    4. Einrichten Modbus Adapter / Solar X3 Gen4
    • ChrisNett
      ChrisNett @ChrisNett last edited by
      verbunden ist er wohl oder ?
      ChrisNett D O 3 Replies Last reply Reply Quote 0
      • ChrisNett
        Ich hab habe den RS485 + & - mal gemessen es kommen +/- 3,26V an auch die 13V und GND vom Solax kommen an.
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ich bekomme aktuell daten aus dem Adapter aber leider bricht er auch immer mal wieder ab, wenn ich zum beispiel ein Reg hinzugefügt habe...
          modbus.0	2022-05-02 10:30:47.427	debug	(68923) [DevID_1/holdingRegs] Poll address 180 DONE
          modbus.0	2022-05-02 10:30:47.413	debug	(68923) [DevID_1/holdingRegs] Poll address 180 - 3 registers
          modbus.0	2022-05-02 10:30:47.413	debug	(68923) [DevID_1/holdingRegs] Poll address 139 DONE
          modbus.0	2022-05-02 10:30:47.387	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30118_Solax_X3 Frequenz L3:{"val":50,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.adm
          modbus.0	2022-05-02 10:30:47.382	debug	(68923) [DevID_1/holdingRegs] Poll address 139 - 19 registers
          modbus.0	2022-05-02 10:30:47.381	debug	(68923) [DevID_1/holdingRegs] Poll address 31 DONE
          modbus.0	2022-05-02 10:30:47.363	debug	(68923) [DevID_1/holdingRegs] Poll address 31 - 7 registers
          modbus.0	2022-05-02 10:30:47.363	debug	(68923) [DevID_1/holdingRegs] Poll address 0 DONE
          modbus.0	2022-05-02 10:30:47.346	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30117_Solax_X3 Wirkleistung L3:{"val":257,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.use
          modbus.0	2022-05-02 10:30:47.346	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30116_Solax_X3 Strom L3:{"val":1.5,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin
          modbus.0	2022-05-02 10:30:47.346	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30115_Solax_X3 Spannung L3:{"val":242.1,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.
          modbus.0	2022-05-02 10:30:47.345	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30114_Solax_X3 Frequenz L2:{"val":50,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.adm
          modbus.0	2022-05-02 10:30:47.343	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30113_Solax_X3 Wirkleistung L2:{"val":236,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.use
          modbus.0	2022-05-02 10:30:47.343	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30112_Solax_X3 Strom L2:{"val":1.4,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin
          modbus.0	2022-05-02 10:30:47.342	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30111_Solax_X3 Spannung L2:{"val":239.6,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.
          modbus.0	2022-05-02 10:30:47.341	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30110_Solax_X3 Frequenz L1:{"val":50,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.ad
          modbus.0	2022-05-02 10:30:47.341	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30109_Solax_X3 Wirkleistung L1:{"val":256,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.use
          modbus.0	2022-05-02 10:30:47.340	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30108_Solax_X3 Strom L1:{"val":1.4,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin
          modbus.0	2022-05-02 10:30:47.339	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30107_Solax_X3 Spannung L1:{"val":240.5,"ack":true,"ts":1651480247338,"q":0,"from":"system.adapter.modbus.0","user":"system.user.
          modbus.0	2022-05-02 10:30:47.337	debug	(68923) [DevID_1/holdingRegs] Poll address 0 - 14 registers
          modbus.0	2022-05-02 10:30:47.337	debug	(68923) [DevID_1/inputRegs] Poll address 145 DONE
          modbus.0	2022-05-02 10:30:47.316	silly	(68923) States user redis pmessage modbus.0.*/modbus.0.inputRegisters.30071_SolaX_X3 Netzsensor Leistung 3~:{"val":244,"ack":true,"ts":1651480247315,"q":0,"from":"system.adapter.modbus.0","user":"sys
          modbus.0	2022-05-02 10:30:47.314	debug	(68923) [DevID_1/inputRegs] Poll address 145 - 11 registers
          modbus.0	2022-05-02 10:30:47.312	debug	(68923) [DevID_1/inputRegs] Poll address 106 DONE
          modbus.0	2022-05-02 10:30:47.289	debug	(68923) [DevID_1/inputRegs] Poll address 106 - 12 registers
          modbus.0	2022-05-02 10:30:47.288	debug	(68923) [DevID_1/inputRegs] Poll address 70 DONE
          er Aktualisiert die Daten in den Objekten nicht? ich sehe keinen fehler ihr?
