    3. Off Topic
    4. Proxmox
    5. Proxmox VM friert ein
    • 9
      900icarD @Glasfaser last edited by
      @glasfaser
      ok, here we go. Gehen nur 100.000 Zeichen.
      Wie gesagt, einige Adapter sind noch nicht fertig konfiguriert.
      2023-01-18 08:00:00.033 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13044
      2023-01-18 08:00:01.413 - info: sbfspot.0 (13044) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 08:00:01.543 - info: sbfspot.0 (13044) start with mySQL
      2023-01-18 08:00:01.590 - info: sbfspot.0 (13044) got data from with ID 0
      2023-01-18 08:00:02.250 - info: sbfspot.0 (13044) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 08:00:02.771 - info: sbfspot.0 (13044) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 08:00:03.224 - info: sbfspot.0 (13044) all done ...
      2023-01-18 08:00:03.225 - info: sbfspot.0 (13044) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 08:00:03.741 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 08:07:03.460 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:07:06.719 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:07:08.737 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:00.590 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:02.603 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:05.119 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:18.130 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:22.100 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:10:24.108 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:15:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13064
      2023-01-18 08:15:01.474 - info: sbfspot.0 (13064) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 08:15:01.618 - info: sbfspot.0 (13064) start with mySQL
      2023-01-18 08:15:01.665 - info: sbfspot.0 (13064) got data from with ID 0
      2023-01-18 08:15:01.948 - info: sbfspot.0 (13064) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 08:15:02.280 - info: sbfspot.0 (13064) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 08:15:02.565 - info: sbfspot.0 (13064) all done ...
      2023-01-18 08:15:02.567 - info: sbfspot.0 (13064) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 08:15:03.103 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 08:30:00.038 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13087
      2023-01-18 08:30:01.459 - info: sbfspot.0 (13087) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 08:30:01.595 - info: sbfspot.0 (13087) start with mySQL
      2023-01-18 08:30:01.634 - info: sbfspot.0 (13087) got data from with ID 0
      2023-01-18 08:30:02.040 - info: sbfspot.0 (13087) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 08:30:02.484 - info: sbfspot.0 (13087) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 08:30:02.786 - info: sbfspot.0 (13087) all done ...
      2023-01-18 08:30:02.788 - info: sbfspot.0 (13087) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 08:30:03.309 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 08:45:00.028 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13106
      2023-01-18 08:45:01.407 - info: sbfspot.0 (13106) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 08:45:01.565 - info: sbfspot.0 (13106) start with mySQL
      2023-01-18 08:45:01.614 - info: sbfspot.0 (13106) got data from with ID 0
      2023-01-18 08:45:01.922 - info: sbfspot.0 (13106) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 08:45:02.280 - info: sbfspot.0 (13106) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 08:45:02.615 - info: sbfspot.0 (13106) all done ...
      2023-01-18 08:45:02.617 - info: sbfspot.0 (13106) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 08:45:03.146 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 08:50:51.822 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:50:59.143 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 08:51:01.156 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 09:00:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13126
      2023-01-18 09:00:01.502 - info: sbfspot.0 (13126) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 09:00:01.642 - info: sbfspot.0 (13126) start with mySQL
      2023-01-18 09:00:01.691 - info: sbfspot.0 (13126) got data from with ID 0
      2023-01-18 09:00:02.019 - info: sbfspot.0 (13126) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 09:00:02.340 - info: sbfspot.0 (13126) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 09:00:02.664 - info: sbfspot.0 (13126) all done ...
      2023-01-18 09:00:02.665 - info: sbfspot.0 (13126) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 09:00:03.209 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 09:15:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13143
      2023-01-18 09:15:01.166 - info: sbfspot.0 (13143) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 09:15:01.277 - info: sbfspot.0 (13143) start with mySQL
      2023-01-18 09:15:01.313 - info: sbfspot.0 (13143) got data from with ID 0
      2023-01-18 09:15:01.551 - info: sbfspot.0 (13143) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 09:15:01.810 - info: sbfspot.0 (13143) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 09:15:02.057 - info: sbfspot.0 (13143) all done ...
      2023-01-18 09:15:02.058 - info: sbfspot.0 (13143) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 09:15:02.578 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 09:17:56.764 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 09:17:56.814 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
      2023-01-18 09:17:56.815 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
      2023-01-18 09:17:56.900 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
      2023-01-18 09:17:56.900 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
      2023-01-18 09:17:56.944 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
      2023-01-18 09:17:56.990 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
      2023-01-18 09:17:56.991 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
      2023-01-18 09:17:57.036 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
      2023-01-18 09:17:57.037 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
      2023-01-18 09:17:57.080 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
      2023-01-18 09:17:59.263 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 09:17:59.310 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
      2023-01-18 09:17:59.311 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
      2023-01-18 09:17:59.395 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
      2023-01-18 09:17:59.396 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
      2023-01-18 09:17:59.440 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
      2023-01-18 09:17:59.486 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
      2023-01-18 09:17:59.487 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
      2023-01-18 09:17:59.490 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
      2023-01-18 09:17:59.532 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
      2023-01-18 09:17:59.533 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
      2023-01-18 09:30:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13167
      2023-01-18 09:30:01.093 - info: sbfspot.0 (13167) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 09:30:01.202 - info: sbfspot.0 (13167) start with mySQL
      2023-01-18 09:30:01.246 - info: sbfspot.0 (13167) got data from with ID 0
      2023-01-18 09:30:01.503 - info: sbfspot.0 (13167) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 09:30:01.768 - info: sbfspot.0 (13167) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 09:30:02.018 - info: sbfspot.0 (13167) all done ...
      2023-01-18 09:30:02.019 - info: sbfspot.0 (13167) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 09:30:02.537 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 09:45:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13185
      2023-01-18 09:45:01.079 - info: sbfspot.0 (13185) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 09:45:01.204 - info: sbfspot.0 (13185) start with mySQL
      2023-01-18 09:45:01.260 - info: sbfspot.0 (13185) got data from with ID 0
      2023-01-18 09:45:01.526 - info: sbfspot.0 (13185) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 09:45:01.788 - info: sbfspot.0 (13185) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 09:45:02.051 - info: sbfspot.0 (13185) all done ...
      2023-01-18 09:45:02.052 - info: sbfspot.0 (13185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 09:45:02.571 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 10:00:00.045 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13204
      2023-01-18 10:00:01.194 - info: sbfspot.0 (13204) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 10:00:01.302 - info: sbfspot.0 (13204) start with mySQL
      2023-01-18 10:00:01.334 - info: sbfspot.0 (13204) got data from with ID 0
      2023-01-18 10:00:01.567 - info: sbfspot.0 (13204) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 10:00:01.798 - info: sbfspot.0 (13204) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 10:00:02.059 - info: sbfspot.0 (13204) all done ...
      2023-01-18 10:00:02.060 - info: sbfspot.0 (13204) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 10:00:02.579 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 10:15:00.022 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13222
      2023-01-18 10:15:01.121 - info: sbfspot.0 (13222) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 10:15:01.265 - info: sbfspot.0 (13222) start with mySQL
      2023-01-18 10:15:01.313 - info: sbfspot.0 (13222) got data from with ID 0
      2023-01-18 10:15:01.547 - info: sbfspot.0 (13222) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 10:15:01.765 - info: sbfspot.0 (13222) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 10:15:01.982 - info: sbfspot.0 (13222) all done ...
      2023-01-18 10:15:01.984 - info: sbfspot.0 (13222) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 10:15:02.505 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 10:30:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13247
      2023-01-18 10:30:01.154 - info: sbfspot.0 (13247) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 10:30:01.266 - info: sbfspot.0 (13247) start with mySQL
      2023-01-18 10:30:01.310 - info: sbfspot.0 (13247) got data from with ID 0
      2023-01-18 10:30:01.567 - info: sbfspot.0 (13247) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 10:30:01.815 - info: sbfspot.0 (13247) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 10:30:02.061 - info: sbfspot.0 (13247) all done ...
      2023-01-18 10:30:02.062 - info: sbfspot.0 (13247) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 10:30:02.586 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 10:45:00.019 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13266
      2023-01-18 10:45:01.085 - info: sbfspot.0 (13266) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 10:45:01.189 - info: sbfspot.0 (13266) start with mySQL
      2023-01-18 10:45:01.229 - info: sbfspot.0 (13266) got data from with ID 0
      2023-01-18 10:45:01.452 - info: sbfspot.0 (13266) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 10:45:01.685 - info: sbfspot.0 (13266) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 10:45:01.932 - info: sbfspot.0 (13266) all done ...
      2023-01-18 10:45:01.933 - info: sbfspot.0 (13266) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 10:45:02.453 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 11:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13285
      2023-01-18 11:00:01.187 - info: sbfspot.0 (13285) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 11:00:01.291 - info: sbfspot.0 (13285) start with mySQL
      2023-01-18 11:00:01.329 - info: sbfspot.0 (13285) got data from with ID 0
      2023-01-18 11:00:01.571 - info: sbfspot.0 (13285) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 11:00:01.819 - info: sbfspot.0 (13285) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 11:00:02.038 - info: sbfspot.0 (13285) all done ...
