    4. JavaScript
    5. Roborock Adapter tester gesucht
    • copystring
      copystring @Black Thunder last edited by
      @black-thunder Das sollte in der branch laufen. Habe auch den S7 und da läuft es.
      • wendy2702
        wendy2702 @copystring last edited by
        @copystring sagte in Roborock Adapter tester gesucht:
        Schick mal bitte ein debug log nach dem Start des Adapters.
        Bitte schön:
        2023-01-26 22:42:29.674  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
        false2023-01-26 22:42:29.679  - info: roborock.0 (1067687) Got terminate signal TERMINATE_YOURSELF
        false2023-01-26 22:42:29.681  - info: roborock.0 (1067687) terminating
        false2023-01-26 22:42:29.682  - info: roborock.0 (1067687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        false2023-01-26 22:42:29.716  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
        false2023-01-26 22:42:30.371  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        false2023-01-26 22:42:32.877  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1068227
        false2023-01-26 22:42:33.813  - debug: roborock.0 (1068227) Redis Objects: Use Redis connection: 0.0.0.0:9001
        false2023-01-26 22:42:33.855  - debug: roborock.0 (1068227) Objects client ready ... initialize now
        false2023-01-26 22:42:33.856  - debug: roborock.0 (1068227) Objects create System PubSub Client
        false2023-01-26 22:42:33.857  - debug: roborock.0 (1068227) Objects create User PubSub Client
        false2023-01-26 22:42:33.933  - debug: roborock.0 (1068227) Objects client initialize lua scripts
        false2023-01-26 22:42:33.938  - debug: roborock.0 (1068227) Objects connected to redis: 0.0.0.0:9001
        false2023-01-26 22:42:33.965  - debug: roborock.0 (1068227) Redis States: Use Redis connection: 0.0.0.0:9000
        false2023-01-26 22:42:33.991  - debug: roborock.0 (1068227) States create System PubSub Client
        false2023-01-26 22:42:33.992  - debug: roborock.0 (1068227) States create User PubSub Client
        false2023-01-26 22:42:34.072  - debug: roborock.0 (1068227) States connected to redis: 0.0.0.0:9000
        false2023-01-26 22:42:34.278  - info: roborock.0 (1068227) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        false2023-01-26 22:42:34.443  - debug: roborock.0 (1068227) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
        false2023-01-26 22:42:34.473  - info: roborock.0 (1068227) MQTT initialized
        false2023-01-26 22:42:34.475  - debug: roborock.0 (1068227) Robot key: roborock.vacuum.a15
        false2023-01-26 22:42:34.632  - debug: roborock.0 (1068227) Latest data requested
        false2023-01-26 22:42:34.633  - debug: roborock.0 (1068227) getParameter: get_mop_mode
        false2023-01-26 22:42:34.635  - debug: roborock.0 (1068227) getParameter: get_water_box_custom_mode
        false2023-01-26 22:42:34.636  - debug: roborock.0 (1068227) getParameter: get_status
        false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_consumable
        false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_network_info
        false2023-01-26 22:42:34.637  - debug: roborock.0 (1068227) getParameter: get_carpet_mode
        false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_carpet_cleaning_mode
        false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_fw_features
        false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) Firmware features request
        false2023-01-26 22:42:34.638  - debug: roborock.0 (1068227) getParameter: get_multi_maps_list
        false2023-01-26 22:42:34.639  - debug: roborock.0 (1068227) getParameter: get_room_mapping
        false2023-01-26 22:42:34.639  - debug: roborock.0 (1068227) get_room_mapping
        false2023-01-26 22:42:34.688  - debug: roborock.0 (1068227) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":4527,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
        false2023-01-26 22:42:34.689  - debug: roborock.0 (1068227) dps debug: {"id":1,"result":[302]}
        false2023-01-26 22:42:34.691  - debug: roborock.0 (1068227) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":4528,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
        false2023-01-26 22:42:34.692  - debug: roborock.0 (1068227) dps debug: {"id":5,"result":[{"main_brush_work_time":581958,"side_brush_work_time":581958,"filter_work_time":36866,"filter_element_work_time":0,"sensor_dirty_time":50176,"dust_collection_work_times":26}]}
        false2023-01-26 22:42:34.702  - debug: roborock.0 (1068227) dps debug: {"id":3,"result":[203]}
        false2023-01-26 22:42:34.733  - debug: roborock.0 (1068227) dps debug: {"id":6,"result":{"ssid":"WXXXXO","ip":"192.168.178.73","mac":"b0:xxxx:72","bssid":"6a:d7:9a:18:ce:bb","rssi":-58}}
        false2023-01-26 22:42:34.770  - debug: roborock.0 (1068227) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674662405,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
        false2023-01-26 22:42:34.776  - debug: roborock.0 (1068227) dps debug: {"id":12,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
        false2023-01-26 22:42:34.776  - debug: roborock.0 (1068227) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
        false2023-01-26 22:42:34.777  - debug: roborock.0 (1068227) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
        false2023-01-26 22:42:34.778  - debug: roborock.0 (1068227) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
        false2023-01-26 22:42:34.785  - debug: roborock.0 (1068227) dps debug: {"id":9,"result":"unknown_method"}
        false2023-01-26 22:42:34.786  - debug: roborock.0 (1068227) Unknown parameter: "unknown_method"
        false2023-01-26 22:42:34.786  - debug: roborock.0 (1068227) dps debug: {"id":7,"result":{"clean_time":581938,"clean_area":8566392500,"clean_count":355,"dust_collection_count":292,"records":[1674660336,1674660313,1674577216,1674310611,1673963198,1673962557,1673625667,1673624409,1673450020,1673279186,1673177137,1673177094,1672931751,1672839102,1672839052,1672676949,1672483666,1671550852,1671550717,1671292694]}}
        false2023-01-26 22:42:34.834  - debug: roborock.0 (1068227) dps debug: {"id":13,"result":[{"begin":1674660336,"end":1674662311,"duration":1975,"area":30992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.838  - debug: roborock.0 (1068227) dps debug: {"id":14,"result":[{"begin":1674660313,"end":1674660315,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
        false2023-01-26 22:42:34.840  - debug: roborock.0 (1068227) dps debug: {"id":15,"result":[{"begin":1674577216,"end":1674583431,"duration":3658,"area":39990000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":20,"result":[{"begin":1673624409,"end":1673624479,"duration":70,"area":1490000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":16,"result":[{"begin":1674310611,"end":1674311055,"duration":444,"area":6152500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.841  - debug: roborock.0 (1068227) dps debug: {"id":21,"result":[{"begin":1673450020,"end":1673452606,"duration":2586,"area":39457500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.842  - debug: roborock.0 (1068227) dps debug: {"id":17,"result":[{"begin":1673963198,"end":1673970437,"duration":2672,"area":37172500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.842  - debug: roborock.0 (1068227) dps debug: {"id":18,"result":[{"begin":1673962557,"end":1673962598,"duration":15,"area":0,"error":0,"complete":0,"start_type":1,"clean_type":1,"finish_reason":21,"dust_collection_status":0}]}
        false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":22,"result":[{"begin":1673279186,"end":1673280386,"duration":1200,"area":18042500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":26,"result":[{"begin":1672839102,"end":1672847459,"duration":2861,"area":39335000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.843  - debug: roborock.0 (1068227) dps debug: {"id":29,"result":[{"begin":1672483666,"end":1672484896,"duration":1230,"area":17945000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.854  - debug: roborock.0 (1068227) dps debug: {"id":25,"result":[{"begin":1672931751,"end":1672934471,"duration":2720,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.854  - debug: roborock.0 (1068227) dps debug: {"id":28,"result":[{"begin":1672676949,"end":1672678212,"duration":1263,"area":17982500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.855  - debug: roborock.0 (1068227) dps debug: {"id":30,"result":[{"begin":1671550852,"end":1671553922,"duration":3062,"area":39902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.855  - debug: roborock.0 (1068227) dps debug: {"id":19,"result":[{"begin":1673625667,"end":1673628366,"duration":2699,"area":39452500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.856  - debug: roborock.0 (1068227) dps debug: {"id":27,"result":[{"begin":1672839052,"end":1672839065,"duration":13,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
