    3. Einsteigerfragen
    4. Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter
    • V
      V8Turbo @V8Turbo last edited by
      Und so sieht das ganze aus wenn es eine weile lief...
      modbus.0
      2023-01-13 09:14:40.917	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:14:40.916	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:14:40.910	info	Disconnected from slave
      modbus.0
      2023-01-13 09:14:39.907	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:14:39.906	error	Request timed out.
      modbus.0
      2023-01-13 09:14:39.905	warn	Error: undefined
      modbus.0
      2023-01-13 09:14:34.935	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:14:34.901	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:14:34.900	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:14:33.843	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 09:14:33.793	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:14:33.792	debug	Initialization of scale factors done!
      modbus.0
      2023-01-13 09:14:33.789	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:14:33.787	info	Connected to slave
      modbus.0
      2023-01-13 09:14:33.778	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:14:33.501	debug	Add holdingRegisters.1056_Temperature_Inv1: {"_id":"holdingRegisters.1056_Temperature_Inv1","type":"state","common":{"name":"","role":"state","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":1056,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
      modbus.0
      2023-01-13 09:14:33.501	debug	Initialize Objects for holdingRegs: [{"_address":"1056","name":"Temperature_Inv1","description":"","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"state","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1056,"id":"holdingRegisters.1056_Temperature_Inv1"}]
      modbus.0
      2023-01-13 09:14:33.500	debug	Initialize Objects for inputRegs: []
      modbus.0
      2023-01-13 09:14:33.499	debug	Initialize Objects for coils: []
      modbus.0
      2023-01-13 09:14:33.498	debug	Initialize Objects for disInputs: []
      modbus.0
      2023-01-13 09:14:33.357	info	starting. Version 5.0.11 (non-npm: ioBroker/ioBroker.modbus) in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
      modbus.0
      2023-01-13 09:14:33.037	debug	Plugin sentry Initialize Plugin (enabled=true)
      host.raspberrypi
      2023-01-13 09:14:31.670	info	instance system.adapter.modbus.0 started with pid 6057
      host.raspberrypi
      2023-01-13 09:14:30.562	info	Restart adapter system.adapter.modbus.0 because enabled
      host.raspberrypi
      2023-01-13 09:14:30.561	info	instance system.adapter.modbus.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      modbus.0
      2023-01-13 09:14:29.937	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      modbus.0
      2023-01-13 09:14:29.936	debug	Plugin sentry destroyed
      modbus.0
      2023-01-13 09:14:29.934	error	Reconnect did not help, restart adapter
      modbus.0
      2023-01-13 09:14:29.933	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:14:29.932	error	Request timed out.
      modbus.0
      2023-01-13 09:14:29.931	warn	Error: undefined
      modbus.0
      2023-01-13 09:14:24.960	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:14:24.929	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:14:24.928	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:14:24.927	info	Connected to slave
      modbus.0
      2023-01-13 09:14:24.921	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:13:24.923	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:13:24.922	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:13:24.919	info	Disconnected from slave
      modbus.0
      2023-01-13 09:13:23.918	warn	Poll error count: 12 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:13:23.917	error	Request timed out.
      modbus.0
      2023-01-13 09:13:23.916	warn	Error: undefined
      modbus.0
      2023-01-13 09:13:18.944	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:13:18.914	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:13:18.914	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:13:18.913	info	Connected to slave
      modbus.0
      2023-01-13 09:13:18.907	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:12:18.908	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:12:18.907	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:12:18.905	info	Disconnected from slave
      modbus.0
      2023-01-13 09:12:17.904	warn	Poll error count: 11 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:12:17.904	error	Request timed out.
      modbus.0
      2023-01-13 09:12:17.903	warn	Error: undefined
      modbus.0
      2023-01-13 09:12:12.931	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:12:12.901	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:12:12.900	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:12:12.897	info	Connected to slave
      modbus.0
      2023-01-13 09:12:12.891	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:11:12.895	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:11:12.894	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:11:12.890	info	Disconnected from slave
      modbus.0
      2023-01-13 09:11:11.890	warn	Poll error count: 10 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:11:11.889	error	Request timed out.
      modbus.0
      2023-01-13 09:11:11.888	warn	Error: undefined
      modbus.0
      2023-01-13 09:11:06.919	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:11:06.885	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:11:06.885	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:11:06.883	info	Connected to slave
      modbus.0
      2023-01-13 09:11:06.876	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:10:06.877	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:10:06.876	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:10:06.873	info	Disconnected from slave
      modbus.0
      2023-01-13 09:10:05.872	warn	Poll error count: 9 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:10:05.871	error	Request timed out.
