    5. Fehler javascript.1 (818) at Object.<anonymous>
    • wauzzi
      wauzzi last edited by Homoran
      Hallo IO Broker Gemeinde,
      ich habe -wie gewohnt- ein harmloses Blockly Skript entwickelt.
      Das Skript funktioniert wie es soll, jedoch erscheint immer wieder die Meldung "javascript.1 (818) at Object.<anonymous> (script.js.Test.TibberBlockly:4:5)"
        <block type="comment" id="cjAXfrHzVfB$0/|{M;=?" x="-674" y="-482">
          <field name="COMMENT">SUN2000 An/Aus</field>
            <block type="on_ext" id="q36`2xwzX/7}8Q@9#FdM">
              <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
              <value name="OID0">
                <shadow type="field_oid" id=".`}0$y^/Qgwo#uCd`{g-">
                  <field name="oid">ManuelleStates.0.Wallbox_Aktueller_Zaehlerstand.Wallbox_Stomverbrauch_Aktuell</field>
              <value name="OID1">
                <shadow type="field_oid" id="1H(K3@S^}et_H6#zbsks">
                  <field name="oid">fritzdect.0.DECT_087610364944.power</field>
              <value name="OID2">
                <shadow type="field_oid" id="LIoaL!pcv7MdEOiSjvNb">
                  <field name="oid">sonoff.0.Trockner.ENERGY_Power</field>
                <block type="controls_if" id="I6pY1{.-gYD{$fWhXuy=">
                    <block type="logic_compare" id="R)7QuYwl2p-m3VEY33J(">
                      <field name="OP">EQ</field>
                        <block type="get_value" id="S)5XowwmT4j,HmYuNy;o">
                          <field name="OID">0_userdata.0.Powerwall.Akkubetrieb</field>
                        <block type="logic_boolean" id="T:ZA@R.j0U/4,H=MicEd">
                    <block type="control" id="fJq(Cj[sv`%wh%0jdd{|">
                      <field name="OID">mqtt.0.SUN2000.ACSetpointOVR</field>
                        <block type="math_round" id="A*g)tBtA4e8W7,28]mRf">
                          <field name="OP">ROUNDDOWN</field>
                          <value name="NUM">
                            <shadow type="math_number" id="BY(ka-dm.5vUj`SG5{5N">
                              <field name="NUM">3.1</field>
                            <block type="math_on_list" id="mydSFuz~HqFl{;SdUWRi">
                              <mutation op="SUM"></mutation>
                              <field name="OP">SUM</field>
                              <value name="LIST">
                                <block type="lists_create_with" id="K^De_]%UR*7V`/ORJxq%">
                                  <mutation items="4"></mutation>
                                  <value name="ADD0">
                                    <block type="math_number" id="j*3J!VFM]ud5y,Z~@q;a">
                                      <field name="NUM">140</field>
                                  <value name="ADD1">
                                    <block type="math_arithmetic" id="agdMWP#d7K{ip69G=Ob(">
                                        <shadow type="math_number" id="mV%K-*E5mCBFp.`)x%P]">
                                          <field name="NUM">1</field>
                                        <block type="get_value_var" id="f%enDF5|Jpjc9=qOL:~P">
                                          <value name="OID">
                                            <shadow type="text">
                                              <field name="TEXT"></field>
                                            <block type="field_oid" id="nWvzx_+?@K/Mcdd$rj|B">
                                        <shadow type="math_number" id="eSx+lqC7y:c^l5vI$(^+">
                                          <field name="NUM">1000</field>
                                  <value name="ADD2">
                                    <block type="get_value_var" id="x3x5l#5T47XH(2[`pYU:">
                                      <value name="OID">
                                        <block type="field_oid" id="`X]S|U@{,3RIa+L2*c7]">
                                  <value name="ADD3">
                                    <block type="get_value_var" id="?Rq9u=V!,83$Q%.h}VI(">
                                      <value name="OID">
