    4. JavaScript
    5. Roborock Adapter tester gesucht
    • O
      oxident @copystring last edited by oxident
      @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
      Hole ich aber nach!
      • M-A Hueb
        M-A Hueb @copystring last edited by
        @copystring Hallo,
        ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
        roborock.0
        	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        	2023-01-26 08:19:05.034	info	terminating
        roborock.0
        	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
        roborock.0
        	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
        roborock.0
        	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
        roborock.0
        	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        roborock.0
        	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
        roborock.0
        	2023-01-26 08:19:05.007	info	MQTT initialized
        roborock.0
        	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
        roborock.0
        	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        copystring O 2 Replies Last reply Reply Quote 0
        • copystring
          copystring @M-A Hueb last edited by
          @m-a-hueb said in Roborock Adapter tester gesucht:
          @copystring Hallo,
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
          • M-A Hueb
            @copystring Heute morgen
            • O
              oxident @M-A Hueb last edited by
              @copystring Hallo,
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
              • copystring
                War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                • wendy2702
                  wendy2702 @copystring last edited by
                  @copystring sagte in Roborock Adapter tester gesucht:
                  Wie bzw. woran erkennt man einen Unterschied?
                  • copystring
                    Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
                    • wendy2702
                      @copystring OK.
                      Dann sehe ich bei mir keinen Unterschied 😁
                      copystring 1 Reply Last reply Reply Quote 0
                      • copystring
                        copystring @wendy2702 last edited by
                        @wendy2702 😞 welcher Fehler kommt?
                        • wendy2702
                          @copystring nein nein...
                          kein Fehler.
                          Habe S7+, Adapter startet.
                          Lediglich einige Objekte nach wie vor leer.
                          • copystring
                            @wendy2702 Ach so. Ja das kann sein. Dazu komme ich dann wenn der Adapter aus branch split_robots_into_classes überhaupt wieder startet.
                            Durch diese branch kann jeder seine eigene Konfiguration erhalten und nicht die gleiche für alle 🙂
                            Was ist denn leer? Dann würde ich das direkt für deinen Roboter anpassen.
                            • wendy2702
                              @copystring
                              Hier steht immer nur "0h", keine Ahnung ob das so sein soll:
                              Und dann hier einige von denen welche von Interesse sein könnten, wie z.B Akku
                              Dann z.B. hier
                              • copystring
                                @wendy2702 hm ja es scheint so, als ob der S7 und seine variationen dust_collection_work_times und filter_element_work_time gar nicht unterstützen. Daher kommt da auch kein Wert.
                                Warum bei dir Bettery etc aber (null) ist verstehe ich nicht. Schick mal bitte ein debug log nach dem Start des Adapters.
                                Bei deviceInfo gucke ich nochmal rein. Da werden anscheinend nicht alle Parameter sauber abgefragt.
                                • Black Thunder
                                  Black Thunder Developer last edited by Black Thunder
                                  @copystring Erstmal vielen Dank, dass du dich um einen dedizierten Roborock-Adapter kümmerst. 👍
                                  Hab gerade mal meinen Roborock S7 von der Xiaomi Home App in die Roborock-App umgezogen und die aktuelle Version deines Adapters aus dem "split_robots_into_classes"-Branch installiert. Grundsätzlich klappt die Verbindung auf jeden Fall schon mal und es werden auch einige Daten vom Roboter abgerufen. Allerdings ebenso mit den bereits hier berichteten teils fehlenden/falschen Zuordnungen zu den korrekten States (speziell unter "roborock.0.Devices.XXX.deviceStatus").