      modbus.0
      2023-01-13 09:10:05.870	warn	Error: undefined
      modbus.0
      2023-01-13 09:10:00.898	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:10:00.868	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:10:00.867	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:10:00.865	info	Connected to slave
      modbus.0
      2023-01-13 09:10:00.860	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:09:00.863	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:09:00.862	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:09:00.858	info	Disconnected from slave
      modbus.0
      2023-01-13 09:08:59.856	warn	Poll error count: 8 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:08:59.856	error	Request timed out.
      modbus.0
      2023-01-13 09:08:59.855	warn	Error: undefined
      modbus.0
      2023-01-13 09:08:54.885	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:08:54.853	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:08:54.852	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:08:54.851	info	Connected to slave
      modbus.0
      2023-01-13 09:08:54.846	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:07:54.859	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:07:54.858	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:07:54.844	info	Disconnected from slave
      modbus.0
      2023-01-13 09:07:53.843	warn	Poll error count: 7 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:07:53.842	error	Request timed out.
      modbus.0
      2023-01-13 09:07:53.841	warn	Error: undefined
      modbus.0
      2023-01-13 09:07:48.871	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:07:48.839	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:07:48.839	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:07:48.838	info	Connected to slave
      modbus.0
      2023-01-13 09:07:48.831	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:06:48.835	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:06:48.834	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:06:48.830	info	Disconnected from slave
      modbus.0
      2023-01-13 09:06:47.830	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:06:47.829	error	Request timed out.
      modbus.0
      2023-01-13 09:06:47.828	warn	Error: undefined
      modbus.0
      2023-01-13 09:06:42.855	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:06:42.826	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:06:42.826	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:06:42.825	info	Connected to slave
      modbus.0
      2023-01-13 09:06:42.820	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:05:42.824	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:05:42.822	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:05:42.819	info	Disconnected from slave
      modbus.0
      2023-01-13 09:05:41.819	warn	Poll error count: 5 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:05:41.819	error	Request timed out.
      modbus.0
      2023-01-13 09:05:41.817	warn	Error: undefined
      modbus.0
      2023-01-13 09:05:36.922	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:05:36.815	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:05:36.815	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:05:36.814	info	Connected to slave
      modbus.0
      2023-01-13 09:05:36.807	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:04:36.809	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:04:36.808	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:04:36.806	info	Disconnected from slave
      modbus.0
      2023-01-13 09:04:35.806	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:04:35.805	error	Request timed out.
      modbus.0
      2023-01-13 09:04:35.804	warn	Error: undefined
      modbus.0
      2023-01-13 09:04:30.909	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:04:30.802	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:04:30.801	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:04:30.800	info	Connected to slave
      modbus.0
      2023-01-13 09:04:30.790	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:03:30.793	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:03:30.792	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:03:30.789	info	Disconnected from slave
      modbus.0
      2023-01-13 09:03:29.789	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:03:29.788	error	Request timed out.
      modbus.0
      2023-01-13 09:03:29.787	warn	Error: undefined
      modbus.0
      2023-01-13 09:03:24.891	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:03:24.785	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:03:24.784	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:03:24.784	info	Connected to slave
      modbus.0
      2023-01-13 09:03:24.778	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:02:24.781	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:02:24.780	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:02:24.777	info	Disconnected from slave
      modbus.0
      2023-01-13 09:02:23.777	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:02:23.776	error	Request timed out.
      modbus.0
      2023-01-13 09:02:23.775	warn	Error: undefined
      modbus.0
      2023-01-13 09:02:18.874	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:02:18.772	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:02:18.771	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:02:18.770	info	Connected to slave
      modbus.0
      2023-01-13 09:02:18.761	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:01:18.764	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:01:18.763	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:01:18.759	info	Disconnected from slave
      modbus.0
      2023-01-13 09:01:17.759	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:01:17.758	error	Request timed out.
      modbus.0
      2023-01-13 09:01:17.757	warn	Error: undefined
      modbus.0
      2023-01-13 09:01:12.856	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
      modbus.0
      2023-01-13 09:01:12.756	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:01:12.752	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:01:11.699	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 09:01:11.667	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:01:11.666	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:01:11.664	info	Connected to slave
      modbus.0
      2023-01-13 09:01:11.655	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 09:00:11.657	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 09:00:11.656	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 09:00:11.653	info	Disconnected from slave
      modbus.0
      2023-01-13 09:00:10.653	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 09:00:10.652	error	Request timed out.
