    3. Entwicklung
    4. Ecovacs Deebot Adapter: Status und Feedback
    • mrbungle64
      mrbungle64 Developer @jm3west last edited by
      @jm3west
      Dieser Fehler sollte jetzt übrigens auch nicht mehr kommen 😉
      warn  received error event with code '-2' and message 'resultData.repeat.split is not a function'
      Falls doch, sag bitte mal bescheid
        jm3west @mrbungle64 last edited by
        Ich trau mich es gar nicht zu posten ....
         warn  got payload for unknown command 'onSimpleARMapSet': {"type":"ar","speechVer":"2.0","mid":"732490256","msid":"1863920572","subsets":[{"name":"Esszimmer1","mssid":"1","subtype":"2","totalCount":0},{"name":"","mssid":"2","subtype":"1","totalCount":0},{"name":"Küche1","mssid":"3","subtype":"5","totalCount":0},{"name":"Schlafzimmer1","mssid":"6","subtype":"3","totalCount":0},{"name":"Flur1","mssid":"8","subtype":"12","totalCount":0},{"name":"Badezimmer2","mssid":"7","subtype":"6","totalCount":0}]}
         MQTT  iot/atr/onSched_V2/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onSched_V2
         payload  {"header":{"pri":1,"tzm":60,"ts":"1674393364941","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{}}
         event  Error resultData.repeat.split is not a function
         MQTT  iot/atr/onNextSched/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onNextSched
         payload
         warn  got payload for unknown command 'onNextSched': []
         MQTT  iot/atr/onFwBuryPoint-areasInfo/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onFwBuryPoint-areasInfo
         payload  {"header":{"pri":1,"tzm":60,"ts":"1674393364960","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{"gid":"G1674393364934","index":"0000001272","ts":"1674393364934","mid":732490256,"areas":[{"id":1,"name":"Esszimmer1","type":2,"priority":0,"waterLevel":2,"fanLevel":1,"cleanCnt":2},{"id":2,"name":"","type":1,"priority":0,"waterLevel":0,"fanLevel":1,"cleanCnt":1},{"id":3,"name":"Küche1","type":5,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1},{"id":6,"name":"Schlafzimmer1","type":3,"priority":0,"waterLevel":2,"fanLevel":1,"cleanCnt":2},{"id":8,"name":"Flur1","type":12,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":2},{"id":7,"name":"Badezimmer2","type":6,"priority":0,"waterLevel":1,"fanLevel":0,"cleanCnt":1}]}}
         warn  got payload for unknown command 'onFwBuryPoint-areasInfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674393364960\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674393364934\",\"index\":\"0000001272\",\"ts\":\"1674393364934\",\"mid\":732490256,\"areas\":[{\"id\":1,\"name\":\"Esszimmer1\",\"type\":2,\"priority\":0,\"waterLevel\":2,\"fanLevel\":1,\"cleanCnt\":2},{\"id\":2,\"name\":\"\",\"type\":1,\"priority\":0,\"waterLevel\":0,\"fanLevel\":1,\"cleanCnt\":1},{\"id\":3,\"name\":\"Küche1\",\"type\":5,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":6,\"name\":\"Schlafzimmer1\",\"type\":3,\"priority\":0,\"waterLevel\":2,\"fanLevel\":1,\"cleanCnt\":2},{\"id\":8,\"name\":\"Flur1\",\"type\":12,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":2},{\"id\":7,\"name\":\"Badezimmer2\",\"type\":6,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1}]}}"
         MQTT  iot/atr/onNextVideoSched/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onNextVideoSched
         payload
         warn  got payload for unknown command 'onNextVideoSched': []
         MQTT  iot/atr/onFwBuryPoint-bd_mapinfo/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onFwBuryPoint-bd_mapinfo
         payload  {"header":{"pri":1,"tzm":60,"ts":"1674393365440","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{"gid":"G1674393365410","index":"0000001273","ts":"1674393365410","mapinfos":[{"mapid":0,"name":"","savemapType":0,"isActive":0,"isRecentMap":0,"cleanCount":0,"priority":0},{"mapid":732490256,"name":"OG Loft","savemapType":1,"isActive":1,"isRecentMap":1,"cleanCount":2,"priority":28},{"mapid":0,"name":"","savemapType":2,"isActive":0,"isRecentMap":0,"cleanCount":0,"priority":0},{"mapid":0,"name":"","savemapType":3,"isActive":0,"isRecentMap":0,"cleanCount":0,"priority":0}]}}
