    3. Einsteigerfragen
    4. Fehlermeldungen bei Backup auf NAS [gelöst]
      Peter666666 @Thomas Braun last edited by Peter666666
      Also so? Oder die restlichen Sachen rauslöschen?
      2023-01-24 12:44:57.248 - error: host.e73f64821262 Invalid request getRepository. "callback" or "from" is null
      2023-01-24 12:45:00.060 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 22228
      2023-01-24 12:45:01.280 - info: daswetter.0 (22228) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 12:45:09.592 - info: daswetter.0 (22228) still wrong data structure from server received! repaired...
      2023-01-24 12:45:11.841 - info: daswetter.0 (22228) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-24 12:45:12.348 - info: daswetter.0 (22228) cleaned everything up...
      2023-01-24 12:45:12.369 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 12:48:19.854 - info: cloud.1 (849) User accessed from cloud: K-kYA9Klo_WrLGffATFY
      2023-01-24 12:49:18.372 - info: cloud.1 (849) User disconnected from cloud: K-kYA9Klo_WrLGffATFY
      2023-01-24 12:49:20.259 - info: cloud.1 (849) User accessed from cloud: xw-RPZCn509e9VYiATF7
      2023-01-24 12:49:53.606 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-01-24 12:49:53.610 - info: backitup.0 (21654) Got terminate signal TERMINATE_YOURSELF
      2023-01-24 12:49:53.612 - info: backitup.0 (21654) cleaned everything up...
      2023-01-24 12:49:53.613 - info: backitup.0 (21654) terminating
      2023-01-24 12:49:53.613 - info: backitup.0 (21654) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-24 12:49:53.649 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
      2023-01-24 12:49:54.160 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 12:49:56.751 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 22504
      2023-01-24 12:49:58.043 - info: backitup.0 (22504) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 12:49:58.171 - info: backitup.0 (22504) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-01-24 12:49:58.664 - error: backitup.0 (22504) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      Unable to apply new capability set.
      2023-01-24 12:50:09.166 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-01-24 12:50:09.170 - info: backitup.0 (22504) Got terminate signal TERMINATE_YOURSELF
      2023-01-24 12:50:09.171 - info: backitup.0 (22504) cleaned everything up...
      2023-01-24 12:50:09.171 - info: backitup.0 (22504) terminating
      2023-01-24 12:50:09.172 - info: backitup.0 (22504) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-24 12:50:09.209 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
      2023-01-24 12:50:09.714 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 12:50:12.253 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 22540
      2023-01-24 12:50:13.411 - info: backitup.0 (22540) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 12:50:13.473 - info: backitup.0 (22540) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-01-24 12:50:13.867 - error: backitup.0 (22540) Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 12:50:24.620 - error: backitup.0 (22540) [iobroker/mount] [undefined Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 12:50:24.620 - error: backitup.0 (22540) [iobroker/mount] Unable to apply new capability set.
      2023-01-24 12:50:24.621 - error: backitup.0 (22540) [iobroker/mount] Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 12:50:24.621 - error: backitup.0 (22540) [iobroker/mount] Unable to apply new capability set.
      2023-01-24 12:50:24.622 - error: backitup.0 (22540) [iobroker] Error: Command failed: mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 12:51:12.196 - info: cloud.1 (849) User disconnected from cloud: xw-RPZCn509e9VYiATF7
      2023-01-24 12:51:25.737 - info: cloud.1 (849) User accessed from cloud: 3gwKk0kJePfRo1C5ATHI
      2023-01-24 12:52:41.430 - warn: cloud.1 (849) User disconnected from cloud: 0 3gwKk0kJePfRo1C5ATHI
      2023-01-24 12:52:41.431 - info: cloud.1 (849) User disconnected from cloud:
      2023-01-24 12:57:39.273 - info: cloud.1 (849) received all objects
      2023-01-24 12:59:04.419 - info: admin.0 (530) Request actual repository...
      2023-01-24 12:59:04.732 - info: host.e73f64821262 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-01-24 12:59:05.842 - info: admin.0 (530) Repository received successfully.