        false2023-01-26 22:42:34.856  - debug: roborock.0 (1068227) dps debug: {"id":23,"result":[{"begin":1673177137,"end":1673179722,"duration":2585,"area":36967500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":24,"result":[{"begin":1673177094,"end":1673177102,"duration":8,"area":0,"error":0,"complete":0,"start_type":4,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
        false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":31,"result":[{"begin":1671550717,"end":1671550797,"duration":80,"area":1050000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
        false2023-01-26 22:42:34.857  - debug: roborock.0 (1068227) dps debug: {"id":32,"result":[{"begin":1671292694,"end":1671294598,"duration":1904,"area":27470000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        copystring 1 Reply Last reply Reply Quote 0
        • copystring
          copystring @wendy2702 last edited by
          @wendy2702 @Black-Thunder Danke für die logs. Ich denke das gucke ich mir am Wochenende mal genauer an aber ist schon irgendwie merkwürdig, dass bei euch nicht läuft und ich mir wie ihr auch von Github die branch ziehe und bei mir dann diese Probleme nicht auftauchen...
          • copystring
            copystring @copystring last edited by copystring
            ich habe mal für das Setzen der Parameter ein zusätzliches Debuglogging eingefügt. Bitte die neue Version ausprobieren und mir ein neues Log schicken: https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
            Bei mir steht z.B. deviceInfo battery set with value: 100 und
            deviceInfo filter_life set with value: 58 und wurde dementsprechend sauber gesetzt. Steht das bei euch nicht drin dann ruft er die Funktion gar nicht auf was aber eigentlich gar nicht sein kann...
            Black Thunder 1 Reply Last reply Reply Quote 0
            • Black Thunder
              Black Thunder Developer @copystring last edited by Black Thunder
              @copystring Also ich hab jetzt nochmal den kompletten Adapter inkl. aller Objekte gelöscht und alles frisch geholt, damit ich nen sauberen Stand habe. Jetzt sind auch etliche zusätzliche Warnings im Log.
              Zum Beispiel "deviceStatus 125 set with value: 21" sollte vermutlich in meinem Fall die Lebensdauer der Hauptbürste sein. Das wäre zumindest der einzige Wert mit 21, den ich in der App sehe.
              EDIT: Ja, das steht auch so in HomeData:
              //// schnipp
                        "id": "125",
                        "name": "主刷寿命",
                        "code": "main_brush_life",
                        "mode": "rw",
                        "type": "VALUE",
                        "property": "{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}",
                        "desc": null
              //// schnipp
              2023-01-26 23:39:55.542 - info: host.raspberrypi-gang "system.adapter.roborock.0" enabled
              2023-01-26 23:39:56.157 - info: host.raspberrypi-gang instance system.adapter.roborock.0 started with pid 22375
              2023-01-26 23:39:57.793 - debug: roborock.0 (22375) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2023-01-26 23:39:57.874 - debug: roborock.0 (22375) Objects client ready ... initialize now
              2023-01-26 23:39:57.877 - debug: roborock.0 (22375) Objects create System PubSub Client
              2023-01-26 23:39:57.879 - debug: roborock.0 (22375) Objects create User PubSub Client
              2023-01-26 23:39:58.029 - debug: roborock.0 (22375) Objects client initialize lua scripts
              2023-01-26 23:39:58.038 - debug: roborock.0 (22375) Objects connected to redis: 127.0.0.1:9001
              2023-01-26 23:39:58.041 - silly: roborock.0 (22375) redis psubscribe cfg.o.system.user.*
              2023-01-26 23:39:58.098 - silly: roborock.0 (22375) redis psubscribe cfg.o.enum.*
              2023-01-26 23:39:58.105 - silly: roborock.0 (22375) objectDB connected
              2023-01-26 23:39:58.109 - debug: roborock.0 (22375) Redis States: Use Redis connection: 127.0.0.1:6379
              2023-01-26 23:39:58.118 - debug: roborock.0 (22375) States create System PubSub Client
              2023-01-26 23:39:58.120 - debug: roborock.0 (22375) States create User PubSub Client
              2023-01-26 23:39:58.133 - debug: roborock.0 (22375) States connected to redis: 127.0.0.1:6379
              2023-01-26 23:39:58.135 - silly: roborock.0 (22375) statesDB connected
              2023-01-26 23:39:58.459 - info: roborock.0 (22375) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
              2023-01-26 23:39:58.592 - silly: roborock.0 (22375) States system redis pmessage io.system.adapter.roborock.0.logLevel/io.system.adapter.roborock.0.logLevel:{"val":"silly","ack":true,"ts":1674772798507,"q":0,"from":"system.adapter.roborock.0","lc":1674772798507}
              2023-01-26 23:39:58.912 - debug: roborock.0 (22375) UserData: [object Object]
              2023-01-26 23:39:59.220 - debug: roborock.0 (22375) RoomIDs debug: {"10467471":"Wohnzimmer","10467473":"Zimmer Domi","10467476":"Küche","10467477":"Schlafzimmer","10467479":"Bad","10467481":"Balkon","10467484":"Gang"}
              2023-01-26 23:39:59.335 - info: roborock.0 (22375) MQTT initialized
              2023-01-26 23:39:59.427 - debug: roborock.0 (22375) Robot key: roborock.vacuum.a15
              2023-01-26 23:40:07.824 - debug: roborock.0 (22375) Latest data requested
              2023-01-26 23:40:07.826 - debug: roborock.0 (22375) getParameter: get_mop_mode
              2023-01-26 23:40:07.838 - debug: roborock.0 (22375) getParameter: get_water_box_custom_mode
              2023-01-26 23:40:07.841 - debug: roborock.0 (22375) getParameter: get_status
              2023-01-26 23:40:07.843 - debug: roborock.0 (22375) getParameter: get_consumable
              2023-01-26 23:40:07.845 - debug: roborock.0 (22375) getParameter: get_network_info
              2023-01-26 23:40:07.851 - debug: roborock.0 (22375) getParameter: get_carpet_mode
              2023-01-26 23:40:07.853 - debug: roborock.0 (22375) getParameter: get_carpet_cleaning_mode
              2023-01-26 23:40:07.856 - debug: roborock.0 (22375) getParameter: get_fw_features
              2023-01-26 23:40:07.857 - debug: roborock.0 (22375) Firmware features request
              2023-01-26 23:40:07.859 - debug: roborock.0 (22375) getParameter: get_multi_maps_list
              2023-01-26 23:40:07.863 - debug: roborock.0 (22375) getParameter: get_room_mapping
              2023-01-26 23:40:07.864 - debug: roborock.0 (22375) get_room_mapping
              2023-01-26 23:40:07.944 - debug: roborock.0 (22375) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1536,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
              2023-01-26 23:40:07.965 - debug: roborock.0 (22375) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
              2023-01-26 23:40:07.968 - debug: roborock.0 (22375) dps debug: {"id":5,"result":[{"main_brush_work_time":863894,"side_brush_work_time":0,"filter_work_time":313720,"filter_element_work_time":0,"sensor_dirty_time":58909,"dust_collection_work_times":0}]}
              2023-01-26 23:40:07.971 - debug: roborock.0 (22375) dps debug: {"id":7,"result":{"clean_time":863797,"clean_area":13435762500,"clean_count":336,"dust_collection_count":0,"records":[1674725138,1674725117,1674725026,1674643201,1674470400,1674211201,1674038400,1673865601,1673606401,1673433600,1673260802,1673001600,1672828801,1672656000,1672396799,1672224000,1672051200,1671791332,1671619200,1671446400]}}
              2023-01-26 23:40:07.998 - debug: roborock.0 (22375) dps debug: {"id":1,"result":[300]}
              2023-01-26 23:40:08.001 - debug: roborock.0 (22375) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1537,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
              2023-01-26 23:40:08.007 - debug: roborock.0 (22375) dps debug: {"id":9,"result":"unknown_method"}
              2023-01-26 23:40:08.009 - debug: roborock.0 (22375) Unknown parameter: "unknown_method"
