    3. Einsteigerfragen
    4. InfluxDB - Daten weg / Wiederherstellung [gelöst]
    • N
      Naturfreund @Thomas Braun last edited by Naturfreund
      Ne, das ist up to date (Adapter, Grafana, Influx)
      Was meinst du mit Pack das System an?
        Thomas Braun Most Active @Naturfreund last edited by
        @naturfreund
        sudo apt update
        zeigen.
        • N
          Connecting to 192.168.1.100 port 22, please wait...
          login as: pi pi@192.168.1.100's password:
          Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Thu Jan 19 20:12:17 2023 from 192.168.1.67
          pi@raspberrypi:~ $ sudo apt update
          0% [Wird verarbeitet]
          Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
          0% [1 InRelease 0 B/15,0 kB 0%] [Verbunden mit archive.raspbian.org (93.93.128.
          0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Verbunden mit apt.graf
          OK:2 https://repos.influxdata.com/debian buster InRelease
          Holen:3 https://apt.grafana.com stable InRelease [5.984 B]
          0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [3 InRelease 2.742 B/5.
          0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Warten auf Kopfzeilen]
          OK:4 https://deb.nodesource.com/node_16.x buster InRelease
          0% [Warten auf Kopfzeilen] [Warten auf Kopfzeilen]
          Holen:5 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
          0% [Warten auf Kopfzeilen] [5 InRelease 2.705 B/32,6 kB 8%]
          Holen:6 https://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
          0% [6 InRelease 15,0 kB/15,0 kB 100%] [5 InRelease 23,0 kB/32,6 kB 70%]
          0% [5 InRelease 23,0 kB/32,6 kB 70%]
          Holen:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
          0% [7 Packages 14,2 kB/13,0 MB 0%]
          0% [7 Packages 3.997 kB/13,0 MB 31%]
          0% [7 Packages 12,5 MB/13,0 MB 96%]
          0% [7 Packages store 0 B]
          Holen:8 https://archive.raspbian.org/raspbian buster/main Sources [11,4 MB]
          0% [7 Packages store 0 B] [8 Sources 32,5 kB/11,4 MB 0%]
          53% [7 Packages store 0 B] [8 Sources 3.260 kB/11,4 MB 29%]
          Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
          58% [7 Packages store 0 B] [8 Sources 5.292 kB/11,4 MB 47%] [9 Packages 1.221 B
          64% [7 Packages store 0 B] [8 Sources 7.811 kB/11,4 MB 69%]
          71% [7 Packages store 0 B]
          Holen:10 https://archive.raspbian.org/raspbian buster/main armhf Packages [13,0 MB]
          71% [7 Packages store 0 B] [10 Packages 24,6 kB/13,0 MB 0%]
          88% [7 Packages store 0 B] [10 Packages 8.081 kB/13,0 MB 62%]
          99% [7 Packages store 0 B]
          99% [7 Packages store 0 B]                                       6.075 kB/s 0 s
          99% [Wird verarbeitet]                                           6.075 kB/s 0 s
          99% [9 Packages store 0 B]                                       6.075 kB/s 0 s
          99% [8 Sources store 0 B]                                        6.075 kB/s 0 s
          100% [Wird verarbeitet]                                          6.075 kB/s 0 s
          100% [10 Packages store 0 B]                                     6.075 kB/s 0 s
          Es wurden 37,9 MB in 25 s geholt (1.513 kB/s).
          Paketlisten werden gelesen... 0%
          Paketlisten werden gelesen... 24%
          Paketlisten werden gelesen... 42%
          Paketlisten werden gelesen... 48%
          Paketlisten werden gelesen... 49%
          Paketlisten werden gelesen... 90%
          Paketlisten werden gelesen... 97%
          Paketlisten werden gelesen... 98%
          Paketlisten werden gelesen... 99%
          Paketlisten werden gelesen... Fertig
          Abhängigkeitsbaum wird aufgebaut.... 0%
          Abhängigkeitsbaum wird aufgebaut.... 50%
          Statusinformationen werden eingelesen.... 0%
          Statusinformationen werden eingelesen.... Fertig
          Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
          pi@raspberrypi:~ $
            @naturfreund
            Buster ist tot. Geh auf das aktuelle stable-Release Bullseye.
            • N
              Wie mache ich das?
              Google fördert 2 unterschiedliche Vorgehensweisen zu Tage. Kann nicht einschätzen welche davon "richtiger" ist.
                @naturfreund
                Hab ich mal ein kleines HowTo zu geschrieben. Schau durch meine Themen durch.
                  Thomas Braun Most Active @Naturfreund last edited by Thomas Braun
                  @naturfreund
                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                  Ich würde aber wohl auf ein 64bit-Release wechseln, wenn dein Raspi das kann. Muss allerdings dann komplett neuinstalliert werden, ein Wechsel der Architektur ist so nicht möglich.
                  • N
                    Ich finde deine Beiträge immer echt super. Die haben mir schon ein paar mal weiter geholfen. Würde auch auf 64 Bit wechseln wollen, den Aufwand muss ich aber zeitlich dahin verlagern wo ich auch genug Zeit habe mich damit auseinander zu setzen.