      modbus.0
      2023-01-13 09:00:10.651	warn	Error: undefined
      modbus.0
      2023-01-13 09:00:05.681	error	Error response: 20
      modbus.0
      2023-01-13 09:00:05.649	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:00:05.648	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:00:04.596	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 09:00:04.567	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:00:04.566	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:00:03.513	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 09:00:03.481	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:00:03.480	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:00:02.427	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 09:00:02.266	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 09:00:02.265	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 09:00:02.264	info	Connected to slave
      modbus.0
      2023-01-13 09:00:02.257	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:59:02.260	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:59:02.259	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:59:02.254	info	Disconnected from slave
      modbus.0
      2023-01-13 08:59:01.254	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:59:01.253	error	Request timed out.
      modbus.0
      2023-01-13 08:59:01.252	warn	Error: undefined
      modbus.0
      2023-01-13 08:58:56.280	error	unknown function code: 0x20, 0x20
      modbus.0
      2023-01-13 08:58:56.251	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:58:56.250	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:58:56.250	info	Connected to slave
      modbus.0
      2023-01-13 08:58:56.243	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:57:56.245	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:57:56.244	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:57:56.241	info	Disconnected from slave
      modbus.0
      2023-01-13 08:57:55.242	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:57:55.241	error	Request timed out.
      modbus.0
      2023-01-13 08:57:55.240	warn	Error: undefined
      modbus.0
      2023-01-13 08:57:50.269	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
      modbus.0
      2023-01-13 08:57:50.268	error	Error response for FCx64: Illegal Data Address
      modbus.0
      2023-01-13 08:57:50.238	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:57:50.237	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:57:50.236	info	Connected to slave
      modbus.0
      2023-01-13 08:57:50.229	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:56:50.232	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:56:50.231	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:56:50.228	info	Disconnected from slave
      modbus.0
      2023-01-13 08:56:49.227	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:56:49.226	error	Request timed out.
      modbus.0
      2023-01-13 08:56:49.225	warn	Error: undefined
      modbus.0
      2023-01-13 08:56:44.255	error	unknown function code: 0x20, 0x20
      modbus.0
      2023-01-13 08:56:44.223	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:56:44.222	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:56:43.169	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:56:43.137	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:56:43.136	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:56:42.084	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:56:41.987	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:56:41.986	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:56:41.984	info	Connected to slave
      modbus.0
      2023-01-13 08:56:41.977	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:55:41.981	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:55:41.980	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:55:41.976	info	Disconnected from slave
      modbus.0
      2023-01-13 08:55:40.977	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:55:40.975	error	Request timed out.
      modbus.0
      2023-01-13 08:55:40.974	warn	Error: undefined
      modbus.0
      2023-01-13 08:55:36.063	error	Error response: 20
      modbus.0
      2023-01-13 08:55:35.973	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:55:35.971	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:55:34.919	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:55:34.887	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:55:34.885	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:55:33.832	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:55:33.800	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:55:33.796	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:55:32.743	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:55:32.709	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:55:32.708	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:55:32.707	info	Connected to slave
      modbus.0
      2023-01-13 08:55:32.700	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:54:32.703	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:54:32.701	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:54:32.698	info	Disconnected from slave
      modbus.0
      2023-01-13 08:54:31.697	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:54:31.696	error	Request timed out.
      modbus.0
      2023-01-13 08:54:31.695	warn	Error: undefined
      modbus.0
      2023-01-13 08:54:26.724	error	unknown function code: 0x20, 0x20
      modbus.0
      2023-01-13 08:54:26.693	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:54:26.691	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:54:25.638	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:54:25.605	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:54:25.604	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:54:25.603	info	Connected to slave
      modbus.0
      2023-01-13 08:54:25.596	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:53:25.598	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:53:25.597	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:53:25.594	info	Disconnected from slave
      modbus.0
      2023-01-13 08:53:24.593	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:53:24.592	error	Request timed out.
      modbus.0
      2023-01-13 08:53:24.591	warn	Error: undefined
      modbus.0
      2023-01-13 08:53:19.618	error	unknown function code: 0x20, 0x19
      modbus.0
      2023-01-13 08:53:19.588	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:53:19.587	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:53:19.585	info	Connected to slave
      modbus.0
      2023-01-13 08:53:19.577	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:52:19.579	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:52:19.578	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:52:19.575	info	Disconnected from slave
      modbus.0
      2023-01-13 08:52:18.574	warn	Poll error count: 5 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:52:18.573	error	Request timed out.
