    • DK43
      DK43 @simatec last edited by DK43
      @simatec
      Richtig. Also auf dem Raspi 3b+ mit 2GB RAM
      so siehts aus wenn ich mit der Wiederherstellung starte
      und bleibt auch so.
      2023-01-18 10:50:14.294 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
      2023-01-18 10:50:14.807 - debug: backitup.0 (5032) telegram-instance:
      2023-01-18 10:50:19.539 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
      2023-01-18 10:50:31.094 - info: admin.0 (4576) ==> Connected system.user.admin from ::1
      2023-01-18 10:50:33.628 - debug: backitup.0 (5032) Backup list be read ...
      2023-01-18 10:50:39.519 - debug: backitup.0 (5032) set chmod for "C:/Users/FujitsuSmartHome/backups" successfully
      2023-01-18 10:50:46.897 - info: admin.0 (4576) <== Disconnect system.user.admin from ::1
      2023-01-18 10:50:56.674 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:50:56.678 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:50:56.678 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:50:56.679 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:50:58.799 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      2023-01-18 10:51:01.115 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:51:01.119 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:51:01.119 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:51:01.120 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:51:03.236 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      2023-01-18 10:51:05.766 - info: host.iobroker-pi iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 10:51:05.771 - info: host.iobroker-pi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 10:51:05.771 - info: host.iobroker-pi hostname: iobroker-pi, node: v16.15.1
      2023-01-18 10:51:05.772 - info: host.iobroker-pi ip addresses: 2003:c9:1706:5500:d92d:a5dd:dbba:a5a4 2003:c9:1706:5500:a1ce:ec6f:1b0a:7bbd fe80::d92d:a5dd:dbba:a5a4 192.168.178.75
      2023-01-18 10:51:07.903 - error: host.iobroker-pi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "C:\Users\FujitsuSmartHome\iobroker-data\objects.jsonl"!
      • simatec
        simatec Developer Most Active @DK43 last edited by
        @dk43 Dann installiere mal über Github, mache danach zur Sicherheit einen Upload und zeige mir danach mal den Inhalt von C:\iobroker\iobroker-data\backitup
        DK43 1 Reply Last reply Reply Quote 0
        • DK43
          @simatec
          • simatec
            @dk43 Zeige mal den Inhalt von der external.bat und der stopIOB.bat
            • DK43
              @simatec
              external.bat
              cd "C:\Users\FujitsuSmartHome"
              call iobroker stop
              timeout /T 10
              if exist "C:\Users\FujitsuSmartHome\iobroker-data\backitup\.redis.info" (
              redis-server --service-stop
              if exist "C:/Users/FujitsuSmartHome/iobroker-data/backitup/.redis.info" (
              cd "C:\Users\FujitsuSmartHome\node_modules\iobroker.backitup\lib"
              ) else (
              cd "C:/Users/FujitsuSmartHome/iobroker-data/backitup"
              node restore.js
              stop.bat
              start "" "C:\Users\FujitsuSmartHome\iobroker-data\backitup\external.bat"
              • simatec
                @dk43 Mache mein ein Doppelklick auf die stopIOB.bat und poste mal die Ausgabe
                • DK43
                  @simatec
                  Running Admin shell
                  Invoking UAC for Privilege Escalation
                  Waiting for  0 seconds, press a key to continue ...
                  [DEBUG] [iobroker] Start ioBroker Restore ...
                  [ERROR] [iobroker] Stop iobroker first!
                  [DEBUG] [iobroker] ioBroker Restore completed successfully
                  [EXIT] 99
                  C:\Users\FujitsuSmartHome\iobroker-data\backitup>
                  • simatec
                    @dk43 sagte in Test Adapter ioBroker.backitup v2.5.x:
                    Hast du bei Aufruf gewartet oder oder den Timeout abgebrochen?
                    Da musst du beim Aufruf warten, damit sich iobroker erstmal beenden kann
                    • DK43
                      @simatec
                      Ich habe es so laufen lassen. Also keine Eingabe
                      • simatec
                        simatec Developer Most Active @DK43 last edited by simatec
                        @dk43
                        Ändere mal bitte den Inhalt von der external.bat wie folgt ab und versuche es nochmal
                        iobroker stop
                        timeout /T 15
                        ) else (
                        cd "C:\Users\FujitsuSmartHome\iobroker-data\backitup"
                        node restore.js
                        • DK43
                          @simatec
                          hab den inhalt der external.bat geändert.