              2023-01-26 23:40:08.023 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.024 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.026 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.027 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.029 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.030 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.031 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.033 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.035 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.036 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.038 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.039 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.040 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.041 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.042 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.043 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.044 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.045 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.046 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.047 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.048 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.049 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.051 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.053 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.054 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.056 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.057 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.059 - debug: roborock.0 (22375) dps debug: {"id":3,"result":[203]}
              2023-01-26 23:40:08.062 - debug: roborock.0 (22375) dps debug: {"id":12,"result":[[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]}
              2023-01-26 23:40:08.064 - debug: roborock.0 (22375) get_room_mapping: [[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]
              2023-01-26 23:40:08.067 - debug: roborock.0 (22375) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
              2023-01-26 23:40:08.073 - debug: roborock.0 (22375) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674730815,"length":10,"name":"Hauptkarte","bak_maps":[{"mapFlag":4,"add_time":1674646243}]}]}]}
              2023-01-26 23:40:08.076 - debug: roborock.0 (22375) dps debug: {"id":6,"result":{"ssid":"1.FCGlucke","ip":"192.168.2.102","mac":"b0:4a:39:04:69:e9","bssid":"44:4e:6d:69:b7:f1","rssi":-62}}
              2023-01-26 23:40:08.079 - debug: roborock.0 (22375) dps debug: {"id":14,"result":[{"begin":1674725117,"end":1674725124,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":0}]}
              2023-01-26 23:40:08.083 - debug: roborock.0 (22375) dps debug: {"id":16,"result":[{"begin":1674643201,"end":1674646187,"duration":2986,"area":45902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.088 - debug: roborock.0 (22375) dps debug: {"id":13,"result":[{"begin":1674725138,"end":1674730242,"duration":5104,"area":46190000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.158 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.159 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.161 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.164 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.164 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.165 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.166 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.167 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.168 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.169 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.170 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.172 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.173 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.174 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.175 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.176 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.177 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.178 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.179 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.180 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.181 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.182 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.183 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.185 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.187 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.188 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.194 - warn: roborock.0 (22375) State "roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
              2023-01-26 23:40:08.199 - debug: roborock.0 (22375) dps debug: {"id":15,"result":[{"begin":1674725026,"end":1674725079,"duration":41,"area":920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0}]}
              2023-01-26 23:40:08.204 - debug: roborock.0 (22375) dps debug: {"id":27,"result":[{"begin":1672396799,"end":1672399678,"duration":2879,"area":46062500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.211 - debug: roborock.0 (22375) dps debug: {"id":23,"result":[{"begin":1673260802,"end":1673263712,"duration":2910,"area":45922500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.214 - debug: roborock.0 (22375) dps debug: {"id":17,"result":[{"begin":1674470400,"end":1674473247,"duration":2847,"area":45627500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.217 - debug: roborock.0 (22375) dps debug: {"id":18,"result":[{"begin":1674211201,"end":1674214020,"duration":2819,"area":45745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.220 - debug: roborock.0 (22375) dps debug: {"id":24,"result":[{"begin":1673001600,"end":1673001754,"duration":147,"area":3327500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0}]}
              2023-01-26 23:40:08.223 - debug: roborock.0 (22375) dps debug: {"id":19,"result":[{"begin":1674038400,"end":1674041195,"duration":2795,"area":45662500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.226 - debug: roborock.0 (22375) dps debug: {"id":25,"result":[{"begin":1672828801,"end":1672831852,"duration":3051,"area":45580000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.228 - debug: roborock.0 (22375) dps debug: {"id":28,"result":[{"begin":1672224000,"end":1672226907,"duration":2907,"area":45725000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.230 - debug: roborock.0 (22375) dps debug: {"id":20,"result":[{"begin":1673865601,"end":1673868654,"duration":3053,"area":45852500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.232 - debug: roborock.0 (22375) dps debug: {"id":22,"result":[{"begin":1673433600,"end":1673436525,"duration":2925,"area":45552500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.237 - debug: roborock.0 (22375) dps debug: {"id":30,"result":[{"begin":1671791332,"end":1671794384,"duration":3051,"area":46140000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.239 - debug: roborock.0 (22375) dps debug: {"id":26,"result":[{"begin":1672656000,"end":1672658889,"duration":2888,"area":45622500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.241 - debug: roborock.0 (22375) dps debug: {"id":21,"result":[{"begin":1673606401,"end":1673609286,"duration":2885,"area":45722500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.242 - debug: roborock.0 (22375) dps debug: {"id":32,"result":[{"begin":1671446400,"end":1671449983,"duration":3583,"area":45985000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.244 - debug: roborock.0 (22375) dps debug: {"id":29,"result":[{"begin":1672051200,"end":1672054195,"duration":2995,"area":46020000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.246 - debug: roborock.0 (22375) dps debug: {"id":31,"result":[{"begin":1671619200,"end":1671622099,"duration":2898,"area":45690000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
              2023-01-26 23:40:08.531 - silly: roborock.0 (22375) States user redis pmessage io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.*/io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.load_multi_map:{"val":0,"ack":true,"ts":1674772808526,"q":32,"from":"system.adapter.roborock.0","user":"system.user.admin","lc":1674772808526}
              2023-01-26 23:40:08.539 - debug: roborock.0 (22375) onStateChange: load_multi_map with value: 0
              2023-01-26 23:40:08.541 - error: roborock.0 (22375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-01-26 23:40:08.541 - error: roborock.0 (22375) unhandled promise rejection: Cannot read properties of undefined (reading 'command')
              2023-01-26 23:40:08.544 - error: roborock.0 (22375) TypeError: Cannot read properties of undefined (reading 'command')
              at Roborock.onStateChange (/opt/iobroker/node_modules/iobroker.roborock/main.js:274:25)
              at Roborock.emit (node:events:513:28)
              at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5385:53)
              at processImmediate (node:internal/timers:466:21)
              2023-01-26 23:40:08.545 - error: roborock.0 (22375) Cannot read properties of undefined (reading 'command')
              2023-01-26 23:40:08.553 - info: roborock.0 (22375) terminating
              2023-01-26 23:40:08.554 - warn: roborock.0 (22375) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-01-26 23:40:08.729 - debug: roborock.0 (22375) deviceStatus 120 set with value: 0
