    4. Iobroker startet nicht mehr
      SR277 @Thomas Braun last edited by
      Das sieht hier schon sehr komisch aus.
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
      │ │ │ ├── github-from-package@0.0.0
      │   ├── github-url-from-git@1.5.0
      │   ├─┬ new-github-release-url@1.0.0
      npm ERR! peer dep missing: @types/express@^4.17.13, required by http-proxy-middleware@2.0.2
      npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
        Thomas Braun Most Active @SR277 last edited by
        @sr277
        Nö, alles i. O.
          SR277 @Thomas Braun last edited by SR277
          So habe es installiert.
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v16.19.0
          v16.19.0
          8.19.3
          8.19.3
          4.0.23
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists... Done
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          Fehler besteht aber weiterhin:
          pi@raspberrypi:~ $ iob start admin
           Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
          0 var di'it;
          SyntaxError: Unexpected token 'var'
              at Object.compileFunction (node:vm:360:18)
              at wrapSafe (node:internal/modules/cjs/loader:1094:15)
              at Module._compile (node:internal/modules/cjs/loader:1129:27)
              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
              at Module.load (node:internal/modules/cjs/loader:1043:32)
              at Function.Module._load (node:internal/modules/cjs/loader:878:12)
              at Module.require (node:internal/modules/cjs/loader:1067:19)
              at require (node:internal/modules/cjs/helpers:103:18)
              at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
              at Module._compile (node:internal/modules/cjs/loader:1165:14)
            @sr277
            cd /opt/iobroker
            npm ls source-map
              pi@raspberrypi:/opt/iobroker $ npm ls source-map
              iobroker.inst@3.0.0 /opt/iobroker
              ├─┬ iobroker.alexa2@3.12.0
              │ └─┬ source-map-support@0.5.21
              │   └── source-map@0.6.1
              └─┬ iobroker.iot@1.11.5
                └─┬ jsdom@19.0.0
                  └─┬ escodegen@2.0.0
                    └── source-map@0.6.1 deduped
                @sr277
                Lange das System nicht mehr abgestaubt...
                iob stop
                iob fix
                iob restart
                  pi@raspberrypi:~ $ iob stop
                  pi@raspberrypi:~ $ iob fix
                  library: loaded
                  Library version=2022-12-09
                      Welcome to the ioBroker installation fixer!
                      Script version: 2022-12-22
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/4)
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Installed gcc-c++
                      Checking ioBroker user and directory permissions (2/4)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Database maintenance (3/4)
                  Checking for uncompressed JSONL databases... This might take a while!
                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                  Compressed 2 JSONL files. Done
                      Checking autostart (4/4)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  pi@raspberrypi:~ $ iob restart
                    @sr277
                    iobroker status
                      pi@raspberrypi:~ $ iobroker status
                       Objects database error: read ECONNRESET
                      0 var di'it;
                        @sr277
                        Keine Ahnung.
                        iob update
                        funktioniert vermutlich auch nicht?
                          Ne das gleiche. 😞
                          pi@raspberrypi:~ $ iob update
                          0 var di'it;
                            @sr277
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install iobroker.alexa2
                            sudo -H -u iobroker npm install iobroker.iot
                              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                              npm WARN old lockfile
                              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                              npm WARN old lockfile This is a one-time fix-up, please be patient...
                              added 12 packages, removed 121 packages, and changed 31 packages in 1m
                              137 packages are looking for funding
                                run `npm fund` for details
                              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                              added 2 packages, removed 1 package, and changed 1 package in 13s
                              138 packages are looking for funding
                              Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                                @sr277
                                iob status
                                  pi@raspberrypi:/opt/iobroker $ iob status
                                   States database error: connect ECONNREFUSED 127.0.0.1:9000
                                   redis get system.host.raspberrypi.alive, error - Connection is closed.
                                   redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                                  0 var di'it;
                                    Homoran Global Moderator Administrators @SR277 last edited by
                                    @sr277 sagte in Iobroker startet nicht mehr:
                                    warum?
                                    da bist du richtig!
                                      @sr277
                                      ls -lAh /opt/iobroker/iobroker-data/
                                      Im Prompt steht der Verzeichnispfad, in dem du dich gerade befindest. Vollkommen korrekt für den Moment.
                                        pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                                        total 53M
                                        drwxrwxr-x+  2 iobroker iobroker 4.0K Feb 11  2022 backitup
                                        drwxrwxr-x+  2 iobroker iobroker  12K Oct  1 20:53 backup-objects
                                        drwxrwxr-x+ 70 iobroker iobroker 4.0K May 13  2022 files
                                        -rw-rwxr--+  1 iobroker iobroker 5.0K Feb  8  2022 iobroker.json
                                        drwxrwxr-x+  3 iobroker iobroker 4.0K Jan 26  2022 jarvis
                                        -rw-rwxr--+  1 iobroker iobroker    3 Jan 15 17:19 notifications.json
                                        -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.bak.migrated
                                        -rw-rw-r--+  1 iobroker iobroker  17M Jan 15 17:19 objects.jsonl
                                        -rw-rwxr--+  1 iobroker iobroker  14M Feb  8  2022 objects.json.migrated
                                        -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.bak.migrated
                                        -rw-rw-r--+  1 iobroker iobroker 4.2M Jan 15 17:19 states.jsonl
                                        -rw-rwxr--+  1 iobroker iobroker 2.6M Feb  8  2022 states.json.migrated
                                        drwxrwxr-x+  2 iobroker iobroker 4.0K May  1  2022 telegram_0
                                        drwxrwxr-x+  3 iobroker iobroker 4.0K Feb  8  2022 tmp
                                          getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                            pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                                            getfacl: Removing leading '/' from absolute path names
                                            # file: opt/iobroker/iobroker-data/objects.jsonl
                                            # owner: iobroker
                                            # group: iobroker
                                            user::rw-
                                            group::r-x                      #effective:r--
                                            group:iobroker:rwx              #effective:rw-
                                            mask::rw-
                                            other::r--
                                            1597