            Dominic151617 @ChrisNett last edited by
            @christian-sandkaulen sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
            g hinzugefügt hab
            Auf doof: Wenn ich mich nicht irre, startet der Adapter neu, wenn Du ein Register hinzufügst. Das ist aber nicht die Unterbrechung, die Du meinst, oder?
            Fehler in dem Log sehe ich auch nicht. Hast Du mal versucht, die Daten über den HistoryAdapter oder so aufzuzeichen. Dann kann man später aus der Tabelle erkennen, ob sich was tut. Vielleicht ist es ja nur ein Dastellungsproblem des Browsers.
            • ChrisNett
              ChrisNett @Dominic151617 last edited by
              @dominic151617 sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
              g hinzugefügt hab
              Danke, ja er startet dann neu, aber danach kommen erstmal keine Daten zumindest sehe ich das im Browser nicht, aber gute zeit ich zeichne das mal auf!
                Ich bin kein Modbus Experte, aber wenn ich es richtig interpretiere, sind die "Input Register" Werte, die Du in das Gerät schreibst. Du möchtest aber Werte aus dem Wechselrichter lesen. Das müssten dann "Holding Register" sein.
                • Meister Mopper
                  Meister Mopper @Dominic151617 last edited by
                  @dominic151617
                  Nein, Input-Register = nur lesen, Holding-Register = lesen und schreiben.
                  Also ist input-register schon mal richtig. So lese ich z. B. einen Victronenergy Laderegler aus.
                  • O
                    OKTP @ChrisNett last edited by
                    @christian-sandkaulen konntest du das Problem lösen? Wenn nicht schick mal bitte ein Bild wie du das Register im Adapter eingerichtet hast.
                    McWoolf 1 Reply Last reply Reply Quote 0
                    • McWoolf
                      McWoolf @OKTP last edited by McWoolf
                      Hallo Leute!
                      Ich habe heute meinen USR-TCP232-304 bekommen um Ihn mit dem Solax Hybrit WR 4.G zu verbinden. Er ist soweit eingerichtet. Aber ich bekomme keine Daten aus dem WR raus, nicht mal eine Verbindung mit dem modbus-adapter bekomme ich hin. Schön langsam drehe ich hier durch. Vielleicht kann mir jemand auf die Sprünge helfen.
                      Vielen Dank im Voraus
                      • wendy2702
                        wendy2702 @McWoolf last edited by
                        @mcwoolf Ich kenne das USR Teil nicht aber Remote Port 8081 für Modbus kommt mir komisch vor.
                        Ich würde da auch eine 502 erwarten.
                        Hast du im Adapter schon Register eingetragen, ohne mindestens 1 Register funktioniert der nicht.
                        Glaube @klassisch kennt sich mit dem USR aus.
                        • McWoolf
                          McWoolf @wendy2702 last edited by
                          @wendy2702
                          Alles klar werde ich dann gleich mal versuchen. Der Port 8081 ist vom ioBroker. Dachte da müsste man den Port für die Gegenseite eintragen.
                          • wendy2702
                            @mcwoolf Port 8081 ist für den Admin, nicht für Modbus.
                            • McWoolf
                              @wendy2702 wenn ich aber einen anderen Port nehme, habe ich gar keine Kommunikation mehr.
                              • McWoolf
                                McWoolf @McWoolf last edited by
                                @mcwoolf sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
                                Mit dieser Einstellung zählt wenigstens der TX Count
                                • wendy2702
                                  wendy2702 @McWoolf last edited by wendy2702
                                  @mcwoolf Was ist mit den Adapter/Register einstellungen?
                                  Welches Device hat welche Adresse?
                                  Ws kommt im Debug log vom Adapter?