                    Ich aktualisiere jetzt erst mal nach deinem Tutorial.
                    pi@raspberrypi:~ $ neofetch
                      `.::///+:/-.        --///+//-:``    pi@raspberrypi
                     `+oooooooooooo:   `+oooooooooooo:    --------------
                      /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 11 (bullseye) armv
                      `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi 4 Model B Rev 1.4
                       `:oooooooo+``    `.oooooooo+-      Kernel: 5.15.84-v7l+
                         `:++ooo/.        :+ooo+/.`       Uptime: 9 mins
                            ...`  `.----.` ``..           Packages: 714 (dpkg)
                         .::::-``:::::::::.`-:::-`        Shell: bash 5.1.4
                        -:::-`   .:::::::-`  `-:::-       Terminal: /dev/pts/0
                       `::.  `.--.`  `` `.---.``.::`      CPU: BCM2711 (4) @ 1.500GHz
                           .::::::::`  -::::::::` `       Memory: 1221MiB / 7898MiB
                    top - 22:55:01 up 3 min,  1 user,  load average: 1,04, 0,91, 0,40
                    Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                    %CPU(s): 11,9 us,  1,7 sy,  0,0 ni, 85,5 id,  0,1 wa,  0,0 hi,  0,8 si,  0,0 st
                    MiB Spch:   7898,9 total,   6200,7 free,   1211,3 used,    486,9 buff/cache
                    MiB Swap:    100,0 total,    100,0 free,      0,0 used.   6805,6 avail Spch
                    Läuft, danke dir!
                    • N
                      Naturfreund @Naturfreund last edited by Naturfreund
                      Ich hab jetzt nochmal die Historie in einem Post zusammen gefasst.
                      @naturfreund said in InfluxDB - Daten weg / Wiederherstellung:
                      Nach dem Update sind Daten die in der Vergangenheit schon mal weg waren, wieder aufgetaucht (nach dem 13.01.2023) :
                      Vor der Update auf bullseye gab es 3 Einträge ECONNREFUSED, aber anscheinend ohne die Auswirkung, das weitere Daten verschwinden.
                      2023-01-19 15:03:16.967 - info: shelly.0 (11384) [MQTT] Device 192.168.1.113 (shellyht / shellyht-F4423D / SHHT-1#F4423D#1) connected! Polltime set to 5 sec.
                      2023-01-19 15:03:44.307 - info: influxdb.0 (15156) Store 1001 buffered influxDB history points
                      2023-01-19 15:03:44.377 - warn: influxdb.0 (15156) Error on writeSeries: Error: connect ECONNREFUSED 127.0.0.1:8086
                      2023-01-19 15:03:44.378 - info: influxdb.0 (15156) Host not available, move all points back in the Buffer
                      2023-01-19 15:03:54.381 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                      2023-01-19 15:03:54.381 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                      2023-01-19 15:03:54.389 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2023-01-19 15:04:04.389 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                      2023-01-19 15:04:04.390 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                      2023-01-19 15:04:04.396 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2023-01-19 15:04:14.397 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                      2023-01-19 15:04:14.397 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                      2023-01-19 15:04:14.404 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2023-01-19 15:04:24.405 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                      2023-01-19 15:04:24.406 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                      2023-01-19 15:04:24.703 - info: influxdb.0 (15156) Store 1424 buffered influxDB history points
                      • N
                        2023-01-20 13:30:00.062 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 23539
                        2023-01-20 13:30:02.185 - info: influxdb.0 (789) Store 1001 buffered influxDB history points
                        2023-01-20 13:30:02.252 - warn: influxdb.0 (789) Error on writeSeries: Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:30:02.253 - info: influxdb.0 (789) Host not available, move all points back in the Buffer
                        2023-01-20 13:30:02.913 - info: weatherunderground.0 (23539) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.0, js-controller: 4.0.24
                        2023-01-20 13:30:11.798 - info: weatherunderground.0 (23539) Terminated (NO_ERROR): Without reason
                        2023-01-20 13:30:12.255 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:30:12.256 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:30:12.265 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:30:12.348 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                        2023-01-20 13:30:22.265 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:30:22.266 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:30:22.271 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:30:32.272 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:30:32.272 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:30:32.276 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:30:42.286 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:30:42.286 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:30:42.292 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:30:48.601 - info: shelly.0 (913) [MQTT] Device 192.168.1.110 (shellyht / shellyht-F4483E / SHHT-1#F4483E#1) connected! Polltime set to 5 sec.
                        2023-01-20 13:30:52.293 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:30:52.294 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:30:52.298 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:02.299 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:02.299 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:02.304 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:12.306 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:12.306 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:12.311 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:22.311 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:22.312 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:22.316 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:32.318 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:32.318 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:32.323 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:42.324 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:42.325 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:42.329 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:52.329 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:31:52.329 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:31:52.334 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:31:58.430 - info: shelly.0 (913) [MQTT] Device 192.168.1.113 (shellyht / shellyht-F4423D / SHHT-1#F4423D#1) connected! Polltime set to 5 sec.
