    4. JavaScript
    5. Roborock Adapter tester gesucht
    • copystring
      copystring last edited by
      Wenn keine Fehlermeldung erscheint 🙂
      • wendy2702
        wendy2702 @copystring last edited by
        @copystring Im Debug log beim Adpater start meinst du?
        • copystring
          Genau so ist es. Ansonsten meldet der Adapter, dass der Roboter nicht unterstützt ist.
          • wendy2702
            @copystring Bei mir läuft er nicht mehr:
            2023-01-25 18:25:30.721  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
            2023-01-25 18:25:30.729  - info: roborock.0 (1033377) Got terminate signal TERMINATE_YOURSELF
            2023-01-25 18:25:30.738  - info: roborock.0 (1033377) terminating
            2023-01-25 18:25:30.739  - info: roborock.0 (1033377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-01-25 18:25:30.792  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
            2023-01-25 18:25:31.353  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-25 18:25:34.032  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1047380
            2023-01-25 18:25:34.745  - debug: roborock.0 (1047380) Redis Objects: Use Redis connection: 0.0.0.0:9001
            2023-01-25 18:25:34.788  - debug: roborock.0 (1047380) Objects client ready ... initialize now
            2023-01-25 18:25:34.789  - debug: roborock.0 (1047380) Objects create System PubSub Client
            2023-01-25 18:25:34.790  - debug: roborock.0 (1047380) Objects create User PubSub Client
            2023-01-25 18:25:34.870  - debug: roborock.0 (1047380) Objects client initialize lua scripts
            2023-01-25 18:25:34.876  - debug: roborock.0 (1047380) Objects connected to redis: 0.0.0.0:9001
            2023-01-25 18:25:34.910  - debug: roborock.0 (1047380) Redis States: Use Redis connection: 0.0.0.0:9000
            2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create System PubSub Client
            2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create User PubSub Client
            2023-01-25 18:25:35.016  - debug: roborock.0 (1047380) States connected to redis: 0.0.0.0:9000
            2023-01-25 18:25:35.221  - info: roborock.0 (1047380) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
            2023-01-25 18:25:35.432  - debug: roborock.0 (1047380) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
            2023-01-25 18:25:35.458  - info: roborock.0 (1047380) MQTT initialized
            2023-01-25 18:25:35.459  - debug: roborock.0 (1047380) Detected robot model: roborock.vacuum.a15
            2023-01-25 18:25:35.460  - debug: roborock.0 (1047380) Robot key: undefined
            2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-01-25 18:25:35.462  - error: roborock.0 (1047380) unhandled promise rejection: Cannot find module 'ioBroker.roborock/lib/basic_robot'
            - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js
            - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js
            - /opt/iobroker/node_modules/iobroker.roborock/main.js
            2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Error: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js:5:21)
            2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Exception-Code: MODULE_NOT_FOUND: Cannot find module 'ioBroker.roborock/lib/basic_robot'
            2023-01-25 18:25:35.463  - info: roborock.0 (1047380) terminating
            2023-01-25 18:25:35.464  - warn: roborock.0 (1047380) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-01-25 18:25:36.081  - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-01-25 18:25:36.081  - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
            copystring 1 Reply Last reply Reply Quote 0
            • copystring
              copystring @wendy2702 last edited by
              @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
                DonToben last edited by
                roborock.0
                	2023-01-25 18:37:11.775	debug	Detected robot model: roborock.vacuum.a62
                Ich denke, er hat den Rocorock S7 Pro Ultra jetzt richtig erkannt.
                • wendy2702
                  @copystring sagte in Roborock Adapter tester gesucht:
                  Erledigt.
                  Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
                  {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
                  S7+
                    DonToben @wendy2702 last edited by
                    @wendy2702 said in Roborock Adapter tester gesucht:
                    Erledigt.
                    S7+
                    ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
                    @copystring
                    Würde dir die Daten dann per PN schicken.
                    • wendy2702
                      wendy2702 @DonToben last edited by
                      @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
                      • copystring
                        Da steht nicht so viel spannendes drin. Aber gerne via pn.
                          worxweis @copystring last edited by
                          @copystring Also meiner ist lt. App ein roborock.vacuum.s6
                          • copystring
                            Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
                            O M-A Hueb 2 Replies Last reply Reply Quote 0
                            • O
                              oxident @copystring last edited by oxident
                              @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
                              Hole ich aber nach!
                              • M-A Hueb
                                M-A Hueb @copystring last edited by
                                @copystring Hallo,
                                ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
                                roborock.0
                                	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                roborock.0
                                	2023-01-26 08:19:05.034	info	terminating
                                roborock.0
                                	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
                                roborock.0
                                	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
                                roborock.0
                                	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
                                roborock.0
                                	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                roborock.0
                                	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
                                roborock.0
                                	2023-01-26 08:19:05.007	info	MQTT initialized
                                roborock.0
                                	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
                                roborock.0
                                	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                copystring O 2 Replies Last reply Reply Quote 0
                                • copystring
                                  copystring @M-A Hueb last edited by
                                  @m-a-hueb said in Roborock Adapter tester gesucht:
                                  @copystring Hallo,
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
                                  • M-A Hueb
                                    @copystring Heute morgen
                                    • O
                                      oxident @M-A Hueb last edited by
                                      @copystring Hallo,
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      roborock.0
                                      Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
                                      • copystring
                                        War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                                        • wendy2702
                                          Wie bzw. woran erkennt man einen Unterschied?
                                          • copystring
                                            Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
                                            766
                                            242051