              2023-01-26 23:40:08.739 - debug: roborock.0 (22375) deviceStatus 121 set with value: 8
              2023-01-26 23:40:08.750 - debug: roborock.0 (22375) deviceStatus 122 set with value: 100
              2023-01-26 23:40:08.760 - debug: roborock.0 (22375) deviceStatus 123 set with value: 102
              2023-01-26 23:40:08.777 - debug: roborock.0 (22375) deviceStatus 124 set with value: 203
              2023-01-26 23:40:08.789 - debug: roborock.0 (22375) deviceStatus 125 set with value: 21
              2023-01-26 23:40:08.816 - debug: roborock.0 (22375) deviceStatus 126 set with value: 100
              2023-01-26 23:40:08.825 - debug: roborock.0 (22375) deviceStatus 127 set with value: 43
              2023-01-26 23:40:09.286 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                DonToben @wendy2702 last edited by
                @wendy2702 said in Roborock Adapter tester gesucht:
                Woran kann man erkennen das der Typ erkannt wurde ?
                EDIT: Vielleicht kannst du die Versionsnummern mal hochzählen damit man sehen kann ob die richtige Version installiert wurde und läuft.
                Ja eine Versionierung wäre wirklich nicht schlecht. Aktuell verliere ich auch bisschen den Überblick.
                  DonToben last edited by DonToben
                  @copystring
                  Hier ein aktueller Log mit der aktuellsten Version.
                  Die Warnmeldungen sind nicht wirklich weniger geworden.
                  2023-01-27 07:15:30.980 - info: roborock.0 (1849) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v14.18.1, js-controller: 4.0.24
                  2023-01-27 07:15:31.179 - debug: roborock.0 (1849) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer B","8937854":"Kinderzimmer L","8937856":"Schlafzimmer","10093883":"Bad"}
                  2023-01-27 07:15:31.259 - info: roborock.0 (1849) MQTT initialized
                  2023-01-27 07:15:31.264 - debug: roborock.0 (1849) Robot key: roborock.vacuum.a62
                  2023-01-27 07:15:31.686 - debug: roborock.0 (1849) Latest data requested
                  2023-01-27 07:15:31.689 - debug: roborock.0 (1849) getParameter: get_mop_mode
                  2023-01-27 07:15:31.694 - debug: roborock.0 (1849) getParameter: get_water_box_custom_mode
                  2023-01-27 07:15:31.696 - debug: roborock.0 (1849) getParameter: get_status
                  2023-01-27 07:15:31.697 - debug: roborock.0 (1849) getParameter: get_consumable
                  2023-01-27 07:15:31.698 - debug: roborock.0 (1849) getParameter: get_network_info
                  2023-01-27 07:15:31.701 - debug: roborock.0 (1849) getParameter: get_carpet_mode
                  2023-01-27 07:15:31.702 - debug: roborock.0 (1849) getParameter: get_carpet_cleaning_mode
                  2023-01-27 07:15:31.703 - debug: roborock.0 (1849) getParameter: get_fw_features
                  2023-01-27 07:15:31.703 - debug: roborock.0 (1849) Firmware features request
                  2023-01-27 07:15:31.704 - debug: roborock.0 (1849) getParameter: get_multi_maps_list
                  2023-01-27 07:15:31.705 - debug: roborock.0 (1849) getParameter: get_room_mapping
                  2023-01-27 07:15:31.706 - debug: roborock.0 (1849) get_room_mapping
                  2023-01-27 07:15:31.785 - debug: roborock.0 (1849) dps debug: {"id":3,"result":{"water_box_mode":202}}
                  2023-01-27 07:15:31.788 - debug: roborock.0 (1849) dps debug: {"id":5,"result":[{"main_brush_work_time":314911,"side_brush_work_time":314911,"filter_work_time":314911,"filter_element_work_time":0,"sensor_dirty_time":93051,"strainer_work_times":112,"dust_collection_work_times":172,"cleaning_brush_work_times":266}]}
                  2023-01-27 07:15:31.791 - debug: roborock.0 (1849) dps debug: {"id":1,"result":[300]}
                  2023-01-27 07:15:31.793 - debug: roborock.0 (1849) dps debug: {"id":9,"result":"unknown_method"}
                  2023-01-27 07:15:31.794 - debug: roborock.0 (1849) Unknown parameter: "unknown_method"
                  2023-01-27 07:15:31.800 - debug: roborock.0 (1849) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":498,"state":8,"battery":100,"clean_time":19,"clean_area":155000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}]}
                  2023-01-27 07:15:31.814 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.815 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.817 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.818 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.819 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.820 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.821 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.822 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.823 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.823 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.824 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.825 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.826 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.827 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.back_type" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.828 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_phase" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.829 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_ready" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.830 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.831 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.831 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.832 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.833 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.834 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.835 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.836 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.837 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.838 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.839 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.839 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.840 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.841 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.switch_map_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.842 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.852 - debug: roborock.0 (1849) dps debug: {"id":6,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"cc:ce:1e:2b:39:8c","rssi":-75}}
                  2023-01-27 07:15:31.866 - debug: roborock.0 (1849) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":499,"state":8,"battery":100,"clean_time":19,"clean_area":155000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}]}
                  2023-01-27 07:15:31.870 - debug: roborock.0 (1849) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                  2023-01-27 07:15:31.872 - debug: roborock.0 (1849) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                  2023-01-27 07:15:31.875 - debug: roborock.0 (1849) dps debug: {"id":7,"result":{"clean_time":314911,"clean_area":5200022500,"clean_count":256,"dust_collection_count":172,"records":[1674754825,1674742452,1674729983,1674669094,1674664205,1674664145,1674663820,1674663752,1674663532,1674663218,1674662179,1674662106,1674661947,1674661250,1674587117,1674582931,1674582605,1674577286,1674558275,1674554746]}}
                  2023-01-27 07:15:31.905 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.charge_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.912 - debug: roborock.0 (1849) dps debug: {"id":12,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
                  2023-01-27 07:15:31.913 - debug: roborock.0 (1849) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
                  2023-01-27 07:15:31.915 - debug: roborock.0 (1849) dps debug: {"id":11,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1674743903,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
                  2023-01-27 07:15:31.924 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.927 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.929 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.929 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.930 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.931 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.932 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.945 - debug: roborock.0 (1849) dps debug: {"id":23,"result":[{"begin":1674662179,"end":1674662208,"duration":29,"area":410000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.950 - debug: roborock.0 (1849) dps debug: {"id":18,"result":[{"begin":1674664145,"end":1674664166,"duration":21,"area":452500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.953 - debug: roborock.0 (1849) dps debug: {"id":14,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:31.956 - debug: roborock.0 (1849) dps debug: {"id":13,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.958 - debug: roborock.0 (1849) dps debug: {"id":16,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
