    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. [gelöst]TR-064 wird nicht grün
      Wolfshunter @frankthegreat last edited by
      @frankthegreat
      das was dort drin steht habe ich gemacht hat nichts geholfen
        Wolfshunter @DJMarc75 last edited by
        @djmarc75
        Das steht drin wenn ich den Adapter starte
        DJMarc75 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @Wolfshunter last edited by
          @wolfshunter Text bitte kopieren und hier in Codetags ( </> ) einstellen - Screenshots lassen sich schlecht lesen und man kann nix kopieren und zitieren.
          Fritzbox auch mal neu gestartet wie es im LOG steht ?
            Wolfshunter @DJMarc75 last edited by wendy2702
            @djmarc75
            tr-064.0
            	2023-01-26 19:48:52.278	error	adapter disabled
            host.iobroker
            	2023-01-26 19:48:31.356	info	"system.adapter.tr-064.0" disabled
            host.iobroker
            	2023-01-26 19:48:20.701	info	Restart adapter system.adapter.tr-064.0 because enabled
            host.iobroker
            	2023-01-26 19:48:20.701	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            tr-064.0
            	2023-01-26 19:48:20.167	warn	Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
            tr-064.0
            	2023-01-26 19:48:20.166	error	~
            tr-064.0
            	2023-01-26 19:48:20.166	error	~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
            tr-064.0
            	2023-01-26 19:48:20.165	error	~~ Fatal error. Can not connect to your FritzBox.
            tr-064.0
            tr-064.0
            	2023-01-26 19:48:20.164	error	!device - "!device"
            tr-064.0
            	2023-01-26 19:48:20.074	info	starting. Version 4.2.17 in /opt/iobroker/node_modules/iobroker.tr-064, node: v16.19.0, js-controller: 4.0.24
            host.iobroker
            	2023-01-26 19:48:18.445	info	instance system.adapter.tr-064.0 started with pid 15506
            host.iobroker
            	2023-01-26 19:48:18.413	info	"system.adapter.tr-064.0" enabled
            host.iobroker
            	2023-01-26 19:48:16.192	info	Do not restart adapter system.adapter.tr-064.0 because disabled or deleted
            host.iobroker
            	2023-01-26 19:48:16.191	error	instance system.adapter.tr-064.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            tr-064.0
            	2023-01-26 19:48:15.659	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            tr-064.0
            	2023-01-26 19:48:15.565	error	adapter disabled
            admin.0
            	2023-01-26 19:48:14.074	info	<== Disconnect system.user.admin from ::ffff:192.168.178.41
            admin.0
            	2023-01-26 19:47:56.912	info	==> Connected system.user.admin from ::ffff:192.168.178.41
            host.iobroker
            	2023-01-26 19:47:55.290	info	"system.adapter.tr-064.0" disabled
            host.iobroker
            	2023-01-26 19:47:44.000	info	Restart adapter system.adapter.tr-064.0 because enabled
            MOD EDIT: LOG Korrigiert
            • DJMarc75
              @wolfshunter und lass uns bitte mal wissen auf welchem System Du da wie unterwegs bist.
                @djmarc75
                Habe hier einen ThinClient mit Proxmox und in dem läuft ein LCX Container
                mit Debian 11 und dort wurde dann der ioBroker installiert.
                • DJMarc75
                  @wolfshunter sagte in TR-064 wird nicht grün:
                  da kann ich nicht helfen aber ich denke mal dass es wohl an fehlerhaften Einstellungen bzgl. LXC hängen kann.
                  Aber da können andere besser helfen.
                  • wendy2702
                    wendy2702 @Wolfshunter last edited by wendy2702
                    host.iobroker
                    host.iobroker
                    tr-064.0
                    Das macht mich gerade etwas stutzig.
                    Aber mal von vorne. Wie ist der Container konfiguriert? Firewall? Privilegiert?
                    Wie ioBroker installiert?
                    Bitte mal die Ausgabe von
                    iob diag
                    Zeigen.
                    Kannst du aus dem Container die Fritzbox pingen?
                    Container und FB im gleichen Netz?
                      Wolfshunter @wendy2702 last edited by Wolfshunter
                      @wendy2702
                      Also am Container wird es nicht liegen. Habe gerade mal auf einer anderen Seite
                      was gelesen und es war ein Hacken der in meiner Fritzbox nicht gesetzt war.
                      Unzwar war es unter: Heimnetz » Heimnetzübersicht » Netzwerkeinstellungen
                      Dort mußte der Punkt „Zugriff für Anwendungen zulassen“. Aktiviert sein.
                      Jetzt ist mein TR-064 auch grün.
                      Danke für eure Hilfen
                      PS: Ja ich konnte die fritzbox anpingen
                      • wendy2702
                        @wolfshunter Steht sogar in der Anleitung zum Adapter
                        Bitte noch deinen ersten Post bearbeiten und ein [Gelöst] vor den Titel setzen.
                          @wendy2702
                          Da hatte ich jetzt nicht geschaut 😞
                          346