      modbus.0
      2023-01-13 08:52:18.572	warn	Error: undefined
      modbus.0
      2023-01-13 08:52:13.602	error	Wrong CRC for frame: 3,2,0,25,61
      modbus.0
      2023-01-13 08:52:13.569	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:52:13.568	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:52:13.567	info	Connected to slave
      modbus.0
      2023-01-13 08:52:13.561	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:51:13.564	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:51:13.563	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:51:13.559	info	Disconnected from slave
      modbus.0
      2023-01-13 08:51:12.559	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:51:12.558	error	Request timed out.
      modbus.0
      2023-01-13 08:51:12.557	warn	Error: undefined
      modbus.0
      2023-01-13 08:51:07.588	error	Wrong CRC for frame: 3,2,0,25,61
      modbus.0
      2023-01-13 08:51:07.555	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:51:07.554	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:51:07.552	info	Connected to slave
      modbus.0
      2023-01-13 08:51:07.545	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:50:07.547	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:50:07.546	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:50:07.542	info	Disconnected from slave
      modbus.0
      2023-01-13 08:50:06.542	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:50:06.541	error	Request timed out.
      modbus.0
      2023-01-13 08:50:06.541	warn	Error: undefined
      modbus.0
      2023-01-13 08:50:01.569	error	Wrong CRC for frame: 6,3,2,0,25,61,142
      modbus.0
      2023-01-13 08:50:01.537	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:50:01.536	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:50:01.535	info	Connected to slave
      modbus.0
      2023-01-13 08:50:01.528	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:49:01.528	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:49:01.527	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:49:01.524	info	Disconnected from slave
      modbus.0
      2023-01-13 08:49:00.523	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:49:00.522	error	Request timed out.
      modbus.0
      2023-01-13 08:49:00.521	warn	Error: undefined
      modbus.0
      2023-01-13 08:48:55.550	error	Wrong CRC for frame: 6,3,2,0,25,61,142
      modbus.0
      2023-01-13 08:48:55.517	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:48:55.516	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:48:55.515	info	Connected to slave
      modbus.0
      2023-01-13 08:48:55.507	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0
      2023-01-13 08:47:55.508	debug	Cleaning up request fifo.
      modbus.0
      2023-01-13 08:47:55.507	debug	Clearing timeout of the current request.
      modbus.0
      2023-01-13 08:47:55.504	info	Disconnected from slave
      modbus.0
      2023-01-13 08:47:54.503	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.0
      2023-01-13 08:47:54.501	error	Request timed out.
      modbus.0
      2023-01-13 08:47:54.499	warn	Error: undefined
      modbus.0
      2023-01-13 08:47:49.530	error	unknown function code: 0x20, 0x20
      modbus.0
      2023-01-13 08:47:49.497	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:49.495	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:48.443	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:48.411	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:48.410	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:47.356	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:47.323	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:47.322	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:46.269	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:46.165	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:46.163	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:45.109	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:45.076	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:45.075	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:44.022	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:43.985	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:43.984	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:42.930	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
      modbus.0
      2023-01-13 08:47:42.892	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
      modbus.0
      2023-01-13 08:47:42.891	debug	Initialization of scale factors done!
      modbus.0
      2023-01-13 08:47:42.889	debug	[DevID_2] Poll start ---------------------
      modbus.0
      2023-01-13 08:47:42.888	info	Connected to slave
      modbus.0
      2023-01-13 08:47:42.870	debug	connect to serial /dev/ttyUSB0 with 9600
      • wendy2702
        wendy2702 @V8Turbo last edited by
        @v8turbo sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
        <- Wie soll ich das machen ? Es gibt nur eine Einstellung im WR und da kann man die BAUD eintragen. Anleitung steht auch nichts...
        Das ist schlecht. Hersteller und/oder Installateur mal kontaktiert?
        Weil wenn das nicht passt kannst du lange probieren.
        Dann wäre noch wichtig ob das Excel auch wirklich zu deiner SW Version passt.
        Hast du mal den Rat von @Glasfaser befolgt?
