TERMINATE_YOURSELF
      life360.0
      2023-01-01 20:19:39.142	warn	No data received from Life360 cloud services!
      life360.0
      2023-01-01 20:19:39.142	error	Error: Error: Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:39.142	error	Failed to connect or to login for 6 times. Aborting ...
      life360.0
      2023-01-01 20:19:39.141	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:39.140	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:39.066	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:39.065	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:38.997	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:38.996	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:38.937	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:38.936	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:37.586	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:37.585	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:19:36.238	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:19:36.237	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.720	warn	No data received from Life360 cloud services!
      life360.0
      2023-01-01 20:18:36.720	error	Error: Error: Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.720	error	Failed to connect or to login for 6 times. Aborting ...
      life360.0
      2023-01-01 20:18:36.719	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.718	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.639	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.638	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.526	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.525	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.440	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.439	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.353	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.352	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:18:36.237	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:18:36.236	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:42.865	warn	No data received from Life360 cloud services!
      life360.0
      2023-01-01 20:17:42.865	error	Error: Error: Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:42.865	error	Failed to connect or to login for 6 times. Aborting ...
      life360.0
      2023-01-01 20:17:42.864	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:42.863	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:42.792	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:42.790	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:41.469	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:41.468	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:40.187	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:40.185	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:38.886	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:38.885	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:17:37.549	info	Disconnected from Life360 cloud services.
      life360.0
      2023-01-01 20:17:37.549	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:17:37.548	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:13:39.013	info	Connected to Life360 cloud services.
      life360.0
      2023-01-01 20:13:37.603	info	Disconnected from Life360 cloud services.
      life360.0
      2023-01-01 20:13:37.603	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:13:37.602	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:12:38.858	info	Connected to Life360 cloud services.
      life360.0
      2023-01-01 20:12:37.496	info	Disconnected from Life360 cloud services.
      life360.0
      2023-01-01 20:12:37.495	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:12:37.494	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:08:40.221	info	Connected to Life360 cloud services.
      life360.0
      2023-01-01 20:08:38.825	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:08:38.823	error	Connection established but failed to authenticate. Check your credentials!
      life360.0
      2023-01-01 20:08:37.561	info	Disconnected from Life360 cloud services.
      life360.0
      2023-01-01 20:08:37.560	info	Waiting for online operations to finish ...
      life360.0
      2023-01-01 20:08:37.559	error	Connection established but failed to authenticate. Check your credentials!
      Trotz der Meldungen scheint der Adapter zu funktionieren.
      Die Login Daten habe ich bereits neu eingegeben.
      Was kann das Problem sein?
      MiGoller 1 Reply Last reply Reply Quote 0
      • MiGoller
        MiGoller Developer @Rushmed last edited by
        @rushmed Hey, danke für das Feedback. Der Adapter liefert Dir Positionsdaten trotz der Meldungen? Du hast aber nicht noch eine weitere Instanz laufen, oder? Ich befürchte fast, dass sich da ein Prozess aufgehangen hat, so dass der Timer da dauernd etwas neu starten will. Das muss ich noch beheben, bevor der Adapter per Repo installierbar sein kann.
        Hast Du den kompletten ioBroker oder sogar den Host, den Containert, etc. ,auf dem ioBroker läuft, mal neu gestartet oder aktualisiert? Welche Version des Adapters setzt Du ein?
          Rushmed Most Active @MiGoller last edited by
          @migoller sagte in [Neuer Adapter] Life360:
          Ja, das war bis gestern so. Ich vermute dass nicht jeder Login fehlgeschlagen ist und es zwischenzeitlich zu Verbindung kam.
          Eine zweite Instanz habe ich nicht.
          Habe alles mehrmals neu gestartet.
          Heute musste ich aus einem anderen Grund ein Backup wiederherstellen. Seit dem bekomme ich garkeine Verbindung mehr und die Errors im Log erscheinen kontinuierlich. Bis vor dem Restore gabs sozusagen Errorpausen.
          Die App funktioniert. Habe mein Passwort geändert (nicht über "vergessen"), leider ohne Erfolg.
          Habe auch den Login per Mail oder Telefonnummer und Ländercode erfolglos probiert.
          Eine Frage hier zu Eingabe. Den Ländercode ohne 00 oder + also nur 49 und die Telefonnumer ohne anführende "0" oder?
          • MiGoller
            @rushmed Hey, bitte auf Version 0.2.19 aktualisieren. Die Version behebt das Problem, dass der Zugriff auf den Life360 Service seitens des Adapters wieder zuverlässiger funktioniert.
            R K 2 Replies Last reply Reply Quote 0
              @migoller Cooolio, danke für die schnelle Hilfe.
              Nach dem Update gings mit dem eMaillogin immernoch nicht.
              Mit Ländercode und Handynummer bin ich jetzt grün.
              Thanksalot!
                K_o_bold @MiGoller last edited by
                @migoller ,
                sehr geil... Vielen Dank für die schnelle Hilfe.