                        2023-01-20 13:32:02.334 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:02.335 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:02.340 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:32:12.342 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:12.342 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:12.347 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:32:22.348 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:22.349 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:22.354 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:32:32.355 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:32.356 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:32.364 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:32:42.365 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:42.366 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:42.370 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:32:52.371 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:32:52.372 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:32:52.377 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:33:02.377 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:33:02.378 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:33:02.382 - error: influxdb.0 (789) Error: connect ECONNREFUSED 127.0.0.1:8086
                        2023-01-20 13:33:12.384 - info: influxdb.0 (789) Connecting http://127.0.0.1:8086/ ...
                        2023-01-20 13:33:12.384 - info: influxdb.0 (789) Influx DB Version used: 1.x
                        2023-01-20 13:33:12.812 - info: influxdb.0 (789) Store 3457 buffered influxDB history points
                        Noch mehr Daten in der Vergangenheit weg, jetzt durchgehend vom 13.12.2022 bis einschließlich 11.01.2023:
                        Warum verschwinden denn da bitte Daten aus der Vergangenheit? Die hat er doch schon längst in die Datenbank geschrieben? Warum werden denn die nochmal angepackt?
                        Oder stirbt hier langsam meine SD Karte?
                        • Glasfaser
                          Glasfaser @Glasfaser last edited by
                          @Naturfreund
                          @glasfaser sagte in InfluxDB - Daten weg / Wiederherstellung:
                          @naturfreund
                          Wenn du mal Zeit hast ... starte deine Kiste neu und dann das Log hier rein posten !
                          @naturfreund sagte in InfluxDB - Daten weg / Wiederherstellung:
                          Kann ich das irgendwie in einem Log nachsehen?
                          dsmeg-T
                          Zeige mal aktuell !
                          • N
                            Naturfreund @Glasfaser last edited by Naturfreund
                            @glasfaser
                            Linux raspberrypi 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l
                            Last login: Thu Jan 19 23:18:21 2023 from 192.168.1.17
                            pi@raspberrypi:~ $ dmesg -T
                            [Do Jan 19 22:51:35 2023] Booting Linux on physical CPU 0x0
                            [Do Jan 19 22:51:35 2023] Linux version 5.15.84-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 12:01:26 GMT 2023
                            [Do Jan 19 22:51:35 2023] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                            [Do Jan 19 22:51:35 2023] CPU: div instructions available: patching division code
                            [Do Jan 19 22:51:35 2023] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                            [Do Jan 19 22:51:35 2023] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
                            [Do Jan 19 22:51:35 2023] random: crng init done
                            [Do Jan 19 22:51:35 2023] Memory policy: Data cache writealloc
                            [Do Jan 19 22:51:35 2023] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                            [Do Jan 19 22:51:35 2023] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                            [Do Jan 19 22:51:35 2023] Zone ranges:
                            [Do Jan 19 22:51:35 2023]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                            [Do Jan 19 22:51:35 2023]   Normal   empty
                            [Do Jan 19 22:51:35 2023]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
                            [Do Jan 19 22:51:35 2023] Movable zone start for each node
                            [Do Jan 19 22:51:35 2023] Early memory node ranges
                            [Do Jan 19 22:51:35 2023]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                            [Do Jan 19 22:51:35 2023]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                            [Do Jan 19 22:51:35 2023]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
                            [Do Jan 19 22:51:35 2023] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                            [Do Jan 19 22:51:35 2023] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
                            [Do Jan 19 22:51:35 2023] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
                            [Do Jan 19 22:51:35 2023] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                            [Do Jan 19 22:51:35 2023] Built 1 zonelists, mobility grouping on.  Total pages: 2059584
                            [Do Jan 19 22:51:35 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:CB:FB:79 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4e9ce0cb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [Do Jan 19 22:51:35 2023] Kernel parameter elevator= does not have any effect anymore.
                                                      Please use sysfs to set IO scheduler for individual devices.
                            [Do Jan 19 22:51:35 2023] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                            [Do Jan 19 22:51:35 2023] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                            [Do Jan 19 22:51:35 2023] mem auto-init: stack:off, heap alloc:off, heap free:off
                            [Do Jan 19 22:51:35 2023] software IO TLB: mapped [mem 0x0000000012400000-0x0000000016400000] (64MB)
                            [Do Jan 19 22:51:35 2023] Memory: 7758764K/8245248K available (10240K kernel code, 1386K rwdata, 3308K rodata, 2048K init, 591K bss, 158804K reserved, 327680K cma-reserved, 7458816K highmem)
                            [Do Jan 19 22:51:35 2023] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                            [Do Jan 19 22:51:35 2023] ftrace: allocating 35518 entries in 105 pages
                            [Do Jan 19 22:51:35 2023] ftrace: allocated 105 pages with 4 groups
                            [Do Jan 19 22:51:35 2023] trace event string verifier disabled
                            [Do Jan 19 22:51:35 2023] rcu: Hierarchical RCU implementation.
                            [Do Jan 19 22:51:35 2023]   Rude variant of Tasks RCU enabled.
                            [Do Jan 19 22:51:35 2023]   Tracing variant of Tasks RCU enabled.