                  2023-01-27 07:15:31.963 - debug: roborock.0 (1849) dps debug: {"id":20,"result":[{"begin":1674663752,"end":1674663777,"duration":25,"area":662500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.966 - debug: roborock.0 (1849) dps debug: {"id":17,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.968 - debug: roborock.0 (1849) dps debug: {"id":25,"result":[{"begin":1674661947,"end":1674661968,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.971 - debug: roborock.0 (1849) dps debug: {"id":24,"result":[{"begin":1674662106,"end":1674662127,"duration":21,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.973 - debug: roborock.0 (1849) dps debug: {"id":19,"result":[{"begin":1674663820,"end":1674663840,"duration":20,"area":467500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.976 - debug: roborock.0 (1849) dps debug: {"id":15,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:31.978 - debug: roborock.0 (1849) dps debug: {"id":21,"result":[{"begin":1674663532,"end":1674663569,"duration":37,"area":885000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:31.980 - debug: roborock.0 (1849) dps debug: {"id":22,"result":[{"begin":1674663218,"end":1674663240,"duration":22,"area":420000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:31.981 - debug: roborock.0 (1849) dps debug: {"id":27,"result":[{"begin":1674587117,"end":1674587629,"duration":512,"area":5695000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:31.987 - debug: roborock.0 (1849) dps debug: {"id":30,"result":[{"begin":1674577286,"end":1674577646,"duration":221,"area":3375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                  2023-01-27 07:15:31.989 - debug: roborock.0 (1849) dps debug: {"id":28,"result":[{"begin":1674582931,"end":1674584850,"duration":1919,"area":40270000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:31.992 - debug: roborock.0 (1849) dps debug: {"id":26,"result":[{"begin":1674661250,"end":1674661308,"duration":14,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0,"wash_count":1}]}
                  2023-01-27 07:15:31.994 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.995 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.996 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.996 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.997 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.back_type" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.998 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_phase" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:31.999 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_ready" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.000 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.001 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.002 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.003 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.004 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.004 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.005 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.006 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.007 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.008 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.008 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.009 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.010 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.011 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.switch_map_mode" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.011 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.012 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.charge_status" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.097 - debug: roborock.0 (1849) dps debug: {"id":32,"result":[{"begin":1674554746,"end":1674556140,"duration":1394,"area":20745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":1}]}
                  2023-01-27 07:15:32.100 - debug: roborock.0 (1849) dps debug: {"id":31,"result":[{"begin":1674558275,"end":1674559264,"duration":989,"area":11415000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
                  2023-01-27 07:15:32.102 - debug: roborock.0 (1849) dps debug: {"id":29,"result":[{"begin":1674582605,"end":1674582695,"duration":90,"area":3110000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1,"wash_count":0}]}
                  2023-01-27 07:15:32.116 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.10.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.118 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.5.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.120 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.1.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.123 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.0.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.125 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.3.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.127 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.7.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.129 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.4.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.130 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.12.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.132 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.11.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.134 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.6.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.136 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.2.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.138 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.8.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.140 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.9.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.143 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.14.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.145 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.17.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.148 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.15.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.150 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.13.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.215 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.19.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.217 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.18.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.228 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.16.wash_count" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.472 - debug: roborock.0 (1849) deviceStatus 120 set with value: 0
                  2023-01-27 07:15:32.476 - debug: roborock.0 (1849) deviceStatus 121 set with value: 8
                  2023-01-27 07:15:32.481 - debug: roborock.0 (1849) deviceStatus 122 set with value: 100
                  2023-01-27 07:15:32.485 - debug: roborock.0 (1849) deviceStatus 123 set with value: 102
                  2023-01-27 07:15:32.489 - debug: roborock.0 (1849) deviceStatus 124 set with value: 202
                  2023-01-27 07:15:32.494 - debug: roborock.0 (1849) deviceStatus 125 set with value: 71
                  2023-01-27 07:15:32.498 - debug: roborock.0 (1849) deviceStatus 126 set with value: 57
                  2023-01-27 07:15:32.502 - debug: roborock.0 (1849) deviceStatus 127 set with value: 42
                  2023-01-27 07:15:32.507 - debug: roborock.0 (1849) deviceStatus 128 set with value: 0
                  2023-01-27 07:15:32.509 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.128" has no existing object, this might lead to an error in future versions
                  2023-01-27 07:15:32.558 - debug: roborock.0 (1849) deviceStatus 133 set with value: 1
                  2023-01-27 07:15:32.560 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.133" has no existing object, this might lead to an error in future versions
                  M-A Hueb D 2 Replies Last reply Reply Quote 0
                  • M-A Hueb
                    M-A Hueb @DonToben last edited by M-A Hueb
                    @copystring Habe gerade die aktuellste Version aus dem Tree installiert. sieht gut. Meldungen decken sich mit dennen von @DonToben wenn gewünscht poste ich gerne auch das Log.
                    Ich habe 2 Etagen, EG und OG. Ausgelesen wird nur das EG. Liegt es daran das er gerade dort aktiv ist?
