    4. JavaScript
    5. Roborock Adapter tester gesucht
    • copystring
      copystring last edited by
      OK. Ich denke ich habe den Fehler gefunden. Die Abhängigkeit von axios war nicht hinterlegt. Mal bitte diese Branch testen: https://github.com/copystring/ioBroker.roborock/tree/fix_missing_dependencies
      H O 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @oxident last edited by
        @oxident sagte in [Tester gesucht] Roborock-API:
        28 packages can be upgraded.
        Ran da.
        • O
          oxident @Thomas Braun last edited by
          @thomas-braun said in [Tester gesucht] Roborock-API:
          Ran da.
          War leider nicht so spektakulär:
          The following packages have been kept back:
            grub-common grub-pc grub-pc-bin grub2-common
          The following packages will be upgraded:
            apport libgbm-dev libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0 libsasl2-2 libsasl2-modules libsasl2-modules-db
            linux-firmware mesa-va-drivers mesa-vdpau-drivers mesa-vulkan-drivers nodejs open-vm-tools openssh-client openssh-server
            openssh-sftp-server python3-apport python3-problem-report python3-software-properties python3-update-manager
            software-properties-common update-manager-core
          Mach ich natürlich trotzdem 😉
          @copystring
          Hat leider nichts geändert. Hier der Output mit Loglevel "silly":
          host.iobroker
          2023-01-15 17:24:06.223	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          roborock.0
          2023-01-15 17:24:05.449	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          roborock.0
          2023-01-15 17:24:05.448	info	terminating
          roborock.0
          2023-01-15 17:24:05.447	silly	States system redis pmessage io.system.adapter.roborock.0.logLevel/io.system.adapter.roborock.0.logLevel:{"val":"silly","ack":true,"ts":1673799845428,"q":0,"from":"system.adapter.roborock.0","lc":1673799845428}
          roborock.0
          2023-01-15 17:24:05.446	error	Cannot read properties of null (reading 'token')
          roborock.0
          2023-01-15 17:24:05.445	error	TypeError: Cannot read properties of null (reading 'token') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:96:64) at runNextTicks (node:internal/process/task_queues:61:5) at processImmediate (node:internal/timers:437:9)
          roborock.0
          2023-01-15 17:24:05.444	error	unhandled promise rejection: Cannot read properties of null (reading 'token')
          roborock.0
          2023-01-15 17:24:05.444	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2023-01-15 17:24:05.360	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#fix_missing_dependencies) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
            homecineplexx @copystring last edited by
            @copystring said in [Tester gesucht] Roborock-API:
            hallo
            danke, dass du dich für den Adapter annimmst bzw was baust.
            ich hab das Mal installiert und es läuft, auch sind Daten in den Objekten. Interessant wäre zb nur, dieses Update interval (60000) sind das ms oder Sekunden?
            Und dann wäre noch eine kurze Beschreibung der einzelnen Objekte interessant
              DonToben last edited by
              Wie installiert ihr den Adapter.
              Über iobroker und benutzerdefinierte Installation mit URL?
                homecineplexx @DonToben last edited by
                @dontoben said in [Tester gesucht] Roborock-API:
                ja, ganz genau
                • O
                  oxident @copystring last edited by
                  Hmm, nachdem ich diesen Branch installiert hatte gab's Stress mit einem meiner Javascript-Instanzen (!). Erst nach Entfernen vom Roborock-Adapter lief das System wieder rund. Keine Ahnung ob's am Adapter lag oder meinem System 😉
                  Also vielleicht sollten die anderen Tester lieber den master-Branch versuchen!
                  H copystring 2 Replies Last reply Reply Quote 0
                    homecineplexx @oxident last edited by
                    @oxident said in [Tester gesucht] Roborock-API:
                    ich hab doch oben gerade geschrieben, dass ich es installiert habe und bei mir läuft es!
                    • O
                      oxident @homecineplexx last edited by
                      @homecineplexx said in [Tester gesucht] Roborock-API:
                      Jepp, ich weiß. Wusste jetzt aber nicht, welchen Branch Du genommen hast 😉
                      • copystring
                        copystring @oxident last edited by copystring
                        @oxident die master branch kann nicht laufen da die axios Abhängigkeit fehlt. Daher bitte die andere branch testen.
                        EDIT: Wenn die läuft füge ich das zur master branch hinzu. Brauche eure Rückmeldung.
                        H O 2 Replies Last reply Reply Quote 2
                          nochmals diese läuft!
                          • O
                            @copystring Bei mir leider nicht. Siehe hier inkl. der Probleme nicht gefundener Module (z.B. ajv.js) beim Javascript-Adapter 😞
                              wird wahrscheinlich interessant sein welche nodejs und npm du verwendest
                              copystring 1 Reply Last reply Reply Quote 0
                              • O
                                oxident @oxident last edited by
                                Also NodeJS ist v16.18.1, NPM v8.19.2 und JS-Controller v6.3.5
                                • copystring
                                  copystring @homecineplexx last edited by
                                  @homecineplexx den Adapter Mal bitte löschen und alle Objekte aus iobroker ebenfalls danach löschen. Dann über die URL https://github.com/copystring/ioBroker.roborock/tree/fix_missing_dependencies neu installieren
                                    hast du nun was geändert? bei mir lief das teil ja!
                                    • copystring
                                      @homecineplexx oopsi. Das war für @oxident
                                      • O
                                        @copystring @homecineplexx Sorry, jetzt hab ich Euch wohl durcheinander gebracht.
                                        Ich warte erstmal Eure Tests ab und versuche dann den Master nochmal.
                                          so, ich hab alles gelöscht, Instanz, Adapter, Objekte und das ganze nochmals von https://github.com/copystring/ioBroker.roborock/tree/fix_missing_dependencies gemacht und es hat wieder geklappt!
                                            mp3junkie last edited by
                                            Bei mir wird der Adapter kurz grün, dann rot.
                                            Deinstalliert, installiert. Bleibt so.
                                            1.5k
                                            766
                                            241254
