    4. Test Adapter TibberConnect 0.0.x inkl. Tibber Pulse
      Michaelnorge last edited by
      Hallo.
      Ich bekomme den Adapter seit gestern nicht mehr online.
      Laufend bekomme ich die unten genannten Fehler.
      Hab schon vor einiger Zeit ein issue aufgemacht, da war es nur sporadisch - aber jetzt geht nichts mehr.
      Gibt es hier mehrere mit dem gleichen Problem?
      Ich benutze den Pulse.
      Michael
      2023-01-12 15:43:46.138 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:46.946 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:47.247 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:48.076 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:48.766 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:49.512 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:50.051 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:50.370 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:50.688 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:51.224 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:51.566 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:52.162 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:52.258 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:52.676 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:53.007 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:53.798 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:54.498 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:54.562 - error: tibberconnect.0 (16647) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-01-12 15:43:54.563 - error: tibberconnect.0 (16647) unhandled promise rejection: undefined
      2023-01-12 15:43:54.563 - error: tibberconnect.0 (16647) undefined
      2023-01-12 15:43:54.570 - info: tibberconnect.0 (16647) terminating
      2023-01-12 15:43:54.571 - warn: tibberconnect.0 (16647) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-01-12 15:43:55.013 - info: tibberconnect.0 (16647) Feed was disconnected. I try to reconnect in 5s
      2023-01-12 15:43:55.014 - warn: tibberconnect.0 (16647) setInterval called, but adapter is shutting down
      2023-01-12 15:43:55.130 - warn: tibberconnect.0 (16647) get state error: Connection is closed.
      2023-01-12 15:43:55.261 - error: host.raspberrypi instance system.adapter.tibberconnect.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-01-12 15:43:55.262 - info: host.raspberrypi Restart adapter system.adapter.tibberconnect.0 because enabled
        Michaelnorge @MikeRow last edited by
        @mikerow Jepp, mir bekannt, geht zur Zeit nichts mehr.
          ThomKast last edited by ThomKast
          ****** ÄHM, sorry... Nur für alle, die die Daten zwischenzeitlich mit der NodeRed-Lösung abholen *******
          Hallo Zusammen,
          der TIBBER-Adpater in NodeRed muss aktualisiert werden. Es liegt eine neue Version 5.1.4 vor, mit dieser funktioniert der Verbindungsaufbau wieder.
          Folgendes Vorgehen für die Aktualisierung:
          • In NodeRed -> Hamburger-Menu -> Palette verwalten
          • "tibber" im Suchfeld eingeben und nach der angezeigten Erweiterung suchen
          • an der Stelle des langen, leeren, roten Kästchen erschien die Info zur Aktualisierung.
            Diese durchführen.
          • Danach muss NodeRed neu gestartet werden. Also NICHT NUR die Flows neustarten, sondern im ioBroker unter den Instanzen die NodeRed-Instanz.
          • Dann das NodeRed-Fenster neu laden und die Verbindung zu Tibber sollte wieder laufen, also "connected" sein.
          Hat irgendjemand Ahnung, wie man sich über Aktualisierungen der NodeRed-Adapter informieren lassen kann?
          Beste Grüße, Thomas
            ThomKast @MikeRow last edited by
            @mikerow
            Kann es sein, dass Du etwas durcheinander wirfst?..? Die Daten die Du dort zeigst, werden doch durch meine Skript-Lösung aus dem anderen Beitrag erzeugt. Oder irre ich mich??? 😉
            Sollte ich nicht irren, dann wird dazu kein Adapter benötigt, sondern nur der Request aus dem Script ausgeführt.
              MikeRow @ThomKast last edited by
              @thomkast Ja, du hast Recht. Ich hatte auf den Beitrag von @JoAu84 geantwortet. Er meinte, dein Script liefert keine Daten. Da ist wohl etwas durcheinander geraten.
                Wieviele Anfragen sendet der Adapter eigentlich? Wenn ich ihn starte, gibt es eine Fehlermeldung von Pi-Hole:
                2023-01-12 19:08:41	RATE_LIMIT	Client 192.168.178.149 has been rate-limited (current config allows up to 1000 queries in 60 seconds)
                Hab ja nicht viel Plan, aber kann es sein, daß die API blockt bei zu vielen Anfragen?