      2023-01-18 11:00:02.039 - info: sbfspot.0 (13285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 11:00:02.561 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 11:15:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13303
      2023-01-18 11:15:01.087 - info: sbfspot.0 (13303) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 11:15:01.193 - info: sbfspot.0 (13303) start with mySQL
      2023-01-18 11:15:01.229 - info: sbfspot.0 (13303) got data from with ID 0
      2023-01-18 11:15:01.487 - info: sbfspot.0 (13303) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 11:15:01.738 - info: sbfspot.0 (13303) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 11:15:01.971 - info: sbfspot.0 (13303) all done ...
      2023-01-18 11:15:01.972 - info: sbfspot.0 (13303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 11:15:02.491 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 11:30:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13326
      2023-01-18 11:30:01.209 - info: sbfspot.0 (13326) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 11:30:01.318 - info: sbfspot.0 (13326) start with mySQL
      2023-01-18 11:30:01.350 - info: sbfspot.0 (13326) got data from with ID 0
      2023-01-18 11:30:01.587 - info: sbfspot.0 (13326) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 11:30:01.831 - info: sbfspot.0 (13326) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 11:30:02.044 - info: sbfspot.0 (13326) all done ...
      2023-01-18 11:30:02.045 - info: sbfspot.0 (13326) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 11:30:02.565 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 11:45:00.022 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13345
      2023-01-18 11:45:01.140 - info: sbfspot.0 (13345) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 11:45:01.242 - info: sbfspot.0 (13345) start with mySQL
      2023-01-18 11:45:01.284 - info: sbfspot.0 (13345) got data from with ID 0
      2023-01-18 11:45:01.500 - info: sbfspot.0 (13345) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 11:45:01.729 - info: sbfspot.0 (13345) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 11:45:01.985 - info: sbfspot.0 (13345) all done ...
      2023-01-18 11:45:01.986 - info: sbfspot.0 (13345) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 11:45:02.505 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 12:00:00.035 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13364
      2023-01-18 12:00:01.160 - info: sbfspot.0 (13364) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 12:00:01.269 - info: sbfspot.0 (13364) start with mySQL
      2023-01-18 12:00:01.303 - info: sbfspot.0 (13364) got data from with ID 0
      2023-01-18 12:00:01.559 - info: sbfspot.0 (13364) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 12:00:01.834 - info: sbfspot.0 (13364) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 12:00:02.076 - info: sbfspot.0 (13364) all done ...
      2023-01-18 12:00:02.077 - info: sbfspot.0 (13364) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 12:00:02.599 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 12:15:00.016 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13384
      2023-01-18 12:15:01.144 - info: sbfspot.0 (13384) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 12:15:01.255 - info: sbfspot.0 (13384) start with mySQL
      2023-01-18 12:15:01.289 - info: sbfspot.0 (13384) got data from with ID 0
      2023-01-18 12:15:01.519 - info: sbfspot.0 (13384) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 12:15:01.745 - info: sbfspot.0 (13384) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 12:15:01.968 - info: sbfspot.0 (13384) all done ...
      2023-01-18 12:15:01.969 - info: sbfspot.0 (13384) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 12:15:02.497 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 12:30:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13406
      2023-01-18 12:30:01.140 - info: sbfspot.0 (13406) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 12:30:01.244 - info: sbfspot.0 (13406) start with mySQL
      2023-01-18 12:30:01.287 - info: sbfspot.0 (13406) got data from with ID 0
      2023-01-18 12:30:01.506 - info: sbfspot.0 (13406) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 12:30:01.726 - info: sbfspot.0 (13406) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 12:30:01.961 - info: sbfspot.0 (13406) all done ...
      2023-01-18 12:30:01.962 - info: sbfspot.0 (13406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 12:30:02.482 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 12:45:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13425
      2023-01-18 12:45:01.148 - info: sbfspot.0 (13425) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 12:45:01.248 - info: sbfspot.0 (13425) start with mySQL
      2023-01-18 12:45:01.290 - info: sbfspot.0 (13425) got data from with ID 0
      2023-01-18 12:45:01.535 - info: sbfspot.0 (13425) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 12:45:01.787 - info: sbfspot.0 (13425) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 12:45:02.027 - info: sbfspot.0 (13425) all done ...
      2023-01-18 12:45:02.028 - info: sbfspot.0 (13425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 12:45:02.546 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 13:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13444
      2023-01-18 13:00:01.070 - info: sbfspot.0 (13444) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 13:00:01.177 - info: sbfspot.0 (13444) start with mySQL
      2023-01-18 13:00:01.209 - info: sbfspot.0 (13444) got data from with ID 0
      2023-01-18 13:00:01.445 - info: sbfspot.0 (13444) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 13:00:01.679 - info: sbfspot.0 (13444) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 13:00:01.945 - info: sbfspot.0 (13444) all done ...
      2023-01-18 13:00:01.946 - info: sbfspot.0 (13444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 13:00:02.465 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 13:09:09.145 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 13:09:09.196 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
      2023-01-18 13:09:09.197 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
      2023-01-18 13:09:09.285 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
      2023-01-18 13:09:09.286 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
      2023-01-18 13:09:09.330 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
      2023-01-18 13:09:09.379 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
      2023-01-18 13:09:09.380 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
      2023-01-18 13:09:09.424 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
      2023-01-18 13:09:09.427 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
      2023-01-18 13:09:09.429 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
      2023-01-18 13:15:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13462
      2023-01-18 13:15:01.146 - info: sbfspot.0 (13462) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 13:15:01.271 - info: sbfspot.0 (13462) start with mySQL
      2023-01-18 13:15:01.303 - info: sbfspot.0 (13462) got data from with ID 0
      2023-01-18 13:15:01.522 - info: sbfspot.0 (13462) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 13:15:01.762 - info: sbfspot.0 (13462) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 13:15:02.029 - info: sbfspot.0 (13462) all done ...
      2023-01-18 13:15:02.030 - info: sbfspot.0 (13462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 13:15:02.549 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 13:30:00.028 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13484
      2023-01-18 13:30:01.118 - info: sbfspot.0 (13484) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 13:30:01.237 - info: sbfspot.0 (13484) start with mySQL
      2023-01-18 13:30:01.280 - info: sbfspot.0 (13484) got data from with ID 0
      2023-01-18 13:30:01.560 - info: sbfspot.0 (13484) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 13:30:01.828 - info: sbfspot.0 (13484) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 13:30:02.062 - info: sbfspot.0 (13484) all done ...
      2023-01-18 13:30:02.063 - info: sbfspot.0 (13484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 13:30:02.580 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 13:45:00.025 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13503
      2023-01-18 13:45:01.094 - info: sbfspot.0 (13503) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 13:45:01.213 - info: sbfspot.0 (13503) start with mySQL
      2023-01-18 13:45:01.246 - info: sbfspot.0 (13503) got data from with ID 0
      2023-01-18 13:45:01.530 - info: sbfspot.0 (13503) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 13:45:01.810 - info: sbfspot.0 (13503) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 13:45:02.062 - info: sbfspot.0 (13503) all done ...
      2023-01-18 13:45:02.063 - info: sbfspot.0 (13503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 13:45:02.581 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 14:00:00.018 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13522
      2023-01-18 14:00:01.149 - info: sbfspot.0 (13522) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 14:00:01.261 - info: sbfspot.0 (13522) start with mySQL
      2023-01-18 14:00:01.296 - info: sbfspot.0 (13522) got data from with ID 0
      2023-01-18 14:00:01.544 - info: sbfspot.0 (13522) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 14:00:01.787 - info: sbfspot.0 (13522) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 14:00:02.050 - info: sbfspot.0 (13522) all done ...
      2023-01-18 14:00:02.051 - info: sbfspot.0 (13522) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 14:00:02.574 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 14:15:00.025 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13541
      2023-01-18 14:15:01.113 - info: sbfspot.0 (13541) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 14:15:01.216 - info: sbfspot.0 (13541) start with mySQL
      2023-01-18 14:15:01.254 - info: sbfspot.0 (13541) got data from with ID 0
      2023-01-18 14:15:01.493 - info: sbfspot.0 (13541) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 14:15:01.715 - info: sbfspot.0 (13541) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 14:15:01.976 - info: sbfspot.0 (13541) all done ...
      2023-01-18 14:15:01.977 - info: sbfspot.0 (13541) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 14:15:02.497 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 14:30:00.027 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13565
      2023-01-18 14:30:01.127 - info: sbfspot.0 (13565) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 14:30:01.231 - info: sbfspot.0 (13565) start with mySQL
      2023-01-18 14:30:01.271 - info: sbfspot.0 (13565) got data from with ID 0
      2023-01-18 14:30:01.550 - info: sbfspot.0 (13565) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 14:30:01.800 - info: sbfspot.0 (13565) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 14:30:02.037 - info: sbfspot.0 (13565) all done ...
