    5. Selbst erstellter Datenpunkt, Problem <0 [gelöst]
      hardl @Homoran last edited by
      @homoran sorry,
      javascript.0
      2023-01-20 11:31:36.766	warn	at processImmediate (node:internal/timers:466:21)
      javascript.0
      2023-01-20 11:31:36.765	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
      javascript.0
      2023-01-20 11:31:36.765	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
      javascript.0
      2023-01-20 11:31:36.765	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
      javascript.0
      2023-01-20 11:31:36.765	warn	at Object.<anonymous> (script.js.Poolsteuerung.Debug_Diff:6:3)
      javascript.0
      2023-01-20 11:31:36.765	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
      javascript.0
      2023-01-20 11:31:36.764	warn	State "Object ID" not found
      javascript.0
      2023-01-20 11:31:36.764	info	script.js.Poolsteuerung.Debug_Diff: getState(id=mqtt.0.ESP_Easy.Solarsensor.temperature, timerId=undefined) => {"val":20.6,"ack":true,"ts":1674210696758,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1674210696758}
      javascript.0
      2023-01-20 11:31:36.763	info	script.js.Poolsteuerung.Debug_Diff: number
      javascript.0
      2023-01-20 11:31:36.763	info	script.js.Poolsteuerung.Debug_Diff: getState(id=mqtt.0.ESP_Easy.Poolsensor.temperature, timerId=undefined) => {"val":21.1,"ack":true,"ts":1674210695846,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1674210472569}
      javascript.0
        Homoran Global Moderator Administrators @hardl last edited by
        @hardl
        geht es um diese Kommas?
        Die gehören nicht zur Zahl.
          hardl @Codierknecht last edited by
          @codierknecht Nein, das Script ist neu und nichts dahinter.
          Alle DP habe ich nochmals geprüft.
          Homoran Codierknecht 2 Replies Last reply Reply Quote 0
            @hardl sagte in Selbst erstellter Datenpunkt, Problem <0:
            nein!
            bei aktualisiere fehlt die zu aktualisierende DP ID
            • Codierknecht
              Codierknecht Developer Most Active @hardl last edited by
              Schau doch mal in den JS-Code, wo da ein "Object ID" versteckt ist.
              Das muss ja irgendwoher kommen.
                @homoran Inzwischen habe ich gesehen, dass bei glatt 21 keine Punkte oder Kommas dargestellt werden.
                Du hast natürlich Recht......
                Ich habe das Object mit Ist-Diff ersetzt und der Fehler ist weg.
                  Homoran Global Moderator Administrators @hardl last edited by Homoran
                  heisst?
                  zeigen!
                    admin.0
                    2023-01-20 12:05:00.946	info	<== Disconnect system.user.admin from ::ffff:192.168.178.22 javascript
                    admin.0
                    javascript.0
                    2023-01-20 12:04:56.994	info	script.js.Poolsteuerung.Debug_Diff: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                    javascript.0
                    2023-01-20 12:04:56.994	info	script.js.Poolsteuerung.Debug_Diff: subscribe: {"pattern":{"id":"mqtt.0.ESP_Easy.Solarsensor.temperature","change":"ne","q":0},"name":"script.js.Poolsteuerung.Debug_Diff"}
                    javascript.0
                    2023-01-20 12:04:56.988	info	Start javascript script.js.Poolsteuerung.Debug_Diff
                    Ich werde jetzt mal sehen, wie ich einen Debug Block in das normale Script einfüge, um zu sehen was passiert, wenn die Differenz <0 ist.
                      @hardl zeig doch bitte das jetzige Script
                          paul53 @hardl last edited by paul53
                          @hardl
                          Keine Trigger innerhalb von Triggern anordnen!
                          Vorschlag:
                            hardl @paul53 last edited by
                            @paul53 @Homoran @Codierknecht, Ich habe jetzt einfach die inneren Trigger und auch die später eingefügte Zeile, damit unter 0 nicht gerechnet wird, entfernt.
                            Es sieht so aus, als ob damit auch mein Problem erledigt ist.
                            Der Datenpunkt nimmt jetzt problemlos negative und positive Zahlen auf.
                            Ich danke Euch für die super gute und schnelle Hilfe und habe dabei auch Grundlagen des Debuggen gelernt.
                            Sollte noch etwas auftauchen, melde ich mich.
                              @hardl sagte: die inneren Trigger und auch die später eingefügte Zeile, damit unter 0 nicht gerechnet wird, entfernt.
                              Du liest aber nicht den Datenpunkt "Ist-Diff" gleich wieder ein, nachdem er geschrieben wurde? Das funktioniert wegen der asynchronen Ausführung von "steuere" nicht. Deshalb verwendet man Variablen.
                                @paul53 sagte in Selbst erstellter Datenpunkt, Problem <0:
                                Datenpunkt
                                Deinen Vorschlag habe ich nun umgesetzt und es läuft einwandfrei.
                                Bisher hatte ich noch nicht mit Variablen in Blockly gearbeitet sondern immer in Datenpunkte geschrieben.
                                Das Argument kann ich auch nachvollziehen und werde meine wenigen Skripte entsprechend überarbeiten.
                                  @hardl sagte: es läuft einwandfrei.
                                  Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                                    @paul53 Ich bräuchte da noch eine Ergänzung. Wie Du geschrieben hast, sollte kein Trigger innerhalb von Triggern vorkommen.
                                    Ich möchte noch einen Schalter integrieren, der meiner Poolsteuerung vorgelagert ist und bei 0 die Routine ausführt, bei 1 aber die Pumpe auf Dauer schaltet.
                                      @hardl sagte in Selbst erstellter Datenpunkt, Problem <0 [gelöst]:
                                      dann nimm einen Logikblock falls und prüfe den State.
                                      je nach Zustand führst du aus was du willst.
                                      Aber ich denke du sagst nicht alles was du wirklich erwartest.
                                        @hardl sagte: bei 0 die Routine ausführt, bei 1 aber die Pumpe auf Dauer schaltet.
                                        Die Pumpe bei 1 einschalten und den Modus im Solartemperatur-Trigger auf 0 prüfen.
                                        Den Rest innerhalb des mache-Zweiges ausführen.
                                          @homoran sagte in Selbst erstellter Datenpunkt, Problem <0 [gelöst]:
                                          Was meinst du damit?
                                          Ich bin sehr zufrieden wie das in der Simulation funktioniert. Die Hardware ist auf dem Steckbrett auch nahezu einsatzbereit.
                                          Eventuell könnte ich noch einen Pumpe-Dauer-Aus Schalter hinzufügen.
                                          @paul53: Ich habe nur 0 und 1 beim Switch und den Trigger gedreht zum besseren Verständnis.
                                            @hardl sagte: 0 und 1 beim Switch und den Trigger gedreht zum besseren Verständnis.
                                            Dann stimmt der Kommentar nicht, denn bei 0 wird eingeschaltet.
                                            Statt eines zusätzlichen DP würde ich einen Multistate-DP verwenden.
                                            "states": {
                                                "0": "Aus",
                                                "1": "Auto",
                                                "2": "Ein"
                                            blockly
                                            2328