                  @michaelnorge
                  Hatten wir das nicht schon mal weiter oben??
                  Allerdings hatte ich dazu keine Antwort finden können...
                    tobe4it @ThomKast last edited by
                    Der tibberconnect Adapter V0.0.9 läuft nicht mehr. Ich nehme an, dass das an der Umstellung seitens Tibber liegt: Breaking change in websocket subscription:
                    https://developer.tibber.com/docs/overview#breaking-websocket-change
                    Im Code des Adapters steht noch api.tibber.com. Ich hab' versucht das auf websocket-api.tibber.com zu ändern, blicke bei dem Code aber scheinbar nicht durch. Sind nur main.ts und main.js anzupassen?
                    Ich hab' das für mich jetzt mit dem Umweg über die Anbindung von Home Assistant an ioBroker gelöst. Dort wurde die Änderung bereits eingepflegt.
                    • O
                      oxident last edited by
                      Komisch, bei mir klappt der Adapter wunderbar. Jedoch beginnt mein Vertrag erst in ein paar Wochen und der Pulse ist auch nicht da.
                      Aber die stündlichen Preise werden brav aktualisiert.
                        MikeRow @oxident last edited by
                        @oxident nur der Teil mit dem Pulse funktioniert derzeit nicht
                        • O
                          oxident @MikeRow last edited by
                          @mikerow said in Test Adapter TibberConnect 0.0.x inkl. Tibber Pulse:
                          Ahh ok. Das ist wirklich nicht gut. Wollte darüber in Zukunft die Steuerung meines PC-Akkus laufen lassen. Wäre blöd, wenn das "unzuverlässig" ist.
                            Michaelnorge @oxident last edited by
                            @oxident said in Test Adapter TibberConnect 0.0.x inkl. Tibber Pulse:
                            Nicht nur Du bei der die ganze Stromregulierung abhängig ist von diesem Adapter.
                            Aber keine Angst, es wird sicher daran gearbeitet!!
                              theGrinch last edited by theGrinch
                              Auf Anregung von @MikeRow habe ich mal die BarChart von @Familienvater auf diesen Adapter angepasst.
                              Einfach das "home" reinkopieren in Zeile 6+7.
                              var myName = "tibber.createchartdata";
                              var logOn           = false;     // Skript Logausgabe ein- (true) / ausschalten (false). Fehler werden immer ausgegeben.
                              var forceCreation    = false;    // Default: false. true: Datenpunkte werden überschrieben (wenn z.B. Bezeichnungen geändert wurden)
                              var tibberPricesToday = "tibberconnect.0.Homes.*****.PricesToday.";        // mit . am Ende!
                              var tibberPricesTomorrow = "tibberconnect.0.Homes.*****.PricesTomorrow.";  // mit . am Ende!
