    4. JavaScript
    5. Roborock Adapter tester gesucht
    • copystring
      copystring @M-A Hueb last edited by
      @m-a-hueb said in Roborock Adapter tester gesucht:
      @copystring
      Da bekomme ich eine Fehlermedlung im Log:
      roborock.0
      	2023-01-25 09:02:56.087	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      	2023-01-25 09:02:56.086	info	terminating
      roborock.0
      	2023-01-25 09:02:56.085	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
      roborock.0
      	2023-01-25 09:02:56.085	error	Error: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:19:31) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:172:20)
      roborock.0
      	2023-01-25 09:02:56.085	error	unhandled promise rejection: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
      roborock.0
      	2023-01-25 09:02:56.085	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      	2023-01-25 09:02:56.082	info	MQTT initialized
      roborock.0
      	2023-01-25 09:02:55.464	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
      Ist das ein debug Log? Es fehlt der Name vom Roboter der via debug angezeigt werden sollte.
      M-A Hueb 1 Reply Last reply Reply Quote 0
      • M-A Hueb
        M-A Hueb @copystring last edited by
        @copystring Sorry war zu schnell und hatte den neu installierten Adapter noch auf Info stehen.
        roborock.0
        	2023-01-25 09:09:53.586	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        	2023-01-25 09:09:53.586	info	terminating
        roborock.0
        	2023-01-25 09:09:53.584	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
        roborock.0
        	2023-01-25 09:09:53.584	error	Error: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:19:31) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:172:20)
        roborock.0
        	2023-01-25 09:09:53.584	error	unhandled promise rejection: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
        roborock.0
        	2023-01-25 09:09:53.583	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        	2023-01-25 09:09:53.582	debug	Test vacuum log: undefined
        roborock.0
        	2023-01-25 09:09:53.582	debug	Detected robot name: Wall-E
        roborock.0
        	2023-01-25 09:09:53.581	info	MQTT initialized
        roborock.0
        	2023-01-25 09:09:53.565	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
        roborock.0
        	2023-01-25 09:09:53.418	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        copystring 1 Reply Last reply Reply Quote 0
        • copystring
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          Wall-E? Okay dann geht das nicht so wie ich mir das vorgestellt habe. Danke.
          wendy2702 D 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @copystring last edited by wendy2702
            @copystring den Namen kann man in der App frei einstellen.
            Vielleicht sieht man in der API die Modell Bezeichnung!?
            Bei mir halt ein S7+
              DonToben last edited by
              Bei mir S7 Pro Ultra
              • M-A Hueb
                M-A Hueb @DonToben last edited by M-A Hueb
                roborock.vacuuum.a27 Roborrock Maxv Ultra
                  Dimi @copystring last edited by
                  @copystring
                  Hallo, tolle Arbeit.
                  Also ich habe einen Roborock S6 MaxV und der hat laut App die Modellbezeichnung roborock.vacuum.a10
                    @copystring
                    Hi, ich habe ein Problem mit dem Roborock Adapter festgestellt. Er reagiert nicht immer auf steuern app_segment_clean. Räume sind auf true gesetzt. Komplettreinigung über app_start funktioniert immer.
                    Nach Adapter Neustart geht dann wieder app_segment_clean für eine bestimmte Zeit.
                    • copystring
                      Die meisten Roboter sollten nun laufen.
                      Beim S4 scheint es keinen Mop zu geben. Für diesen habe ich das Feature entfernt.
                      https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                      • copystring
                        copystring last edited by copystring
                        Wenn ihr euer homedata zuschicken könntet dann kann ich für jeden Roboter den deviceStatus vollständig erstellen.
                        • wendy2702
                          @copystring sagte in Roborock Adapter tester gesucht:
                          Woran kann man erkennen das der Typ erkannt wurde ?
                          EDIT: Vielleicht kannst du die Versionsnummern mal hochzählen damit man sehen kann ob die richtige Version installiert wurde und läuft.
                          • copystring
                            Wenn keine Fehlermeldung erscheint 🙂
                            • wendy2702
                              @copystring Im Debug log beim Adpater start meinst du?
                              • copystring
                                Genau so ist es. Ansonsten meldet der Adapter, dass der Roboter nicht unterstützt ist.
                                • wendy2702
                                  @copystring Bei mir läuft er nicht mehr:
                                  2023-01-25 18:25:30.721  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                  2023-01-25 18:25:30.729  - info: roborock.0 (1033377) Got terminate signal TERMINATE_YOURSELF
                                  2023-01-25 18:25:30.738  - info: roborock.0 (1033377) terminating
                                  2023-01-25 18:25:30.739  - info: roborock.0 (1033377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-01-25 18:25:30.792  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                  2023-01-25 18:25:31.353  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-01-25 18:25:34.032  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1047380
                                  2023-01-25 18:25:34.745  - debug: roborock.0 (1047380) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2023-01-25 18:25:34.788  - debug: roborock.0 (1047380) Objects client ready ... initialize now
                                  2023-01-25 18:25:34.789  - debug: roborock.0 (1047380) Objects create System PubSub Client
                                  2023-01-25 18:25:34.790  - debug: roborock.0 (1047380) Objects create User PubSub Client
                                  2023-01-25 18:25:34.870  - debug: roborock.0 (1047380) Objects client initialize lua scripts
                                  2023-01-25 18:25:34.876  - debug: roborock.0 (1047380) Objects connected to redis: 0.0.0.0:9001
                                  2023-01-25 18:25:34.910  - debug: roborock.0 (1047380) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create System PubSub Client
                                  2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create User PubSub Client
                                  2023-01-25 18:25:35.016  - debug: roborock.0 (1047380) States connected to redis: 0.0.0.0:9000
                                  2023-01-25 18:25:35.221  - info: roborock.0 (1047380) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                  2023-01-25 18:25:35.432  - debug: roborock.0 (1047380) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
                                  2023-01-25 18:25:35.458  - info: roborock.0 (1047380) MQTT initialized
                                  2023-01-25 18:25:35.459  - debug: roborock.0 (1047380) Detected robot model: roborock.vacuum.a15
                                  2023-01-25 18:25:35.460  - debug: roborock.0 (1047380) Robot key: undefined
                                  2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-01-25 18:25:35.462  - error: roborock.0 (1047380) unhandled promise rejection: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                                  - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js
                                  - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js
                                  - /opt/iobroker/node_modules/iobroker.roborock/main.js
                                  2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Error: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                                      at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js:5:21)
                                  2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Exception-Code: MODULE_NOT_FOUND: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                                  2023-01-25 18:25:35.463  - info: roborock.0 (1047380) terminating
                                  2023-01-25 18:25:35.464  - warn: roborock.0 (1047380) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2023-01-25 18:25:36.081  - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  2023-01-25 18:25:36.081  - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
                                  • copystring
                                    copystring @wendy2702 last edited by
                                    @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
                                      roborock.0
                                      	2023-01-25 18:37:11.775	debug	Detected robot model: roborock.vacuum.a62
                                      Ich denke, er hat den Rocorock S7 Pro Ultra jetzt richtig erkannt.
                                      • wendy2702
                                        Erledigt.
                                        Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
                                        {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
                                        S7+
                                          DonToben @wendy2702 last edited by
                                          @wendy2702 said in Roborock Adapter tester gesucht:
                                          Erledigt.
                                          S7+
                                          ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
                                          @copystring
                                          Würde dir die Daten dann per PN schicken.
                                          • wendy2702
                                            wendy2702 @DonToben last edited by
                                            @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
                                            766
                                            242047