      2023-01-18 14:30:02.038 - info: sbfspot.0 (13565) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 14:30:02.558 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 14:45:00.021 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13584
      2023-01-18 14:45:01.130 - info: sbfspot.0 (13584) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 14:45:01.233 - info: sbfspot.0 (13584) start with mySQL
      2023-01-18 14:45:01.273 - info: sbfspot.0 (13584) got data from with ID 0
      2023-01-18 14:45:01.491 - info: sbfspot.0 (13584) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 14:45:01.739 - info: sbfspot.0 (13584) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 14:45:01.965 - info: sbfspot.0 (13584) all done ...
      2023-01-18 14:45:01.966 - info: sbfspot.0 (13584) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 14:45:02.484 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 15:00:00.024 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13603
      2023-01-18 15:00:01.144 - info: sbfspot.0 (13603) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 15:00:01.249 - info: sbfspot.0 (13603) start with mySQL
      2023-01-18 15:00:01.283 - info: sbfspot.0 (13603) got data from with ID 0
      2023-01-18 15:00:01.554 - info: sbfspot.0 (13603) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 15:00:01.804 - info: sbfspot.0 (13603) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 15:00:02.025 - info: sbfspot.0 (13603) all done ...
      2023-01-18 15:00:02.026 - info: sbfspot.0 (13603) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 15:00:02.544 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 15:08:32.588 - warn: wled.0 (11253) State attribute definition missing for : liveseg with value : -1
      2023-01-18 15:08:32.634 - warn: wled.0 (11253) State attribute definition missing for : cpalcount with value : 0
      2023-01-18 15:08:32.635 - warn: wled.0 (11253) State attribute definition missing for : 0 with value : 0
      2023-01-18 15:08:32.717 - warn: wled.0 (11253) State attribute definition missing for : c1 with value : 128
      2023-01-18 15:08:32.719 - warn: wled.0 (11253) State attribute definition missing for : c2 with value : 128
      2023-01-18 15:08:32.764 - warn: wled.0 (11253) State attribute definition missing for : c3 with value : 16
      2023-01-18 15:08:32.810 - warn: wled.0 (11253) State attribute definition missing for : o1 with value : false
      2023-01-18 15:08:32.811 - warn: wled.0 (11253) State attribute definition missing for : o2 with value : false
      2023-01-18 15:08:32.856 - warn: wled.0 (11253) State attribute definition missing for : o3 with value : false
      2023-01-18 15:08:32.857 - warn: wled.0 (11253) State attribute definition missing for : si with value : 0
      2023-01-18 15:08:32.901 - warn: wled.0 (11253) State attribute definition missing for : m12 with value : 0
      2023-01-18 15:15:00.026 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13622
      2023-01-18 15:15:01.146 - info: sbfspot.0 (13622) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 15:15:01.254 - info: sbfspot.0 (13622) start with mySQL
      2023-01-18 15:15:01.295 - info: sbfspot.0 (13622) got data from with ID 0
      2023-01-18 15:15:01.581 - info: sbfspot.0 (13622) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 15:15:01.805 - info: sbfspot.0 (13622) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 15:15:02.024 - info: sbfspot.0 (13622) all done ...
      2023-01-18 15:15:02.025 - info: sbfspot.0 (13622) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 15:15:02.544 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 15:30:00.019 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13644
      2023-01-18 15:30:01.186 - info: sbfspot.0 (13644) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 15:30:01.302 - info: sbfspot.0 (13644) start with mySQL
      2023-01-18 15:30:01.350 - info: sbfspot.0 (13644) got data from with ID 0
      2023-01-18 15:30:01.589 - info: sbfspot.0 (13644) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 15:30:01.844 - info: sbfspot.0 (13644) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 15:30:02.095 - info: sbfspot.0 (13644) all done ...
      2023-01-18 15:30:02.096 - info: sbfspot.0 (13644) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 15:30:02.618 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 15:34:21.089 - warn: hmip.0 (7979) ws connection closed (0) - code: 1006 - reason:
      2023-01-18 15:34:31.156 - warn: hmip.0 (7979) ws connection error (0): Error: connect ECONNREFUSED 62.113.249.105:8888
      2023-01-18 15:34:31.156 - warn: hmip.0 (7979) ws connection closed (2) - code: 1006 - reason:
      2023-01-18 15:34:42.457 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:34:42.543 - warn: hmip.0 (7979) ws connection closed (3) - code: 1000 - reason:
      2023-01-18 15:34:53.807 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:34:53.830 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:35:05.089 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:35:05.114 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:35:16.482 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:35:16.519 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:35:27.845 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:35:27.886 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:35:39.393 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:35:39.507 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:35:50.413 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:35:50.449 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:01.347 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:01.383 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:12.284 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:12.310 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:23.160 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:23.194 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:34.012 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:34.041 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:44.803 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:44.824 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:36:55.562 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:36:55.615 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:06.260 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:06.290 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:16.847 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:16.921 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:27.525 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:27.553 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:38.103 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:38.127 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:48.683 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:48.717 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:37:59.111 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:37:59.153 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:38:09.571 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:38:09.601 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:38:20.572 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:38:20.645 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:38:30.809 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:38:30.840 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:38:40.957 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:38:41.003 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:38:51.296 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:38:51.338 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:01.772 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:01.808 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:12.196 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:12.224 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:22.582 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:22.617 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:33.411 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:33.567 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:43.701 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:43.727 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:39:53.847 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:39:53.872 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:40:04.128 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:40:04.197 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:40:14.308 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:40:14.329 - warn: hmip.0 (7979) ws connection closed (1) - code: 1000 - reason:
      2023-01-18 15:40:24.462 - info: hmip.0 (7979) ws connection opened
      2023-01-18 15:45:00.029 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13663
      2023-01-18 15:45:01.177 - info: sbfspot.0 (13663) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 15:45:01.282 - info: sbfspot.0 (13663) start with mySQL
      2023-01-18 15:45:01.322 - info: sbfspot.0 (13663) got data from with ID 0
      2023-01-18 15:45:01.592 - info: sbfspot.0 (13663) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 15:45:01.870 - info: sbfspot.0 (13663) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 15:45:02.111 - info: sbfspot.0 (13663) all done ...
      2023-01-18 15:45:02.112 - info: sbfspot.0 (13663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 15:45:02.630 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 16:00:00.037 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13683
      2023-01-18 16:00:01.211 - info: sbfspot.0 (13683) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 16:00:01.356 - info: sbfspot.0 (13683) start with mySQL
      2023-01-18 16:00:01.398 - info: sbfspot.0 (13683) got data from with ID 0
      2023-01-18 16:00:01.638 - info: sbfspot.0 (13683) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 16:00:01.864 - info: sbfspot.0 (13683) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 16:00:02.091 - info: sbfspot.0 (13683) all done ...
      2023-01-18 16:00:02.092 - info: sbfspot.0 (13683) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 16:00:02.612 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 16:15:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13701
      2023-01-18 16:15:01.230 - info: sbfspot.0 (13701) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 16:15:01.339 - info: sbfspot.0 (13701) start with mySQL
      2023-01-18 16:15:01.372 - info: sbfspot.0 (13701) got data from with ID 0
      2023-01-18 16:15:01.620 - info: sbfspot.0 (13701) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 16:15:01.851 - info: sbfspot.0 (13701) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 16:15:02.081 - info: sbfspot.0 (13701) all done ...
      2023-01-18 16:15:02.082 - info: sbfspot.0 (13701) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 16:15:02.603 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 16:30:00.026 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13724
      2023-01-18 16:30:01.197 - info: sbfspot.0 (13724) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 16:30:01.306 - info: sbfspot.0 (13724) start with mySQL
      2023-01-18 16:30:01.342 - info: sbfspot.0 (13724) got data from with ID 0
      2023-01-18 16:30:01.603 - info: sbfspot.0 (13724) got data from SB 4000TL-20 with ID 2100101691
      2023-01-18 16:30:01.883 - info: sbfspot.0 (13724) got data from SB 4000TL-20 with ID 2100111075
      2023-01-18 16:30:02.122 - info: sbfspot.0 (13724) all done ...
      2023-01-18 16:30:02.124 - info: sbfspot.0 (13724) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 16:30:02.647 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 16:45:00.023 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13742
      2023-01-18 16:45:01.138 - info: sbfspot.0 (13742) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 16:45:01.174 - info: sbfspot.0 (13742) nothing to do, because no daylight ...
      2023-01-18 16:45:01.175 - info: sbfspot.0 (13742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 16:45:01.698 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 16:51:01.900 - info: admin.0 (484) Adapter rating updated
      2023-01-18 16:51:23.523 - info: admin.0 (484) Request actual repository...