                                  Zusätzlich habe ich aber noch das Problem, dass der Adapter abstürzt, sobald ein beliebiges Kommando unter "roborock.0.Devices.XXX.commands" gesetzt wird. Im Log sieht das dann z.B. für "commands.load_multi_map" so aus:
                                  2023-01-26 22:31:46.562 - info: host.raspberrypi-gang "system.adapter.roborock.0" enabled
                                  2023-01-26 22:31:47.186 - info: host.raspberrypi-gang instance system.adapter.roborock.0 started with pid 7107
                                  2023-01-26 22:31:48.988 - debug: roborock.0 (7107) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2023-01-26 22:31:49.067 - debug: roborock.0 (7107) Objects client ready ... initialize now
                                  2023-01-26 22:31:49.070 - debug: roborock.0 (7107) Objects create System PubSub Client
                                  2023-01-26 22:31:49.071 - debug: roborock.0 (7107) Objects create User PubSub Client
                                  2023-01-26 22:31:49.214 - debug: roborock.0 (7107) Objects client initialize lua scripts
                                  2023-01-26 22:31:49.222 - debug: roborock.0 (7107) Objects connected to redis: 127.0.0.1:9001
                                  2023-01-26 22:31:49.226 - silly: roborock.0 (7107) redis psubscribe cfg.o.system.user.*
                                  2023-01-26 22:31:49.285 - silly: roborock.0 (7107) redis psubscribe cfg.o.enum.*
                                  2023-01-26 22:31:49.292 - silly: roborock.0 (7107) objectDB connected
                                  2023-01-26 22:31:49.296 - debug: roborock.0 (7107) Redis States: Use Redis connection: 127.0.0.1:6379
                                  2023-01-26 22:31:49.305 - debug: roborock.0 (7107) States create System PubSub Client
                                  2023-01-26 22:31:49.307 - debug: roborock.0 (7107) States create User PubSub Client
                                  2023-01-26 22:31:49.320 - debug: roborock.0 (7107) States connected to redis: 127.0.0.1:6379
                                  2023-01-26 22:31:49.322 - silly: roborock.0 (7107) statesDB connected
                                  2023-01-26 22:31:49.599 - info: roborock.0 (7107) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                  2023-01-26 22:31:49.741 - silly: roborock.0 (7107) States system redis pmessage io.system.adapter.roborock.0.logLevel/io.system.adapter.roborock.0.logLevel:{"val":"silly","ack":true,"ts":1674768709647,"q":0,"from":"system.adapter.roborock.0","lc":1674260525427}
                                  2023-01-26 22:31:49.853 - debug: roborock.0 (7107) RoomIDs debug: {"10467471":"Wohnzimmer","10467473":"Zimmer Domi","10467476":"Küche","10467477":"Schlafzimmer","10467479":"Bad","10467481":"Balkon","10467484":"Gang"}
                                  2023-01-26 22:31:49.931 - info: roborock.0 (7107) MQTT initialized
                                  2023-01-26 22:31:49.979 - debug: roborock.0 (7107) Robot key: roborock.vacuum.a15
                                  2023-01-26 22:31:50.437 - debug: roborock.0 (7107) Latest data requested
                                  2023-01-26 22:31:50.441 - debug: roborock.0 (7107) getParameter: get_mop_mode
                                  2023-01-26 22:31:50.446 - debug: roborock.0 (7107) getParameter: get_water_box_custom_mode
                                  2023-01-26 22:31:50.449 - debug: roborock.0 (7107) getParameter: get_status
                                  2023-01-26 22:31:50.450 - debug: roborock.0 (7107) getParameter: get_consumable
                                  2023-01-26 22:31:50.452 - debug: roborock.0 (7107) getParameter: get_network_info
                                  2023-01-26 22:31:50.454 - debug: roborock.0 (7107) getParameter: get_carpet_mode
                                  2023-01-26 22:31:50.456 - debug: roborock.0 (7107) getParameter: get_carpet_cleaning_mode
                                  2023-01-26 22:31:50.458 - debug: roborock.0 (7107) getParameter: get_fw_features
                                  2023-01-26 22:31:50.458 - debug: roborock.0 (7107) Firmware features request
                                  2023-01-26 22:31:50.459 - debug: roborock.0 (7107) getParameter: get_multi_maps_list
                                  2023-01-26 22:31:50.461 - debug: roborock.0 (7107) getParameter: get_room_mapping
                                  2023-01-26 22:31:50.461 - debug: roborock.0 (7107) get_room_mapping
                                  2023-01-26 22:31:50.545 - debug: roborock.0 (7107) dps debug: {"id":3,"result":[203]}
                                  2023-01-26 22:31:50.550 - debug: roborock.0 (7107) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1521,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                  2023-01-26 22:31:50.559 - debug: roborock.0 (7107) dps debug: {"id":1,"result":[300]}
                                  2023-01-26 22:31:50.563 - debug: roborock.0 (7107) dps debug: {"id":7,"result":{"clean_time":863797,"clean_area":13435762500,"clean_count":336,"dust_collection_count":0,"records":[1674725138,1674725117,1674725026,1674643201,1674470400,1674211201,1674038400,1673865601,1673606401,1673433600,1673260802,1673001600,1672828801,1672656000,1672396799,1672224000,1672051200,1671791332,1671619200,1671446400]}}
                                  2023-01-26 22:31:50.584 - debug: roborock.0 (7107) dps debug: {"id":9,"result":"unknown_method"}
                                  2023-01-26 22:31:50.586 - debug: roborock.0 (7107) Unknown parameter: "unknown_method"
                                  2023-01-26 22:31:50.588 - debug: roborock.0 (7107) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1522,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                  2023-01-26 22:31:50.591 - debug: roborock.0 (7107) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                  2023-01-26 22:31:50.615 - debug: roborock.0 (7107) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                                  2023-01-26 22:31:50.619 - debug: roborock.0 (7107) dps debug: {"id":6,"result":{"ssid":"1.FCGlucke","ip":"192.168.2.102","mac":"b0:4a:39:04:69:e9","bssid":"44:4e:6d:69:b7:f1","rssi":-62}}
                                  2023-01-26 22:31:50.623 - debug: roborock.0 (7107) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674730815,"length":10,"name":"Hauptkarte","bak_maps":[{"mapFlag":4,"add_time":1674646243}]}]}]}