                      DonToben @M-A Hueb last edited by
                      @m-a-hueb said in Roborock Adapter tester gesucht:
                      Sende mal das Command load_multi_map mit dem Wert für das OG.
                      Aber wahrscheinlich sollte er gerade nicht reinigen ...
                        DonToben @DonToben last edited by
                        @dontoben said in Roborock Adapter tester gesucht:
                        @copystring
                        127 = Filter
                        126 = Seitenbürste
                        125 = Hauptbürste
                        muss noch zugeordnet werden.
                        Bei 120 bis 124 habe ich noch keine Ahnung, was das sein könnte.
                        • wendy2702
                          @copystring sagte in Roborock Adapter tester gesucht:
                          Habe auch gerade mal komplett gelöscht und neu installiert. So sieht das log aus:
                          2023-01-27 09:11:45.094  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1075557
                          2023-01-27 09:11:46.186  - debug: roborock.0 (1075557) Redis Objects: Use Redis connection: 0.0.0.0:9001
                          2023-01-27 09:11:46.247  - debug: roborock.0 (1075557) Objects client ready ... initialize now
                          2023-01-27 09:11:46.252  - debug: roborock.0 (1075557) Objects create System PubSub Client
                          2023-01-27 09:11:46.253  - debug: roborock.0 (1075557) Objects create User PubSub Client
                          2023-01-27 09:11:46.331  - debug: roborock.0 (1075557) Objects client initialize lua scripts
                          2023-01-27 09:11:46.334  - debug: roborock.0 (1075557) Objects connected to redis: 0.0.0.0:9001
                          2023-01-27 09:11:46.369  - debug: roborock.0 (1075557) Redis States: Use Redis connection: 0.0.0.0:9000
                          2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create System PubSub Client
                          2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create User PubSub Client
                          2023-01-27 09:11:46.493  - debug: roborock.0 (1075557) States connected to redis: 0.0.0.0:9000
                          2023-01-27 09:11:46.769  - info: roborock.0 (1075557) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                          2023-01-27 09:11:46.912  - debug: roborock.0 (1075557) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
                          2023-01-27 09:11:46.940  - info: roborock.0 (1075557) MQTT initialized
                          2023-01-27 09:11:46.953  - debug: roborock.0 (1075557) Robot key: roborock.vacuum.a15
                          2023-01-27 09:11:47.081  - debug: roborock.0 (1075557) Latest data requested
                          2023-01-27 09:11:47.083  - debug: roborock.0 (1075557) getParameter: get_mop_mode
                          2023-01-27 09:11:47.085  - debug: roborock.0 (1075557) getParameter: get_water_box_custom_mode
                          2023-01-27 09:11:47.086  - debug: roborock.0 (1075557) getParameter: get_status
                          2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_consumable
                          2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_network_info
                          2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_mode
                          2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_cleaning_mode
                          2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_fw_features
                          2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) Firmware features request
                          2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_multi_maps_list
                          2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) getParameter: get_room_mapping
                          2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) get_room_mapping
                          2023-01-27 09:11:47.146  - debug: roborock.0 (1075557) dps debug: {"id":3,"result":[203]}
                          2023-01-27 09:11:47.147  - debug: roborock.0 (1075557) dps debug: {"id":5,"result":[{"main_brush_work_time":581958,"side_brush_work_time":581958,"filter_work_time":36866,"filter_element_work_time":0,"sensor_dirty_time":50176,"dust_collection_work_times":26}]}
                          2023-01-27 09:11:47.207  - debug: roborock.0 (1075557) dps debug: {"id":6,"result":{"ssid":"WXXXXXXXSOHO","ip":"192.168.178.73","mac":"b0XXX:72","bssid":"76:83:c2:9a:11:5d","rssi":-64}}
                          2023-01-27 09:11:47.214  - debug: roborock.0 (1075557) dps debug: {"id":1,"result":[302]}
                          2023-01-27 09:11:47.215  - debug: roborock.0 (1075557) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                          2023-01-27 09:11:47.216  - debug: roborock.0 (1075557) dps debug: {"id":7,"result":{"clean_time":581938,"clean_area":8566392500,"clean_count":355,"dust_collection_count":292,"records":[1674660336,1674660313,1674577216,1674310611,1673963198,1673962557,1673625667,1673624409,1673450020,1673279186,1673177137,1673177094,1672931751,1672839102,1672839052,1672676949,1672483666,1671550852,1671550717,1671292694]}}
                          2023-01-27 09:11:47.223  - debug: roborock.0 (1075557) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1311,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                          2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) dps debug: {"id":12,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
                          2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
                          2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674662405,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
                          2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":9,"result":"unknown_method"}
                          2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) Unknown parameter: "unknown_method"
                          2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                          2023-01-27 09:11:47.230  - debug: roborock.0 (1075557) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1312,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                          2023-01-27 09:11:47.233  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.250  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.262  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.267  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.268  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
                          2023-01-27 09:11:47.269  - debug: roborock.0 (1075557) dps debug: {"id":15,"result":[{"begin":1674577216,"end":1674583431,"duration":3658,"area":39990000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.271  - debug: roborock.0 (1075557) dps debug: {"id":13,"result":[{"begin":1674660336,"end":1674662311,"duration":1975,"area":30992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.272  - debug: roborock.0 (1075557) dps debug: {"id":14,"result":[{"begin":1674660313,"end":1674660315,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
                          2023-01-27 09:11:47.273  - debug: roborock.0 (1075557) dps debug: {"id":18,"result":[{"begin":1673962557,"end":1673962598,"duration":15,"area":0,"error":0,"complete":0,"start_type":1,"clean_type":1,"finish_reason":21,"dust_collection_status":0}]}
                          2023-01-27 09:11:47.274  - debug: roborock.0 (1075557) dps debug: {"id":17,"result":[{"begin":1673963198,"end":1673970437,"duration":2672,"area":37172500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.293  - debug: roborock.0 (1075557) dps debug: {"id":19,"result":[{"begin":1673625667,"end":1673628366,"duration":2699,"area":39452500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":16,"result":[{"begin":1674310611,"end":1674311055,"duration":444,"area":6152500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":22,"result":[{"begin":1673279186,"end":1673280386,"duration":1200,"area":18042500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":23,"result":[{"begin":1673177137,"end":1673179722,"duration":2585,"area":36967500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":26,"result":[{"begin":1672839102,"end":1672847459,"duration":2861,"area":39335000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":28,"result":[{"begin":1672676949,"end":1672678212,"duration":1263,"area":17982500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":20,"result":[{"begin":1673624409,"end":1673624479,"duration":70,"area":1490000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":29,"result":[{"begin":1672483666,"end":1672484896,"duration":1230,"area":17945000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":21,"result":[{"begin":1673450020,"end":1673452606,"duration":2586,"area":39457500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":30,"result":[{"begin":1671550852,"end":1671553922,"duration":3062,"area":39902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.298  - debug: roborock.0 (1075557) dps debug: {"id":25,"result":[{"begin":1672931751,"end":1672934471,"duration":2720,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.301  - debug: roborock.0 (1075557) dps debug: {"id":27,"result":[{"begin":1672839052,"end":1672839065,"duration":13,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
                          2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":32,"result":[{"begin":1671292694,"end":1671294598,"duration":1904,"area":27470000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":31,"result":[{"begin":1671550717,"end":1671550797,"duration":80,"area":1050000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
                          2023-01-27 09:11:47.303  - debug: roborock.0 (1075557) dps debug: {"id":24,"result":[{"begin":1673177094,"end":1673177102,"duration":8,"area":0,"error":0,"complete":0,"start_type":4,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
                          2023-01-27 09:11:48.417  - debug: roborock.0 (1075557) deviceStatus 120 set with value: 0
                          2023-01-27 09:11:48.423  - debug: roborock.0 (1075557) deviceStatus 121 set with value: 8
                          2023-01-27 09:11:48.426  - debug: roborock.0 (1075557) deviceStatus 122 set with value: 100
                          2023-01-27 09:11:48.430  - debug: roborock.0 (1075557) deviceStatus 123 set with value: 104
                          2023-01-27 09:11:48.433  - debug: roborock.0 (1075557) deviceStatus 124 set with value: 203
                          2023-01-27 09:11:48.437  - debug: roborock.0 (1075557) deviceStatus 125 set with value: 47
                          2023-01-27 09:11:48.440  - debug: roborock.0 (1075557) deviceStatus 126 set with value: 20
                          2023-01-27 09:11:48.446  - debug: roborock.0 (1075557) deviceStatus 127 set with value: 94
                          So die Objekte:
                          Gibt es in der API eine Übersicht was die "8" bei Device State bedeutet? Bei Xiaomi war es "Lädt"
                          • copystring
                            copystring last edited by
                            Danke für die vielen logs. Ich habe schon ein paar gute Ideen und werde die sehr wahrscheinlich am Wochenende umsetzen können.
