    4. Alpha Testing: OCPP Wallbox Adapter
    • Soeni
      Soeni @Soeni last edited by
      Hier noch mal das Log mit Einstellung alles:
      ocpp.0
      	2023-01-18 21:01:53.638	info	Received Status Notification from "/.1": Finishing
      ocpp.0
      	2023-01-18 21:01:53.638	debug	{"connectorId":1,"errorCode":"NoError","status":"Finishing","timestamp":"2023-01-18T20:01:53.000Z","commandOcpp":"StatusNotification"}
      ocpp.0
      	2023-01-18 21:01:53.484	info	Received Status Notification from "/.0": Available
      ocpp.0
      	2023-01-18 21:01:53.483	debug	{"connectorId":0,"errorCode":"NoError","status":"Available","timestamp":"2023-01-18T20:01:53.000Z","commandOcpp":"StatusNotification"}
      ocpp.0
      	2023-01-18 21:01:53.285	info	Received boot notification from "/"
      ocpp.0
      	2023-01-18 21:01:53.284	debug	{"chargePointVendor":"go-e","chargePointModel":"go-eCharger","chargePointSerialNumber":"114962","firmwareVersion":"055.0","commandOcpp":"BootNotification"}
      ocpp.0
      	2023-01-18 21:01:53.174	warn	Could not request states of "/": you must provide a joi schema
      ocpp.0
      	2023-01-18 21:01:53.158	info	Requesting StatusNotification from "/"
      ocpp.0
      	2023-01-18 21:01:53.155	info	New device connected: "/"
      ocpp.0
      	2023-01-18 21:01:52.955	info	New valid connection from "/" (http/ocpp1.6)
      ocpp.0
      	2023-01-18 21:01:52.952	debug	Connection from "/" with credentials "undefined", protocol: "http", OCPP: ocpp1.6
      ocpp.0
      	2023-01-18 21:01:44.331	info	Server listening on port 9220
      ocpp.0
      	2023-01-18 21:01:44.208	info	Starting OCPP Server
      ocpp.0
      	2023-01-18 21:01:44.156	info	starting. Version 0.9.1 (non-npm: foxriver76/ioBroker.ocpp) in /opt/iobroker/node_modules/iobroker.ocpp, node: v16.14.2, js-controller: 4.0.23
      ocpp.0
      	2023-01-18 21:01:43.862	debug	States connected to redis: 127.0.0.1:9000
      ocpp.0
      	2023-01-18 21:01:43.829	debug	States create User PubSub Client
      ocpp.0
      	2023-01-18 21:01:43.827	debug	States create System PubSub Client
      ocpp.0
      	2023-01-18 21:01:43.807	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      ocpp.0
      	2023-01-18 21:01:43.766	debug	Objects connected to redis: 127.0.0.1:9001
      ocpp.0
      	2023-01-18 21:01:43.759	debug	Objects client initialize lua scripts
      ocpp.0
      	2023-01-18 21:01:43.647	debug	Objects create User PubSub Client
      ocpp.0
      	2023-01-18 21:01:43.645	debug	Objects create System PubSub Client
      ocpp.0
      	2023-01-18 21:01:43.642	debug	Objects client ready ... initialize now
      ocpp.0
      	2023-01-18 21:01:43.551	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        fL4sH 0 @foxriver76 last edited by
        @foxriver76 said in Alpha Testing: OCPP Wallbox Adapter:
        @fl4sh-0 Es gibt noch MeterValuesAlignedDataMaxLength und das gleiche für MeterValuesSampledDataMaxLength evtl. lässt sampled Data mehr Punkte zu als aligned data?
        Da hast du recht, danke für den Hinweis. MeterValuesAlignedDataMaxLength lässt nur 4 Werte zu und MeterValuesSampledDataMaxLength lässt 22 Werte zu. Beide States sind leider schreibgeschützt.
          frank11 @foxriver76 last edited by
          @foxriver76 authList fehlt. Obwohl "Local Auth List Management" laut SupportedFeatureProfiles unterstützt wird.
          • foxriver76
            foxriver76 Developer @frank11 last edited by
            @frank11 Zeig mal bitte das Log, er schreibt da die unterstützen Profile rein und auch wenn er States löscht, weil nicht unterstützt.