                            [Do Jan 19 22:51:35 2023] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                            [Do Jan 19 22:51:35 2023] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            [Do Jan 19 22:51:35 2023] GIC: Using split EOI/Deactivate mode
                            [Do Jan 19 22:51:35 2023] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                            [Do Jan 19 22:51:35 2023] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                            [Do Jan 19 22:51:35 2023] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                            [Do Jan 19 22:51:35 2023] Switching to timer-based delay loop, resolution 18ns
                            [Do Jan 19 22:51:35 2023] Console: colour dummy device 80x30
                            [Do Jan 19 22:51:35 2023] printk: console [tty1] enabled
                            [Do Jan 19 22:51:35 2023] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                            [Do Jan 19 22:51:35 2023] pid_max: default: 32768 minimum: 301
                            [Do Jan 19 22:51:35 2023] LSM: Security Framework initializing
                            [Do Jan 19 22:51:35 2023] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            [Do Jan 19 22:51:35 2023] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            [Do Jan 19 22:51:35 2023] cgroup: Disabling memory control group subsystem
                            [Do Jan 19 22:51:35 2023] CPU: Testing write buffer coherency: ok
                            [Do Jan 19 22:51:35 2023] CPU0: Spectre BHB: enabling loop workaround for all CPUs
                            [Do Jan 19 22:51:35 2023] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            [Do Jan 19 22:51:35 2023] Setting up static identity map for 0x200000 - 0x20003c
                            [Do Jan 19 22:51:35 2023] rcu: Hierarchical SRCU implementation.
                            [Do Jan 19 22:51:35 2023] smp: Bringing up secondary CPUs ...
                            [Do Jan 19 22:51:35 2023] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            [Do Jan 19 22:51:35 2023] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                            [Do Jan 19 22:51:35 2023] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                            [Do Jan 19 22:51:35 2023] smp: Brought up 1 node, 4 CPUs
                            [Do Jan 19 22:51:35 2023] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                            [Do Jan 19 22:51:35 2023] CPU: All CPU(s) started in HYP mode.
                            [Do Jan 19 22:51:35 2023] CPU: Virtualization extensions available.
                            [Do Jan 19 22:51:35 2023] devtmpfs: initialized
                            [Do Jan 19 22:51:35 2023] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                            [Do Jan 19 22:51:35 2023] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            [Do Jan 19 22:51:35 2023] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                            [Do Jan 19 22:51:35 2023] pinctrl core: initialized pinctrl subsystem
                            [Do Jan 19 22:51:35 2023] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                            [Do Jan 19 22:51:35 2023] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                            [Do Jan 19 22:51:35 2023] audit: initializing netlink subsys (disabled)
                            [Do Jan 19 22:51:35 2023] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
                            [Do Jan 19 22:51:35 2023] thermal_sys: Registered thermal governor 'step_wise'
                            [Do Jan 19 22:51:35 2023] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                            [Do Jan 19 22:51:35 2023] hw-breakpoint: maximum watchpoint size is 8 bytes.
                            [Do Jan 19 22:51:35 2023] Serial: AMBA PL011 UART driver
                            [Do Jan 19 22:51:35 2023] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                            [Do Jan 19 22:51:35 2023] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:46:54, variant start
                            [Do Jan 19 22:51:35 2023] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
                            [Do Jan 19 22:51:35 2023] Kprobes globally optimized
                            [Do Jan 19 22:51:35 2023] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                            [Do Jan 19 22:51:35 2023] vgaarb: loaded
                            [Do Jan 19 22:51:35 2023] SCSI subsystem initialized
                            [Do Jan 19 22:51:35 2023] usbcore: registered new interface driver usbfs
                            [Do Jan 19 22:51:35 2023] usbcore: registered new interface driver hub
                            [Do Jan 19 22:51:35 2023] usbcore: registered new device driver usb
                            [Do Jan 19 22:51:35 2023] usb_phy_generic phy: supply vcc not found, using dummy regulator
                            [Do Jan 19 22:51:35 2023] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
                            [Do Jan 19 22:51:35 2023] pps_core: LinuxPPS API ver. 1 registered
                            [Do Jan 19 22:51:35 2023] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
                            [Do Jan 19 22:51:35 2023] PTP clock support registered
                            [Do Jan 19 22:51:35 2023] clocksource: Switched to clocksource arch_sys_counter
                            [Do Jan 19 22:51:35 2023] VFS: Disk quotas dquot_6.6.0
                            [Do Jan 19 22:51:35 2023] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                            [Do Jan 19 22:51:35 2023] FS-Cache: Loaded
                            [Do Jan 19 22:51:35 2023] CacheFiles: Loaded
                            [Do Jan 19 22:51:35 2023] NET: Registered PF_INET protocol family
                            [Do Jan 19 22:51:35 2023] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                            [Do Jan 19 22:51:35 2023] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                            [Do Jan 19 22:51:35 2023] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                            [Do Jan 19 22:51:35 2023] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                            [Do Jan 19 22:51:35 2023] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                            [Do Jan 19 22:51:35 2023] TCP: Hash tables configured (established 8192 bind 8192)
                            [Do Jan 19 22:51:35 2023] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                            [Do Jan 19 22:51:35 2023] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                            [Do Jan 19 22:51:35 2023] NET: Registered PF_UNIX/PF_LOCAL protocol family
                            [Do Jan 19 22:51:35 2023] RPC: Registered named UNIX socket transport module.
