    • DK43
      DK43 @simatec last edited by
      @simatec
      beim installieren
      $ iobroker url https://github.com/simatec/ioBroker.backitup.git --host iobroker-pi --debug
      install simatec/ioBroker.backitup#7449f768b8a58f5a996f2b504f07d9cff2cf61b6
      host.iobroker-pi Adapter "system.adapter.backitup.0" is stopped.
      npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
      up to date, audited 702 packages in 8s
      51 packages are looking for funding run `npm fund` for details
      upload [19] backitup.admin C:/Users/FujitsuSmartHome/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [12] backitup.admin C:/Users/FujitsuSmartHome/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [1] backitup.admin C:/Users/FujitsuSmartHome/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      host.iobroker-pi Adapter "system.adapter.backitup.0" is started
      Process exited with code 0
      und debug unmittelbar nach dem restore
      2023-01-18 10:03:51.477 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
      2023-01-18 10:03:52.001 - debug: backitup.0 (6468) telegram-instance:
      2023-01-18 10:03:54.155 - debug: backitup.0 (6468) Backup list be read ...
      2023-01-18 10:03:58.573 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
      2023-01-18 10:04:04.714 - info: host.iobroker-pi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-01-18 10:04:04.717 - info: host.iobroker-pi stopInstance system.adapter.backitup.0 send kill signal
      2023-01-18 10:04:04.716 - info: backitup.0 (6468) Got terminate signal TERMINATE_YOURSELF
      2023-01-18 10:04:04.717 - info: backitup.0 (6468) cleaned everything up...
      2023-01-18 10:04:04.718 - info: backitup.0 (6468) terminating
      2023-01-18 10:04:04.719 - debug: backitup.0 (6468) Plugin sentry destroyed
      2023-01-18 10:04:04.721 - info: backitup.0 (6468) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 10:04:05.273 - info: host.iobroker-pi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 10:04:07.749 - info: host.iobroker-pi instance system.adapter.backitup.0 started with pid 6824
      2023-01-18 10:04:08.937 - debug: backitup.0 (6824) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-01-18 10:04:08.963 - debug: backitup.0 (6824) Objects client ready ... initialize now
      2023-01-18 10:04:08.964 - debug: backitup.0 (6824) Objects create System PubSub Client
      2023-01-18 10:04:08.965 - debug: backitup.0 (6824) Objects create User PubSub Client
      2023-01-18 10:04:08.977 - debug: backitup.0 (6824) Objects client initialize lua scripts
      2023-01-18 10:04:08.983 - debug: backitup.0 (6824) Objects connected to redis: 127.0.0.1:9001
      2023-01-18 10:04:08.996 - debug: backitup.0 (6824) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-01-18 10:04:09.001 - debug: backitup.0 (6824) States create System PubSub Client
      2023-01-18 10:04:09.002 - debug: backitup.0 (6824) States create User PubSub Client
      2023-01-18 10:04:09.008 - debug: backitup.0 (6824) States connected to redis: 127.0.0.1:9000
      2023-01-18 10:04:09.025 - debug: backitup.0 (6824) Plugin sentry Initialize Plugin (enabled=true)
      2023-01-18 10:04:09.322 - info: backitup.0 (6824) starting. Version 2.5.10 (non-npm: simatec/ioBroker.backitup#7449f768b8a58f5a996f2b504f07d9cff2cf61b6) in C:/Users/FujitsuSmartHome/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.24
      2023-01-18 10:04:09.336 - debug: backitup.0 (6824) Backitup has recognized a win32 system
      2023-01-18 10:04:09.409 - info: backitup.0 (6824) [iobroker] backup was activated at 01:30 every 1 day(s)
      2023-01-18 10:04:09.469 - debug: backitup.0 (6824) [iobroker] 10 30 01 */1 * *
      2023-01-18 10:04:10.374 - error: backitup.0 (6824) Dropbox: "expired_access_token/..."
      2023-01-18 10:04:10.375 - error: backitup.0 (6824) Dropbox: "expired_access_token/..."