      2023-01-24 13:00:00.069 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 23095
      2023-01-24 13:00:01.223 - info: daswetter.0 (23095) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:00:02.051 - error: cloud.1 (849) Cannot request admin pages:
      Cannot GET /socket.io/
      2023-01-24 13:00:03.487 - error: cloud.1 (849) Cannot request admin pages:
      2023-01-24 13:00:04.095 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 23110
      2023-01-24 13:00:05.305 - error: cloud.1 (849) Cannot request admin pages:
      2023-01-24 13:00:06.086 - info: fuelpricemonitor.0 (23110) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:00:06.110 - info: fuelpricemonitor.0 (23110) Started with JSON-Explorer version 0.1.10
      2023-01-24 13:00:10.404 - error: cloud.1 (849) Cannot request admin pages:
      2023-01-24 13:00:13.461 - info: fuelpricemonitor.0 (23110) Terminated (NO_ERROR): Without reason
      2023-01-24 13:00:13.969 - info: fuelpricemonitor.0 (23110) cleaned everything up...
      2023-01-24 13:00:13.985 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
      2023-01-24 13:00:15.310 - info: daswetter.0 (23095) still wrong data structure from server received! repaired...
      2023-01-24 13:00:17.533 - info: daswetter.0 (23095) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-24 13:00:18.045 - info: daswetter.0 (23095) cleaned everything up...
      2023-01-24 13:00:18.064 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 13:00:19.559 - info: cloud.1 (849) User accessed from cloud: AZEXg8FpqhnWdZqAATLo
      2023-01-24 13:00:22.020 - info: cloud.1 (849) User disconnected from cloud: AZEXg8FpqhnWdZqAATLo
      2023-01-24 13:05:55.389 - info: cloud.1 (849) User accessed from cloud: MMm1qIvpysIQNsBUATOq
      2023-01-24 13:13:17.305 - info: cloud.1 (849) User disconnected from cloud: MMm1qIvpysIQNsBUATOq
      2023-01-24 13:13:17.311 - info: cloud.1 (849) User disconnected from cloud: NokHvXGAjLO20NjTATC_
      2023-01-24 13:15:00.057 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 23905
      2023-01-24 13:15:01.192 - info: daswetter.0 (23905) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:15:09.230 - info: daswetter.0 (23905) still wrong data structure from server received! repaired...
      2023-01-24 13:15:11.432 - info: daswetter.0 (23905) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-24 13:15:11.940 - info: daswetter.0 (23905) cleaned everything up...
      2023-01-24 13:15:11.960 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 13:20:00.095 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 24180
      2023-01-24 13:20:01.317 - info: fuelpricemonitor.0 (24180) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:20:01.337 - info: fuelpricemonitor.0 (24180) Started with JSON-Explorer version 0.1.10
      2023-01-24 13:20:06.683 - info: fuelpricemonitor.0 (24180) Terminated (NO_ERROR): Without reason
      2023-01-24 13:20:07.191 - info: fuelpricemonitor.0 (24180) cleaned everything up...
      2023-01-24 13:20:07.209 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
      2023-01-24 13:22:21.568 - info: cloud.1 (849) User accessed from cloud: taDOa7y5WAhUpOs1ATVS
      2023-01-24 13:23:29.644 - info: cloud.1 (849) User disconnected from cloud: taDOa7y5WAhUpOs1ATVS
      2023-01-24 13:30:00.059 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 24711
      2023-01-24 13:30:01.243 - info: daswetter.0 (24711) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:30:07.530 - error: daswetter.0 (24711) exception in HourlyForecast [AxiosError: Request failed with status code 502]
      2023-01-24 13:30:07.653 - error: daswetter.0 (24711) exception in getForecastDataHourlyJSON [AxiosError: Request failed with status code 502]
      2023-01-24 13:30:07.654 - info: daswetter.0 (24711) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-24 13:30:08.162 - info: daswetter.0 (24711) cleaned everything up...
      2023-01-24 13:30:08.175 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 13:39:36.607 - info: cloud.1 (849) User accessed from cloud: K6va0EGI5Fmv9Yk3ATcP
      2023-01-24 13:39:45.764 - info: cloud.1 (849) User accessed from cloud: qbIfXHpE25svn3RPATcc
      2023-01-24 13:39:59.789 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-01-24 13:39:59.794 - info: backitup.0 (22540) Got terminate signal TERMINATE_YOURSELF
      2023-01-24 13:39:59.795 - info: backitup.0 (22540) cleaned everything up...
