    3. Einsteigerfragen
    4. IoBroker ist nicht mehr über Browser erreichbar
      Bastel2021 last edited by
      @thomas-braun sagte in IoBroker ist nicht mehr über Browser erreichbar:
      iobroker fix
        Bastel2021 @Thomas Braun last edited by
        pi@raspberrypi:~ $ iobroker fix
        library: loaded
        Library version=2022-12-09
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        pi@raspberrypi:~ $
          Thomas Braun Most Active @Bastel2021 last edited by Thomas Braun
          @bastel2021
          Bitte statt der Spoiler lieber CodeTags verwenden. Danke.
            library: loaded
            pi@raspberrypi:~ $
              @bastel2021
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                npm WARN old lockfile
                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                npm WARN old lockfile This is a one-time fix-up, please be patient...
                npm ERR! code 22
                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! command failed
                npm ERR! command sh -c -- node iobroker.js setup first
                npm ERR! No connection to databases possible ...
                npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_15_40_711Z-debug-0.log
                  @bastel2021 sagte in IoBroker ist nicht mehr über Browser erreichbar:
                  sudo -H -u iobroker npm install iobroker.js-controller --debug
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller --debug
                    npm ERR! code 22
                    npm ERR!     /home/iobroker/.npm/_logs/2023-01-15T16_20_29_487Z-debug-0.log
                      @bastel2021
                      ls -lAh /opt/iobroker/iobroker-data/
                        pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/iobroker-data/
                        insgesamt 650M
                        drwxrwxr-x+  2 iobroker iobroker 4,0K 22. Mär 2022  backitup
                        drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 12:35 backup-objects
                        drwxrwxr-x+ 17 iobroker iobroker 4,0K 14. Jan 17:26 files
                        -rw-rwxr--+  1 iobroker iobroker 7,4K 22. Mär 2022  iobroker.json
                        drwxrwxr-x+  4 iobroker iobroker 4,0K  1. Jan 14:32 node-red
                        -rw-rw-r--+  1 iobroker iobroker    3 25. Mär 2022  notifications.json
                        -rw-rwxr--+  1 iobroker iobroker 648M 15. Jan 14:12 objects.jsonl
                        -rw-rw-r--+  1 iobroker iobroker 1,7M 15. Jan 15:01 states.jsonl
                        drwxrwxr-x+  2 iobroker iobroker 4,0K 15. Jan 14:12 zigbee_0
                          Die könnte etwas fett sein.
                          iob fix
                            pi@raspberrypi:/opt/iobroker $ iob fix
                            library: loaded
                              @bastel2021
                                insgesamt 456K
                                drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 02:40 backups
                                -rwxrwxrwx+   1 iobroker iobroker  133 22. Mär 2022  INSTALLER_INFO.txt
                                lrwxrwxrwx    1 iobroker iobroker   22 22. Mär 2022  iob -> /opt/iobroker/iobroker
                                -rwxrwxr-x+   1 iobroker iobroker  309 22. Mär 2022  iobroker
                                drwxrwxr-x+   7 iobroker iobroker 4,0K 15. Jan 17:21 iobroker-data
                                drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jan 14:59 log
                                drwxrwxr-x+ 570 iobroker iobroker  20K 15. Jan 17:21 node_modules
                                -rw-rwxr--+   1 iobroker iobroker  155 22. Mär 2022  .npmrc
                                -rw-rwxr--+   1 iobroker iobroker  603 14. Jan 17:26 package.json
                                -rw-rwxr--+   1 iobroker iobroker 406K 14. Jan 17:26 package-lock.json
                                  @bastel2021
                                  ./iobroker -v
                                    pi@raspberrypi:/opt/iobroker $ ./iobroker -v
                                    node:internal/modules/cjs/loader:998
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                        at node:internal/main/run_main_module:22:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                      @bastel2021
                                      Fällt mir nix zu ein.
                                        ein backup aus dem System herraus ist wahrscheinlich auch nicht möglich, oder?
                                        B Thomas Braun 2 Replies Last reply Reply Quote 0
                                          Bastel2021 @Bastel2021 last edited by
                                          ich meine ein Backup einspielen
                                            @bastel2021
                                            Was haste denn da vorliegen?
                                            5085