                              var tibberStartsAt = "startsAt";
                              var tibberTotal = "total";
                              // Datenpunkte anlegen:
                              var idChartData = "tibber.prices.chartData";                      // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                              createState(idChartData, '[{"label":"15","value":"25.2","dataColor":"#ffffff"},{"label":"16","value":"28.8","dataColor":"#ffffff"},{"label":"17","value":3"5.2","dataColor":"#ffffff"},{"label":"18","value":"33.2","dataColor":"#ffffff"},{"label":"19","value":"20.2","dataColor":"#ffffff"}]', forceCreation, {
                                   name: 'Chart-Data Price Forecast',
                                   desc: 'Chart-Data Price Forecast',
                                   type: 'string',
                                   role: 'value'
                              var idBarChartData = "tibber.prices.barChartData";                      // Pfad und Name, unter dem in der Javascript-Instanz der Datenpunkte angelegt wird
                              createState(idBarChartData, '[{"label":"15","value":"25.2","dataColor":"#ffffff"},{"label":"16","value":"28.8","dataColor":"#ffffff"},{"label":"17","value":3"5.2","dataColor":"#ffffff"},{"label":"18","value":"33.2","dataColor":"#ffffff"},{"label":"19","value":"20.2","dataColor":"#ffffff"}]', forceCreation, {
                                   name: 'Bar Chart-Data Price Forecast',
                                   desc: 'Bar Chart-Data Price Forecast',
                                   type: 'string',
                                   role: 'value'
                              createBarChartData();
                              // Cron-Job, zum Stundenwechsel
                              // Stundenwechsel, Ausführen immer um *:00:10
                              schedule('10 0 * * * *', function () {createBarChartData()});
                              function createBarChartData () {
                              	if(logOn) console.log(myName + " Stundenwechsel");
                                  let barChart = [];
                                  var jetzt = new Date(Date.now());
                                  var aktStunde = jetzt.getHours();
                                  var unixTimestamp=new Date().getTime();
                                  // bis zu 18 Stunden in die Zukunft
                                  const offsets=[0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 12, 13, 14, 15, 16, 17, 18];
                                  for (let offset of offsets)
                                      // Template Objekt für BarChart erzeugen
                                      let itemData ={label:"", value:0.0, dataColor: "#c2c2c2", valueColor: "#dddddd"}; //, valueAppendix: "", valueColor: #ffffff"
                                      // Vorbereitung um Werte aus Tibber Adapter zu holen
                                      var prefix="";
                                      aktStunde=jetzt.getHours()+offset;
                                      if (aktStunde>23)
                                          aktStunde=aktStunde-24;
                                          prefix=tibberPricesTomorrow;
                                      else
                                          prefix=tibberPricesToday;
                                      var strStunde = (aktStunde.toString()).slice(-2); //("0" + aktStunde.toString()).slice(-2);
                                      itemData['label']=strStunde;
                                      prefix=prefix+strStunde+'.';
                                      var aktPrice=getState(prefix+tibberTotal).val;
                                      // falls keine Daten vorliegen, weiter ohne diese ItemData an das Chart-Objekt anzuhängen
                                      if (aktPrice==null && aktStunde>=0)
                                          continue;
                                      // von 0.2345 € auf Cent mit einer Nachkomma-Stelle umrechnen
                                      itemData['value']=Math.round(aktPrice*1000)/10.0;
                                      // Je nach Preis den Balken einfärben
                                      if (aktPrice<0.30)
                                          itemData['dataColor']="green";
                                      else
                                      if (aktPrice<0.40)
                                          itemData['dataColor']="yellow";
                                      else
                                      if (aktPrice<0.50)
                                          itemData['dataColor']="orange";
                                      else
                                      if (aktPrice<0.60)
                                          itemData['dataColor']="red";
                                      else
                                          itemData['dataColor']="magenta";
                                      // Daten für diese Stunde dem Objekt zufügen
                                      barChart.push(itemData);
                                  // fertiges Objekt in den Datenpunkt als JSON schreiben
                                  setState("javascript."+instance+"."+idBarChartData, JSON.stringify(barChart), true);
                              function createChartData () {
                                  let chart = {};
                                  let axisLabels =[];
                                  let values =[];
                                  let datalabels =[];
                                  // Spaltenbeschriftungen
                                  //chart.graphs[0].axisLables=axisLabels;
                                  chart.graphs=new Array();
                                  chart.graphs.push({});
                                  chart.graphs[0].color="green";
                                  chart.graphs[0].type="bar";
                                  chart.graphs[0].datalabel_rotation=-90;
                                  chart.graphs[0].datalabel_color="lightgreen";
                                  chart.graphs[0].datalabel_fontSize=10;
                                  chart.graphs[0].yAxis_title_text="cent";
                                  chart.graphs[0].yAxis_show=true;
