    4. JavaScript
    5. Roborock Adapter tester gesucht
    • wendy2702
      wendy2702 @copystring last edited by
      @copystring sagte in Roborock Adapter tester gesucht:
      @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
      Erledigt.
      Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
      {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
      S7+
        DonToben @wendy2702 last edited by
        @wendy2702 said in Roborock Adapter tester gesucht:
        Erledigt.
        S7+
        ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
        @copystring
        Würde dir die Daten dann per PN schicken.
        • wendy2702
          wendy2702 @DonToben last edited by
          @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
          • copystring
            Da steht nicht so viel spannendes drin. Aber gerne via pn.
              worxweis @copystring last edited by
              @copystring Also meiner ist lt. App ein roborock.vacuum.s6
              • copystring
                Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
                O M-A Hueb 2 Replies Last reply Reply Quote 0
                • O
                  oxident @copystring last edited by oxident
                  @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
                  Hole ich aber nach!
                  • M-A Hueb
                    M-A Hueb @copystring last edited by
                    @copystring Hallo,
                    ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
                    roborock.0
                    	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    roborock.0
                    	2023-01-26 08:19:05.034	info	terminating
                    roborock.0
                    	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
                    roborock.0
                    	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
                    roborock.0
                    	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
                    roborock.0
                    	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    roborock.0
                    	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
                    roborock.0
                    	2023-01-26 08:19:05.007	info	MQTT initialized
                    roborock.0
                    	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
                    roborock.0
                    	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                    copystring O 2 Replies Last reply Reply Quote 0
                    • copystring
                      copystring @M-A Hueb last edited by
                      @m-a-hueb said in Roborock Adapter tester gesucht:
                      @copystring Hallo,
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
                      • M-A Hueb
                        @copystring Heute morgen
                        • O
                          oxident @M-A Hueb last edited by
                          @copystring Hallo,
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
                          • copystring
                            War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                            • wendy2702
                              Wie bzw. woran erkennt man einen Unterschied?
                              • copystring
                                Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
                                • wendy2702
                                  @copystring OK.
                                  Dann sehe ich bei mir keinen Unterschied 😁
                                  copystring 1 Reply Last reply Reply Quote 0
                                  • copystring
                                    copystring @wendy2702 last edited by
                                    @wendy2702 😞 welcher Fehler kommt?
                                    • wendy2702
                                      @copystring nein nein...
                                      kein Fehler.
                                      Habe S7+, Adapter startet.
                                      Lediglich einige Objekte nach wie vor leer.
                                      • copystring
                                        @wendy2702 Ach so. Ja das kann sein. Dazu komme ich dann wenn der Adapter aus branch split_robots_into_classes überhaupt wieder startet.
                                        Durch diese branch kann jeder seine eigene Konfiguration erhalten und nicht die gleiche für alle 🙂
                                        Was ist denn leer? Dann würde ich das direkt für deinen Roboter anpassen.
                                        • wendy2702
                                          @copystring
                                          Hier steht immer nur "0h", keine Ahnung ob das so sein soll:
                                          Und dann hier einige von denen welche von Interesse sein könnten, wie z.B Akku
                                          Dann z.B. hier
                                          • copystring
                                            @wendy2702 hm ja es scheint so, als ob der S7 und seine variationen dust_collection_work_times und filter_element_work_time gar nicht unterstützen. Daher kommt da auch kein Wert.
                                            Warum bei dir Bettery etc aber (null) ist verstehe ich nicht. Schick mal bitte ein debug log nach dem Start des Adapters.
                                            Bei deviceInfo gucke ich nochmal rein. Da werden anscheinend nicht alle Parameter sauber abgefragt.
                                            766
                                            242125