         warn  got payload for unknown command 'onFwBuryPoint-bd_mapinfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674393365440\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674393365410\",\"index\":\"0000001273\",\"ts\":\"1674393365410\",\"mapinfos\":[{\"mapid\":0,\"name\":\"\",\"savemapType\":0,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":732490256,\"name\":\"OG Loft\",\"savemapType\":1,\"isActive\":1,\"isRecentMap\":1,\"cleanCount\":2,\"priority\":28},{\"mapid\":0,\"name\":\"\",\"savemapType\":2,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":0,\"name\":\"\",\"savemapType\":3,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0}]}}"
         MQTT  iot/atr/onFwBuryPoint-bd_setting-evt/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onFwBuryPoint-bd_setting-evt
         payload  {"header":{"pri":1,"tzm":60,"ts":"1674393372891","ver":"0.0.1","fwVer":"2.3.9","hwVer":"0.1.1","wkVer":"0.1.54"},"body":{"gid":"G1674393372885","index":"0000001274","ts":"1674393372885","orig":{"personalClean":1},"new":{"personalClean":0}}}
         MQTT  iot/atr/onCleanPreference/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onCleanPreference
         payload
        { enable: 0 }
         result  cleanPreference: 0
         MQTT  iot/atr/onCustomAreaMode/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onCustomAreaMode
         payload
        { sweepMode: 0 }
         warn  got payload for unknown command 'onCustomAreaMode': {"sweepMode":0}
         MQTT  iot/atr/onEvt/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onEvt
         payload
        { code: 1141 }
         warn  Unhandled Evt code: '1141'
         MQTT  iot/atr/onSweepMode/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onSweepMode
         payload
        { type: 0 }
         MQTT  iot/atr/onBorderSpin/98904d32-fe49-4040-92a1-2a7e49d2cd82/1vxt52/bCpp/j
         MQTT  onBorderSpin
         payload
        { enable: 0, type: 1 }
         result  BorderSpin: 0
        mrbungle64 2 Replies Last reply Reply Quote 0
        • mrbungle64
          mrbungle64 Developer @jm3west last edited by mrbungle64
          @jm3west sagte in Ecovacs Deebot Adapter: Status und Feedback:
          Ist ja nicht schlimm, dann muss ich da halt noch mal ran 😉
          bekomme ich schon noch gefixt
          ist kein Fehler - der Code könnte halt irgendwann mal "entschlüsselt" werden 😉
          Sonst noch was in deiner Ausgabe was dir "Sorgen" macht?
          • mrbungle64
            @jm3west
            Wenn du möchtest kannst du mal die Version 1.4.12-alpha.10 von GitHub testen, ob wir den "Ecken-Tiefenreinigung" Modus ("control.extended.edgeDeepCleaning") und den "Nur wischen" Modus ("control.extended.mopOnlyMode") erfolgreich integriert bekommen haben 😉
            mrbungle64 1 Reply Last reply Reply Quote 0
            • mrbungle64
              mrbungle64 Developer @mrbungle64 last edited by mrbungle64
              @mrbungle64 sagte in Ecovacs Deebot Adapter: Status und Feedback:
              @jm3west
              @jm3west
              In der 1.4.12-alpha.11 gibt es nun auch den Datenpunkt "info.extended.sweepMode" für den "Wischmodus" - der ist aber aktuell nur read-only. Da müssten wir erstmal schauen, was es mit diesem "CustomAreaMode" noch so alles auf sich hat, bevor das auch in die andere Richtung übertragen werden kann. Ich kann das hier ja aktuell leider nicht nachstellen bzw. testen.
                jm3west @mrbungle64 last edited by jm3west
                @mrbungle64 mal was ganz vertrauensvolles.