                            [Do Jan 19 22:51:35 2023] RPC: Registered udp transport module.
                            [Do Jan 19 22:51:35 2023] RPC: Registered tcp transport module.
                            [Do Jan 19 22:51:35 2023] RPC: Registered tcp NFSv4.1 backchannel transport module.
                            [Do Jan 19 22:51:35 2023] PCI: CLS 0 bytes, default 64
                            [Do Jan 19 22:51:36 2023] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
                            [Do Jan 19 22:51:36 2023] Initialise system trusted keyrings
                            [Do Jan 19 22:51:36 2023] workingset: timestamp_bits=14 max_order=21 bucket_order=7
                            [Do Jan 19 22:51:36 2023] zbud: loaded
                            [Do Jan 19 22:51:36 2023] FS-Cache: Netfs 'nfs' registered for caching
                            [Do Jan 19 22:51:36 2023] NFS: Registering the id_resolver key type
                            [Do Jan 19 22:51:36 2023] Key type id_resolver registered
                            [Do Jan 19 22:51:36 2023] Key type id_legacy registered
                            [Do Jan 19 22:51:36 2023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                            [Do Jan 19 22:51:36 2023] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                            [Do Jan 19 22:51:36 2023] Key type asymmetric registered
                            [Do Jan 19 22:51:36 2023] Asymmetric key parser 'x509' registered
                            [Do Jan 19 22:51:36 2023] bounce: pool size: 64 pages
                            [Do Jan 19 22:51:36 2023] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                            [Do Jan 19 22:51:36 2023] io scheduler mq-deadline registered
                            [Do Jan 19 22:51:36 2023] io scheduler kyber registered
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                            [Do Jan 19 22:51:36 2023] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                            [Do Jan 19 22:51:36 2023] pci_bus 0000:00: root bus resource [bus 00-ff]
                            [Do Jan 19 22:51:36 2023] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                            [Do Jan 19 22:51:36 2023] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                            [Do Jan 19 22:51:36 2023] pci 0000:00:00.0: PME# supported from D0 D3hot
                            [Do Jan 19 22:51:36 2023] PCI: bus0: Fast back to back transfers disabled
                            [Do Jan 19 22:51:36 2023] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                            [Do Jan 19 22:51:36 2023] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                            [Do Jan 19 22:51:36 2023] pci 0000:01:00.0: PME# supported from D0 D3hot
                            [Do Jan 19 22:51:36 2023] PCI: bus1: Fast back to back transfers disabled
                            [Do Jan 19 22:51:36 2023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                            [Do Jan 19 22:51:36 2023] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                            [Do Jan 19 22:51:36 2023] pci 0000:00:00.0: PCI bridge to [bus 01]
                            [Do Jan 19 22:51:36 2023] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                            [Do Jan 19 22:51:36 2023] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                            [Do Jan 19 22:51:36 2023] pcieport 0000:00:00.0: PME: Signaling with IRQ 59
                            [Do Jan 19 22:51:36 2023] iproc-rng200 fe104000.rng: hwrng registered
                            [Do Jan 19 22:51:36 2023] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                            [Do Jan 19 22:51:36 2023] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                            [Do Jan 19 22:51:36 2023] brd: module loaded
                            [Do Jan 19 22:51:36 2023] loop: module loaded
                            [Do Jan 19 22:51:36 2023] Loading iSCSI transport class v2.0-870.
                            [Do Jan 19 22:51:36 2023] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                            [Do Jan 19 22:51:36 2023] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver r8152
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver lan78xx
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver smsc95xx
                            [Do Jan 19 22:51:36 2023] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            [Do Jan 19 22:51:36 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                            [Do Jan 19 22:51:36 2023] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
                            [Do Jan 19 22:51:36 2023] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                            [Do Jan 19 22:51:36 2023] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                            [Do Jan 19 22:51:36 2023] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
                            [Do Jan 19 22:51:36 2023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            [Do Jan 19 22:51:36 2023] usb usb1: Product: xHCI Host Controller
                            [Do Jan 19 22:51:36 2023] usb usb1: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
                            [Do Jan 19 22:51:36 2023] usb usb1: SerialNumber: 0000:01:00.0
                            [Do Jan 19 22:51:36 2023] hub 1-0:1.0: USB hub found
                            [Do Jan 19 22:51:36 2023] hub 1-0:1.0: 1 port detected
                            [Do Jan 19 22:51:36 2023] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
                            [Do Jan 19 22:51:36 2023] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            [Do Jan 19 22:51:36 2023] usb usb2: Product: xHCI Host Controller