        @glasfaser sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
        Mache es so , mit einem Windows Programm QModMaster , zuerst alles raussuchen :
        https://forum.iobroker.net/post/829310
        • V
          V8Turbo @wendy2702 last edited by V8Turbo
          @wendy2702 nein habe ich noch nicht gemacht aber kann das nochmal mit QModMaster probieren. Die Excel passt, die ist für die aktuelle FW die ich gestern Installiert habe. Jetzt sogar mit Deutsch als Sprache 🙂
          Hersteller und/oder Installateur mal kontaktiert? <- Habe ich vorhin gerade, aber die Werte sind ja fast immer gleich also die sollten wohl passen. Ich denke immernoch es liegt an dem "Pausen" Problem wie in dem Thread den ich weiter oben verlinkt habe geschrieben wurde.
          https://forum.iobroker.net/topic/22126/adapter-modbus-mehrere-geräte-ids-timeout-beim-auslesen-von-mehr-als-einen-teilnehmern/17
          wendy2702 M 2 Replies Last reply Reply Quote 0
          • wendy2702
            @v8turbo Das kann viele Ursachen haben. Möglich ist auch ein "schlechter USB-RS485" Adapter.
            Da hatte ich zu Beginn auch immer Probleme mit.
            Seit 2 Tagen nutze ich ein Waveshare RS485<->LAN Adapter zur Abfrage eines Modbus Gerätes und das klappt bisher ohne aussetzer.
            • V
              @wendy2702 ```
              [RTU]>Tx > 11:37:06:762 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:06:798 - 02 03 08 01 5A 00 91 0F 57 01 54 EE 2C
              [RTU]>Tx > 11:37:09:763 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:09:799 - 02 03 08 01 2A 00 82 0F F6 01 49 8B C3
              [RTU]>Tx > 11:37:12:763 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:12:799 - FF 02 03 08 01 5E 00 91
              Sys > 11:37:13:309 - Error : Response not from requested slave
              [RTU]>Tx > 11:37:15:764 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:15:798 - 02 03 08 01 45 00 8B 0F D0 01 4E 68 CD
              [RTU]>Tx > 11:37:18:762 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:18:797 - FF 02 03 08 01 1C 00 7C
              Sys > 11:37:19:302 - Error : Response not from requested slave
              [RTU]>Tx > 11:37:21:765 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:21:877 - 02 03 08 01 52 00 90 0F 85 01 52 7A 17
              [RTU]>Tx > 11:37:24:763 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:24:799 - FF 02 03 08 01 5F 00 90
              Sys > 11:37:25:312 - Error : Response not from requested slave
              [RTU]>Tx > 11:37:27:815 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:27:849 - 02 03 08 01 57 00 90 0F 60 01 54 BE E2
              [RTU]>Tx > 11:37:30:762 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:30:796 - 02 03 08 01 27 00 80 0F FB 01 49 BF 00
              [RTU]>Tx > 11:37:33:765 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:33:839 - 02 03 08 01 34 00 86 0F EA 01 4A 05 C5
              [RTU]>Tx > 11:37:36:763 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:36:798 - FF 02 03 08 01 5F 00 91
              Sys > 11:37:37:309 - Error : Response not from requested slave
              [RTU]>Tx > 11:37:39:764 - 02 03 05 85 00 04 55 1F
              [RTU]>Rx > 11:37:39:799 - 02 03 08 01 41 00 8A 0F BC 01 4F 11 10
              • wendy2702
                Wovon ist das?
                • V
                  @wendy2702 QModMaster ?!
                  • V
                    Mit neuem Seriellen RS485 FTDI Chip auf USB...
