    3. Einsteigerfragen
    4. IoBroker ist nicht mehr über Browser erreichbar
      Bastel2021 last edited by
      ich glaube das sieht nicht so gut aus
      pi@raspberrypi:~ $ sudo -H -u iobroker npm cache clear
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      npm ERR! As of npm@5, the npm cache self-heals from corruption issues
      npm ERR! by treating integrity mismatches as cache misses. As a result,
      npm ERR! data extracted from the cache is guaranteed to be valid. If you
      npm ERR! want to make sure everything is consistent, use npm cache verify
      npm ERR! instead. Deleting the cache can only make npm go slower, and is
      npm ERR! not likely to correct any problems you may be encountering!
      npm ERR!
      npm ERR! On the other hand, if you're debugging an issue with the installer,
      npm ERR! or race conditions that depend on the timing of writing to an empty
      npm ERR! cache, you can use npm install --cache /tmp/empty-cache to use a
      npm ERR! temporary cache instead of nuking the actual one.
      npm ERR!
      npm ERR! If you're sure you want to delete the entire cache, rerun this command
      npm ERR! with --force.
      npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_51_24_403Z-debug-0.log
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! code 22
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c -- node iobroker.js setup first
      npm ERR! No connection to databases possible ...
      npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_51_26_424Z-debug-0.log
      pi@raspberrypi:/opt/iobroker $
        Thomas Braun Most Active @Bastel2021 last edited by
        @bastel2021
        Sorry, muss
        sudo -H -u iobroker npm cache clear --force
        lauten.
          Bastel2021 @Thomas Braun last edited by
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm cache clear --forcecd /opt/iobroker
          npm WARN Not Found: /opt/iobroker
          npm ERR! code 22
          npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_59_37_585Z-debug-0.log
            @bastel2021
            iobroker fix
              @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
              iobroker fix
                pi@raspberrypi:~ $ iobroker fix
                library: loaded
                Library version=2022-12-09
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                pi@raspberrypi:~ $
                  Thomas Braun Most Active @Bastel2021 last edited by Thomas Braun
                  @bastel2021
                  Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
                    library: loaded
                    pi@raspberrypi:~ $
                      @bastel2021
                      cd /opt/iobroker
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                        npm ERR! code 22
                        npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
                          @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
                          sudo -H -u iobroker npm install iobroker.js-controller --debug
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
                            npm ERR! code 22
                            npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
                              @bastel2021
                              ls -lAh /opt/iobroker/iobroker-data/
                                pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                                insgesamt 650M
                                drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                                drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                                drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                                -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                                drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                                -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                                -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                                -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                                drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                                  Die könnte etwas fett sein.
                                  iob fix
                                    pi@raspberrypi:/opt/iobroker $ iob fix
                                    library: loaded
                                      @bastel2021
                                        insgesamt 456K
                                        drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                                        -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                                        lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                                        -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                                        drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                                        drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                                        drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                                        -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                                        -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                                        -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                                          @bastel2021
                                          ./iobroker -v
                                            pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                                            node:internal/modules/cjs/loader:998
                                              throw err;
                                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                                at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                                at node:internal/main/run_main_module:22:47 {
                                              code: 'MODULE_NOT_FOUND',
                                              requireStack: []
                                            5085