                                        <block type="field_oid" id="GkIxLcUJG2|vT}NqA?V8">
                        <block type="control" id="u2l.BS}idU+`-Z,22Raf">
                          <field name="OID">0_userdata.0.Powerwall.Ladebetrieb</field>
                            <block type="logic_boolean" id="cCI`;XF]BD$W;?e8:0_3">
                    <block type="controls_if" id="e+KHk;^aE}r{%hsf[(8y">
                        <block type="logic_compare" id="ELY?Fy*L?12%IpReKij8">
                            <block type="get_value" id="``ILgl?.!cFqkjqxRPtR">
                            <block type="logic_boolean" id="cNPAewa75$Rns4/{t~@m">
                        <block type="control" id="1ZwOs*s4zbWV{W1.PFbK">
                            <block type="math_number" id="i~C}VVTtku]/dB6-rR44">
                              <field name="NUM">0</field>
                <block type="on" id="(3E|~dT0=2]kV~tD*/)5">
                  <field name="CONDITION">false</field>
                    <block type="control" id="BHGJg.[C^fTB^Bl5knb,">
                      <field name="OID">mqtt.1.LFP_Hausspeicher_BMS.DALY-BMS-to-MQTT.Device_Control.Pack_DischargeFET</field>
                      <field name="DELAY_MS">15</field>
                        <block type="logic_boolean" id="s?J{NS?8ZF?|+*AKx@N:">
                    <block type="on" id=",C?P*s^sNwj:[IX2y;`a">
                        <block type="control" id="R|+Jx$lI%(#CbF+6O;Ra">
                            <block type="logic_boolean" id="a~EmG1o4p3!1)rW_7PJS">
                        <block type="comment" id="5Y]vW|]0lW]HYMUHAmo(">
                          <field name="COMMENT">HuaweiR4850G2_CAN_BUS_Control</field>
                            <block type="on_ext" id="G.L2_3QHaA{M^n%zeafr">
                              <value name="OID0">
                                <shadow type="field_oid" id="-6f]MQG:*A51Yc8{-t:O">
                                  <field name="oid">0_userdata.0.Powerwall.Ladebetrieb</field>
                              <value name="OID1">
                                <shadow type="field_oid" id="TvEEJ+^E73t;Z)/vHqme">
                                  <field name="oid">0_userdata.0.Powerwall.Ladestaerke_A</field>
                                <block type="controls_if" id="vGnnWDvh2VaWz4-~HE(I">
                                    <block type="logic_compare" id="OZ|y:x(m/~F=Yz}y{HxD">
                                        <block type="get_value" id="4lkVmsrh;vy~k_~OcHzN">
                                        <block type="logic_boolean" id="@lVHQ9qBJJzx$=!h/5(l">
                                    <block type="request" id=".-.g_-=L9s(9m%2gSRcE">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                      <field name="WITH_STATEMENT">FALSE</field>
                                      <field name="LOG"></field>
                                      <value name="URL">
                                        <shadow type="text" id=";`Vij$3_oWQ16om4gM/6">
                                          <field name="TEXT">http://192.168.2.59/System?SM=Online&amp;V=56.8&amp;A=0&amp;P1V=56.8&amp;P1A=50&amp;P2V=56.8&amp;P2A=25&amp;P3V=&amp;P3A=</field>
                                        <block type="control" id=".C+,_W?%N4`3!b*NJ+L$">
                                          <field name="OID">zigbee.1.7cb03eaa00b1b43e.state</field>
                                          <field name="DELAY_MS">30</field>
                                            <block type="logic_boolean" id="E?ayDlwpnr^cj(q!8Li]">
                                    <block type="controls_if" id="]++grqQk}f{mJB24zyss">
                                        <block type="logic_compare" id="XBSOUKh7*Eas@3O^A}7M">
                                            <block type="get_value" id=",tsFu[}}aE{b}$fGUimr">
                                            <block type="logic_boolean" id="jmDj(^A65nj{ltDU_vQ-">
                                        <block type="control" id="I$VHgc55O-a7)wzDgvHr">
                                            <block type="logic_boolean" id="?ZQ?#x]vlB@ylKurL7/7">