                    modbus.0
                    	2023-01-16 20:55:36.525	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:55:36.523	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:55:36.520	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:55:35.519	warn	Poll error count: 9 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2023-01-16 20:55:35.518	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:55:35.517	warn	Error: undefined
                    admin.0
                    	2023-01-16 20:55:30.945	info	==> Connected system.user.admin from ::ffff:192.168.178.201
                    modbus.0
                    	2023-01-16 20:55:30.516	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:55:30.514	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:55:30.481	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:55:30.481	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:55:30.480	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:55:30.473	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:54:30.477	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:54:30.475	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:54:30.472	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:54:29.473	warn	Poll error count: 8 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2023-01-16 20:54:29.472	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:54:29.470	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:54:24.497	error	Wrong CRC for frame: 2,3,2,128,2,3,86
                    modbus.0
                    	2023-01-16 20:54:24.468	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:54:24.466	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:54:24.426	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:54:24.425	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:54:24.424	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:54:24.415	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:53:24.419	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:53:24.418	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:53:24.413	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:53:23.411	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:53:23.410	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:53:23.400	warn	Poll error count: 7 code: "App Timeout"
                    modbus.0
                    	2023-01-16 20:53:18.409	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
                    modbus.0
                    	2023-01-16 20:53:18.407	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                    modbus.0
                    	2023-01-16 20:53:18.364	debug	[DevID_2/holdingRegs] Poll address 1412 - 6 registers
                    modbus.0
                    	2023-01-16 20:53:18.359	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                    modbus.0
                    	2023-01-16 20:53:18.234	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:53:18.231	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:53:18.198	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:53:18.197	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:53:18.196	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:53:18.187	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:52:18.203	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:52:18.202	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:52:18.185	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:52:18.133	warn	Poll error count: 6 code: "App Timeout"
                    modbus.0
                    	2023-01-16 20:52:13.248	debug	[DevID_2/holdingRegs] Poll address 1544 - 3 registers
                    modbus.0
                    	2023-01-16 20:52:13.246	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
                    modbus.0
                    	2023-01-16 20:52:13.217	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
                    modbus.0
                    	2023-01-16 20:52:13.214	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                    modbus.0
                    	2023-01-16 20:52:13.169	debug	[DevID_2/holdingRegs] Poll address 1412 - 6 registers
                    modbus.0
                    	2023-01-16 20:52:13.166	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                    modbus.0
                    	2023-01-16 20:52:13.040	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:52:13.038	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:52:12.932	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:52:12.931	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:52:12.930	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:52:12.922	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:51:12.924	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:51:12.923	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:51:12.920	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:51:12.825	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:51:12.824	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:51:11.920	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:51:11.919	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:51:11.772	warn	Poll error count: 5 code: "App Timeout"
                    modbus.0
                    	2023-01-16 20:51:06.918	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                    modbus.0
                    	2023-01-16 20:51:06.917	debug	[DevID_2/holdingRegs] Poll address 1640 DONE
                    modbus.0
                    	2023-01-16 20:51:06.886	debug	[DevID_2/holdingRegs] Poll address 1640 - 2 registers
                    modbus.0
                    	2023-01-16 20:51:06.885	debug	[DevID_2/holdingRegs] Poll address 1544 DONE
                    modbus.0
                    	2023-01-16 20:51:06.839	debug	[DevID_2/holdingRegs] Poll address 1544 - 3 registers
                    modbus.0
                    	2023-01-16 20:51:06.837	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
                    modbus.0
                    	2023-01-16 20:51:06.792	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
                    modbus.0
                    	2023-01-16 20:51:06.789	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                    modbus.0
                    	2023-01-16 20:51:06.744	debug	[DevID_2/holdingRegs] Poll address 1412 - 6 registers
                    modbus.0
                    	2023-01-16 20:51:06.741	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                    modbus.0
                    	2023-01-16 20:51:06.616	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:51:06.613	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:51:06.572	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:51:06.571	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:51:06.570	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:51:06.561	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:50:06.564	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:50:06.563	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:50:06.560	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:50:05.561	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2023-01-16 20:50:05.560	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:50:05.552	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:50:00.582	error	Wrong CRC for frame: 2,3,2,0,2,3,86
                    modbus.0
                    	2023-01-16 20:50:00.552	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:50:00.550	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:50:00.434	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:50:00.434	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:50:00.434	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:50:00.428	debug	connect to serial /dev/ttyUSB0 with 9600
                    javascript.0
                    	2023-01-16 20:50:00.014	info	script.js.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                    modbus.0
                    	2023-01-16 20:49:00.430	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:49:00.429	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:49:00.426	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:48:59.433	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2023-01-16 20:48:59.426	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:48:59.425	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:48:54.423	debug	[DevID_2/holdingRegs] Poll address 1412 - 6 registers
                    modbus.0
                    	2023-01-16 20:48:54.419	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                    modbus.0
                    	2023-01-16 20:48:54.293	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:48:54.291	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:48:54.258	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:48:54.257	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:48:54.256	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:48:54.248	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:47:54.251	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:47:54.249	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:47:54.246	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:47:53.245	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2023-01-16 20:47:53.244	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:47:53.243	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:47:48.239	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:47:48.237	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:47:48.208	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:47:48.208	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:47:48.206	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:47:48.196	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2023-01-16 20:46:48.199	debug	Cleaning up request fifo.
                    modbus.0
                    	2023-01-16 20:46:48.198	debug	Clearing timeout of the current request.
                    modbus.0
                    	2023-01-16 20:46:48.193	info	Disconnected from slave
                    modbus.0
                    	2023-01-16 20:46:48.126	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:46:48.125	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:46:47.192	error	Request timed out.