                Läut wieder 🙂
                  Hallo, seit heute ist bei mir wieder was defekt:
                  life360.0
                  2023-01-13 19:17:30.916	warn	No data received from Life360 cloud services!
                  life360.0
                  2023-01-13 19:17:30.914	error	Error: Error: Unable to connect: Error: Client network socket disconnected before secure TLS connection was established
                  life360.0
                  2023-01-13 19:17:30.912	error	Failed to connect or to login for 6 times. Aborting ...
                  life360.0
                  2023-01-13 19:17:30.910	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.877	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.841	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.806	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.771	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.729	info	Waiting for online operations to finish ...
                  life360.0
                  2023-01-13 19:17:30.610	info	Polling enabled every 60 seconds.
                  life360.0
                  2023-01-13 19:17:30.541	info	starting. Version 0.2.19 (non-npm: MiGoller/ioBroker.life360) in /opt/iobroker/node_modules/iobroker.life360, node: v16.19.0, js-controller: 4.0.24
                  Kann das jemand bestätigen?
                  T Siragus 2 Replies Last reply Reply Quote 0
                    Tobi68 @Rushmed last edited by
                    @rushmed
                    Jupp, bei mir läuft auch nur das error log voll
                      Rushmed Most Active @Tobi68 last edited by
                      @tobi68 Danke, bei mir bekommt auch die App keine Verbindung. Kannst du das auch bestätigen?
                      • BananaJoe
                        BananaJoe Most Active last edited by
                        Meine App spinnt auch zwischendurch, wird also irgendetwas bei denen sein.
                          @rushmed
                          In die app komme ich im Moment rein.
                          Dort und im dem adapter bin ich und meine Frau seit 20.25 zuhause da ist hier auch ne routine abgelaufen..
                          wir sind aber schon seit 18.30 zuhause.. da ist die Routine halt nicht gelaufen.
                          • Siragus
                            Siragus @Rushmed last edited by
                            @rushmed
                            Hallo rushmed, ich habe auch seit gestern die gleichen Meldungen im ioBrocker Log wie Du.
                            Und seit heute bekomme ich in der App die Nachricht, dass Life360 einige Systemwartungen durchführen und es zu Verzögerungen beim Zugriff auf's Konto kommen kann.
                            Ich gehe jetzt mal davon aus, dass wir uns so lange gedulden müssen, bis Life360 seine Wartungsarbeiten beendet hat.
                              Danke für eure Rückmeldungen bei mir laufen Adapter und App wieder.
                              • MiGoller
                                @rushmed Kann ich bestätigen: Habe keine Meldung mehr in der App bzgl einer Wartung. Mal schauen, ob ich herausfinden kann, wie die App den "Wartungsmodus" erkennt. 😉 Der Adapter sollte auch wieder wie gewohnt funktionieren.
                                • Paul Reinhart
                                  Paul Reinhart last edited by
                                  Bei mir kann sich der Adapter nicht mehr anmelden obwohl die Zugangsdaten nicht geändert wurden.
                                  Im Log bekomme ich die Meldung "Connection established but failed to authenticate. Check your credentials."
                                  • MiGoller
                                    MiGoller Developer @Paul Reinhart last edited by
                                    @paul-reinhart Guten Morgen. Nutzt Du die Version v0.2.19 des Adapters? Falls nicht, dann aktualisiere bitte auf diese Version; es gab ein paar Veränderungen bei Life360, auf die ich mit einer neuen Version reagieren musste. (vgl. https://github.com/MiGoller/ioBroker.life360/issues/68 )
                                    Pauli29 created this issue in MiGoller/ioBroker.life360
                                    closed Authentifizierung schlägt fehl ... #68
                                    MiGoller S 2 Replies Last reply Reply Quote 0
                                    • MiGoller
                                      MiGoller Developer @MiGoller last edited by
                                      @Paul-Reinhart Vielen Dank für das Feedback über GitHub. Schön, dass es bei Dir wieder funktioniert. Schönen Sonntag noch.
                                      • Palm_Maniac
                                        Palm_Maniac last edited by
                                        Perfekt. Ich hatte auch die Probleme und mit der 0.2.19 läuft der Adapter endlich wieder. Vielen Dank für die Info.
                                          stefu87_CH @Palm_Maniac last edited by
                                          Hallo zusammen
                                          Ich habe eine Verstädnis Frage zum Datenpunkt:
                                          Der Datenpunkt sollte doch auf true ändern, wenn ich am eingetragen my Place ankomme?
                                          Oder interpretiere ich da was falsch?
                                            Rushmed Most Active @stefu87_CH last edited by
                                            @stefu87_ch Denke ich auch.
                                            Welcher Radius ist in den Einstellungen des Adapters für diesen Place eingestellt und ist der kleiner als die angezeigte Distanz von 1018 m? Wenn ja funktioniert es korrekt.
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            157734