                                  2023-01-26 22:31:50.627 - debug: roborock.0 (7107) dps debug: {"id":5,"result":[{"main_brush_work_time":863894,"side_brush_work_time":0,"filter_work_time":313720,"filter_element_work_time":0,"sensor_dirty_time":58909,"dust_collection_work_times":0}]}
                                  2023-01-26 22:31:50.632 - debug: roborock.0 (7107) dps debug: {"id":12,"result":[[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]}
                                  2023-01-26 22:31:50.633 - debug: roborock.0 (7107) get_room_mapping: [[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]
                                  2023-01-26 22:31:50.695 - debug: roborock.0 (7107) dps debug: {"id":13,"result":[{"begin":1674725138,"end":1674730242,"duration":5104,"area":46190000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.698 - debug: roborock.0 (7107) dps debug: {"id":17,"result":[{"begin":1674470400,"end":1674473247,"duration":2847,"area":45627500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.700 - debug: roborock.0 (7107) dps debug: {"id":14,"result":[{"begin":1674725117,"end":1674725124,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.703 - debug: roborock.0 (7107) dps debug: {"id":18,"result":[{"begin":1674211201,"end":1674214020,"duration":2819,"area":45745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.705 - debug: roborock.0 (7107) dps debug: {"id":15,"result":[{"begin":1674725026,"end":1674725079,"duration":41,"area":920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.707 - debug: roborock.0 (7107) dps debug: {"id":16,"result":[{"begin":1674643201,"end":1674646187,"duration":2986,"area":45902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.709 - debug: roborock.0 (7107) dps debug: {"id":19,"result":[{"begin":1674038400,"end":1674041195,"duration":2795,"area":45662500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.712 - debug: roborock.0 (7107) dps debug: {"id":20,"result":[{"begin":1673865601,"end":1673868654,"duration":3053,"area":45852500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.714 - debug: roborock.0 (7107) dps debug: {"id":24,"result":[{"begin":1673001600,"end":1673001754,"duration":147,"area":3327500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.716 - debug: roborock.0 (7107) dps debug: {"id":25,"result":[{"begin":1672828801,"end":1672831852,"duration":3051,"area":45580000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.718 - debug: roborock.0 (7107) dps debug: {"id":27,"result":[{"begin":1672396799,"end":1672399678,"duration":2879,"area":46062500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.720 - debug: roborock.0 (7107) dps debug: {"id":30,"result":[{"begin":1671791332,"end":1671794384,"duration":3051,"area":46140000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.721 - debug: roborock.0 (7107) dps debug: {"id":31,"result":[{"begin":1671619200,"end":1671622099,"duration":2898,"area":45690000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.723 - debug: roborock.0 (7107) dps debug: {"id":28,"result":[{"begin":1672224000,"end":1672226907,"duration":2907,"area":45725000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.725 - debug: roborock.0 (7107) dps debug: {"id":32,"result":[{"begin":1671446400,"end":1671449983,"duration":3583,"area":45985000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.727 - debug: roborock.0 (7107) dps debug: {"id":21,"result":[{"begin":1673606401,"end":1673609286,"duration":2885,"area":45722500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.729 - debug: roborock.0 (7107) dps debug: {"id":29,"result":[{"begin":1672051200,"end":1672054195,"duration":2995,"area":46020000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.731 - debug: roborock.0 (7107) dps debug: {"id":26,"result":[{"begin":1672656000,"end":1672658889,"duration":2888,"area":45622500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.733 - debug: roborock.0 (7107) dps debug: {"id":23,"result":[{"begin":1673260802,"end":1673263712,"duration":2910,"area":45922500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:50.865 - debug: roborock.0 (7107) dps debug: {"id":22,"result":[{"begin":1673433600,"end":1673436525,"duration":2925,"area":45552500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                  2023-01-26 22:31:54.524 - silly: roborock.0 (7107) States user redis pmessage io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.*/io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.load_multi_map:{"val":0,"ack":false,"ts":1674768714518,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1674726972089}
                                  2023-01-26 22:31:54.528 - debug: roborock.0 (7107) onStateChange: load_multi_map with value: 0
                                  2023-01-26 22:31:54.532 - error: roborock.0 (7107) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2023-01-26 22:31:54.533 - error: roborock.0 (7107) unhandled promise rejection: Cannot read properties of undefined (reading 'command')
                                  2023-01-26 22:31:54.543 - error: roborock.0 (7107) TypeError: Cannot read properties of undefined (reading 'command')
                                  at Roborock.onStateChange (/opt/iobroker/node_modules/iobroker.roborock/main.js:274:25)
                                  at Roborock.emit (node:events:513:28)
                                  at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5385:53)
                                  at processImmediate (node:internal/timers:466:21)
                                  2023-01-26 22:31:54.544 - error: roborock.0 (7107) Cannot read properties of undefined (reading 'command')
                                  2023-01-26 22:31:54.558 - info: roborock.0 (7107) terminating
                                  2023-01-26 22:31:54.561 - warn: roborock.0 (7107) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2023-01-26 22:31:55.212 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  2023-01-26 22:31:55.212 - info: host.raspberrypi-gang Restart adapter system.adapter.roborock.0 because enabled
                                  2023-01-26 22:31:57.948 - info: host.raspberrypi-gang "system.adapter.roborock.0" disabled
                                  2023-01-26 22:32:27.491 - debug: roborock.0 (7494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2023-01-26 22:32:27.577 - debug: roborock.0 (7494) Objects client ready ... initialize now
                                  2023-01-26 22:32:27.579 - debug: roborock.0 (7494) Objects create System PubSub Client