                            Black Thunder 1 Reply Last reply Reply Quote 0
                            • Black Thunder
                              Black Thunder Developer @copystring last edited by
                              @copystring Weiß zwar nicht, ob du es vielleicht schon selbst rausgefunden hast, aber ich konnte mein Absturzproblem beim Absetzen von Kommandos lösen. Und zwar funktioniert die Art, wie du das Extrahieren der Device-ID aus dem State implementiert hast, in meinem Fall nicht sauber. Meine Device-ID ist 21 Stellen lang, dein Code geht aber fix von 22 Stellen aus. Deswegen kommt es zu der Exception beim Zugriff auf das "vacuums"-Array.
                              Hab dir gerade mal auf GitHub einen PR als Vorschlag geschickt, wie man das lösen könnte, ohne eine fixe Länge zu erwarten. Kannst dir ja mal bei Gelegenheit angucken. 😉
                              • O
                                oxident @Black Thunder last edited by
                                @black-thunder @copystring Ich habe mal den Branch nach dem Merge des PR getestet und leider mit meinen S7 Max ProV keinen Erfolg gehabt:
                                host.iobroker
                                2023-01-28 12:39:50.439	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                roborock.0
                                2023-01-28 12:39:50.000	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.924	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.923	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.923	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.921	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.920	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.919	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.918	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.917	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.916	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.915	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.886	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.884	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.881	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.878	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.877	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.875	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.872	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.869	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.861	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.847	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
                                roborock.0
                                2023-01-28 12:39:49.846	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                roborock.0
                                2023-01-28 12:39:49.844	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
                                roborock.0
                                2023-01-28 12:39:49.819	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
                                roborock.0
                                2023-01-28 12:39:49.817	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
                                roborock.0
                                2023-01-28 12:39:49.816	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
                                roborock.0
                                2023-01-28 12:39:49.807	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-61}}
                                roborock.0
                                2023-01-28 12:39:49.804	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
                                roborock.0
                                2023-01-28 12:39:49.794	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
                                roborock.0
                                2023-01-28 12:39:49.791	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
                                roborock.0
                                2023-01-28 12:39:49.789	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                                roborock.0
                                2023-01-28 12:39:49.774	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
                                roborock.0
                                2023-01-28 12:39:49.765	error	Cannot read properties of undefined (reading 'divider')
                                roborock.0
                                2023-01-28 12:39:49.764	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                roborock.0
                                2023-01-28 12:39:49.764	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
                                roborock.0
                                2023-01-28 12:39:49.763	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                roborock.0
                                2023-01-28 12:39:49.759	debug	get_status: {"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                                roborock.0
                                2023-01-28 12:39:49.757	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:49.691	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                roborock.0
                                2023-01-28 12:39:49.690	info	terminating
                                roborock.0
                                2023-01-28 12:39:49.683	error	Cannot read properties of undefined (reading 'model')
                                roborock.0
                                2023-01-28 12:39:49.682	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
                                roborock.0
                                2023-01-28 12:39:49.681	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
                                roborock.0
                                2023-01-28 12:39:49.680	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                roborock.0
                                2023-01-28 12:39:49.676	debug	get_room_mapping
                                roborock.0
                                2023-01-28 12:39:49.675	debug	getParameter: get_room_mapping
                                roborock.0
                                2023-01-28 12:39:49.673	debug	getParameter: get_multi_maps_list
                                roborock.0
                                2023-01-28 12:39:49.672	debug	Firmware features request
                                roborock.0
                                2023-01-28 12:39:49.672	debug	getParameter: get_fw_features
                                roborock.0
                                2023-01-28 12:39:49.670	debug	getParameter: get_carpet_clean_mode
                                roborock.0
                                2023-01-28 12:39:49.668	debug	getParameter: get_carpet_mode
                                roborock.0
                                2023-01-28 12:39:49.666	debug	getParameter: get_network_info
                                roborock.0
                                2023-01-28 12:39:49.664	debug	getParameter: get_consumable
                                roborock.0
                                2023-01-28 12:39:49.663	debug	getParameter: get_water_box_custom_mode
                                roborock.0
                                2023-01-28 12:39:49.657	debug	getParameter: get_status
                                roborock.0
                                2023-01-28 12:39:49.655	debug	Latest data requested
                                roborock.0
                                2023-01-28 12:39:49.227	debug	Robot key: roborock.vacuum.a27
                                roborock.0
                                2023-01-28 12:39:49.222	info	MQTT initialized
                                roborock.0
                                2023-01-28 12:39:49.135	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                2023-01-28 12:39:48.829	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                roborock.0
                                2023-01-28 12:39:48.544	debug	States connected to redis: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:48.532	debug	States create User PubSub Client
                                roborock.0
                                2023-01-28 12:39:48.530	debug	States create System PubSub Client
                                roborock.0
                                2023-01-28 12:39:48.514	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:48.481	debug	Objects connected to redis: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:48.474	debug	Objects client initialize lua scripts
                                roborock.0
                                2023-01-28 12:39:48.034	debug	Objects create User PubSub Client
                                roborock.0
                                2023-01-28 12:39:48.033	debug	Objects create System PubSub Client
                                roborock.0
                                2023-01-28 12:39:48.031	debug	Objects client ready ... initialize now
                                roborock.0
                                2023-01-28 12:39:47.999	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                                host.iobroker
                                2023-01-28 12:39:40.788	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                roborock.0
                                2023-01-28 12:39:40.407	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.406	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.404	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.402	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.346	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.343	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.342	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.339	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.336	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.335	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.333	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.330	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.329	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.325	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.324	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.322	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.320	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.317	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.302	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.298	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.263	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
