    3. Einsteigerfragen
    4. InfluxDB - Daten weg / Wiederherstellung [gelöst]
    • Glasfaser
      Glasfaser @Naturfreund last edited by
      @naturfreund sagte in InfluxDB - Daten weg / Wiederherstellung:
      Kann ich das irgendwie in einem Log nachsehen?
      dsmeg-T
      N 1 Reply Last reply Reply Quote 1
      • N
        Naturfreund @Glasfaser last edited by
        @glasfaser
        Nichts auffälliges zu finden. Schon gar nichts, was mit der Uhrzeit zusammen fällt.
        Ich habe so einen Verdacht, dass wenn die Datenbank eine Größe von >= 1,3 GB erreicht, es zu dem Problem kommt. We will see...
        • Glasfaser
          Geheim ... poste es trotzdem mal
          • N
            @glasfaser
            [Fr Jan 13 15:18:33 2023] FS-Cache: Netfs 'cifs' registered for caching
            [Fr Jan 13 15:18:33 2023] Key type cifs.spnego registered
            [Fr Jan 13 15:18:33 2023] Key type cifs.idmap registered
            [Fr Jan 13 15:18:33 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
            [Fr Jan 13 15:18:33 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 15:18:34 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
            [Fr Jan 13 15:18:34 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 15:18:34 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
            [Fr Jan 13 15:18:34 2023] CIFS VFS: cifs_mount failed w/return code = -95
            [Fr Jan 13 15:21:12 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
            [Fr Jan 13 15:21:12 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 15:21:12 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 15:21:12 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
            [Fr Jan 13 15:21:12 2023] CIFS VFS: cifs_mount failed w/return code = -95
            [Fr Jan 13 15:21:50 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
            [Fr Jan 13 15:21:50 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 15:21:50 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 15:21:50 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
            [Fr Jan 13 15:21:50 2023] CIFS VFS: cifs_mount failed w/return code = -95
            [Fr Jan 13 15:42:36 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 15:43:07 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 15:44:50 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 15:45:17 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 15:45:47 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 15:47:20 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 16:06:16 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:14:33 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:14:39 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:14:39 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 23:14:39 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:14:39 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 23:14:45 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:14:45 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 23:36:01 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:36:07 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:36:07 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 23:36:07 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:36:07 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 23:36:13 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:36:13 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 23:39:38 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:39:44 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:39:44 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Fr Jan 13 23:39:44 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Fr Jan 13 23:39:44 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Fr Jan 13 23:39:50 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
            [Fr Jan 13 23:39:50 2023] CIFS VFS: cifs_mount failed w/return code = -2
            [Sa Jan 14 08:03:54 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [So Jan 15 08:03:55 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [So Jan 15 14:08:21 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mo Jan 16 08:03:56 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Di Jan 17 08:03:56 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 08:03:57 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 08:15:42 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 08:15:43 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 08:15:43 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Mi Jan 18 08:15:43 2023] FS-Cache: Duplicate cookie detected
            [Mi Jan 18 08:15:43 2023] FS-Cache: O-cookie c=4cff64b5 [p=fb6e51ba fl=222 nc=1                                                           na=1]
            [Mi Jan 18 08:15:43 2023] FS-Cache: O-cookie d=9dc44908 n=ee5fbc8a
            [Mi Jan 18 08:15:43 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
            [Mi Jan 18 08:15:43 2023] FS-Cache: N-cookie c=a1814f56 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
            [Mi Jan 18 08:15:43 2023] FS-Cache: N-cookie d=9dc44908 n=cefe596f
            [Mi Jan 18 08:15:43 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
            [Mi Jan 18 08:15:43 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
            [Mi Jan 18 08:15:43 2023] CIFS VFS: cifs_mount failed w/return code = -95
            [Mi Jan 18 08:45:26 2023] printk: systemd: 42 output lines suppressed due to rat                                                          elimiting
            [Mi Jan 18 08:45:26 2023] systemd[1]: systemd 241 running in system mode. (+PAM                                                           +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN                                                          UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie                                                          rarchy=hybrid)
            [Mi Jan 18 08:45:26 2023] systemd[1]: Detected architecture arm.
            [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:26: Unknown lvalue 'ProtectClock' in section 'Service', ignoring
            [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:29: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring
            [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:30: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring
            [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:33: Unknown lvalue 'ProtectProc' in section 'Service', ignoring
            [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:39: Unknown lvalue 'RestrictSUIDSGID' in section 'Service', ignoring
            [Mi Jan 18 08:45:26 2023] systemd[1]: Stopping Journal Service...
            [Mi Jan 18 08:45:26 2023] systemd-journald[112]: Received SIGTERM from PID 1 (sy                                                          stemd).
            [Mi Jan 18 08:45:26 2023] systemd[1]: systemd-journald.service: Succeeded.
            [Mi Jan 18 08:45:26 2023] systemd[1]: Stopped Journal Service.
            [Mi Jan 18 08:47:33 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents                                                          :1 across:102396k SSFS
            [Mi Jan 18 08:47:51 2023] debugfs: File 'le_min_key_size' in directory 'hci0' al                                                          ready present!