                            [Do Jan 19 22:51:36 2023] usb usb2: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
                            [Do Jan 19 22:51:36 2023] usb usb2: SerialNumber: 0000:01:00.0
                            [Do Jan 19 22:51:36 2023] hub 2-0:1.0: USB hub found
                            [Do Jan 19 22:51:36 2023] hub 2-0:1.0: 4 ports detected
                            [Do Jan 19 22:51:36 2023] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                            [Do Jan 19 22:51:36 2023] dwc_otg: FIQ enabled
                            [Do Jan 19 22:51:36 2023] dwc_otg: NAK holdoff enabled
                            [Do Jan 19 22:51:36 2023] dwc_otg: FIQ split-transaction FSM enabled
                            [Do Jan 19 22:51:36 2023] Module dwc_common_port init
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver uas
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver usb-storage
                            [Do Jan 19 22:51:36 2023] mousedev: PS/2 mouse device common for all mice
                            [Do Jan 19 22:51:36 2023] sdhci: Secure Digital Host Controller Interface driver
                            [Do Jan 19 22:51:36 2023] sdhci: Copyright(c) Pierre Ossman
                            [Do Jan 19 22:51:36 2023] sdhci-pltfm: SDHCI platform and OF driver helper
                            [Do Jan 19 22:51:36 2023] ledtrig-cpu: registered to indicate activity on CPUs
                            [Do Jan 19 22:51:36 2023] hid: raw HID events driver (C) Jiri Kosina
                            [Do Jan 19 22:51:36 2023] usbcore: registered new interface driver usbhid
                            [Do Jan 19 22:51:36 2023] usbhid: USB HID core driver
                            [Do Jan 19 22:51:36 2023] Initializing XFRM netlink socket
                            [Do Jan 19 22:51:36 2023] NET: Registered PF_PACKET protocol family
                            [Do Jan 19 22:51:36 2023] Key type dns_resolver registered
                            [Do Jan 19 22:51:36 2023] Registering SWP/SWPB emulation handler
                            [Do Jan 19 22:51:36 2023] registered taskstats version 1
                            [Do Jan 19 22:51:36 2023] Loading compiled-in X.509 certificates
                            [Do Jan 19 22:51:36 2023] Key type .fscrypt registered
                            [Do Jan 19 22:51:36 2023] Key type fscrypt-provisioning registered
                            [Do Jan 19 22:51:36 2023] uart-pl011 fe201000.serial: there is not valid maps for state default
                            [Do Jan 19 22:51:36 2023] uart-pl011 fe201000.serial: cts_event_workaround enabled
                            [Do Jan 19 22:51:36 2023] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 32, base_baud = 0) is a PL011 rev2
                            [Do Jan 19 22:51:36 2023] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                            [Do Jan 19 22:51:36 2023] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                            [Do Jan 19 22:51:36 2023] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                            [Do Jan 19 22:51:36 2023] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                            [Do Jan 19 22:51:36 2023] of_cfs_init
                            [Do Jan 19 22:51:36 2023] of_cfs_init: OK
                            [Do Jan 19 22:51:36 2023] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                            [Do Jan 19 22:51:36 2023] Waiting for root device PARTUUID=4e9ce0cb-02...
                            [Do Jan 19 22:51:36 2023] mmc1: new high speed SDIO card at address 0001
                            [Do Jan 19 22:51:36 2023] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                            [Do Jan 19 22:51:36 2023] mmcblk0: mmc0:aaaa SM32G 29.7 GiB
                            [Do Jan 19 22:51:36 2023]  mmcblk0: p1 p2
                            [Do Jan 19 22:51:36 2023] mmcblk0: mmc0:aaaa SM32G 29.7 GiB (quirks 0x00004000)
                            [Do Jan 19 22:51:36 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Do Jan 19 22:51:36 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Do Jan 19 22:51:36 2023] devtmpfs: mounted
                            [Do Jan 19 22:51:36 2023] Freeing unused kernel image (initmem) memory: 2048K
                            [Do Jan 19 22:51:36 2023] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                            [Do Jan 19 22:51:36 2023] Run /sbin/init as init process
                            [Do Jan 19 22:51:36 2023]   with arguments:
                            [Do Jan 19 22:51:36 2023]     /sbin/init
                            [Do Jan 19 22:51:36 2023]   with environment:
                            [Do Jan 19 22:51:36 2023]     HOME=/
                            [Do Jan 19 22:51:36 2023]     TERM=linux
                            [Do Jan 19 22:51:37 2023] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                            [Do Jan 19 22:51:37 2023] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                            [Do Jan 19 22:51:37 2023] usb 1-1: Product: USB2.0 Hub
                            [Do Jan 19 22:51:37 2023] hub 1-1:1.0: USB hub found
                            [Do Jan 19 22:51:37 2023] hub 1-1:1.0: 4 ports detected
                            [Do Jan 19 22:51:37 2023] systemd[1]: System time before build time, advancing clock.
                            [Do Jan 19 22:51:37 2023] NET: Registered PF_INET6 protocol family
                            [Do Jan 19 22:51:37 2023] Segment Routing with IPv6
                            [Do Jan 19 22:51:37 2023] In-situ OAM (IOAM) with IPv6
                            [Do Jan 19 22:51:37 2023] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
                            [Do Jan 19 22:51:37 2023] systemd[1]: Detected architecture arm.
                            [Do Jan 19 22:51:37 2023] systemd[1]: Set hostname to .