                                roborock.0
                                2023-01-28 12:39:40.262	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
                                roborock.0
                                2023-01-28 12:39:40.255	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
                                roborock.0
                                2023-01-28 12:39:40.253	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
                                roborock.0
                                2023-01-28 12:39:40.252	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
                                roborock.0
                                2023-01-28 12:39:40.241	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
                                roborock.0
                                2023-01-28 12:39:40.239	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-62}}
                                roborock.0
                                2023-01-28 12:39:40.237	error	Cannot read properties of undefined (reading 'divider')
                                roborock.0
                                2023-01-28 12:39:40.236	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                roborock.0
                                2023-01-28 12:39:40.236	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
                                roborock.0
                                2023-01-28 12:39:40.235	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                roborock.0
                                2023-01-28 12:39:40.232	debug	get_status: {"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                                roborock.0
                                2023-01-28 12:39:40.231	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                roborock.0
                                2023-01-28 12:39:40.229	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                                roborock.0
                                2023-01-28 12:39:40.227	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
                                roborock.0
                                2023-01-28 12:39:40.225	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                roborock.0
                                2023-01-28 12:39:40.221	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
                                roborock.0
                                2023-01-28 12:39:40.199	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
                                roborock.0
                                2023-01-28 12:39:40.096	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                roborock.0
                                2023-01-28 12:39:40.095	info	terminating
                                roborock.0
                                2023-01-28 12:39:40.091	error	Cannot read properties of undefined (reading 'model')
                                roborock.0
                                2023-01-28 12:39:40.091	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
                                roborock.0
                                2023-01-28 12:39:40.091	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
                                roborock.0
                                2023-01-28 12:39:40.090	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                roborock.0
                                2023-01-28 12:39:40.088	debug	get_room_mapping
                                roborock.0
                                2023-01-28 12:39:40.088	debug	getParameter: get_room_mapping
                                roborock.0
                                2023-01-28 12:39:40.087	debug	getParameter: get_multi_maps_list
                                roborock.0
                                2023-01-28 12:39:40.087	debug	Firmware features request
                                roborock.0
                                2023-01-28 12:39:40.086	debug	getParameter: get_fw_features
                                roborock.0
                                2023-01-28 12:39:40.086	debug	getParameter: get_carpet_clean_mode
                                roborock.0
                                2023-01-28 12:39:40.085	debug	getParameter: get_carpet_mode
                                roborock.0
                                2023-01-28 12:39:40.084	debug	getParameter: get_network_info
                                roborock.0
                                2023-01-28 12:39:40.083	debug	getParameter: get_consumable
                                roborock.0
                                2023-01-28 12:39:40.082	debug	getParameter: get_water_box_custom_mode
                                roborock.0
                                2023-01-28 12:39:40.079	debug	getParameter: get_status
                                roborock.0
                                2023-01-28 12:39:40.078	debug	Latest data requested
                                roborock.0
                                2023-01-28 12:39:39.756	debug	Robot key: roborock.vacuum.a27
                                roborock.0
                                2023-01-28 12:39:39.752	info	MQTT initialized
                                roborock.0
                                2023-01-28 12:39:39.655	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
                                roborock.0
                                2023-01-28 12:39:39.390	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                roborock.0
                                2023-01-28 12:39:39.036	debug	States connected to redis: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:39.025	debug	States create User PubSub Client
                                roborock.0
                                2023-01-28 12:39:39.023	debug	States create System PubSub Client
                                roborock.0
                                2023-01-28 12:39:39.011	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:38.983	debug	Objects connected to redis: 127.0.0.1:6379
                                roborock.0
                                2023-01-28 12:39:38.976	debug	Objects client initialize lua scripts
                                roborock.0
                                2023-01-28 12:39:38.572	debug	Objects create User PubSub Client
                                roborock.0
                                2023-01-28 12:39:38.571	debug	Objects create System PubSub Client
                                roborock.0
                                2023-01-28 12:39:38.570	debug	Objects client ready ... initialize now
                                • copystring
                                  copystring last edited by copystring
                                  Ich bedanke mich für das fleißige Testen! Dadurch konnte ich einen ersten alpha release erstellen.
                                  https://github.com/copystring/ioBroker.roborock hat jetzt einen alpha (v0.0.2-alpha.0) release. Bitte testen und bei Fehlern mit entsprechenden Log ein Issue auf Github öffnen. Die ganzen Protokolle sind mir hier zu viel geworden ich und weiß gar nicht mehr welche tatsächlich noch relevant sind.
                                  Es kann dadurch vorkommen, dass ihr den gleiche Fehler (@oxident) nochmal posten müsst aber nur dadurch kann ich die Fehler sauber im Blick behalten.
                                  wendy2702 1 Reply Last reply Reply Quote 1
                                  • wendy2702
                                    wendy2702 @copystring last edited by
                                    Danke für deine Arbeit!
                                    Installiert und Issue angelegt.
                                    https://github.com/copystring/ioBroker.roborock/issues/14
                                    wendy2702 created this issue in copystring/ioBroker.roborock
                                    closed Alpha 0.0.2 Some states are not showing data S7+ #14
                                      Aktuelle 0.0.5 Alpha funktioniert bei mir überhaupt nicht. Adapter startet ständig neu.
                                      Wie kommt man auf einen älteren Stand? Mir wird in iobroker keine andere Version angezeigt ...
                                      • wendy2702
                                        wendy2702 @DonToben last edited by
                                        @dontoben sagte in Roborock Adapter tester gesucht:
                                        Ist 0.0.5 ein Tippfehler?
                                        Vielleicht macht es Sinn wenn du @copystring das Logfile mit dem Fehler in Github zukommen lässt damit er sich das anschauen kann. Sonst wird der Fehler ja nicht behoben.
                                          DonToben @wendy2702 last edited by
                                          @wendy2702
                                          nein ist kein Tippfehler. Ich bin gerade unterwegs. Evtl. könnte das kurz jemand anderes testen. Danke
                                          wendy2702 2 Replies Last reply Reply Quote 0
                                          • wendy2702
                                            @dontoben Gar nicht mitbekommen das wir schon bei 0.0.5 sind.
                                            Mal testen
                                            766
                                            242400