                                  2023-01-26 22:32:27.581 - debug: roborock.0 (7494) Objects create User PubSub Client
                                  2023-01-26 22:32:27.730 - debug: roborock.0 (7494) Objects client initialize lua scripts
                                  2023-01-26 22:32:27.750 - debug: roborock.0 (7494) Objects connected to redis: 127.0.0.1:9001
                                  2023-01-26 22:32:27.754 - silly: roborock.0 (7494) redis psubscribe cfg.o.system.user.*
                                  2023-01-26 22:32:27.819 - silly: roborock.0 (7494) redis psubscribe cfg.o.enum.*
                                  2023-01-26 22:32:27.826 - silly: roborock.0 (7494) objectDB connected
                                  2023-01-26 22:32:27.830 - debug: roborock.0 (7494) Redis States: Use Redis connection: 127.0.0.1:6379
                                  2023-01-26 22:32:27.839 - debug: roborock.0 (7494) States create System PubSub Client
                                  2023-01-26 22:32:27.842 - debug: roborock.0 (7494) States create User PubSub Client
                                  2023-01-26 22:32:27.853 - debug: roborock.0 (7494) States connected to redis: 127.0.0.1:6379
                                  2023-01-26 22:32:27.855 - silly: roborock.0 (7494) statesDB connected
                                  2023-01-26 22:32:27.892 - error: roborock.0 (7494) adapter disabled
                                  2023-01-26 22:32:27.903 - warn: roborock.0 (7494) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                  2023-01-26 22:32:28.611 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                  Ist das schon bekannt bzw. soll das in diesem Branch noch gar nicht funktionieren?
                                  • copystring
                                    copystring @Black Thunder last edited by
                                    @black-thunder Das sollte in der branch laufen. Habe auch den S7 und da läuft es.
                                    • wendy2702
                                      Bitte schön:
                                      2023-01-26 22:42:29.674  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                      false2023-01-26 22:42:29.679  - info: roborock.0 (1067687) Got terminate signal TERMINATE_YOURSELF
                                      false2023-01-26 22:42:29.681  - info: roborock.0 (1067687) terminating
                                      false2023-01-26 22:42:29.682  - info: roborock.0 (1067687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      false2023-01-26 22:42:29.716  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                      false2023-01-26 22:42:30.371  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      false2023-01-26 22:42:32.877  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1068227
                                      false2023-01-26 22:42:33.813  - debug: roborock.0 (1068227) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                      false2023-01-26 22:42:33.855  - debug: roborock.0 (1068227) Objects client ready ... initialize now
                                      false2023-01-26 22:42:33.856  - debug: roborock.0 (1068227) Objects create System PubSub Client
                                      false2023-01-26 22:42:33.857  - debug: roborock.0 (1068227) Objects create User PubSub Client
                                      false2023-01-26 22:42:33.933  - debug: roborock.0 (1068227) Objects client initialize lua scripts
                                      false2023-01-26 22:42:33.938  - debug: roborock.0 (1068227) Objects connected to redis: 0.0.0.0:9001
                                      false2023-01-26 22:42:33.965  - debug: roborock.0 (1068227) Redis States: Use Redis connection: 0.0.0.0:9000
                                      false2023-01-26 22:42:33.991  - debug: roborock.0 (1068227) States create System PubSub Client
                                      false2023-01-26 22:42:33.992  - debug: roborock.0 (1068227) States create User PubSub Client
                                      false2023-01-26 22:42:34.072  - debug: roborock.0 (1068227) States connected to redis: 0.0.0.0:9000
                                      false2023-01-26 22:42:34.278  - info: roborock.0 (1068227) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                      false2023-01-26 22:42:34.443  - debug: roborock.0 (1068227) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
                                      false2023-01-26 22:42:34.473  - info: roborock.0 (1068227) MQTT initialized
                                      false2023-01-26 22:42:34.475  - debug: roborock.0 (1068227) Robot key: roborock.vacuum.a15
                                      false2023-01-26 22:42:34.632  - debug: roborock.0 (1068227) Latest data requested
                                      false2023-01-26 22:42:34.633  - debug: roborock.0 (1068227) getParameter: get_mop_mode
                                      false2023-01-26 22:42:34.635  - debug: roborock.0 (1068227) getParameter: get_water_box_custom_mode
                                      false2023-01-26 22:42:34.636  - debug: roborock.0 (1068227) getParameter: get_status
                                      false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_consumable
                                      false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_network_info
                                      false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_carpet_mode
                                      false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_carpet_cleaning_mode
                                      false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_fw_features
                                      false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) Firmware features request
                                      false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_multi_maps_list
                                      false2023-01-26 22:42:34.639  - debug: roborock.0 (1068227) getParameter: get_room_mapping
                                      false2023-01-26 22:42:34.639  - debug: roborock.0 (1068227) get_room_mapping
                                      false2023-01-26 22:42:34.688  - debug: roborock.0 (1068227) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":4527,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                      false2023-01-26 22:42:34.689  - debug: roborock.0 (1068227) dps debug: {"id":1,"result":[302]}