                                  • McWoolf
                                    @wendy2702
                                    Also:
                                    USR 192.168.1.246
                                    IOB 192.168.1.250
                                    WR 192.168.1.245 (Lan-Dongle)
                                    Device ID im SolaxWR habe ich mal auf 2 gestellt, zum testen
                                    • McWoolf
                                      @wendy2702
                                      Also:
                                      USR 192.168.1.246
                                      IOB 192.168.1.250
                                      2023-01-18 08:47:04.364 - info: shelly.0 (2744968) [MQTT] Device 192.168.30.41 (shellyht / shellyht-024F7E / SHHT-1#024F7E#1) connected! Polltime set to 5 sec.
                                      2023-01-18 08:47:10.460 - info: modbus.0 (2274495) Got terminate signal TERMINATE_YOURSELF
                                      2023-01-18 08:47:10.460 - info: modbus.0 (2274495) terminating
                                      2023-01-18 08:47:10.461 - info: modbus.0 (2274495) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-01-18 08:47:13.697 - debug: modbus.0 (2274856) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects client ready ... initialize now
                                      2023-01-18 08:47:13.718 - debug: modbus.0 (2274856) Objects create System PubSub Client
                                      2023-01-18 08:47:13.719 - debug: modbus.0 (2274856) Objects create User PubSub Client
                                      2023-01-18 08:47:13.746 - debug: modbus.0 (2274856) Objects client initialize lua scripts
                                      2023-01-18 08:47:13.747 - debug: modbus.0 (2274856) Objects connected to redis: 127.0.0.1:9001
                                      2023-01-18 08:47:13.807 - debug: modbus.0 (2274856) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create System PubSub Client
                                      2023-01-18 08:47:13.815 - debug: modbus.0 (2274856) States create User PubSub Client
                                      2023-01-18 08:47:13.872 - debug: modbus.0 (2274856) States connected to redis: 127.0.0.1:9000
                                      2023-01-18 08:47:13.926 - debug: modbus.0 (2274856) Plugin sentry Initialize Plugin (enabled=true)
                                      2023-01-18 08:47:13.996 - info: modbus.0 (2274856) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
                                      2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for disInputs: []
                                      2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for coils: []
                                      2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for inputRegs: []
                                      2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Initialize Objects for holdingRegs: [{"_address":0,"deviceId":2,"name":"Seriennummer","description":"","unit":"","type":"string","len":7,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":0,"id":"holdingRegisters.0_Seriennummer"}]
                                      2023-01-18 08:47:14.065 - debug: modbus.0 (2274856) Add holdingRegisters.0_Seriennummer: {"_id":"holdingRegisters.0_Seriennummer","type":"state","common":{"name":"","role":"level","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":0,"deviceId":2,"type":"string","len":7,"offset":0,"factor":1,"poll":true}}
                                      2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Socket Error
                                      2023-01-18 08:47:14.168 - error: modbus.0 (2274856) Client in error state.
                                      2023-01-18 08:47:14.168 - warn: modbus.0 (2274856) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.246","port":502}
                                      2023-01-18 08:47:14.168 - debug: modbus.0 (2274856) Socket closed with error
                                      2023-01-18 08:47:14.169 - debug: modbus.0 (2274856) Cleaning up request fifo.
                                      2023-01-18 08:47:15.169 - debug: modbus.0 (2274856) Closing client on purpose.
                                      • McWoolf
                                        @wendy2702
                                        Also:
                                        USR 192.168.1.246
                                        IOB 192.168.1.250
                                        Der zählt übrigens auch, wenn der modbus-Adapter aus ist.
                                        • wendy2702
                                          @mcwoolf
                                          Ich kenne den WR nicht aber wie sieht der Physikalische Aufbau aus?
                                          Das USR RS485 ist mit dem WR bereits verbunden denke ich.
                                          Wie lauten die Modbus einstellungen im WR? Baudrate, Parität, ID usw.
                                          Bitte Screenshot der Adapter Einstellungen und Register.
                                          • wendy2702
                                            Ja, weil er einfach nur RX/TX Pakete zählt.
                                            147
                                            13977