                            [Do Jan 19 22:51:38 2023] systemd[1]: Queued start job for default target Graphical Interface.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Created slice system-getty.slice.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Created slice system-modprobe.slice.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Created slice User and Session Slice.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Reached target Local Encrypted Volumes.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Reached target Paths.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Reached target Slices.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Reached target Swap.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on Syslog Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on fsck to fsckd communication Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on initctl Compatibility Named Pipe.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on Journal Audit Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on Journal Socket (/dev/log).
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on Journal Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on udev Control Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Listening on udev Kernel Socket.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting POSIX Message Queue File System...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting RPC Pipe File System...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting Kernel Debug File System...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting Kernel Trace File System...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Restore / save the current clock...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Set the console keyboard layout...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Create list of static device nodes for the current kernel...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Load Kernel Module configfs...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Load Kernel Module drm...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Load Kernel Module fuse...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting File System Check on Root Device...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Journal Service...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Load Kernel Modules...
                            [Do Jan 19 22:51:38 2023] fuse: init (API version 7.34)
                            [Do Jan 19 22:51:38 2023] systemd[1]: Starting Coldplug All udev Devices...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounted POSIX Message Queue File System.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounted RPC Pipe File System.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounted Kernel Debug File System.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounted Kernel Trace File System.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Finished Restore / save the current clock.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Finished Create list of static device nodes for the current kernel.
                            [Do Jan 19 22:51:38 2023] systemd[1]: modprobe@configfs.service: Succeeded.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Finished Load Kernel Module configfs.
                            [Do Jan 19 22:51:38 2023] systemd[1]: modprobe@fuse.service: Succeeded.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Finished Load Kernel Module fuse.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Finished Load Kernel Modules.
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting FUSE Control File System...
                            [Do Jan 19 22:51:38 2023] systemd[1]: Mounting Kernel Configuration File System...
                            [Do Jan 19 22:51:39 2023] systemd[1]: Started File System Check Daemon to report status.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Starting Apply Kernel Variables...
                            [Do Jan 19 22:51:39 2023] systemd[1]: Mounted FUSE Control File System.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Mounted Kernel Configuration File System.
                            [Do Jan 19 22:51:39 2023] systemd[1]: modprobe@drm.service: Succeeded.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Finished Load Kernel Module drm.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Finished Apply Kernel Variables.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Finished File System Check on Root Device.
                            [Do Jan 19 22:51:39 2023] systemd[1]: Starting Remount Root and Kernel File Systems...
                            [Do Jan 19 22:51:39 2023] systemd[1]: Started Journal Service.
                            [Do Jan 19 22:51:39 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                            [Do Jan 19 22:51:39 2023] systemd-journald[142]: Received client request to flush runtime journal.
                            [Do Jan 19 22:51:39 2023] systemd-journald[142]: File /var/log/journal/b34e21cdd83e475ea4c67d784731758d/system.journal corrupted or uncleanly shut down, renaming and replacing.
                            [Do Jan 19 22:51:40 2023] mc: Linux media interface: v0.10
                            [Do Jan 19 22:51:40 2023] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:40 2023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                            [Do Jan 19 22:51:40 2023] [vc_sm_connected_init]: start
                            [Do Jan 19 22:51:40 2023] [vc_sm_connected_init]: installed successfully
                            [Do Jan 19 22:51:40 2023] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:40 2023] videodev: Linux video capture interface: v2.00
                            [Do Jan 19 22:51:40 2023] bcm2835_audio bcm2835_audio: card created with 8 channels
                            [Do Jan 19 22:51:40 2023] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                            [Do Jan 19 22:51:40 2023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            [Do Jan 19 22:51:41 2023] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            [Do Jan 19 22:51:41 2023] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
                            [Do Jan 19 22:51:41 2023] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                            [Do Jan 19 22:51:41 2023] rpivid feb10000.codec: Device registered as /dev/video19
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                            [Do Jan 19 22:51:41 2023] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                            [Do Jan 19 22:51:41 2023] brcmfmac: F1 signature read @0x18000000=0x15264345
                            [Do Jan 19 22:51:41 2023] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            [Do Jan 19 22:51:41 2023] usbcore: registered new interface driver brcmfmac
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                            [Do Jan 19 22:51:41 2023] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                            [Do Jan 19 22:51:41 2023] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