                                            <block type="control" id="X7{uq]E|Q_3jzpPZgPm;">
                                                <block type="logic_boolean" id="/Tqn$A[B;?Q%ZXML,Sw[">
                                                <block type="timeouts_wait" id="rCUul@J^Nw.kNZE()yuZ">
                                                  <field name="DELAY">7</field>
                                                    <block type="request" id="gq^O_Re9.3,y/Mj3K,fm">
                                                      <value name="URL">
                                                        <shadow type="text" id="rYT)LRdAmpNs]=E0,nG`">
                                                        <block type="text_join" id="n`8*Rad)P^Tewdt}S3/:">
                                                          <value name="ADD0">
                                                            <block type="text" id="w?Q,0=x5+1zWDi9zhcjI">
                                                              <field name="TEXT">http://192.168.2.59/System?SM=Online&amp;V=56.8&amp;A=</field>
                                                          <value name="ADD1">
                                                            <block type="get_value" id="vUo:T`~]$kj+|@O!.?]`">
                                                              <field name="OID">0_userdata.0.Powerwall.Ladestaerke_A</field>
                                                          <value name="ADD2">
                                                            <block type="text" id="BQd{eSTr%n*1]([dX@{a">
                                                              <field name="TEXT">&amp;P1V=56.8&amp;P1A=50&amp;P2V=56.8&amp;P2A=25&amp;P3V=&amp;P3A=</field>
      Codierknecht paul53 Homoran 3 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @wauzzi last edited by
        @wauzzi
        Pack das bitte in Code-Tags </>.
        So kann (und will) das niemand lesen.
          paul53 @wauzzi last edited by paul53
          @wauzzi
          Ohne das Skript zu kennen: Im Tab "Protokolle" erhält meine weitere Informationen.
          EDIT: Ist der DP "mqtt.0.SUN2000.ACSetpointOVR" vom Typ Zahl("number")?
            Homoran Global Moderator Administrators @wauzzi last edited by
            @wauzzi bitte immer auch als Screenshot!
            Was soll man am Handy auch mit einem XML?
            • Codierknecht
              Codierknecht Developer Most Active @paul53 last edited by
              @paul53 sagte in Fehler javascript.1 (818) at Object.<anonymous>:
              Würde ja zumindest zur angemeckerten Zeile passen.
              Aber klärt mich mal auf:
              • Was genau bedeutet in der Fehlermeldung das ":4:5"?
                4 ist die Zeile? Und die 5?
              • Wo kommt ManuelleStates.0 her?
              Homoran 2 Replies Last reply Reply Quote 1
                Homoran Global Moderator Administrators @Codierknecht last edited by Homoran
                @codierknecht sagte in Fehler javascript.1 (818) at Object.<anonymous>:
                das 5. Zeichen = setState
                  so wie bei mir Messwerte.0 und Systemvariablen.0
                  • Codierknecht
                    Codierknecht Developer Most Active @Homoran last edited by
                    @homoran sagte in Fehler javascript.1 (818) at Object.<anonymous>:
                    Prömpelt man die selbst da rein? Ohne Adapter und Instanz?
                      früher war alles besser! 😁
                      Da ging das noch
                      wauzzi 1 Reply Last reply Reply Quote 1
                      • wauzzi
                        wauzzi @Homoran last edited by
                        Hallo Zusammen,
                        vielen lieben Dank für Eure zahlreichen Rückmeldungen.
                        Sorry, natürlich hätte ich den Blockly Export in ein Code Tag einbetten müssen.
                        Ich habe den Datenpunkt ACSetpointOVR von String in Number geändert. Jetzt scheint es zu passen.
                        Ihr seid klasse ! Vielen Dank !!!!
                        367