                                      false2023-01-26 22:42:34.691  - debug: roborock.0 (1068227) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":4528,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                      false2023-01-26 22:42:34.692  - debug: roborock.0 (1068227) dps debug: {"id":5,"result":[{"main_brush_work_time":581958,"side_brush_work_time":581958,"filter_work_time":36866,"filter_element_work_time":0,"sensor_dirty_time":50176,"dust_collection_work_times":26}]}
                                      false2023-01-26 22:42:34.702  - debug: roborock.0 (1068227) dps debug: {"id":3,"result":[203]}
                                      false2023-01-26 22:42:34.733  - debug: roborock.0 (1068227) dps debug: {"id":6,"result":{"ssid":"WXXXXO","ip":"192.168.178.73","mac":"b0:xxxx:72","bssid":"6a:d7:9a:18:ce:bb","rssi":-58}}
                                      false2023-01-26 22:42:34.770  - debug: roborock.0 (1068227) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674662405,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
                                      false2023-01-26 22:42:34.776  - debug: roborock.0 (1068227) dps debug: {"id":12,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
                                      false2023-01-26 22:42:34.776  - debug: roborock.0 (1068227) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
                                      false2023-01-26 22:42:34.777  - debug: roborock.0 (1068227) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                      false2023-01-26 22:42:34.778  - debug: roborock.0 (1068227) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                                      false2023-01-26 22:42:34.785  - debug: roborock.0 (1068227) dps debug: {"id":9,"result":"unknown_method"}
                                      false2023-01-26 22:42:34.786  - debug: roborock.0 (1068227) Unknown parameter: "unknown_method"
                                      false2023-01-26 22:42:34.786  - debug: roborock.0 (1068227) dps debug: {"id":7,"result":{"clean_time":581938,"clean_area":8566392500,"clean_count":355,"dust_collection_count":292,"records":[1674660336,1674660313,1674577216,1674310611,1673963198,1673962557,1673625667,1673624409,1673450020,1673279186,1673177137,1673177094,1672931751,1672839102,1672839052,1672676949,1672483666,1671550852,1671550717,1671292694]}}
                                      false2023-01-26 22:42:34.834  - debug: roborock.0 (1068227) dps debug: {"id":13,"result":[{"begin":1674660336,"end":1674662311,"duration":1975,"area":30992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.838  - debug: roborock.0 (1068227) dps debug: {"id":14,"result":[{"begin":1674660313,"end":1674660315,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
                                      false2023-01-26 22:42:34.840  - debug: roborock.0 (1068227) dps debug: {"id":15,"result":[{"begin":1674577216,"end":1674583431,"duration":3658,"area":39990000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":20,"result":[{"begin":1673624409,"end":1673624479,"duration":70,"area":1490000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":16,"result":[{"begin":1674310611,"end":1674311055,"duration":444,"area":6152500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":21,"result":[{"begin":1673450020,"end":1673452606,"duration":2586,"area":39457500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.842  - debug: roborock.0 (1068227) dps debug: {"id":17,"result":[{"begin":1673963198,"end":1673970437,"duration":2672,"area":37172500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.842  - debug: roborock.0 (1068227) dps debug: {"id":18,"result":[{"begin":1673962557,"end":1673962598,"duration":15,"area":0,"error":0,"complete":0,"start_type":1,"clean_type":1,"finish_reason":21,"dust_collection_status":0}]}
                                      false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":22,"result":[{"begin":1673279186,"end":1673280386,"duration":1200,"area":18042500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":26,"result":[{"begin":1672839102,"end":1672847459,"duration":2861,"area":39335000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":29,"result":[{"begin":1672483666,"end":1672484896,"duration":1230,"area":17945000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.854  - debug: roborock.0 (1068227) dps debug: {"id":25,"result":[{"begin":1672931751,"end":1672934471,"duration":2720,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.854  - debug: roborock.0 (1068227) dps debug: {"id":28,"result":[{"begin":1672676949,"end":1672678212,"duration":1263,"area":17982500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.855  - debug: roborock.0 (1068227) dps debug: {"id":30,"result":[{"begin":1671550852,"end":1671553922,"duration":3062,"area":39902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.855  - debug: roborock.0 (1068227) dps debug: {"id":19,"result":[{"begin":1673625667,"end":1673628366,"duration":2699,"area":39452500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.856  - debug: roborock.0 (1068227) dps debug: {"id":27,"result":[{"begin":1672839052,"end":1672839065,"duration":13,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
                                      false2023-01-26 22:42:34.856  - debug: roborock.0 (1068227) dps debug: {"id":23,"result":[{"begin":1673177137,"end":1673179722,"duration":2585,"area":36967500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":24,"result":[{"begin":1673177094,"end":1673177102,"duration":8,"area":0,"error":0,"complete":0,"start_type":4,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
                                      false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":31,"result":[{"begin":1671550717,"end":1671550797,"duration":80,"area":1050000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
                                      false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":32,"result":[{"begin":1671292694,"end":1671294598,"duration":1904,"area":27470000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                                      • copystring
                                        @wendy2702 @Black-Thunder Danke für die logs. Ich denke das gucke ich mir am Wochenende mal genauer an aber ist schon irgendwie merkwürdig, dass bei euch nicht läuft und ich mir wie ihr auch von Github die branch ziehe und bei mir dann diese Probleme nicht auftauchen...