      2023-01-18 16:51:23.721 - info: host.196-iobroker-vm-V2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-01-18 16:51:26.156 - info: admin.0 (484) Repository received successfully.
      2023-01-18 17:00:00.020 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13775
      2023-01-18 17:00:01.149 - info: sbfspot.0 (13775) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 17:00:01.189 - info: sbfspot.0 (13775) nothing to do, because no daylight ...
      2023-01-18 17:00:01.191 - info: sbfspot.0 (13775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 17:00:01.711 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 17:15:00.034 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 started with pid 13795
      2023-01-18 17:15:01.118 - info: sbfspot.0 (13795) starting. Version 4.1.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 17:15:01.156 - info: sbfspot.0 (13795) nothing to do, because no daylight ...
      2023-01-18 17:15:01.157 - info: sbfspot.0 (13795) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 17:15:01.677 - info: host.196-iobroker-vm-V2 instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 18:58:04.097 - info: host.196-iobroker-vm-V2 iobroker.js-controller version 4.0.24 js-controller starting
      2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 hostname: 196-iobroker-vm-V2, node: v16.19.0
      2023-01-18 18:58:04.101 - info: host.196-iobroker-vm-V2 ip addresses: 192.168.178.231 fe80::bcd2:16ff:fe39:8e82
      2023-01-18 18:58:04.728 - info: host.196-iobroker-vm-V2 connected to Objects and States
      2023-01-18 18:58:04.753 - info: host.196-iobroker-vm-V2 added notifications configuration of host
      2023-01-18 18:58:05.118 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeCurrent"
      2023-01-18 18:58:05.119 - info: host.196-iobroker-vm-V2 44 instances found
      2023-01-18 18:58:05.149 - info: host.196-iobroker-vm-V2 starting 39 instances
      2023-01-18 18:58:05.198 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeNewest"
      2023-01-18 18:58:05.250 - info: host.196-iobroker-vm-V2 instance system.adapter.admin.0 started with pid 445
      2023-01-18 18:58:05.258 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.nodeNewestNext"
      2023-01-18 18:58:05.307 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmCurrent"
      2023-01-18 18:58:05.357 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmNewest"
      2023-01-18 18:58:05.412 - info: host.196-iobroker-vm-V2 Delete state "system.host.196-iobroker-vm-V2.versions.npmNewestNext"
      2023-01-18 18:58:05.478 - info: host.196-iobroker-vm-V2 Some obsolete host states deleted.
      2023-01-18 18:58:07.415 - error: admin.0 (445) admin.0 already running
      2023-01-18 18:58:07.419 - warn: admin.0 (445) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:07.963 - error: host.196-iobroker-vm-V2 instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:07.964 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.admin.0 because enabled
      2023-01-18 18:58:09.187 - info: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 started with pid 456
      2023-01-18 18:58:10.347 - error: influxdb.0 (456) influxdb.0 already running
      2023-01-18 18:58:10.349 - warn: influxdb.0 (456) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:10.898 - error: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:10.898 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.influxdb.0 because enabled
      2023-01-18 18:58:13.268 - info: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 started with pid 467
      2023-01-18 18:58:16.316 - error: javascript.0 (467) javascript.0 already running
      2023-01-18 18:58:16.324 - warn: javascript.0 (467) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:16.897 - error: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:16.898 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.javascript.0 because enabled
      2023-01-18 18:58:17.196 - info: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 started with pid 478
      2023-01-18 18:58:18.689 - error: telegram.0 (478) telegram.0 already running
      2023-01-18 18:58:18.691 - warn: telegram.0 (478) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:19.225 - error: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:19.226 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.telegram.0 because enabled
      2023-01-18 18:58:20.254 - info: host.196-iobroker-vm-V2 instance system.adapter.telegram.0 started with pid 489
      2023-01-18 18:58:21.208 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 496
      2023-01-18 18:58:22.311 - info: telegram.0 (489) starting. Version 1.15.2 in /opt/iobroker/node_modules/iobroker.telegram, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:22.961 - error: alexa2.0 (496) alexa2.0 already running
      2023-01-18 18:58:22.964 - warn: alexa2.0 (496) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:23.514 - error: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:23.515 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.alexa2.0 because enabled
      2023-01-18 18:58:25.181 - info: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 started with pid 515
      2023-01-18 18:58:26.061 - error: hmip.0 (515) hmip.0 already running
      2023-01-18 18:58:26.063 - warn: hmip.0 (515) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:26.597 - error: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:26.597 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hmip.0 because enabled
      2023-01-18 18:58:29.183 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.0 started with pid 526
      2023-01-18 18:58:30.102 - error: hue.0 (526) hue.0 already running
      2023-01-18 18:58:30.104 - warn: hue.0 (526) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:30.643 - error: host.196-iobroker-vm-V2 instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:30.643 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hue.0 because enabled
      2023-01-18 18:58:33.181 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.1 started with pid 537
      2023-01-18 18:58:34.203 - error: hue.1 (537) hue.1 already running
      2023-01-18 18:58:34.205 - warn: hue.1 (537) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:34.758 - error: host.196-iobroker-vm-V2 instance system.adapter.hue.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:34.759 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.hue.1 because enabled
      2023-01-18 18:58:37.183 - info: host.196-iobroker-vm-V2 instance system.adapter.meross.0 started with pid 548
      2023-01-18 18:58:37.995 - info: host.196-iobroker-vm-V2 instance system.adapter.admin.0 started with pid 555
      2023-01-18 18:58:38.366 - error: meross.0 (548) meross.0 already running
      2023-01-18 18:58:38.368 - warn: meross.0 (548) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:38.902 - error: host.196-iobroker-vm-V2 instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:38.903 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.meross.0 because enabled
      2023-01-18 18:58:39.120 - info: admin.0 (555) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:39.142 - info: admin.0 (555) requesting all states
      2023-01-18 18:58:39.142 - info: admin.0 (555) requesting all objects
      2023-01-18 18:58:39.590 - info: admin.0 (555) received all objects
      2023-01-18 18:58:39.865 - info: admin.0 (555) Request actual repository...
      2023-01-18 18:58:39.883 - info: admin.0 (555) http server listening on port 8081
      2023-01-18 18:58:39.883 - info: admin.0 (555) Use link "http://localhost:8081" to configure.
      2023-01-18 18:58:39.889 - info: admin.0 (555) socket.io server listening on port 8081
      2023-01-18 18:58:40.076 - info: host.196-iobroker-vm-V2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-01-18 18:58:41.028 - info: host.196-iobroker-vm-V2 instance system.adapter.influxdb.0 started with pid 586
      2023-01-18 18:58:41.157 - info: admin.0 (555) Repository received successfully.
      2023-01-18 18:58:41.216 - info: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 started with pid 593
      2023-01-18 18:58:42.025 - error: mqtt.0 (593) mqtt.0 already running
      2023-01-18 18:58:42.027 - warn: mqtt.0 (593) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:42.260 - info: influxdb.0 (586) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:42.277 - info: influxdb.0 (586) No stored data from last exit found
      2023-01-18 18:58:42.278 - info: influxdb.0 (586) Connecting http://192.168.178.198:8086/ ...
      2023-01-18 18:58:42.278 - info: influxdb.0 (586) Influx DB Version used: 1.x
      2023-01-18 18:58:42.559 - error: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:42.559 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.mqtt.0 because enabled
      2023-01-18 18:58:45.182 - info: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 started with pid 612
      2023-01-18 18:58:46.194 - error: shelly.0 (612) shelly.0 already running
      2023-01-18 18:58:46.195 - warn: shelly.0 (612) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:46.728 - error: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:46.728 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.shelly.0 because enabled
      2023-01-18 18:58:46.929 - info: host.196-iobroker-vm-V2 instance system.adapter.javascript.0 started with pid 623
      2023-01-18 18:58:48.435 - info: javascript.0 (623) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:48.773 - info: javascript.0 (623) requesting all states
      2023-01-18 18:58:48.773 - info: javascript.0 (623) requesting all objects
      2023-01-18 18:58:49.152 - info: javascript.0 (623) received all objects
      2023-01-18 18:58:49.185 - info: javascript.0 (623) received all states
      2023-01-18 18:58:49.199 - info: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 started with pid 638
      2023-01-18 18:58:50.006 - error: sonoff.0 (638) sonoff.0 already running
      2023-01-18 18:58:50.008 - warn: sonoff.0 (638) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:50.544 - error: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:50.544 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.sonoff.0 because enabled
      2023-01-18 18:58:53.193 - info: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 started with pid 649
      2023-01-18 18:58:53.543 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 656
      2023-01-18 18:58:54.098 - error: sonos.0 (649) sonos.0 already running
      2023-01-18 18:58:54.099 - warn: sonos.0 (649) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:54.634 - error: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:54.634 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.sonos.0 because enabled
      2023-01-18 18:58:54.684 - info: alexa2.0 (656) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:54.714 - info: alexa2.0 (656) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      2023-01-18 18:58:56.653 - info: host.196-iobroker-vm-V2 instance system.adapter.hmip.0 started with pid 675
      2023-01-18 18:58:57.183 - info: host.196-iobroker-vm-V2 instance system.adapter.synology.0 started with pid 682
      2023-01-18 18:58:57.911 - info: hmip.0 (675) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:58:58.393 - error: synology.0 (682) synology.0 already running
      2023-01-18 18:58:58.395 - warn: synology.0 (682) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:58:58.414 - info: alexa2.0 (656) Update cookie in adapter configuration ... restarting ...