                    modbus.0
                    	2023-01-16 20:46:47.190	warn	Error: undefined
                    modbus.0
                    	2023-01-16 20:46:47.071	warn	Poll error count: 1 code: "App Timeout"
                    modbus.0
                    	2023-01-16 20:46:42.188	debug	[DevID_2/holdingRegs] Poll address 1544 - 3 registers
                    modbus.0
                    	2023-01-16 20:46:42.186	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
                    modbus.0
                    	2023-01-16 20:46:42.157	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
                    modbus.0
                    	2023-01-16 20:46:42.154	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                    modbus.0
                    	2023-01-16 20:46:42.111	debug	[DevID_2/holdingRegs] Poll address 1412 - 6 registers
                    modbus.0
                    	2023-01-16 20:46:42.107	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                    modbus.0
                    	2023-01-16 20:46:41.919	debug	[DevID_2/holdingRegs] Poll address 1157 - 43 registers
                    modbus.0
                    	2023-01-16 20:46:41.916	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                    modbus.0
                    	2023-01-16 20:46:41.871	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                    modbus.0
                    	2023-01-16 20:46:41.870	debug	Initialization of scale factors done!
                    modbus.0
                    	2023-01-16 20:46:41.869	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2023-01-16 20:46:41.867	info	Connected to slave
                    modbus.0
                    	2023-01-16 20:46:41.858	debug	connect to serial /dev/ttyUSB0 with 9600
                    • V
                      Mit nur einem Holding und abfrage alle 15sec läuft es.... ?! Woran liegt das ?
                      modbus.0
                      	2023-01-16 21:15:37.511	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                      modbus.0
                      	2023-01-16 21:15:37.465	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
                      modbus.0
                      	2023-01-16 21:15:37.463	debug	[DevID_2] Poll start ---------------------
                      modbus.0
                      	2023-01-16 21:15:21.961	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                      modbus.0
                      	2023-01-16 21:15:21.931	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
                      modbus.0
                      	2023-01-16 21:15:21.931	debug	[DevID_2] Poll start ---------------------
                      modbus.0
                      	2023-01-16 21:15:06.428	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                      modbus.0
                      	2023-01-16 21:15:06.385	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
                      modbus.0
                      	2023-01-16 21:15:06.382	debug	[DevID_2] Poll start ---------------------
                      modbus.0
                      	2023-01-16 21:14:50.878	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                      modbus.0
                      	2023-01-16 21:14:50.838	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
                      modbus.0
                      	2023-01-16 21:14:50.836	debug	[DevID_2] Poll start ---------------------
                      modbus.0
                      	2023-01-16 21:14:35.331	debug	[DevID_2/holdingRegs] Poll address 1157 DONE
                      modbus.0
                      	2023-01-16 21:14:35.236	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
                      modbus.0
                      	2023-01-16 21:14:35.236	debug	Initialization of scale factors done!
                      modbus.0
                      	2023-01-16 21:14:35.234	debug	[DevID_2] Poll start ---------------------
                      modbus.0
                      	2023-01-16 21:14:35.233	info	Connected to slave
                      modbus.0
                      	2023-01-16 21:14:35.218	debug	connect to serial /dev/ttyUSB0 with 9600
                      • wendy2702
                        @v8turbo Gab irgendwo einen anderen Thread wo die user die Register Abfrage Länge unter allgemein auf 1 für Float und Boolean gestellt haben bei einem ähnlichen Problem.
                        Probier das doch mal.
                        • V
                          @wendy2702 Hilft auch nicht. Hab jetzt diese Register...
                          _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
                          1668	PV_Generation_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          1672	Load_Consumption_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          1676	Energy_Purchase_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          1680	Energy_Selling_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          1684	Bat_Charge_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          1688	Bat_Discharge_Today		kWh	uint32be	2	0,01	0		state		true	false	false	false
                          Die liegen wohl alle auf 1668 (modbus.0
                          2023-01-17 10:19:05.533 debug [DevID_2/holdingRegs] Poll address 1668 - 22 registers), zumindest liest er die alle seit gestern Abend alle 15sec ohne Fehler. Sobald ich ein anderes hinzufüge geht es nicht mehr, ich denke auch es hat was mit dem Problem zutun was auch andere hatten...
                          Aber es muss doch jemand eine Lösung dafür haben ??