                                        • copystring
                                          copystring @copystring last edited by copystring
                                          ich habe mal für das Setzen der Parameter ein zusätzliches Debuglogging eingefügt. Bitte die neue Version ausprobieren und mir ein neues Log schicken: https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                                          Bei mir steht z.B. deviceInfo battery set with value: 100 und
                                          deviceInfo filter_life set with value: 58 und wurde dementsprechend sauber gesetzt. Steht das bei euch nicht drin dann ruft er die Funktion gar nicht auf was aber eigentlich gar nicht sein kann...
                                          Black Thunder 1 Reply Last reply Reply Quote 0
                                          • Black Thunder
                                            Black Thunder Developer @copystring last edited by Black Thunder
                                            @copystring Also ich hab jetzt nochmal den kompletten Adapter inkl. aller Objekte gelöscht und alles frisch geholt, damit ich nen sauberen Stand habe. Jetzt sind auch etliche zusätzliche Warnings im Log.
                                            Zum Beispiel "deviceStatus 125 set with value: 21" sollte vermutlich in meinem Fall die Lebensdauer der Hauptbürste sein. Das wäre zumindest der einzige Wert mit 21, den ich in der App sehe.
                                            EDIT: Ja, das steht auch so in HomeData:
                                            //// schnipp
                                                      "id": "125",
                                                      "name": "主刷寿命",
                                                      "code": "main_brush_life",
                                                      "mode": "rw",
                                                      "type": "VALUE",
                                                      "property": "{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}",
                                                      "desc": null
                                            //// schnipp
                                            2023-01-26 23:39:55.542 - info: host.raspberrypi-gang "system.adapter.roborock.0" enabled
                                            2023-01-26 23:39:56.157 - info: host.raspberrypi-gang instance system.adapter.roborock.0 started with pid 22375
                                            2023-01-26 23:39:57.793 - debug: roborock.0 (22375) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                            2023-01-26 23:39:57.874 - debug: roborock.0 (22375) Objects client ready ... initialize now
                                            2023-01-26 23:39:57.877 - debug: roborock.0 (22375) Objects create System PubSub Client
                                            2023-01-26 23:39:57.879 - debug: roborock.0 (22375) Objects create User PubSub Client
                                            2023-01-26 23:39:58.029 - debug: roborock.0 (22375) Objects client initialize lua scripts
                                            2023-01-26 23:39:58.038 - debug: roborock.0 (22375) Objects connected to redis: 127.0.0.1:9001
                                            2023-01-26 23:39:58.041 - silly: roborock.0 (22375) redis psubscribe cfg.o.system.user.*
                                            2023-01-26 23:39:58.098 - silly: roborock.0 (22375) redis psubscribe cfg.o.enum.*
                                            2023-01-26 23:39:58.105 - silly: roborock.0 (22375) objectDB connected
                                            2023-01-26 23:39:58.109 - debug: roborock.0 (22375) Redis States: Use Redis connection: 127.0.0.1:6379
                                            2023-01-26 23:39:58.118 - debug: roborock.0 (22375) States create System PubSub Client
                                            2023-01-26 23:39:58.120 - debug: roborock.0 (22375) States create User PubSub Client
                                            2023-01-26 23:39:58.133 - debug: roborock.0 (22375) States connected to redis: 127.0.0.1:6379
                                            2023-01-26 23:39:58.135 - silly: roborock.0 (22375) statesDB connected
                                            2023-01-26 23:39:58.459 - info: roborock.0 (22375) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                            2023-01-26 23:39:58.592 - silly: roborock.0 (22375) States system redis pmessage io.system.adapter.roborock.0.logLevel/io.system.adapter.roborock.0.logLevel:{"val":"silly","ack":true,"ts":1674772798507,"q":0,"from":"system.adapter.roborock.0","lc":1674772798507}
                                            2023-01-26 23:39:58.912 - debug: roborock.0 (22375) UserData: [object Object]
                                            2023-01-26 23:39:59.220 - debug: roborock.0 (22375) RoomIDs debug: {"10467471":"Wohnzimmer","10467473":"Zimmer Domi","10467476":"Küche","10467477":"Schlafzimmer","10467479":"Bad","10467481":"Balkon","10467484":"Gang"}
                                            2023-01-26 23:39:59.335 - info: roborock.0 (22375) MQTT initialized
                                            2023-01-26 23:39:59.427 - debug: roborock.0 (22375) Robot key: roborock.vacuum.a15
                                            2023-01-26 23:40:07.824 - debug: roborock.0 (22375) Latest data requested
                                            2023-01-26 23:40:07.826 - debug: roborock.0 (22375) getParameter: get_mop_mode
                                            2023-01-26 23:40:07.838 - debug: roborock.0 (22375) getParameter: get_water_box_custom_mode
                                            2023-01-26 23:40:07.841 - debug: roborock.0 (22375) getParameter: get_status
                                            2023-01-26 23:40:07.843 - debug: roborock.0 (22375) getParameter: get_consumable
                                            2023-01-26 23:40:07.845 - debug: roborock.0 (22375) getParameter: get_network_info
                                            2023-01-26 23:40:07.851 - debug: roborock.0 (22375) getParameter: get_carpet_mode
                                            2023-01-26 23:40:07.853 - debug: roborock.0 (22375) getParameter: get_carpet_cleaning_mode