            [Mi Jan 18 08:47:51 2023] debugfs: File 'le_max_key_size' in directory 'hci0' al                                                          ready present!
            [Mi Jan 18 09:01:42 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:19:32 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:21:34 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:21:34 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Mi Jan 18 17:21:34 2023] FS-Cache: Duplicate cookie detected
            [Mi Jan 18 17:21:34 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
            [Mi Jan 18 17:21:34 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
            [Mi Jan 18 17:21:34 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
            [Mi Jan 18 17:21:34 2023] FS-Cache: N-cookie c=392813d8 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
            [Mi Jan 18 17:21:34 2023] FS-Cache: N-cookie d=9dc44908 n=eecf4bf2
            [Mi Jan 18 17:21:34 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
            [Mi Jan 18 17:25:41 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:25:41 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Mi Jan 18 17:25:41 2023] FS-Cache: Duplicate cookie detected
            [Mi Jan 18 17:25:41 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
            [Mi Jan 18 17:25:41 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
            [Mi Jan 18 17:25:41 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
            [Mi Jan 18 17:25:41 2023] FS-Cache: N-cookie c=a288688c [p=fb6e51ba fl=2 nc=0 na                                                          =1]
            [Mi Jan 18 17:25:41 2023] FS-Cache: N-cookie d=9dc44908 n=6eb2b1f4
            [Mi Jan 18 17:25:41 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
            [Mi Jan 18 17:36:35 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:36:36 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
            [Mi Jan 18 17:36:36 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
            [Mi Jan 18 17:36:36 2023] FS-Cache: Duplicate cookie detected
            [Mi Jan 18 17:36:36 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
            [Mi Jan 18 17:36:36 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
            [Mi Jan 18 17:36:36 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
            [Mi Jan 18 17:36:36 2023] FS-Cache: N-cookie c=392813d8 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
            [Mi Jan 18 17:36:36 2023] FS-Cache: N-cookie d=9dc44908 n=63f33383
            [Mi Jan 18 17:36:36 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
            Glasfaser crunchip 3 Replies Last reply Reply Quote 0
            • Glasfaser
              @naturfreund
              Wenn du mal Zeit hast ... starte deine Kiste neu und dann das Log hier rein posten !
              N Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @Naturfreund last edited by Glasfaser
                cifs_mount failed
                das ist das einzige was jetzt aktuell zu sehen ist , wie oft machst du ein Backup ...
                Edit :
                deine Backupeinstellungen würde ich auch mal überprüfen ... unabhängig davon:
                  crunchip Forum Testing Most Active @Naturfreund last edited by crunchip
                  @naturfreund und was ist mit den großen Uhrzeitsprüngen?
                  Ggf auch mal mit 'top' nachsehen mit welcher Last die Kiste läuft
                  • N
                    @glasfaser
                    Ich hab das NAS neu eingebunden. Hatte ich bisher nicht. Den User den ich im NAS abgelegt hatte, der hatte nicht die nötigen Rechte.
                    Die Meldung mit der SMB Version hab ich auch schon gesehen. Meine NAS unterstützt bis SMB 3 alles und so hab ich es auch konfiguriert:
                    Im Synology Adapter kann ich nichts weiter zum SMB Dienst einstellen.
                    Backup läuft täglich um 8:00 Uhr.
                    Du hattest recht, im Backitup war noch SMB 1.0 eingetragen.
                    • N
                      Naturfreund @crunchip last edited by Naturfreund
                      @crunchip
                      Welche Uhrzeitsprünge meinst du? Weil im Log ne längere Zeit nichts passiert?
                      Also mich wundert das nicht, nachdem vom 10. Juni bis 13. Januar kein Eintrag drin war.
                      top - 22:22:10 up 222 days,  9:05,  1 user,  load average: 0,37, 0,58, 0,60
                      Tasks: 139 total,   4 running, 135 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 16,0 us,  2,2 sy,  0,0 ni, 81,4 id,  0,0 wa,  0,0 hi,  0,4 si,  0,0 st
                      MiB Mem :   7875,9 total,   2868,3 free,   1567,3 used,   3440,3 buff/cache
                      MiB Swap:    100,0 total,    100,0 free,      0,0 used.   6258,6 avail Mem
                      crunchip Glasfaser 2 Replies Last reply Reply Quote 0
                        @naturfreund solltes wirklich mal neu starten, zwischendrin vllt mal grössere Upgrades gefahren, welche einen reboot benötigen?
                        Es gibt doch auch ein log für influx (var/log/syslog), sind da irgendwelche Meldungen
                        • Glasfaser
                          up 222 days
                          ... Uih ....... 😵
                          @glasfaser sagte in InfluxDB - Daten weg / Wiederherstellung:
                          @naturfreund
                          ebenfalls schonmal erwähnt ....
                          • N
                            Never change a running system 😂
                              Thomas Braun Most Active @Naturfreund last edited by
                              @naturfreund
                              Dementsprechend regiert bei Updates auch der Gammel, oder?