      2023-01-18 18:58:58.474 - info: host.196-iobroker-vm-V2 stopInstance system.adapter.alexa2.0 (force=false, process=true)
      2023-01-18 18:58:58.482 - info: alexa2.0 (656) Got terminate signal TERMINATE_YOURSELF
      2023-01-18 18:58:58.489 - info: alexa2.0 (656) terminating
      2023-01-18 18:58:58.490 - info: alexa2.0 (656) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-18 18:58:58.535 - info: host.196-iobroker-vm-V2 stopInstance system.adapter.alexa2.0 send kill signal
      2023-01-18 18:58:58.965 - error: host.196-iobroker-vm-V2 instance system.adapter.synology.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:58:58.965 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.synology.0 because enabled
      2023-01-18 18:58:59.046 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-18 18:59:00.683 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.0 started with pid 701
      2023-01-18 18:59:01.225 - info: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 started with pid 708
      2023-01-18 18:59:01.618 - info: host.196-iobroker-vm-V2 instance system.adapter.alexa2.0 started with pid 715
      2023-01-18 18:59:02.246 - info: hue.0 (701) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:03.036 - info: hue.0 (701) skip switch: Daylight.configured
      2023-01-18 18:59:03.037 - info: hue.0 (701) skip switch: Daylight.sunriseoffset
      2023-01-18 18:59:03.038 - info: hue.0 (701) skip switch: Daylight.sunsetoffset
      2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.alert
      2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.sensitivity
      2023-01-18 18:59:03.042 - info: hue.0 (701) skip switch: BWM Gartenhaus.sensitivitymax
      2023-01-18 18:59:03.043 - info: hue.0 (701) skip switch: BWM Gartenhaus.ledindication
      2023-01-18 18:59:03.043 - info: hue.0 (701) skip switch: BWM Gartenhaus.usertest
      2023-01-18 18:59:03.048 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.alert
      2023-01-18 18:59:03.049 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.tholddark
      2023-01-18 18:59:03.049 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.tholdoffset
      2023-01-18 18:59:03.050 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.ledindication
      2023-01-18 18:59:03.050 - info: hue.0 (701) skip switch: Hue outdoor light sensor 1.usertest
      2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.alert
      2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.ledindication
      2023-01-18 18:59:03.054 - info: hue.0 (701) skip switch: Hue outdoor temp. sensor 1.usertest
      2023-01-18 18:59:03.094 - info: hue.0 (701) created/updated 11 sensor channels
      2023-01-18 18:59:03.464 - info: alexa2.0 (715) starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:03.651 - info: hue.0 (701) created/updated 12 light channels
      2023-01-18 18:59:03.653 - info: alexa2.0 (715) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      2023-01-18 18:59:03.673 - warn: hue.0 (701) channel "Terrasse" already exists, using "Terrasse_Room" for group 4
      2023-01-18 18:59:03.682 - info: hue.0 (701) created/updated 8 groups channels
      2023-01-18 18:59:03.684 - info: hue.0 (701) created/updated 36 scenes
      2023-01-18 18:59:03.685 - info: hue.0 (701) creating/updating bridge device
      2023-01-18 18:59:03.796 - info: hmip.0 (675) ws connection opened
      2023-01-18 18:59:04.777 - error: zigbee.0 (708) zigbee.0 already running
      2023-01-18 18:59:04.779 - warn: zigbee.0 (708) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:04.825 - info: host.196-iobroker-vm-V2 instance system.adapter.hue.1 started with pid 742
      2023-01-18 18:59:05.190 - info: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 started with pid 749
      2023-01-18 18:59:05.336 - error: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:05.336 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.zigbee.0 because enabled
      2023-01-18 18:59:06.817 - error: discovery.0 (749) discovery.0 already running
      2023-01-18 18:59:06.818 - warn: discovery.0 (749) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:07.002 - info: hue.1 (742) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:07.348 - error: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:07.348 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.discovery.0 because enabled
      2023-01-18 18:59:07.658 - info: hmip.0 (675) hmip adapter connected and ready
      2023-01-18 18:59:07.809 - info: hue.1 (742) skip switch: Daylight.configured
      2023-01-18 18:59:07.809 - info: hue.1 (742) skip switch: Daylight.sunriseoffset
      2023-01-18 18:59:07.810 - info: hue.1 (742) skip switch: Daylight.sunsetoffset
      2023-01-18 18:59:07.811 - info: hue.1 (742) skip switch: BWM Hausflur oben.alert
      2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.sensitivity
      2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.sensitivitymax
      2023-01-18 18:59:07.812 - info: hue.1 (742) skip switch: BWM Hausflur oben.ledindication
      2023-01-18 18:59:07.813 - info: hue.1 (742) skip switch: BWM Hausflur oben.usertest
      2023-01-18 18:59:07.814 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.alert
      2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.tholddark
      2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.tholdoffset
      2023-01-18 18:59:07.815 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.ledindication
      2023-01-18 18:59:07.816 - info: hue.1 (742) skip switch: Hue ambient light sensor 1.usertest
      2023-01-18 18:59:07.817 - info: hue.1 (742) skip switch: Hue temperature sensor 1.alert
      2023-01-18 18:59:07.818 - info: hue.1 (742) skip switch: Hue temperature sensor 1.ledindication
      2023-01-18 18:59:07.818 - info: hue.1 (742) skip switch: Hue temperature sensor 1.usertest
      2023-01-18 18:59:07.819 - info: hue.1 (742) skip switch: BWM Hausflur unten.alert
      2023-01-18 18:59:07.819 - info: hue.1 (742) skip switch: BWM Hausflur unten.sensitivity
      2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.sensitivitymax
      2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.ledindication
      2023-01-18 18:59:07.820 - info: hue.1 (742) skip switch: BWM Hausflur unten.usertest
      2023-01-18 18:59:07.821 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.alert
      2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.tholddark
      2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.tholdoffset
      2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.ledindication
      2023-01-18 18:59:07.822 - info: hue.1 (742) skip switch: Hue ambient light sensor 2.usertest
      2023-01-18 18:59:07.823 - info: hue.1 (742) skip switch: Hue temperature sensor 2.alert
      2023-01-18 18:59:07.824 - info: hue.1 (742) skip switch: Hue temperature sensor 2.ledindication
      2023-01-18 18:59:07.824 - info: hue.1 (742) skip switch: Hue temperature sensor 2.usertest
      2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.alert
      2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.sensitivity
      2023-01-18 18:59:07.825 - info: hue.1 (742) skip switch: BWM Kellertreppe.sensitivitymax
      2023-01-18 18:59:07.826 - info: hue.1 (742) skip switch: BWM Kellertreppe.ledindication
      2023-01-18 18:59:07.826 - info: hue.1 (742) skip switch: BWM Kellertreppe.usertest
      2023-01-18 18:59:07.827 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.alert
      2023-01-18 18:59:07.827 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.tholddark
      2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.tholdoffset
      2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.ledindication
      2023-01-18 18:59:07.828 - info: hue.1 (742) skip switch: Hue ambient light sensor 3.usertest
      2023-01-18 18:59:07.829 - info: hue.1 (742) skip switch: Hue temperature sensor 3.alert
      2023-01-18 18:59:07.829 - info: hue.1 (742) skip switch: Hue temperature sensor 3.ledindication
      2023-01-18 18:59:07.830 - info: hue.1 (742) skip switch: Hue temperature sensor 3.usertest
      2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.alert
      2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.sensitivity
      2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.sensitivitymax
      2023-01-18 18:59:07.831 - info: hue.1 (742) skip switch: BWM Vorratskeller.ledindication
      2023-01-18 18:59:07.832 - info: hue.1 (742) skip switch: BWM Vorratskeller.usertest
      2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.alert
      2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.tholddark
      2023-01-18 18:59:07.833 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.tholdoffset
      2023-01-18 18:59:07.834 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.ledindication
      2023-01-18 18:59:07.834 - info: hue.1 (742) skip switch: Hue ambient light sensor 4.usertest
      2023-01-18 18:59:07.835 - info: hue.1 (742) skip switch: Hue temperature sensor 4.alert
      2023-01-18 18:59:07.836 - info: hue.1 (742) skip switch: Hue temperature sensor 4.ledindication
      2023-01-18 18:59:07.836 - info: hue.1 (742) skip switch: Hue temperature sensor 4.usertest
      2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.alert
      2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.sensitivity
      2023-01-18 18:59:07.837 - info: hue.1 (742) skip switch: BWM Waschkeller.sensitivitymax
      2023-01-18 18:59:07.838 - info: hue.1 (742) skip switch: BWM Waschkeller.ledindication
      2023-01-18 18:59:07.838 - info: hue.1 (742) skip switch: BWM Waschkeller.usertest
      2023-01-18 18:59:07.839 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.alert
      2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.tholddark