                          Daraufhin in den Backitup adapter --> Wiederherstellen --> Sicherungsquelle lokal --> Sicherung abrufen und die Wiederherstellung gestartet.
                          Es erscheint wieder "localhost refused to connect". ( bei chrome oder einem anderen Browser würde denke ich mal jetzt was anderes stehen).
                          Habe dann direkt die stopIOB.bat gestartet und folgendes wurde geöffnet.
                          Running Admin shell
                          C:\Users\FujitsuSmartHome>
                          Mehr auch nicht.
                          • simatec
                            @dk43
                            dann versuche nochmal bitte mit einem call vorm iobroker stop
                            Sorry, hab kein Windows zum testen laufen und muss dich mal etwas ausnutzen 😊
                            call iobroker stop
                            timeout /T 15
                            ) else (
                            node restore.js
                            • DK43
                              @simatec
                              Überhaupt kein Ding. Bin dir sehr dankbar dafür dass du dir die Zeit nimmst.
                              Was kann ich unter call verstehen?
                              • simatec
                                @dk43 Du muss nur den Inhalt komplett in die external.bat packen
                                call iobroker stop
                                timeout /T 15
                                ) else (
                                node restore.js
                                Da gibt es dann auch diese Zeile
                                call iobroker stop
                                • DK43
                                  @simatec
                                  Bin jetzt wieder wie vorhin vorgegangen
                                  Habe dann direkt die stopIOB.bat gestartet und folgendes wurde geöffnet (nach ablauf der 15 sek.)
                                  node:events:505
                                        throw er; // Unhandled 'error' event
                                  Error: listen EADDRINUSE: address already in use :::8091
                                      at Server.setupListenHandle [as _listen2] (node:net:1372:16)
                                      at listenInCluster (node:net:1420:12)
                                      at Server.listen (node:net:1508:7)
                                      at restoreIF (C:\Users\FujitsuSmartHome\iobroker-data\backitup\restore.js:297:16)
                                      at Object.<anonymous> (C:\Users\FujitsuSmartHome\iobroker-data\backitup\restore.js:314:9)
                                      at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                                      at Module.load (node:internal/modules/cjs/loader:981:32)
                                      at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                  Emitted 'error' event on Server instance at:
                                      at emitErrorNT (node:net:1399:8)
                                      at processTicksAndRejections (node:internal/process/task_queues:83:21) {
                                    code: 'EADDRINUSE',
                                    errno: -4091,
                                    syscall: 'listen',
                                    address: '::',
                                    port: 8091
                                  • simatec
                                    @dk43 sieht schonmal besser aus.
                                    Ist dein Admin über den Port 8091 erreichbar? Oder hast du einen anderen Dienst laufen, der den Port nutzt?
                                    Falls nicht, starte mal den Rechner neu und füge im Anschluss den Inhalt erneut in die external.bat ein.
                                    Backitup erstellt die beim Neustart wieder und deine Änderungen sind weg
                                    • DK43
                                      @simatec
                                      Admin ist bei mir ganz normal über den Port 8081 zu erreichen. Weiß jetzt nicht wo 8091 herkommt.
                                      Hab nun den Rechner neugestartet. Den Inhalt von external.bat geändert.
                                      Dann Sicherung abgerufen und gestartet.
                                      Diesmal war der Admin Ladebalken ständig zu sehen.
                                      Hab dann stopIOB.bat gestartet und das kam nach ablauf der 15 sek. raus:
                                      Running Admin shell
                                      node:events:505
                                        code: 'EADDRINUSE',
                                        errno: -4091,
                                        syscall: 'listen',
                                        address: '::',
                                        port: 8091
                                      • simatec
                                        @dk43 OK das sieht erstmal garnicht so schlecht aus.
                                        Starte mal den Restore und ignoriere erstmal den Fehler im Browser.
                                        Warte mal 15-20 Minuten und starte falls es nicht von alleine passiert, den iobroker neu
                                        • DK43
                                          @simatec
                                          Tatsächlich ist jetzt alles vom alten System da.
                                          Würde mich schon interessieren woran es jetzt lag.
                                          Vielen Dank für deine Arbeit 👍
                                          • simatec
                                            @dk43 ist der iobroker alleine gestartet oder musstest du händisch starten?
                                            170
                                            2779
                                            2306356