                          V Glasfaser wendy2702 3 Replies Last reply Reply Quote 0
                          • V
                            V8Turbo @V8Turbo last edited by V8Turbo
                            @v8turbo
                            admin.0
                            2023-01-17 10:19:58.552	info	<== Disconnect system.user.admin from ::ffff:192.168.178.203 modbus
                            admin.0
                            modbus.0
                            2023-01-17 10:19:52.410	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:19:52.288	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:19:52.286	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:19:36.780	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:19:36.704	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:19:36.703	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:19:21.199	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:19:21.122	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:19:21.121	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:19:05.618	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            modbus.0
                            2023-01-17 10:19:05.532	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:18:50.021	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:18:49.944	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:18:49.942	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:18:34.440	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:18:34.282	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:18:34.281	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:18:18.778	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:18:18.701	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:18:18.700	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:18:03.197	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:18:03.119	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:18:03.118	debug	[DevID_2] Poll start ---------------------
                            modbus.0
                            2023-01-17 10:17:47.684	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0"}]
                            modbus.0
                            2023-01-17 10:17:47.683	info	Check /dev/ttyUSB0 : true
                            modbus.0
                            2023-01-17 10:17:47.683	info	Check /dev/ttyAMA0 : true
                            modbus.0
                            2023-01-17 10:17:47.681	info	Verify [{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A10NB15S","pnpId":"usb-FTDI_FT232R_USB_UART_A10NB15S-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyAMA0"}]
                            modbus.0
                            2023-01-17 10:17:47.616	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
                            modbus.0
                            2023-01-17 10:17:47.541	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
                            modbus.0
                            2023-01-17 10:17:47.540	debug	[DevID_2] Poll start ---------------------
                            • Glasfaser
                              Glasfaser @V8Turbo last edited by
                              wendy2702 meint diesen Thread ... war erst die Tage :
                              https://forum.iobroker.net/post/928897
                              • V
                                V8Turbo @Glasfaser last edited by V8Turbo
                                @glasfaser Hmm habe ich gelesen die haben aber ein anderes Problem denke ich. Wenn ich bei mir 1 Eintrage kommen wieder poll errors. Ich versteh das auch nicht mit den Registern... ?! Eine Adresse ist nicht gleich 1 Register oder ?! Also manchmal.
                                [DevID_2/holdingRegs] Poll address 1157 - 1 registers <- Ist wohl nur 1 Register ?!
                                [DevID_2/holdingRegs] Poll address 1668 - 22 registers <- Sind 22 Register auf einer Adresse oder wie verstehe ich das ??
                                Also solange ich nur eine Adresse Abrufe läuft alles ohne Probleme. Bei 2 oder mehr oder auf unterschiedlichen Bit/Byte dann geht es nicht mehr.
                                Seite 9 stehen die ganzen Daten fürs RS485. Alles standard.
                                Remote Control Description for SOFARSOLAR Hybird Inverter HYD.pdf
                                • Glasfaser
                                  @v8turbo
                                  bin ich selber leider überfragt , was bei dir ist .
                                  bzw. bei ioBroker modbus ist das meistens so , das am ende der Register Adresse +1 / -1 ist .
                                  das heißt soll 1157 sein, ist aber 1156 bzw. 1158
                                  Kannst du nicht hiermit erstmal etwas auslesen !?
                                  https://forum.iobroker.net/post/749115
                                  • wendy2702
                                    Woher kommen den diese Register? Im PDF sind die nicht oder bin ich blind?
                                    Und Rolle ist ein Value, kein State.
                                    • V
                                      @wendy2702 Hm die sind aus dem PDF. Weiss nicht welches du angeschaut hast. Die stimmen aber, bekomme ja die Werte. Nur keine anderen... Ich hab jetzt einen USR-W610 TCP to RS485. Komme aber mit der Configuration des Geräts nicht klar. Was muss ich dort wie einstellen ? Weiß das jemand ?
                                      • wendy2702
                                        @v8turbo Ich meine das PDF das du hier https://forum.iobroker.net/post/930209 eingefügt hast.
                                        Viellicht hilft das: https://forum.iobroker.net/post/930680
                                        Oder wir hoffen das @klassisch hier mal rein schaut.
                                        • V
                                          @wendy2702 Habe mal Klassisch kontaktiert.
                                          @klassisch anbei die Config... Im NEtzwerk (per LAN) ist er. Erreichbar auch.
                                          working_mode.jpg ap_settings.jpg sta_settings.jpg applic_set_1.jpg applic_set_2.jpg
                                          wendy2702 K 2 Replies Last reply Reply Quote 0
                                          • wendy2702
                                            @v8turbo Ist das dieses Teil ?
                                            K V 2 Replies Last reply Reply Quote 0
                                            99
                                            17771