      2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.tholdoffset
      2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.ledindication
      2023-01-18 18:59:07.840 - info: hue.1 (742) skip switch: Hue ambient light sensor 5.usertest
      2023-01-18 18:59:07.844 - info: hue.1 (742) skip switch: Hue temperature sensor 5.alert
      2023-01-18 18:59:07.845 - info: hue.1 (742) skip switch: Hue temperature sensor 5.ledindication
      2023-01-18 18:59:07.845 - info: hue.1 (742) skip switch: Hue temperature sensor 5.usertest
      2023-01-18 18:59:07.846 - info: hue.1 (742) skip switch: BWM Haustür.alert
      2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.sensitivity
      2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.sensitivitymax
      2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.ledindication
      2023-01-18 18:59:07.847 - info: hue.1 (742) skip switch: BWM Haustür.usertest
      2023-01-18 18:59:07.848 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.alert
      2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.tholddark
      2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.tholdoffset
      2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.ledindication
      2023-01-18 18:59:07.849 - info: hue.1 (742) skip switch: Hue outdoor light sensor 1.usertest
      2023-01-18 18:59:07.850 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.alert
      2023-01-18 18:59:07.851 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.ledindication
      2023-01-18 18:59:07.851 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 1.usertest
      2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.alert
      2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.sensitivity
      2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.sensitivitymax
      2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.ledindication
      2023-01-18 18:59:07.852 - info: hue.1 (742) skip switch: BWM Gartentür.usertest
      2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.alert
      2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.tholddark
      2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.tholdoffset
      2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.ledindication
      2023-01-18 18:59:07.854 - info: hue.1 (742) skip switch: Hue outdoor light sensor 2.usertest
      2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.alert
      2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.ledindication
      2023-01-18 18:59:07.856 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 2.usertest
      2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.alert
      2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.sensitivity
      2023-01-18 18:59:07.858 - info: hue.1 (742) skip switch: BWM Flur EG.sensitivitymax
      2023-01-18 18:59:07.859 - info: hue.1 (742) skip switch: BWM Flur EG.ledindication
      2023-01-18 18:59:07.859 - info: hue.1 (742) skip switch: BWM Flur EG.usertest
      2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.alert
      2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.tholddark
      2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.tholdoffset
      2023-01-18 18:59:07.860 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.ledindication
      2023-01-18 18:59:07.861 - info: hue.1 (742) skip switch: Hue outdoor light sensor 3.usertest
      2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.alert
      2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.ledindication
      2023-01-18 18:59:07.862 - info: hue.1 (742) skip switch: Hue outdoor temp. sensor 3.usertest
      2023-01-18 18:59:07.862 - info: hue.1 (742) created/updated 25 sensor channels
      2023-01-18 18:59:08.082 - info: alexa2.0 (715) Initialize all Device states ...
      2023-01-18 18:59:08.212 - info: hue.1 (742) created/updated 9 light channels
      2023-01-18 18:59:08.215 - warn: hue.1 (742) channel "Kellergang" already exists, using "Kellergang_Room" for group 2
      2023-01-18 18:59:08.216 - warn: hue.1 (742) channel "Haustür" already exists, using "Haustür_Room" for group 3
      2023-01-18 18:59:08.217 - warn: hue.1 (742) channel "Garagentür" already exists, using "Garagentür_Room" for group 4
      2023-01-18 18:59:08.219 - warn: hue.1 (742) channel "Gartentür" already exists, using "Gartentür_Room" for group 5
      2023-01-18 18:59:08.224 - info: hue.1 (742) created/updated 9 groups channels
      2023-01-18 18:59:08.226 - info: hue.1 (742) created/updated 26 scenes
      2023-01-18 18:59:08.227 - info: hue.1 (742) creating/updating bridge device
      2023-01-18 18:59:08.930 - info: host.196-iobroker-vm-V2 instance system.adapter.meross.0 started with pid 768
      2023-01-18 18:59:09.203 - info: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 started with pid 775
      2023-01-18 18:59:11.437 - error: backitup.0 (775) backitup.0 already running
      2023-01-18 18:59:11.439 - warn: backitup.0 (775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:11.561 - info: meross.0 (768) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.meross, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:11.975 - error: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:11.976 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.backitup.0 because enabled
      2023-01-18 18:59:12.315 - info: meross.0 (768) Device 2106164874521890852648e1e97294bd initialized
      2023-01-18 18:59:12.563 - info: meross.0 (768) Device: 2106164874521890852648e1e97294bd connected
      2023-01-18 18:59:12.585 - info: host.196-iobroker-vm-V2 instance system.adapter.mqtt.0 started with pid 794
      2023-01-18 18:59:12.736 - info: meross.0 (768) Devices initialized
      2023-01-18 18:59:13.287 - info: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 started with pid 801
      2023-01-18 18:59:15.646 - info: mqtt.0 (794) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:15.984 - info: mqtt.0 (794) Starting MQTT server on 0.0.0.0:1884
      2023-01-18 18:59:16.219 - error: cloud.0 (801) cloud.0 already running
      2023-01-18 18:59:16.221 - warn: cloud.0 (801) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:16.768 - error: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:16.768 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.cloud.0 because enabled
      2023-01-18 18:59:16.825 - info: host.196-iobroker-vm-V2 instance system.adapter.shelly.0 started with pid 820
      2023-01-18 18:59:17.186 - info: host.196-iobroker-vm-V2 instance system.adapter.web.0 started with pid 827
      2023-01-18 18:59:18.576 - info: shelly.0 (820) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:18.681 - info: shelly.0 (820) Starting in MQTT mode. Listening on 0.0.0.0:1882
      2023-01-18 18:59:18.707 - error: web.0 (827) web.0 already running
      2023-01-18 18:59:18.709 - warn: web.0 (827) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:19.250 - error: host.196-iobroker-vm-V2 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:19.250 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.web.0 because enabled
      2023-01-18 18:59:20.568 - info: host.196-iobroker-vm-V2 instance system.adapter.sonoff.0 started with pid 846
      2023-01-18 18:59:21.196 - info: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 started with pid 853
      2023-01-18 18:59:21.724 - info: sonoff.0 (846) starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:21.759 - info: sonoff.0 (846) Starting MQTT authenticated server on port 1883
      2023-01-18 18:59:22.351 - error: go-e.0 (853) go-e.0 already running
      2023-01-18 18:59:22.353 - warn: go-e.0 (853) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:22.885 - error: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:22.886 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.go-e.0 because enabled
      2023-01-18 18:59:24.656 - info: host.196-iobroker-vm-V2 instance system.adapter.sonos.0 started with pid 872
      2023-01-18 18:59:25.191 - info: host.196-iobroker-vm-V2 instance system.adapter.info.0 started with pid 879
      2023-01-18 18:59:25.730 - info: sonos.0 (872) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.sonos, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:26.974 - error: info.0 (879) info.0 already running
      2023-01-18 18:59:26.978 - warn: info.0 (879) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:27.514 - error: host.196-iobroker-vm-V2 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:27.515 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.info.0 because enabled
      2023-01-18 18:59:28.990 - info: host.196-iobroker-vm-V2 instance system.adapter.synology.0 started with pid 910
      2023-01-18 18:59:29.191 - info: host.196-iobroker-vm-V2 instance system.adapter.logparser.0 started with pid 917
      2023-01-18 18:59:30.322 - error: logparser.0 (917) logparser.0 already running
      2023-01-18 18:59:30.324 - warn: logparser.0 (917) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:30.876 - error: host.196-iobroker-vm-V2 instance system.adapter.logparser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:30.877 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.logparser.0 because enabled
      2023-01-18 18:59:30.913 - info: synology.0 (910) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.synology, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:30.947 - info: synology.0 (910) Connecting to Synology 192.168.178.107:5001
      2023-01-18 18:59:33.540 - info: synology.0 (910) DSM 7
      2023-01-18 18:59:33.541 - info: synology.0 (910) DSM 7 detected, set all to true
      2023-01-18 18:59:33.986 - info: vis.0 (936) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:34.011 - error: vis.0 (936) No license found for vis. Please get one on https://iobroker.net !