                                  chart.graphs[0].legendText="Uhrzeit";
                                  chart.graphs[0].datalabel_show=true;
                                  chart.graphs[0].yAxis_minimumDigits=1;
                                  chart.graphs[0].yAxis_maximumDigits=1;
                                      if (aktStunde>23)
                                      axisLabels.push(strStunde)
                                      //axisLabels.push(aktStunde);
                                      var prefix="";
                                      if (aktStunde>23)
                                          prefix=tibberPricesTomorrow+".";
                                      else
                                          prefix=tibberPricesToday+".";
                                      strStunde = ("0" + aktStunde.toString()).slice(-2);
                                      //if(logOn) console.log(myName + " Stundenwechsel, akt Stunde "+strStunde+", prefix "+prefix);
                                      //var aktStartAt=getState(prefix+tibberStartsAt).val;
                                      //if(logOn) console.log(myName + " aktPrice "+aktPrice+", aktStartAt "+aktStartAt);
                                      //let itemData ={t:0, y:0.0};
                                      //itemData['t']=unixTimestamp+3600*offset;
                                      //itemData['y']=aktPrice;
                                      values.push(Math.round(aktPrice*1000)/10.0);
                                      var cents=(Math.round(aktPrice*1000)/10.0).toString();
                                      datalabels.push(cents);
                                  chart.graphs[0].data=values;
                                  chart.graphs[0].datalabel_override=datalabels;
                                  chart.data=values;
                                  chart.datalabel_override=datalabels;
                                  chart.axisLables=axisLabels;
                                  setState("javascript."+instance+"."+idChartData, JSON.stringify(chart));
                              /edit: Originalpost mit allen Infos: https://forum.iobroker.net/topic/47195/diagramm-mit-festen-werten-in-vis-nur-wie/12
                              M O 3 Replies Last reply Reply Quote 1
                                butsch last edited by
                                Hallo ich habe aktuell einen Unterschied zwischen:
                                current total 0.1796
                                und
                                today 21 total 0.1944
                                Aktuell ist 21:48 Uhr
                                Müssten diese Werte nicht identisch sein?
                                  theGrinch @butsch last edited by theGrinch
                                  @butsch müssten Sie, sind sie bei mir auch:
                                  tibberconnect.0.Homes.xxxxx.PricesToday.21.total = 0,1794
                                  tibberconnect.0.Homes.xxxxx.CurrentPrice.total = 0,1794
                                  EPEX-Script:
                                  0_userdata.0.Tibber.EPEX_Spot_DE_heute.ESDE_heute_21 = 0,1794
                                  0,1942 habe ich überall ab 22 Uhr.
                                  /edit: Tibber App sagt 17,9c
                                    butsch @theGrinch last edited by
                                    @thegrinch Danke, habs gegengecheckt und die Uhrzeit am raspberry hat nicht gestimmt (London) ;-(
                                    Sorry
                                      Waldmensch @butsch last edited by
                                      Mal ne Verständnisfrage: Reicht zur Preisabfrage ein Account bei Tibber mit Api Key oder gibt es die Preisinfo nur, wenn man einen Stromvertrag hat? Die Account Basisdaten werden vom Adapter geladen aber die Preisinfos kommen als leere Arrays.
                                      Wen ich auf der Developer Seite eine Abfragemit meinem Token starte, kommt nur
                                        viewer {
                                          homes {
                                            currentSubscription{
                                              priceInfo{
                                                current{
                                                  total
                                                  energy
                                                  tax
                                                  startsAt
                                                today {
                                                  total
                                                  energy
                                                  tax
                                                  startsAt
                                                tomorrow {
                                                  total
                                                  energy
                                                  tax
                                                  startsAt
                                        "data": {
                                          "viewer": {
                                            "homes": [
                                                "currentSubscription": null
                                      T O 2 Replies Last reply Reply Quote 0
                                        MikeRow @theGrinch last edited by
                                        @thegrinch Super, vielen Dank. Läuft!
                                          ThomKast @Waldmensch last edited by
                                          @waldmensch
                                          Preise werden erst mit Abschluss und Aktivierung eines Vertrags übermittelt. Ich hatte im November 2022 den Vertrag zum 01.01.23 geschlossen und hatte ca. Mitte Dezember erstmalig Zugriff auf Preis Informationen.
                                          • O
                                            oxident @Waldmensch last edited by
                                            @waldmensch Ja, gibt es erst nach Vertragsabschluss aber in der Tat auch schon vor Lieferbeginn.
                                            360
                                            81084