                Wie wäre es wenn ich Dir eine Freigabe erteilen würde.
                Könntest Du dann bei Dir debuggen (Technisch gesehen).
                Nicht das ich kein Interesse mehr hätte. Aber es gibt da noch einiges an Datenpunkte die nicht funktionieren!
                Wie zB. Multiple spot-Reinigung (Nur Ess- und Wohnzimmer). Da spuckt der Debugger auch Warnungen aus.
                Andererseits will ich aber auch nicht das Deine Programmierarbeit was exklusives für meinen OMNI X1 wird!!!
                • mrbungle64
                  Das wäre eine gute Idee 👍
                  Geht das auch sogar direkt? Ich habe nämlich heute noch einen Tag frei - ab morgen nicht mehr.
                  Du kannst das Passwort ja temporär ändern und mir die Zugangsdaten per PM (oder per E-Mail an [entfernt]) schicken.
                  • mrbungle64
                    Meinst du Datenpunkte die nicht funktionieren - oder Datenpunkte die fehlen (das ist ja ein Unterschied)?
                    Ja, diese Funktion wird recht neu sein
                    Ist ja kein Problem - du bist ja nicht der einzige mit einem Deebot X1 😉
                      Freigabe ist raus
                        Ich nehme aber an das es nicht funktioniert. Da die Freigabe ohne Passwort erfolgt! 👎
                        • mrbungle64
                          Ja, das hilft uns nur eingeschränkt weiter 😉
                            Ich habe in einer ruhigen Stunde nochmal die iOS App zur Hand genommen und durchgeklickt.
                            Optionen aus iOS App heraus
                            Reinigungseinstellungen > Standard
                            Wischmodus (Scheinbar Standard und Anpassen weil payload der gleiche ist)
                            Reinigungseinstellungen > Anpassen > Bevorzugter Bereich
                            Da für jedes(n) Zimmer/Bereich drei Einstellmöglichkeiten gibt (Reinigen: 1x/2x; Saugkraft: Leise/Standard/Maximal/Maximal+; Wasserdurchflussrate: niedrig/mittel/hoch) werden diese immer als Gesamtes gespeichert, auch wenn zB. nur 2x reinigen ausgewählt wird.
                            Somit sind die unbekannten payloads immer sie gleichen.
                            warn  got payload for unknown command 'onFwBuryPoint-areasInfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674563558544\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674563558521\",\"index\":\"0000000123\",\"ts\":\"1674563558521\",\"mid\":732490256,\"areas\":[{\"id\":1,\"name\":\"Esszimmer1\",\"type\":2,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":2},{\"id\":2,\"name\":\"\",\"type\":1,\"priority\":0,\"waterLevel\":0,\"fanLevel\":1,\"cleanCnt\":1},{\"id\":3,\"name\":\"Küche1\",\"type\":5,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1},{\"id\":6,\"name\":\"Schlafzimmer1\",\"type\":3,\"priority\":0,\"waterLevel\":2,\"fanLevel\":1,\"cleanCnt\":2},{\"id\":8,\"name\":\"Flur1\",\"type\":12,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":2},{\"id\":7,\"name\":\"Badezimmer2\",\"type\":6,\"priority\":0,\"waterLevel\":1,\"fanLevel\":0,\"cleanCnt\":1}]}}"
                            warn  got payload for unknown command 'onFwBuryPoint-bd_mapinfo': "{\"header\":{\"pri\":1,\"tzm\":60,\"ts\":\"1674563558803\",\"ver\":\"0.0.1\",\"fwVer\":\"2.3.9\",\"hwVer\":\"0.1.1\",\"wkVer\":\"0.1.54\"},\"body\":{\"gid\":\"G1674563558794\",\"index\":\"0000000124\",\"ts\":\"1674563558794\",\"mapinfos\":[{\"mapid\":0,\"name\":\"\",\"savemapType\":0,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":732490256,\"name\":\"OG Loft\",\"savemapType\":1,\"isActive\":1,\"isRecentMap\":1,\"cleanCount\":2,\"priority\":26},{\"mapid\":0,\"name\":\"\",\"savemapType\":2,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0},{\"mapid\":0,\"name\":\"\",\"savemapType\":3,\"isActive\":0,\"isRecentMap\":0,\"cleanCount\":0,\"priority\":0}]}}"
                            Das sind eingentlich alle payloads die unbekannt sind.