      2023-01-18 18:59:35.328 - info: vis.0 (936) Terminated (NO_ERROR): Without reason
      2023-01-18 18:59:35.360 - info: host.196-iobroker-vm-V2 instance system.adapter.zigbee.0 started with pid 951
      2023-01-18 18:59:35.887 - info: host.196-iobroker-vm-V2 instance system.adapter.vis.0 terminated while should be started once
      2023-01-18 18:59:37.327 - info: host.196-iobroker-vm-V2 instance system.adapter.vis-inventwo.0 started with pid 962
      2023-01-18 18:59:37.426 - info: host.196-iobroker-vm-V2 instance system.adapter.discovery.0 started with pid 969
      2023-01-18 18:59:37.586 - info: zigbee.0 (951) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:37.902 - info: zigbee.0 (951) Starting Zigbee npm ...
      2023-01-18 18:59:39.290 - info: zigbee.0 (951) Installed Version: iobroker.zigbee@1.8.10
      2023-01-18 18:59:40.212 - error: vis-inventwo.0 (962) vis-inventwo.0 already running
      2023-01-18 18:59:40.214 - warn: vis-inventwo.0 (962) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:40.672 - info: discovery.0 (969) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:40.736 - info: zigbee.0 (951) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      2023-01-18 18:59:40.746 - info: zigbee.0 (951) Unable to disable LED, unsupported function.
      2023-01-18 18:59:40.757 - info: zigbee.0 (951) --> transmitPower : high+
      2023-01-18 18:59:40.775 - error: host.196-iobroker-vm-V2 instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:40.776 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.vis-inventwo.0 because enabled
      2023-01-18 18:59:40.776 - info: zigbee.0 (951) Currently no devices.
      2023-01-18 18:59:40.777 - info: zigbee.0 (951) Zigbee started
      2023-01-18 18:59:41.182 - info: host.196-iobroker-vm-V2 instance system.adapter.proxmox.0 started with pid 992
      2023-01-18 18:59:42.012 - info: host.196-iobroker-vm-V2 instance system.adapter.backitup.0 started with pid 999
      2023-01-18 18:59:42.283 - error: proxmox.0 (992) proxmox.0 already running
      2023-01-18 18:59:42.285 - warn: proxmox.0 (992) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:42.852 - error: host.196-iobroker-vm-V2 instance system.adapter.proxmox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:42.852 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.proxmox.0 because enabled
      2023-01-18 18:59:43.404 - info: backitup.0 (999) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:43.527 - info: backitup.0 (999) [iobroker] backup was activated at every 1 day(s)
      2023-01-18 18:59:45.188 - info: host.196-iobroker-vm-V2 instance scheduled system.adapter.sbfspot.0 */15 * * * *
      2023-01-18 18:59:46.794 - info: host.196-iobroker-vm-V2 instance system.adapter.cloud.0 started with pid 1018
      2023-01-18 18:59:47.813 - info: cloud.0 (1018) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:47.847 - info: cloud.0 (1018) Connecting with https://iobroker.pro:10555 with "@pro_draci009@gmail.com_646bef80-7f06-11ed-85c5-e76fc4fe39c4"
      2023-01-18 18:59:47.983 - info: cloud.0 (1018) Trying to connect as system.user.admin to cloud
      2023-01-18 18:59:48.608 - info: cloud.0 (1018) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
      2023-01-18 18:59:48.610 - info: cloud.0 (1018) Connection changed: disconnect
      2023-01-18 18:59:49.188 - info: host.196-iobroker-vm-V2 instance system.adapter.tankerkoenig.0 started with pid 1033
      2023-01-18 18:59:49.285 - info: host.196-iobroker-vm-V2 instance system.adapter.web.0 started with pid 1040
      2023-01-18 18:59:50.213 - error: tankerkoenig.0 (1033) tankerkoenig.0 already running
      2023-01-18 18:59:50.215 - warn: tankerkoenig.0 (1033) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:50.451 - info: web.0 (1040) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:50.635 - info: web.0 (1040) socket.io server listening on port 8082
      2023-01-18 18:59:50.637 - info: web.0 (1040) http server listening on port 8082
      2023-01-18 18:59:50.745 - error: host.196-iobroker-vm-V2 instance system.adapter.tankerkoenig.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:50.745 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.tankerkoenig.0 because enabled
      2023-01-18 18:59:52.909 - info: host.196-iobroker-vm-V2 instance system.adapter.go-e.0 started with pid 1059
      2023-01-18 18:59:53.188 - info: host.196-iobroker-vm-V2 instance system.adapter.wled.0 started with pid 1066
      2023-01-18 18:59:54.666 - error: wled.0 (1066) wled.0 already running
      2023-01-18 18:59:54.669 - warn: wled.0 (1066) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:55.117 - info: go-e.0 (1059) starting. Version 1.0.23 in /opt/iobroker/node_modules/iobroker.go-e, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:55.134 - info: go-e.0 (1059) Server: 192.168.178.206
      2023-01-18 18:59:55.135 - info: go-e.0 (1059) Intervall: 60
      2023-01-18 18:59:55.135 - warn: go-e.0 (1059) Sentry enabled. You can switch it off in settings of the adapter.
      2023-01-18 18:59:55.232 - error: host.196-iobroker-vm-V2 instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:55.232 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.wled.0 because enabled
      2023-01-18 18:59:57.170 - info: host.196-iobroker-vm-V2 instance system.adapter.yahka.0 started with pid 1085
      2023-01-18 18:59:57.551 - info: host.196-iobroker-vm-V2 instance system.adapter.info.0 started with pid 1092
      2023-01-18 18:59:58.580 - error: yahka.0 (1085) yahka.0 already running
      2023-01-18 18:59:58.582 - warn: yahka.0 (1085) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-01-18 18:59:59.127 - error: host.196-iobroker-vm-V2 instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-01-18 18:59:59.127 - info: host.196-iobroker-vm-V2 Restart adapter system.adapter.yahka.0 because enabled
      2023-01-18 18:59:59.739 - info: info.0 (1092) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
      2023-01-18 18:59:59.791 - info: info.0 (1092) Reading/updating systemdata.
      • Glasfaser
        Glasfaser @900icarD last edited by Glasfaser
        @900icard sagte in Proxmox VM friert ein:
        ab dieser Uhrzeit startet er neu ...
        aber da die Adapter schon gestartet sind kommt halt diese Meldung :
        Adapter .... already running
        Du hast relativ viele Fehlermeldungen / Meldungen im Bereich
        sbfspot.0
        hmip.0
        wled.0
        ich würde eher sagen dein Log quillt über ..
        Mehr kann ich gerade nicht erkennen ...
        9 1 Reply Last reply Reply Quote 0
        • 9
          900icarD @Homoran last edited by
          Also 16 GB RAM davon ca. 10 GB in use bei 5 VMs
          CPU Auslastung bei ca. 18% ebenfalls bei 5 VMs
          local 100GB und davon 9% in use
          local-lvm 360GB davon 40% in use
          Scheint mir auch nicht recht auffällig zu sein aber ich tendiere irgendwie in die Richtung bzgl. Fehler weil es ja Anfangs (fast) sauber lief und seit Weihnachten nicht mehr.
          Davor habe ich als letztes die 5te VM angelegt weil ich da mit PeerTube was testen will, aber noch nix gemacht.
          Die VM hab ich jetzt mal runtergefahren ... mal sehn was passiert.
          • Glasfaser
            Hab eine komplett neue VM aufgesetzt, (Debian 11 ohne Desktop) und ioBroker installiert, lief 3 Tage durch,
            also dann mit einem Backup ..
            aber warum danach daß !?
            dann hab ich gestern alle Adapter neu installiert
            • 9
              900icarD @Glasfaser last edited by
              @glasfaser
              Ja, sbfspot schaut aller 5 Min. nach neuen Daten und wled meckert (warn) schon länger wegen einem value -1 der nicht sein darf.
              Das ist aber nichts neues für mich, im Log.
              hmip konnte heute wohl mal keine Verbindung aufbauen, das ist in der tat neu.
              Ich werde mal, nur damit ich das ggf. ausschließen kann, diese drei Adapter deaktivieren und schauen was passiert.
              • Glasfaser
                Brauchst du diese Info´s im ioBrocker Log !?
                Wenn nicht , dann stelle die Logstufe bei der Instanz auf WARN.
                  Homoran Global Moderator Administrators @900icarD last edited by
                  @900icard was in use ist ist irrelevant!
                  wenn du z.B 128GB Plattenplatz hast, darfst du nicht jeder VM mit 42GB zuweisen.
                  Proxmox selber braucht auch noch etwas. Auch wenn die VMs ihren Platz nicht ausschöpfen!
                  • 9
                    @glasfaser
                    ich hab drei Sachen ausprobiert.
                    1. die komplette VM geklont, gleiches Problem.