                                            2023-01-26 23:40:07.856 - debug: roborock.0 (22375) getParameter: get_fw_features
                                            2023-01-26 23:40:07.857 - debug: roborock.0 (22375) Firmware features request
                                            2023-01-26 23:40:07.859 - debug: roborock.0 (22375) getParameter: get_multi_maps_list
                                            2023-01-26 23:40:07.863 - debug: roborock.0 (22375) getParameter: get_room_mapping
                                            2023-01-26 23:40:07.864 - debug: roborock.0 (22375) get_room_mapping
                                            2023-01-26 23:40:07.944 - debug: roborock.0 (22375) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1536,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                            2023-01-26 23:40:07.965 - debug: roborock.0 (22375) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                            2023-01-26 23:40:07.968 - debug: roborock.0 (22375) dps debug: {"id":5,"result":[{"main_brush_work_time":863894,"side_brush_work_time":0,"filter_work_time":313720,"filter_element_work_time":0,"sensor_dirty_time":58909,"dust_collection_work_times":0}]}
                                            2023-01-26 23:40:07.971 - debug: roborock.0 (22375) dps debug: {"id":7,"result":{"clean_time":863797,"clean_area":13435762500,"clean_count":336,"dust_collection_count":0,"records":[1674725138,1674725117,1674725026,1674643201,1674470400,1674211201,1674038400,1673865601,1673606401,1673433600,1673260802,1673001600,1672828801,1672656000,1672396799,1672224000,1672051200,1671791332,1671619200,1671446400]}}
                                            2023-01-26 23:40:07.998 - debug: roborock.0 (22375) dps debug: {"id":1,"result":[300]}
                                            2023-01-26 23:40:08.001 - debug: roborock.0 (22375) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1537,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                            2023-01-26 23:40:08.007 - debug: roborock.0 (22375) dps debug: {"id":9,"result":"unknown_method"}
                                            2023-01-26 23:40:08.009 - debug: roborock.0 (22375) Unknown parameter: "unknown_method"
                                            2023-01-26 23:40:08.023 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.024 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.026 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.027 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.029 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.030 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.031 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.033 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.035 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.036 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.038 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.039 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.040 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.041 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.042 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.043 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.044 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.045 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.046 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.047 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.048 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.049 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.051 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.053 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.054 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.056 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.057 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.059 - debug: roborock.0 (22375) dps debug: {"id":3,"result":[203]}
                                            2023-01-26 23:40:08.062 - debug: roborock.0 (22375) dps debug: {"id":12,"result":[[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]}
                                            2023-01-26 23:40:08.064 - debug: roborock.0 (22375) get_room_mapping: [[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]
                                            2023-01-26 23:40:08.067 - debug: roborock.0 (22375) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                                            2023-01-26 23:40:08.073 - debug: roborock.0 (22375) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674730815,"length":10,"name":"Hauptkarte","bak_maps":[{"mapFlag":4,"add_time":1674646243}]}]}]}
                                            2023-01-26 23:40:08.076 - debug: roborock.0 (22375) dps debug: {"id":6,"result":{"ssid":"1.FCGlucke","ip":"192.168.2.102","mac":"b0:4a:39:04:69:e9","bssid":"44:4e:6d:69:b7:f1","rssi":-62}}
                                            2023-01-26 23:40:08.079 - debug: roborock.0 (22375) dps debug: {"id":14,"result":[{"begin":1674725117,"end":1674725124,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.083 - debug: roborock.0 (22375) dps debug: {"id":16,"result":[{"begin":1674643201,"end":1674646187,"duration":2986,"area":45902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.088 - debug: roborock.0 (22375) dps debug: {"id":13,"result":[{"begin":1674725138,"end":1674730242,"duration":5104,"area":46190000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.158 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.159 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.161 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.164 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.164 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.165 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.166 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.167 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.168 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.169 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.170 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.172 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.173 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.174 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.175 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.176 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.177 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.178 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.179 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.180 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.181 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.182 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.183 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.185 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.187 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.188 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.194 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