                            [Do Jan 19 22:51:41 2023] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                            [Do Jan 19 22:51:41 2023] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                            [Do Jan 19 22:51:41 2023] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                            [Do Jan 19 22:51:42 2023] 8021q: 802.1Q VLAN Support v1.8
                            [Do Jan 19 22:51:42 2023] uart-pl011 fe201000.serial: no DMA platform data
                            [Do Jan 19 22:51:42 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                            [Do Jan 19 22:51:42 2023] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                            [Do Jan 19 22:51:43 2023] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                            [Do Jan 19 22:51:43 2023] bcmgenet fd580000.ethernet eth0: Link is Down
                            [Do Jan 19 22:51:47 2023] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                            [Do Jan 19 22:51:47 2023] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                            [Do Jan 19 22:51:50 2023] Bluetooth: Core ver 2.22
                            [Do Jan 19 22:51:50 2023] NET: Registered PF_BLUETOOTH protocol family
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI device and connection manager initialized
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI socket layer initialized
                            [Do Jan 19 22:51:50 2023] Bluetooth: L2CAP socket layer initialized
                            [Do Jan 19 22:51:50 2023] Bluetooth: SCO socket layer initialized
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI UART driver ver 2.3
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI UART protocol H4 registered
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            [Do Jan 19 22:51:50 2023] Bluetooth: HCI UART protocol Broadcom registered
                            [Do Jan 19 22:51:50 2023] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            [Do Jan 19 22:51:50 2023] Bluetooth: BNEP filters: protocol multicast
                            [Do Jan 19 22:51:50 2023] Bluetooth: BNEP socket layer initialized
                            [Do Jan 19 22:51:50 2023] NET: Registered PF_ALG protocol family
                            [Do Jan 19 22:51:51 2023] cryptd: max_cpu_qlen set to 1000
                            [Do Jan 19 22:51:54 2023] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                            [Do Jan 19 22:52:06 2023] cam-dummy-reg: disabling
                            [Do Jan 19 22:53:20 2023] FS-Cache: Netfs 'cifs' registered for caching
                            [Do Jan 19 22:53:20 2023] Key type cifs.spnego registered
                            [Do Jan 19 22:53:20 2023] Key type cifs.idmap registered
                            [Do Jan 19 22:53:20 2023] CIFS: Attempting to mount \\192.168.1.99\SmartHome
                            [Fr Jan 20 08:01:09 2023] CIFS: Attempting to mount \\192.168.1.99\SmartHome
                            pi@raspberrypi:~ $
                            Glasfaser 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @Naturfreund last edited by
                              Sehe gerade, die Uhrzeit stimmt nicht:
                              habe ich hier schon ganz am Anfag geschrieben :
                              @crunchip
                              2023-01-08 05:09:53.776 - warn: influxdb.0 (13722) Error on writePoint("{"value":1030.9249,"time":"2023-01-08T04:09:52.757Z","from":"system.adapter.sma-em.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8086""
                              ich lese das so , der Raspberry hat die Zeit 5:09 Uhr und er will den Wert von 4:09 Uhr schreiben .
                              Da passt doch was nicht zusammen , aber ich denke mal nicht das deswegen ein ECONNREFUSED kommt!?
                              • Glasfaser
                                @naturfreund
                                Warum Editiertst du deine Antworten !?
                                N 1 Reply Last reply Reply Quote 1
                                  Thomas Braun Most Active @Glasfaser last edited by
                                  Ich schon.
                                  Zeitreisenden wird der Zugriff verwehrt.
                                  Wenn Netzwerkverkehr mit unplausiblen Timestamps ankommt wird der in der Regel verworfen.
                                  • Glasfaser
                                    Glasfaser @Thomas Braun last edited by
                                    @thomas-braun sagte in InfluxDB - Daten weg / Wiederherstellung:
                                    • N
                                      @glasfaser
                                      pi@raspberrypi:~ $ o date
                                      Fr 20. Jan 18:42:01 CET 2023
                                      pi@raspberrypi:~ $
                                      • N
                                        pi@raspberrypi:~ $
                                        tail /var/log/syslog
                                        Jan 20 18:33:06 raspberrypi influxd-systemd-start.sh[24116]: ts=2023-01-20T17:33:06.755452Z lvl=info msg="Retention policy deletion check (start)" log_id=0fVnTtnl000 service=retention trace_id=0fW3hcGl000 op_name=retention_delete_check op_event=start
                                        Jan 20 18:33:07 raspberrypi influxd-systemd-start.sh[24116]: ts=2023-01-20T17:33:06.756521Z lvl=info msg="Retention policy deletion check (end)" log_id=0fVnTtnl000 service=retention trace_id=0fW3hcGl000 op_name=retention_delete_check op_event=end op_elapsed=1.094ms
                                        Jan 20 18:33:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        Jan 20 18:34:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        Jan 20 18:34:54 raspberrypi influxd-systemd-start.sh[24116]: [httpd] 127.0.0.1 - admin [20/Jan/2023:18:34:53 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" bffefd66-98e8-11ed-80f6-dca632cbfb79 71156
                                        Jan 20 18:35:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        Jan 20 18:36:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        Jan 20 18:37:20 raspberrypi influxd-systemd-start.sh[24116]: [httpd] 127.0.0.1 - admin [20/Jan/2023:18:37:20 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 171a3a3b-98e9-11ed-80f7-dca632cbfb79 78099
                                        Jan 20 18:37:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        Jan 20 18:38:32 raspberrypi bash[683]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                        • Glasfaser
                                          @naturfreund
                                          Was sagt :
                                          date -u && date && date +"%Z %z" && cat /etc/timezone
                                          • N
                                            @glasfaser
                                            pi@raspberrypi:~ $ date -u && date && date +"%Z %z" && cat /etc/timezone
                                            Fr 20. Jan 18:14:49 UTC 2023
                                            Fr 20. Jan 19:14:49 CET 2023
                                            CET +0100
                                            Europe/Berlin
                                            pi@raspberrypi:~ $
                                            11531