                    2. Backup gemacht, ioB neu aufgesetzt und alles per BackItUp Adapter restored, gleiches Problem. (Davor war meine Vermutung der SourceAnalytics Adapter den ich nicht aus dem Stable hatte)
                    3. Neue VM aufgesetzt, blanko, ioB Blanko installiert und alle Adapter von Hand neu installiert und konfiguriert.
                      Heute wollte ich eigentlich weitermachen mit den Javascripten, dem Vis Projekt und der Userdata Objektstruktur aber soweit bin ich nicht gekommen da war er schon wieder abgeschmiert.
                    Also müsste es an einem der Adapter liegen oder generell an Proxmox oder der Hardware. Vielleicht läuft ja wirklich irgendwas voll aber es ist nichts zu erkennen, weder im ioB Log noch im Proxmox Log. Da es - scheinbar zumindest - mit der Grundinstallation des ioB (also nur Admin, Backitup und Discovery läuft) ist meine Vermutung, dass mit diesen drei Adaptern das "volllaufen" nur viel länger dauert und er erst nach 2-3 Wochen oder so abschmieren würde oder es liegt wirklich an einem der Adapter.
                    Mein letztes Problem war das Ding mit dem Netatmo Adapter der keine Live Events mehr aktualiseren konnte. Hab dann aber den cloud Adapter installiert, mir eine Lizenz gekauft und dann lief das wieder. Aber wenn ich sowohl nur den Cloud Adapter alleine oder nur den Netatmo Adapter alleine oder auch beide zusammen deaktiviere, schmiert er trotzdem ab.
                    Verzwickte Sache und Suche nach der Nadel im Heuhaufen grad ...
                    • 9
                      @glasfaser said in Proxmox VM friert ein:
                      Stimmt, brauch ich nicht, habs auf warn gestellt. Danke für den Tip, hab ich garnicht dran gedacht, dass man damit das Log etwas cleaner bekommt.
                      • Glasfaser
                        @900icard
                        ich würde erstmal das Log aufräumen ... das ist schon recht vollgemüllt.
                        Das heißt ...wie du schon selber schreibst einzelne Adapter dazu überprüfen ,
                        aber auch eventuell läuft ein JS Script Amok !?
                        • 9
                          @homoran said in Proxmox VM friert ein:
                          Ok, ja das stimmt.
                          Blöde Frage, in Proxmox steht 100GB bei local und 363GB bei local-lvm als verfügbarer Platz.
                          Müssen die VMs alle mit den 100GB auskommen?
                          Ich hatte jeder 32 GB zugewiesen und x4 ergibt 128GB und da wäre ich ja drüber ... Hmmm, .... das könnte dann in der Tat das Problem sein.
                          Ich hab ja nun die PeerTube VM heruntergefahren aber vermutlich muss ich die komplett killen um den Platz wieder frei zu bekommen.
                          Das werde ich als nächsten (aber erst morgen) mal ausprobieren.
                          Aber Danke schon mal für den Hinweis!
                          • 9
                            @900icard
                            Mach ich, gute Idee. Hat ich auch schon eher mal drauf kommen können. Danke
                            Ein Amok JS Script würde ich mal ausschließen weil ich den JS Adapter auch schon deaktiviert hatte und er trotzdem abgeschmiert ist.
                            Aber Danke Dir und @homoran schon mal für die Unterstützung hier, ich bin grad schon etwas optimistischer das Problem zu finden.
                            Morgen gehts weiter 🙂
                            • Glasfaser
                              es können aber trotzdem noch Zombie Prozesse laufen .
                              dann eher JS aus und Proxmox VM neu starten .
                                crunchip Forum Testing Most Active @900icarD last edited by
                                Deine 100gig ist dein Root Laufwerk
                                Dein lvm ist der Platz der zur Verfügung steht für einzelne Maschinen.
                                Wie ist denn deine Ram Verteilung?
                                • Dr. Bakterius
                                  Dr. Bakterius Most Active @900icarD last edited by
                                  ich werde mir eine AMD Kiste holen und dort Proxmox und die VMs neu aufsetzen.
                                  Funktioniert Proxmox mittlerweile auch mit anderen Prozessoren außer Intel?
                                  W ? 2 Replies Last reply Reply Quote 0
                                    Wildbill @Dr. Bakterius last edited by
                                    @dr-bakterius Warum sollte es nicht? Proxmox baut auf Debian auf, das bekommst Du für so ziemlich alles, was rechnen kann. Mir wäre nicht bekannt, dass Proxmox jemals nur auf Intel lauffähig gewesen wäre. AMD und Intel sind ja beide X86 bzw. X64.
                                    Gruss, Jürgen
                                      A Former User @Dr. Bakterius last edited by
                                      @dr-bakterius sagte in Proxmox VM friert ein:
                                      bei mir läuft alles auf einem uralt PC, CPU(s) 4 x AMD Phenom(tm) II X4 955 Processor (1 Socket) nur ich betreibe nur LXC Container keine VMs.
                                      Kein Glaubenskrieg, aberintel kommt mir auch nicht ins Haus 🙂 🙂
                                      Und noch ein Ansatz, um beim Thema zu bleiben, wie sieht denn die Temperatur der CPU und/oder des Mobos aus?
                                      VG
                                      Bernd
                                      • 9
                                        Hallo Zusammen,
                                        soo, kurzes Update zur Lage der Nation.
                                        Also, gestern Abend hatte ich noch die Adapter WLED, HMIP, SBFsopt sowie Netatmo deaktiviert und die PeerTube VM die als vierte von fünf (die fünfte ist meine neu aufgesetzte ioB VM die aber schon heruntergefahren ist) lief auch heruntergefahren.
                                        Heute morgen leider das mittlerweile übliche Bild, ioB VM eingefroren.
                                        • Also lag es nicht an den o.g. Adaptern.
                                        • Bzgl. der Vermutung das JS Zombie Prozesse laufen könnten ... das würde ich auch ausschließen weil auf der neu aufgesetzten ioB VM noch keine JS Script drauf sind, nur die Adapter incl. JS Adapter und auch die ist ja schon abgeschmiert.
                                        • Also hab ich heute morgen die PeerTube VM komplett gekillt um zu überprüfen ob es ggf. an zu viel zugewiesenen Speicher liegen könnte wobei @crunchip ja sagte, dass die LVM Partition die entscheidende ist für den Platz der VMs. Hier habe ich aber noch genügend frei (363GB)
                                        RAM Verteilung ist wie folgt. 16GB hat der Rechner in Summe und jeder der noch vier vorhandenen VMs sind 4GB zugewiesen.
                                        Heute Nachmittag nach der Arbeit leider wieder, ioB VM eingefroren und zusätzlich auch noch die InfluxDB VM. Zeitlich ist die InfluxDB VM eher eingefroren und ca. 2h später die ioB VM.
                                        Dass auch die InfluxDB VM jetzt manchmal (seltener als die ioB VM) einfriert ist für mich auch eher ein Zeichen, dass es wohl nicht an ioB oder den Adaptern liegen kann.
                                        Ich vermute daher wirklich, dass es am Rechner, dem Debian 11 als Muttersystem, an Proxmox selbst oder an den VM Einstellungen oder dem Debian 11 dort liegt. (Wobei wie gesagt, es ja ein Jahr fast problemlos lief).
                                        Mir bleibt jetzt wohl erstmal nichts anderes übrig als ein Debian 11 mit Proxmox und einer einzelnen ioB VM auf einer AMD Kiste auszuprobieren. (werde mir eine auf Amazon kaufen)
                                        Ich bin mir nicht sicher ob man einen VM Klon vom aktuellen Intel Rechner auf einem anderen mit AMD zum Laufen bringt, mal sehn.
                                        Wenn der Klon dort auch abschmiert dann müsste es ja doch an der VM bzw. deren Konfig. selber liegen und falls nicht dann wohl eher am Rechner/Proxmox.
                                        Außerdem werde ich eine komplett neue VM aufsetzen und wieder alle Adapter manuell neu installieren um auch das Szenario zu testen.
                                        Falls das abschmiert dann falle ich aber vom Glauben ab. Dann könnte das Problem noch vor dem Rechner selbst sitzen 😉
                                        Naja, stay tuned ...
                                        W crunchip ? 3 Replies Last reply Reply Quote 0
                                          Wildbill @900icarD last edited by
                                          @900icard Die VMs kannst Du normalerweise 1:1 übernehmen, auch wenn sich die Architektur des Host ändert. Das ist ja das Schöne an Virtualisierung.
                                          Anstatt Debian und anschließend Proxmox zu installieren würde ich direkt von Proxmox ein fertiges Installationsimage laden. Dann hast Du direkt alles in Einem.
                                          Gruss, Jürgen
                                          9 Homoran 2 Replies Last reply Reply Quote 0
                                            Theoretisch, wenn jede VM den Ram ausschöpfen würde, was bleibt für Proxmox?😉
                                            Vielleicht hast du auch in den Einstellungen etwas generell falsch konfiguriert.
                                            Ansonsten seh dir das syslog und kernel log an
                                            81.1k
                                            186
                                            29465