      2023-01-18 10:04:13.989 - debug: backitup.0 (6824) detect backup file 1 from googledrive: iobroker_2023_01_04-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.990 - debug: backitup.0 (6824) detect backup file 2 from googledrive: iobroker_2022_12_30-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.990 - debug: backitup.0 (6824) detect backup file 3 from googledrive: iobroker_2022_12_28-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.991 - debug: backitup.0 (6824) detect backup file 4 from googledrive: iobroker_2022_12_25-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.991 - debug: backitup.0 (6824) detect backup file 5 from googledrive: iobroker_2022_12_24-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.991 - debug: backitup.0 (6824) detect backup file 6 from googledrive: iobroker_2022_12_23-17_59_32_backupiobroker.tar.gz
      2023-01-18 10:04:13.991 - debug: backitup.0 (6824) detect backup file 7 from googledrive: iobroker_2022_12_23-17_54_33_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 8 from googledrive: iobroker_2022_12_23-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 9 from googledrive: iobroker_2022_12_21-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 10 from googledrive: iobroker_2022_12_20-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 11 from googledrive: iobroker_2022_12_19-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 12 from googledrive: iobroker_2022_12_18-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.992 - debug: backitup.0 (6824) detect backup file 13 from googledrive: iobroker_2022_12_17-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.993 - debug: backitup.0 (6824) detect backup file 14 from googledrive: iobroker_2022_12_13-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.993 - debug: backitup.0 (6824) detect backup file 15 from googledrive: iobroker_2022_12_12-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.993 - debug: backitup.0 (6824) detect backup file 16 from googledrive: iobroker_2022_12_08-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.993 - debug: backitup.0 (6824) detect backup file 17 from googledrive: iobroker_2022_12_07-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.993 - debug: backitup.0 (6824) detect backup file 18 from googledrive: iobroker_2022_12_03-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.994 - debug: backitup.0 (6824) detect backup file 19 from googledrive: iobroker_2022_12_02-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.994 - debug: backitup.0 (6824) detect backup file 20 from googledrive: iobroker_2022_12_01-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:13.995 - debug: backitup.0 (6824) detect last backup file: iobroker_2023_01_04-01_30_10_backupiobroker.tar.gz
      2023-01-18 10:04:15.253 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
      2023-01-18 10:04:15.806 - debug: backitup.0 (6824) telegram-instance:
      2023-01-18 10:04:17.463 - debug: backitup.0 (6824) Backup list be read ...
      2023-01-18 10:04:26.589 - debug: backitup.0 (6824) set chmod for "C:/Users/FujitsuSmartHome/backups" successfully
      2023-01-18 10:04:33.978 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
      2023-01-18 10:04:43.975 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:04:43.980 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:04:43.981 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:04:43.981 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:04:46.108 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      2023-01-18 10:04:48.452 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:04:48.457 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:04:48.457 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:04:48.458 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:04:50.598 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      2023-01-18 10:04:53.233 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:04:53.238 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:04:53.239 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:04:53.239 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:04:55.362 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      komischerweise wird mir noch die v2.5.10 angezeigt.
      simatec 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @DK43 last edited by
        @dk43 Kann es sein, dass dein altes System nicht up2date war?
        Zeige mal bitte die Ausgabe von iobroker status
        DK43 1 Reply Last reply Reply Quote 0
        • simatec
          @dk43 sagte in Test Adapter ioBroker.backitup v2.5.x:
          Warte mal noch kurz, der push läuft noch
          • DK43
            @simatec sagte in Test Adapter ioBroker.backitup v2.5.x:
            C:\Users\FujitsuSmartHome>iobroker status
            Objects type: jsonl
            States  type: jsonl
            auf dem raspi siehts genauso aus bis auf
            iobroker@iobroker-pi:~  $  iobroker status
            • simatec
              @dk43 Und was lief auf deinem alten System? auch die jsonl als Object und File DB?
              • DK43
                DK43 @simatec last edited by DK43
                @simatec
                Richtig. Also auf dem Raspi 3b+ mit 2GB RAM
                so siehts aus wenn ich mit der Wiederherstellung starte
                und bleibt auch so.
                2023-01-18 10:50:14.294 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
                2023-01-18 10:50:14.807 - debug: backitup.0 (5032) telegram-instance:
                2023-01-18 10:50:19.539 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
                2023-01-18 10:50:31.094 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
                2023-01-18 10:50:33.628 - debug: backitup.0 (5032) Backup list be read ...
