    3. Einsteigerfragen
    4. IoBroker ist nicht mehr über Browser erreichbar
      Thomas Braun Most Active @Bastel2021 last edited by
      @bastel2021
      Sorry, muss
      sudo -H -u iobroker npm cache clear --force
      lauten.
        Bastel2021 @Thomas Braun last edited by
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm cache clear --forcecd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN Not Found: /opt/iobroker
        npm WARN old lockfile
        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm ERR! code 22
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c -- node iobroker.js setup first
        npm ERR! No connection to databases possible ...
        npm ERR! /home/iobroker/.npm/_logs/2023-01-15T15_59_37_585Z-debug-0.log
          @bastel2021
          iobroker fix
            @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
            iobroker fix
              pi@raspberrypi:~ $ iobroker fix
              library: loaded
              Library version=2022-12-09
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              pi@raspberrypi:~ $
                Thomas Braun Most Active @Bastel2021 last edited by Thomas Braun
                @bastel2021
                Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
                  library: loaded
                  pi@raspberrypi:~ $
                    @bastel2021
                    cd /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                      npm ERR! code 22
                      npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
                        @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
                        sudo -H -u iobroker npm install iobroker.js-controller --debug
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
                          npm ERR! code 22
                          npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
                            @bastel2021
                            ls -lAh /opt/iobroker/iobroker-data/
                              pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                              insgesamt 650M
                              drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                              drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                              drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                              -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                              drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                              -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                              -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                              -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                              drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                                Die könnte etwas fett sein.
                                iob fix
                                  pi@raspberrypi:/opt/iobroker $ iob fix
                                  library: loaded
                                    @bastel2021
                                      insgesamt 456K
                                      drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                                      -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                                      lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                                      -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                                      drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                                      drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                                      drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                                      -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                                      -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                                      -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                                        @bastel2021
                                        ./iobroker -v
                                          pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                                          node:internal/modules/cjs/loader:998
                                            throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                              at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                              at node:internal/main/run_main_module:22:47 {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: []
                                            @bastel2021
                                            Fällt mir nix zu ein.
                                            5085