      2023-01-24 13:39:59.795 - info: backitup.0 (22540) terminating
      2023-01-24 13:39:59.796 - info: backitup.0 (22540) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-24 13:39:59.835 - info: host.e73f64821262 stopInstance system.adapter.backitup.0 send kill signal
      2023-01-24 13:40:00.063 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 25259
      2023-01-24 13:40:00.340 - info: host.e73f64821262 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 13:40:01.497 - info: fuelpricemonitor.0 (25259) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:40:01.519 - info: fuelpricemonitor.0 (25259) Started with JSON-Explorer version 0.1.10
      2023-01-24 13:40:03.420 - info: host.e73f64821262 instance system.adapter.backitup.0 started with pid 25274
      2023-01-24 13:40:06.392 - info: backitup.0 (25274) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:40:06.453 - info: backitup.0 (25274) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-01-24 13:40:06.993 - error: backitup.0 (25274) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 13:40:07.591 - info: fuelpricemonitor.0 (25259) Terminated (NO_ERROR): Without reason
      2023-01-24 13:40:08.099 - info: fuelpricemonitor.0 (25259) cleaned everything up...
      2023-01-24 13:40:08.117 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
      2023-01-24 13:40:23.585 - error: backitup.0 (25274) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 13:40:23.586 - error: backitup.0 (25274) [iobroker/mount] Unable to apply new capability set.
      2023-01-24 13:40:23.586 - error: backitup.0 (25274) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 13:40:23.587 - error: backitup.0 (25274) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
      2023-01-24 13:40:54.515 - info: cloud.1 (849) User disconnected from cloud: qbIfXHpE25svn3RPATcc
      2023-01-24 13:45:00.060 - info: host.e73f64821262 instance system.adapter.daswetter.0 started with pid 25574
      2023-01-24 13:45:01.221 - info: daswetter.0 (25574) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.23
      2023-01-24 13:45:03.863 - info: cloud.1 (849) User disconnected from cloud: K6va0EGI5Fmv9Yk3ATcP
      2023-01-24 13:45:11.202 - info: daswetter.0 (25574) still wrong data structure from server received! repaired...
      2023-01-24 13:45:13.381 - info: daswetter.0 (25574) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-24 13:45:13.890 - info: daswetter.0 (25574) cleaned everything up...
      2023-01-24 13:45:13.905 - info: host.e73f64821262 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-24 13:59:47.962 - info: cloud.1 (849) User accessed from cloud: NS-F1bJvpGrmox7cATlj
      • Codierknecht
        Codierknecht Developer Most Active @Peter666666 last edited by
        @peter666666
        Nein - damit:
          Thomas Braun Most Active last edited by
          @peter666666
          ioBroker im Container, ohne Privileged Mode?
            Peter666666 @Codierknecht last edited by Peter666666
            @codierknecht erledigt 🙂 - dachte das ist nur für Skript einfügen.
              @thomas-braun was ist Privileged Mode?
                Thomas Braun Most Active @Peter666666 last edited by
                @peter666666
                Eine Konfiguratiosoption für einen Container.
                P Glasfaser 2 Replies Last reply Reply Quote 0
                  @thomas-braun puhh -wo sehe ich das? Habe es lt. Anleitung https://mariushosting.com/how-to-install-iobroker-on-your-synology-nas/ gemacht.
                    @peter666666
                    Bei Containern bin ich raus.
                    • Glasfaser
                      Glasfaser last edited by Glasfaser
                      @peter666666 sagte in Fehlermeldungen bei Backup auf NAS:
                      https://forum.iobroker.net/topic/44092/gelöst-backitup-unable-to-apply-new-capability-set
                      In der Syn Docker Oberfläche , Docker iobroker stoppen " Bearbeiten " Privileged anhaken .
                      Codierknecht P 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        Glasfaser @Thomas Braun last edited by
                        @Peter666666
                        Große Frage , nutzt du auf deiner Synology den Benutzer " Admin " !?