              @foxriver76 Das einzig interessante ist:
              ocpp.0
              2023-01-19 09:52:38.871 info Supported profiles by client "/21178121966125" are "Core,Local Auth List Management,Reservation,Smart Charging,Remote Trigger"
              Oder muss ich irgendwo noch Debugging einschalten?
              • foxriver76
                @frank11 Schreibt er auch Removing LocalAuthListManagement functionality as unsupported?
                Es kann sein, dass ich es abfange, allerdings scheint deine WB OCPP1.6 etwas unsauber zu implementieren wie auch schon an der Configuration gesehen.
                Lt. Standard RemoteTrigger statt wie bei dir Remote Trigger etc.
                Version ist die 0.12.0?
                • foxriver76
                  foxriver76 Developer @Jrlohni last edited by
                  @jrlohni Vorzugsweise im Admin Tab Adapter, Expertenmodus auf die Katze "von NPM installieren"
                    @foxriver76 Ach verdammt, die Einträge hab ich übersehen:
                    ocpp.0
                    2023-01-19 09:52:39.035 info Removing LocalAuthListManagement functionality as unsupported
                    ocpp.0
                    2023-01-19 09:52:38.994 info Removing SmartCharging functionality as unsupported
                    Also auch kein SmartCharging! 😞
                    Ja, habe gerade auf 0.12.0 upgedatet weil ich ja eh die Instanz neu starten musste.
                    foxriver76 2 Replies Last reply Reply Quote 0
                    • foxriver76
                      @frank11 ich baue das ein, dass er das trotzdem erkennt.
                      • foxriver76
                        @frank11 Bitte 0.12.1 testen
                          frank11 @foxriver76 last edited by frank11
                          @foxriver76 Wird noch nicht angeboten, ich schaue morgen nochmal.
                          authList fehlt immer noch.
                            Jrlohni @foxriver76 last edited by
                            @foxriver76 habe die 0.12.1 installiert und eingerichtet. Es tauchen schon deutlich mehr Werte auf! Allerdings klappt das dynamische Laden leider nicht mehr. Vorher konnte ich bei "chargeLimit" die Ampere eingeben und er hat sie anstandslos übernommen. Jetzt werden sie nicht mehr übernommen.
                            So sieht es vor dem anschließen des Autos aus:
                            Bildschirm­foto 2023-01-19 um 15.13.58.png Bildschirm­foto 2023-01-19 um 15.14.18.png
                            So sieht es nach dem Anschließen aus:
                            Bildschirm­foto 2023-01-19 um 16.04.03.png Bildschirm­foto 2023-01-19 um 16.04.26.png
                            Das sagt die Log dazu:
                            Falls die Debug Datei noch was bringt, bräuchte ich einmal Hilfe wo ich diese finde... 🙂
                            Grüße!
                            Soeni foxriver76 F 3 Replies Last reply Reply Quote 0
                            • Soeni
                              Soeni @Jrlohni last edited by
                              Helfen die logs was?
                              • foxriver76
                                foxriver76 Developer @Soeni last edited by
                                @soeni Ich weiß nicht was in der Installation nicht stimmt. Das you most provide a valid joi scheme hatten wir weiter oben schon mal, glaube da war irgendeine Versionskonflikt mit einem anderen Adapter.
                                • foxriver76
                                  @jrlohni Evtl. lehnt die WB ab, da du von 3 phasigen auf 1 phasiges Laden wechselt. Die Möglichkeit ist neu und eigentlich die einzige Änderung zu vorher, dass wir die Anzahl an Phasen mitsenden.
                                  Hast du diesen Punkt in der Config?
                                  F J 2 Replies Last reply Reply Quote 0
                                    @foxriver76 Bei mir funktioniert zumindest jetzt das SmartCharging mit 0.12.1:
                                    • foxriver76
                                      @frank11 sagte in Alpha Testing: OCPP Wallbox Adapter:
                                      D. H. authList nicht da in connector 0?
                                        @foxriver76 Leider nein:
                                        • foxriver76
                                          @frank11 dann log bitte ob er wieder deaktiviert hat
                                          • foxriver76
                                            foxriver76 Developer @frank11 last edited by foxriver76
                                            @frank11 ah ok du hast kein connector 0 😬
                                            Braucht der Adapter nochmal Anpassung
                                            31.7k
                                            79.8k
                                            adapter ocpp wallbox
                                            48
                                            440
                                            78092
