    3. Einsteigerfragen
    4. IoBroker ist nicht mehr über Browser erreichbar
      Thomas Braun Most Active @Bastel2021 last edited by
      @bastel2021
      iobroker list instances
        @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
        pi@raspberrypi:~ $ iobroker list instances
        internal/modules/cjs/loader.js:905
        throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
        pi@raspberrypi:~ $
          @bastel2021
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            Bastel2021 last edited by Homoran
             pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.17
            > unix-dgram@2.0.6 install /opt/iobroker/node_modules/unix-dgram
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
              CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            In file included from ../node_modules/nan/nan.h:60,
                             from ../src/unix_dgram.cc:5:
            /home/iobroker/.cache/node-gyp/14.21.2/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
              793 |       (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/14.21.2/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
              827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
              404 | NODE_MODULE(unix_dgram, Initialize)
              SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
              COPY Release/unix_dgram.node
            make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
            > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            No connection to databases possible ...
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm ERR! code ELIFECYCLE
            npm ERR! errno 22
            npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
            npm ERR! Exit status 22
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T14_41_42_392Z-debug.log
              @bastel2021
              Zuerstmal nodeJS auf einen aktuellen Stand bringen.
              Siehe meine Signatur.
                Hm, was genau meinst du?
                Update und Upgrade habe ich zuletzt gestern gemacht.
                Sorry aber kannst mir da noch etwas genauer weiterhelfen?
                  @bastel2021
                  Was sagt
                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                  uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                    Bastel2021 @Thomas Braun last edited by
                    sorry das ich mich so blöd anstelle aber wie muss ich das genau im Terminal eingeben?
                      @bastel2021
                      So wie es da steht.
                      Am besten kopieren und einfügen.
                        sorry!
                        pi@raspberrypi:~ $
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v14.21.2
                        v14.21.2
                        6.14.17
                        6.14.17
                        throw err;
                        requireStack: []
                        pi@raspberrypi:~ $
                          @bastel2021
                          Zuerstmal auf nodeJS@16 gehen.
                            du schreibst dort ja von einem sauberen "npm tree"
                            der sieht bei mir aber nicht sauber aus!
                            pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                            npm ERR! missing: iobroker.js-controller@4.0.21, required by iobroker.inst@3.0.0
                            npm ERR! extraneous: iobroker.js-controller@4.0.21 /opt/iobroker/node_modules/iobroker.js-controller
                            │ │ │ ├── github-from-package@0.0.0
                            kann ich damit dann weitermachen?
                              @bastel2021
                              Ja. Oder direkt in die /etc/apt/sources.list.d/nodesource.list die 16 eintragen.
                                okay das hat glaube ich geklappt!
                                Und jetzt?
                                  Thomas Braun Most Active @Bastel2021 last edited by Thomas Braun
                                  @bastel2021
                                  Nicht glauben, prüfen.
                                  uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                    das wird ausgegeben
                                    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    8.19.3
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    tty
                                    /home/pi
                                    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                                    Paketlisten werden gelesen… Fertig
                                    nodejs:
                                    Installiert: 16.19.0-deb-1nodesource1
                                    Installationskandidat: 16.19.0-deb-1nodesource1
                                    Versionstabelle:
                                    *** 16.19.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                    100 /var/lib/dpkg/status
                                    12.22.12~dfsg-1~deb11u1 500
                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    pi@raspberrypi:~ $
                                      @bastel2021
                                      sudo -H -u iobroker npm cache clear
                                      cd /opt/iobroker
                                        ich glaube das sieht nicht so gut aus
                                        pi@raspberrypi:~ $ sudo -H -u iobroker npm cache clear
                                        cd /opt/iobroker
                                        npm ERR! As of npm@5, the npm cache self-heals from corruption issues
                                        npm ERR! by treating integrity mismatches as cache misses. As a result,
                                        npm ERR! data extracted from the cache is guaranteed to be valid. If you
                                        npm ERR! want to make sure everything is consistent, use npm cache verify
                                        npm ERR! instead. Deleting the cache can only make npm go slower, and is
                                        npm ERR! not likely to correct any problems you may be encountering!
                                        npm ERR!
                                        npm ERR! On the other hand, if you're debugging an issue with the installer,
                                        npm ERR! or race conditions that depend on the timing of writing to an empty
                                        npm ERR! cache, you can use npm install --cache /tmp/empty-cache to use a
                                        npm ERR! temporary cache instead of nuking the actual one.
                                        npm ERR!
                                        npm ERR! If you're sure you want to delete the entire cache, rerun this command
                                        npm ERR! with --force.
                                        npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_51_24_403Z-debug-0.log
                                        npm WARN old lockfile
                                        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                        npm WARN old lockfile This is a one-time fix-up, please be patient...
                                        npm ERR! code 22
                                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                        npm ERR! command failed
                                        npm ERR! command sh -c -- node iobroker.js setup first
                                        npm ERR! No connection to databases possible ...
                                        npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_51_26_424Z-debug-0.log
                                          @bastel2021
                                          Sorry, muss
                                          sudo -H -u iobroker npm cache clear --force
                                          lauten.
                                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm cache clear --forcecd /opt/iobroker
                                            npm WARN Not Found: /opt/iobroker
                                            npm ERR! code 22
                                            npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_59_37_585Z-debug-0.log
                                            5085