                              Pack das System an!
                              • N
                                Naturfreund @Thomas Braun last edited by Naturfreund
                                Ne, das ist up to date (Adapter, Grafana, Influx)
                                Was meinst du mit Pack das System an?
                                  @naturfreund
                                  sudo apt update
                                  zeigen.
                                  • N
                                    Connecting to 192.168.1.100 port 22, please wait...
                                    login as: pi pi@192.168.1.100's password:
                                    Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Thu Jan 19 20:12:17 2023 from 192.168.1.67
                                    pi@raspberrypi:~ $ sudo apt update
                                    0% [Wird verarbeitet]
                                    Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                    0% [1 InRelease 0 B/15,0 kB 0%] [Verbunden mit archive.raspbian.org (93.93.128.
                                    0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Verbunden mit apt.graf
                                    OK:2 https://repos.influxdata.com/debian buster InRelease
                                    Holen:3 https://apt.grafana.com stable InRelease [5.984 B]
                                    0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [3 InRelease 2.742 B/5.
                                    0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Warten auf Kopfzeilen]
                                    OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                    0% [Warten auf Kopfzeilen] [Warten auf Kopfzeilen]
                                    Holen:5 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                    0% [Warten auf Kopfzeilen] [5 InRelease 2.705 B/32,6 kB 8%]
                                    Holen:6 https://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
                                    0% [6 InRelease 15,0 kB/15,0 kB 100%] [5 InRelease 23,0 kB/32,6 kB 70%]
                                    0% [5 InRelease 23,0 kB/32,6 kB 70%]
                                    Holen:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                                    0% [7 Packages 14,2 kB/13,0 MB 0%]
                                    0% [7 Packages 3.997 kB/13,0 MB 31%]
                                    0% [7 Packages 12,5 MB/13,0 MB 96%]
                                    0% [7 Packages store 0 B]
                                    Holen:8 https://archive.raspbian.org/raspbian buster/main Sources [11,4 MB]
                                    0% [7 Packages store 0 B] [8 Sources 32,5 kB/11,4 MB 0%]
                                    53% [7 Packages store 0 B] [8 Sources 3.260 kB/11,4 MB 29%]
                                    Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                                    58% [7 Packages store 0 B] [8 Sources 5.292 kB/11,4 MB 47%] [9 Packages 1.221 B
                                    64% [7 Packages store 0 B] [8 Sources 7.811 kB/11,4 MB 69%]
                                    71% [7 Packages store 0 B]
                                    Holen:10 https://archive.raspbian.org/raspbian buster/main armhf Packages [13,0 MB]
                                    71% [7 Packages store 0 B] [10 Packages 24,6 kB/13,0 MB 0%]
                                    88% [7 Packages store 0 B] [10 Packages 8.081 kB/13,0 MB 62%]
                                    99% [7 Packages store 0 B]
                                    99% [7 Packages store 0 B]                                       6.075 kB/s 0 s
                                    99% [Wird verarbeitet]                                           6.075 kB/s 0 s
                                    99% [9 Packages store 0 B]                                       6.075 kB/s 0 s
                                    99% [8 Sources store 0 B]                                        6.075 kB/s 0 s
                                    100% [Wird verarbeitet]                                          6.075 kB/s 0 s
                                    100% [10 Packages store 0 B]                                     6.075 kB/s 0 s
                                    Es wurden 37,9 MB in 25 s geholt (1.513 kB/s).
                                    Paketlisten werden gelesen... 0%
                                    Paketlisten werden gelesen... 24%
                                    Paketlisten werden gelesen... 42%
                                    Paketlisten werden gelesen... 48%
                                    Paketlisten werden gelesen... 49%
                                    Paketlisten werden gelesen... 90%
                                    Paketlisten werden gelesen... 97%
                                    Paketlisten werden gelesen... 98%
                                    Paketlisten werden gelesen... 99%
                                    Paketlisten werden gelesen... Fertig
                                    Abhängigkeitsbaum wird aufgebaut.... 0%
                                    Abhängigkeitsbaum wird aufgebaut.... 50%
                                    Statusinformationen werden eingelesen.... 0%
                                    Statusinformationen werden eingelesen.... Fertig
                                    Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                                    pi@raspberrypi:~ $
                                      @naturfreund
                                      Buster ist tot. Geh auf das aktuelle stable-Release Bullseye.
                                      • N
                                        Wie mache ich das?
                                        Google fördert 2 unterschiedliche Vorgehensweisen zu Tage. Kann nicht einschätzen welche davon "richtiger" ist.
                                          @naturfreund
                                          Hab ich mal ein kleines HowTo zu geschrieben. Schau durch meine Themen durch.
                                            Thomas Braun Most Active @Naturfreund last edited by Thomas Braun
                                            @naturfreund
                                            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                            Ich würde aber wohl auf ein 64bit-Release wechseln, wenn dein Raspi das kann. Muss allerdings dann komplett neuinstalliert werden, ein Wechsel der Architektur ist so nicht möglich.
                                            11536