                                            2023-01-26 23:40:08.199 - debug: roborock.0 (22375) dps debug: {"id":15,"result":[{"begin":1674725026,"end":1674725079,"duration":41,"area":920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.204 - debug: roborock.0 (22375) dps debug: {"id":27,"result":[{"begin":1672396799,"end":1672399678,"duration":2879,"area":46062500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.211 - debug: roborock.0 (22375) dps debug: {"id":23,"result":[{"begin":1673260802,"end":1673263712,"duration":2910,"area":45922500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.214 - debug: roborock.0 (22375) dps debug: {"id":17,"result":[{"begin":1674470400,"end":1674473247,"duration":2847,"area":45627500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.217 - debug: roborock.0 (22375) dps debug: {"id":18,"result":[{"begin":1674211201,"end":1674214020,"duration":2819,"area":45745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.220 - debug: roborock.0 (22375) dps debug: {"id":24,"result":[{"begin":1673001600,"end":1673001754,"duration":147,"area":3327500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.223 - debug: roborock.0 (22375) dps debug: {"id":19,"result":[{"begin":1674038400,"end":1674041195,"duration":2795,"area":45662500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.226 - debug: roborock.0 (22375) dps debug: {"id":25,"result":[{"begin":1672828801,"end":1672831852,"duration":3051,"area":45580000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.228 - debug: roborock.0 (22375) dps debug: {"id":28,"result":[{"begin":1672224000,"end":1672226907,"duration":2907,"area":45725000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.230 - debug: roborock.0 (22375) dps debug: {"id":20,"result":[{"begin":1673865601,"end":1673868654,"duration":3053,"area":45852500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.232 - debug: roborock.0 (22375) dps debug: {"id":22,"result":[{"begin":1673433600,"end":1673436525,"duration":2925,"area":45552500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.237 - debug: roborock.0 (22375) dps debug: {"id":30,"result":[{"begin":1671791332,"end":1671794384,"duration":3051,"area":46140000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.239 - debug: roborock.0 (22375) dps debug: {"id":26,"result":[{"begin":1672656000,"end":1672658889,"duration":2888,"area":45622500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.241 - debug: roborock.0 (22375) dps debug: {"id":21,"result":[{"begin":1673606401,"end":1673609286,"duration":2885,"area":45722500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.242 - debug: roborock.0 (22375) dps debug: {"id":32,"result":[{"begin":1671446400,"end":1671449983,"duration":3583,"area":45985000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.244 - debug: roborock.0 (22375) dps debug: {"id":29,"result":[{"begin":1672051200,"end":1672054195,"duration":2995,"area":46020000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.246 - debug: roborock.0 (22375) dps debug: {"id":31,"result":[{"begin":1671619200,"end":1671622099,"duration":2898,"area":45690000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                            2023-01-26 23:40:08.531 - silly: roborock.0 (22375) States user redis pmessage io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.*/io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.load_multi_map:{"val":0,"ack":true,"ts":1674772808526,"q":32,"from":"system.adapter.roborock.0","user":"system.user.admin","lc":1674772808526}
                                            2023-01-26 23:40:08.539 - debug: roborock.0 (22375) onStateChange: load_multi_map with value: 0
                                            2023-01-26 23:40:08.541 - error: roborock.0 (22375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            2023-01-26 23:40:08.541 - error: roborock.0 (22375) unhandled promise rejection: Cannot read properties of undefined (reading 'command')
                                            2023-01-26 23:40:08.544 - error: roborock.0 (22375) TypeError: Cannot read properties of undefined (reading 'command')
                                            2023-01-26 23:40:08.545 - error: roborock.0 (22375) Cannot read properties of undefined (reading 'command')
                                            2023-01-26 23:40:08.553 - info: roborock.0 (22375) terminating
                                            2023-01-26 23:40:08.554 - warn: roborock.0 (22375) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2023-01-26 23:40:08.729 - debug: roborock.0 (22375) deviceStatus 120 set with value: 0
                                            2023-01-26 23:40:08.739 - debug: roborock.0 (22375) deviceStatus 121 set with value: 8
                                            2023-01-26 23:40:08.750 - debug: roborock.0 (22375) deviceStatus 122 set with value: 100
                                            2023-01-26 23:40:08.760 - debug: roborock.0 (22375) deviceStatus 123 set with value: 102
                                            2023-01-26 23:40:08.777 - debug: roborock.0 (22375) deviceStatus 124 set with value: 203
                                            2023-01-26 23:40:08.789 - debug: roborock.0 (22375) deviceStatus 125 set with value: 21
                                            2023-01-26 23:40:08.816 - debug: roborock.0 (22375) deviceStatus 126 set with value: 100
                                            2023-01-26 23:40:08.825 - debug: roborock.0 (22375) deviceStatus 127 set with value: 43
                                            2023-01-26 23:40:09.286 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                            766
                                            242211