                            Die die unbekannt waren hast Du/wir ja schon erörtert.
                            Was mir noch aufgefallen ist.
                            Der Datenpunkt ecovacs-deebot.0.control.extended.volume wird von Dir mit Wert 1-10 vorgegeben.
                            Denoch lässt sich in der iOS App der Wert von 0-10 ändern.
                            So wird es auch im datenpunkt ecovacs-deebot.0.control.extended.volume gesetzt.
                            Mal angenommen ich stelle in der iOS App die Lautstärke auf 5 und setzte sie danach im Datenpunkt ecovacs-deebot.0.control.extended.volume auf 0 springt dieser nach einigen Sekunden wieder auf 5
                            • mrbungle64
                              Was ist es denn nun genau?
                              Hier hattest du noch geschrieben, dass das die Werte "Standard" und "Tief" sind:
                              https://forum.iobroker.net/post/933171
                              So hatte ich es dann auch implementiert:
                              https://forum.iobroker.net/post/933874
                                Damit meinte ich dass, wie schon beschrieben, der payload sowohl bei Standard und Anpassen immer gleich sind, mit gleichen Wertepaar.
                                So würde ich es auch von der optischen Aufteilung interpretieren.
                                Sprich beide werden mit den Werten Standard=0; Tief=1 beschrieben.
                                • mrbungle64
                                  @jm3west
                                  Kannst du mir vielleicht doch noch mal für ne Stunde (oder so) deinen Bot freigeben, so dass ich mir mal das User Interface anschauen kann? Irgendwie verstehe ich das wohl noch nicht so ganz, wie Ecovacs das nun beim X1 aufgebaut hat ...
                                    @mrbungle64 gerne!
                                    Aber Du denkst nicht an heute noch?
                                    • mrbungle64
                                      @mrbungle64 gerne!
                                      Falls das für dich kein Problem ist wäre jetzt direkt ganz günstig für mich 🙂
                                        @mrbungle64 nun für mich nicht.
                                        Aber für jemand anderen der hier sitzt 👱‍♀️
                                        Wir hätten aber doch noch immer das debug-Problem. Da die Freigabe ja kein Passwort hat.
                                        Man musste ja ein VPN-Tunnel erstellen
                                        • mrbungle64
                                          Alles klar 😉 Für mich kein Problem - ich weiß auch ansonsten was mit meiner Zeit anzufangen 😉
                                          Das verstehe ich gerade nicht, zwischen welchen Endpunkten du dafür einen VPN-Tunnel aufbauen willst ...
                                          Ich muss mich mit deinen Zugangsdaten authentifizieren, damit ich mit deinem Bot sprechen und dazu eine Ausgabe über die Library bekomme ...
                                          Wie bereits mitgeteilt habe ich ja sowieso schon ein paar Dinge für den X1 umgesetzt. Wir werden dann früher oder später sehen, ob es funktioniert 😉
                                          J T 2 Replies Last reply Reply Quote 0
                                            @mrbungle64 ach so, das habe ich falsch verstanden.
                                            OK. lass' uns morgen darüber quatschen.
                                            Melde dich wenn du morgen bereit bist
                                            deebot ecovacs ecovacs-deebot ecovacs-deebot adapter saugroboter vacuum
                                            36
                                            576
                                            140093