                2023-01-18 10:50:39.519 - debug: backitup.0 (5032) set chmod for "C:/Users/FujitsuSmartHome/backups" successfully
                2023-01-18 10:50:46.897 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
                2023-01-18 10:50:56.674 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
                2023-01-18 10:50:56.678 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-01-18 10:50:56.678 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
                2023-01-18 10:50:56.679 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
                2023-01-18 10:50:58.799 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
                2023-01-18 10:51:01.115 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
                2023-01-18 10:51:01.119 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-01-18 10:51:01.119 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
                2023-01-18 10:51:01.120 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
                2023-01-18 10:51:03.236 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
                2023-01-18 10:51:05.766 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
                2023-01-18 10:51:05.771 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-01-18 10:51:05.771 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
                2023-01-18 10:51:05.772 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
                2023-01-18 10:51:07.903 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
                • simatec
                  @dk43 Dann installiere mal über Github, mache danach zur Sicherheit einen Upload und zeige mir danach mal den Inhalt von C:\iobroker\iobroker-data\backitup
                  • DK43
                    @simatec
                    • simatec
                      @dk43 Zeige mal den Inhalt von der external.bat und der stopIOB.bat
                      • DK43
                        @simatec
                        external.bat
                        cd "C:\Users\FujitsuSmartHome"
                        call iobroker stop
                        timeout /T 10
                        if exist "C:\Users\FujitsuSmartHome\iobroker-data\backitup\.redis.info" (
                        redis-server --service-stop
                        if exist "C:/Users/FujitsuSmartHome/iobroker-data/backitup/.redis.info" (
                        cd "C:\Users\FujitsuSmartHome\node_modules\iobroker.backitup\lib"
                        ) else (
                        cd "C:/Users/FujitsuSmartHome/iobroker-data/backitup"
                        node restore.js
                        stop.bat
                        start "" "C:\Users\FujitsuSmartHome\iobroker-data\backitup\external.bat"
                        • simatec
                          @dk43 Mache mein ein Doppelklick auf die stopIOB.bat und poste mal die Ausgabe
                          • DK43
                            @simatec
                            Running Admin shell
                            Invoking UAC for Privilege Escalation
                            Waiting for  0 seconds, press a key to continue ...
                            [DEBUG] [iobroker] Start ioBroker Restore ...
                            [ERROR] [iobroker] Stop iobroker first!
                            [DEBUG] [iobroker] ioBroker Restore completed successfully
                            [EXIT] 99
                            C:\Users\FujitsuSmartHome\iobroker-data\backitup>
                            • simatec
                              Hast du bei Aufruf gewartet oder oder den Timeout abgebrochen?
                              Da musst du beim Aufruf warten, damit sich iobroker erstmal beenden kann
                              • DK43
                                @simatec
                                Ich habe es so laufen lassen. Also keine Eingabe
                                • simatec
                                  simatec Developer Most Active @DK43 last edited by simatec
                                  @dk43
                                  Ändere mal bitte den Inhalt von der external.bat wie folgt ab und versuche es nochmal
                                  iobroker stop
                                  timeout /T 15
                                  ) else (
                                  cd "C:\Users\FujitsuSmartHome\iobroker-data\backitup"
                                  node restore.js
                                  • DK43
                                    @simatec
                                    hab den inhalt der external.bat geändert.
                                    Daraufhin in den Backitup adapter --> Wiederherstellen --> Sicherungsquelle lokal --> Sicherung abrufen und die Wiederherstellung gestartet.
                                    Es erscheint wieder "localhost refused to connect". ( bei chrome oder einem anderen Browser würde denke ich mal jetzt was anderes stehen).
                                    Habe dann direkt die stopIOB.bat gestartet und folgendes wurde geöffnet.
                                    Running Admin shell
                                    Mehr auch nicht.
                                    • simatec
                                      @dk43
                                      dann versuche nochmal bitte mit einem call vorm iobroker stop
                                      Sorry, hab kein Windows zum testen laufen und muss dich mal etwas ausnutzen 😊
                                      call iobroker stop
                                      timeout /T 15
                                      ) else (
                                      node restore.js
                                      • DK43
                                        @simatec
                                        Überhaupt kein Ding. Bin dir sehr dankbar dafür dass du dir die Zeit nimmst.
                                        Was kann ich unter call verstehen?
                                        • simatec
                                          @dk43 Du muss nur den Inhalt komplett in die external.bat packen
                                          call iobroker stop
                                          timeout /T 15
                                          ) else (
                                          node restore.js
                                          Da gibt es dann auch diese Zeile
                                          call iobroker stop
                                          • DK43
                                            @simatec
                                            Bin jetzt wieder wie vorhin vorgegangen
                                            Habe dann direkt die stopIOB.bat gestartet und folgendes wurde geöffnet (nach ablauf der 15 sek.)
                                            node:events:505
                                                  throw er; // Unhandled 'error' event
                                            Error: listen EADDRINUSE: address already in use :::8091
                                                at Server.setupListenHandle [as _listen2] (node:net:1372:16)
                                                at listenInCluster (node:net:1420:12)
                                                at Server.listen (node:net:1508:7)
                                                at restoreIF (C:\Users\FujitsuSmartHome\iobroker-data\backitup\restore.js:297:16)
                                                at Object.<anonymous> (C:\Users\FujitsuSmartHome\iobroker-data\backitup\restore.js:314:9)
                                                at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                                                at Module.load (node:internal/modules/cjs/loader:981:32)
                                                at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                            Emitted 'error' event on Server instance at:
                                                at emitErrorNT (node:net:1399:8)
                                                at processTicksAndRejections (node:internal/process/task_queues:83:21) {
                                              code: 'EADDRINUSE',
                                              errno: -4091,
                                              syscall: 'listen',
                                              address: '::',
                                              port: 8091
                                            1.0k
                                            170
                                            2780
                                            2376294