                        • Codierknecht
                          Codierknecht Developer Most Active @Glasfaser last edited by
                          @glasfaser sagte in Fehlermeldungen bei Backup auf NAS:
                          In DSM 6 hieß das noch "Container mit hoher Priorität ausführen"
                          • Glasfaser
                            Glasfaser @Codierknecht last edited by
                            @codierknecht sagte in Fehlermeldungen bei Backup auf NAS:
                            Ist auch gleich geblieben ... bei DSM 7 ..
                            binn halt das Wort "Privileged " gewohnt ,
                            ... es kann auch auch sein das er Portainer nutzt ... dort ist es "Privileged Mode"
                              Peter666666 @Glasfaser last edited by
                              @glasfaser Nein nutze ich nicht. Warum?
                                @glasfaser Habe ich gemacht (mit hoher Prio ausführen - root). Leider kommen wieder Fehlermeldungen:
                                2023-01-24 17:38:51.311 - info: admin.0 (148) ==> Connected system.user.admin from ::ffff:172.17.0.1
                                2023-01-24 17:38:59.746 - info: admin.0 (148) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                                2023-01-24 17:39:02.751 - info: admin.0 (148) ==> Connected system.user.admin from ::ffff:172.17.0.1
                                2023-01-24 17:39:32.451 - error: backitup.0 (320) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                                2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] mount error(13): Permission denied
                                2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                2023-01-24 17:39:32.452 - error: backitup.0 (320) [iobroker/mount] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                                2023-01-24 17:39:32.453 - error: backitup.0 (320) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                2023-01-24 17:39:32.453 - error: backitup.0 (320) [iobroker] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.0.3/Peter/ioBroker/Backups /opt/iobroker/backups
                                2023-01-24 17:39:56.571 - info: admin.0 (148) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                                2023-01-24 17:40:00.055 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 started with pid 643
                                2023-01-24 17:40:01.279 - info: fuelpricemonitor.0 (643) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v16.19.0, js-controller: 4.0.23
                                2023-01-24 17:40:01.302 - info: fuelpricemonitor.0 (643) Started with JSON-Explorer version 0.1.10
                                2023-01-24 17:40:07.364 - info: fuelpricemonitor.0 (643) Terminated (NO_ERROR): Without reason
                                2023-01-24 17:40:07.871 - info: fuelpricemonitor.0 (643) cleaned everything up...
                                2023-01-24 17:40:07.886 - info: host.e73f64821262 instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                                • Glasfaser
                                  Glasfaser @Peter666666 last edited by Glasfaser
                                  Ich würde gerne das ioBroker Backup auf mein NAS sichern.
                                  Sorry habe nicht den ganzen Beitrag gelesen , aber
                                  du hast eine Syn Nas , auf der ist im Docker ioBroker und du möchtest das Backup auslagern ...
                                  auf die selbe Syn Nas ....
                                  Ist unlogisch , denn warum gehts du über CIFS bzw. so einen UMWEG !
                                  Mounte den Backup Ordner von deiner Nas in den Einstellungen vom ioBroker Docker .
                                    @glasfaser das hört sich einfacher an. Blöde Frage 🙂 Wie Mounte ich den Ordner?
                                    • Glasfaser
                                      Naja ... bin ja nicht so... in der Suche ...
                                      https://forum.iobroker.net/post/896365
                                        @glasfaser vielen Dank!!! Hab nur mehr zwei Fehler drinnen bzgl. History.
                                        2023-01-24 18:15:24.628 - info: admin.0 (139) ==> Connected system.user.admin from ::ffff:172.17.0.1
                                        2023-01-24 18:15:46.168 - error: backitup.0 (324) [iobroker/historyDB] Backitup cannot found source "undefined" for compress!
                                        2023-01-24 18:15:46.169 - error: backitup.0 (324) [iobroker] Backitup cannot found source "undefined" for compress!
                                        2023-01-24 18:16:30.124 - info: admin.0 (139) <== Disconnect system.user.admin from ::ffff:172.17.0.1
                                        • Glasfaser
                                          @peter666666
                                          https://forum.iobroker.net/topic/61217/gelöst-backitup-cannot-found-source-undefined-for-compress
                                          bahnuhr 1 Reply Last reply Reply Quote 1
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @Glasfaser last edited by
                                            @glasfaser
                                            Die Suche muss @Peter666666 noch lernen 😉
                                            Glasfaser 1 Reply Last reply Reply Quote 2
                                            867
