    3. Off Topic
    4. InfluxDB
    5. [Gelöst] InfluxDB Upgrade error
    • Latzi
      Latzi @Guest last edited by
      @dp20eic
      irgendwie funktioniert´s bei mir nicht, mit der Fehlermeldung beim sudo apt update kann ich nichts anfangen.
      Indfluxdb2 läuft in einem Proxmox LXC
      latzi@influxDB:~$ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      latzi@influxDB:~$ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
      pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
            9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
      uid                      InfluxData Package Signing Key <support@influxdata.com>
      latzi@influxDB:~$ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
      latzi@influxDB:~$ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      latzi@influxDB:~$ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
      latzi@influxDB:~$ sudo apt update
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
      Err:5 https://repos.influxdata.com/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Fetched 7022 B in 0s (15.8 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      latzi@influxDB:~$
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Latzi last edited by
        @latzi sagte in [Gelöst] InfluxDB Upgrade error:
        Der öffentliche Schlüssel D8FF8E1F7DF8B07E wurde nicht richtig reingeladen bei dir.
        Latzi 1 Reply Last reply Reply Quote 0
        • Latzi
          Latzi @Thomas Braun last edited by
          okay, wie bekomm ich den rein? Ich hab die obigen statements schon mehrmals durchlaufen lassen - ändert leider nichts.
          Hast du einen Tipp für mich?
            Bin im Moment nicht am Rechner.
            • Latzi
              😉 kein Problem - eilt gar nicht - ich bin dir für deine Unterstützung sehr dankbar!
                A Former User @Latzi last edited by
                @latzi
                Moin,
                kenne Deine Installation nicht, bei mir ging es genau so. Ich brauchte nur nichts löschen, da das File /etc/apt/trusted.gpg.d/influxdb.gpg nicht gab.
                Hast Du unten weiter gelesen?
                The above specifies paths to files and configuration from the most recent documentation. Users who use a different file than /etc/apt/sources.list.d/influxdata.list need to update the file to use signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg. Similarly, users who installed the old key in a different location than /etc/apt/trusted.gpg.d/influxdb.gpg need to use that location to remove the old key.
                Meine Source.list sieht so aus
                [dp20eic@influxDB ~]$ ls -la /etc/apt//sources.list.d/
                total 14
                drwxr-xr-x 2 root root   4 Jan 27 11:06 .
                drwxr-xr-x 8 root root  11 Aug  9  2021 ..
                -rw-r--r-- 1 root root 117 Jan 27 09:49 influxdata.list
                -rw-r--r-- 1 root root  59 May  8  2022 non-free.list
                Die dazugehörige trusted.gpg.d
                [dp20eic@influxDB ~]$ ls -la /etc/apt/trusted.gpg.d/
                total 110
                drwxr-xr-x 2 root root   12 Jan 27 09:47 .
                -rw-r--r-- 1 root root 8700 Feb 25  2021 debian-archive-bullseye-automatic.gpg
                -rw-r--r-- 1 root root 8709 Feb 25  2021 debian-archive-bullseye-security-automatic.gpg
                -rw-r--r-- 1 root root 2453 Feb 25  2021 debian-archive-bullseye-stable.gpg
                -rw-r--r-- 1 root root 8132 Feb 25  2021 debian-archive-buster-automatic.gpg
                -rw-r--r-- 1 root root 8141 Feb 25  2021 debian-archive-buster-security-automatic.gpg
                -rw-r--r-- 1 root root 2332 Feb 25  2021 debian-archive-buster-stable.gpg
                -rw-r--r-- 1 root root 7443 Feb 25  2021 debian-archive-stretch-automatic.gpg
                -rw-r--r-- 1 root root 7452 Feb 25  2021 debian-archive-stretch-security-automatic.gpg
                -rw-r--r-- 1 root root 2263 Feb 25  2021 debian-archive-stretch-stable.gpg
                -rw-r--r-- 1 root root 1185 Jan 27 09:48 influxdata-archive_compat.gpg
                Buster und stretch muss ich mal schauen, die kann ich glaube ich entfernen, muss mal bei Debian nachlesen, aktuell stören sie mich aber nicht.
                VG
                Bernd
                • Latzi
                  @dp20eic
                  schaut bei mir so aus:
                  latzi@influxDB:~$ ls -la /etc/apt//sources.list.d/
                  total 16
                  drwxr-xr-x 2 root root 4096 Jan 27 11:10 .
                  drwxr-xr-x 8 root root 4096 Aug 16  2021 ..
                  -rw-r--r-- 1 root root  117 Jan 27 11:01 influxdata.list
                  -rw-r--r-- 1 root root  101 Jan 27 11:10 influxdb.list
                  latzi@influxDB:~$
                  latzi@influxDB:~$ ls -la /etc/apt/trusted.gpg.d/
                  total 80
                  drwxr-xr-x 2 root root 4096 Jan 27 08:25 .
                  -rw-r--r-- 1 root root 1185 Jan 27 11:00 influxdata-archive_compat.gpg
                  latzi@influxDB:~$
                    Moin,
                    Du hast da noch zwei Sorces für Influx, siehe
                    total 16
                    Wenn Du apt-get update ausführst, dann bekommst Du den Fehler
                    Schau mal was in den einzelnen Source-Listen steht
                    [dp20eic@influxDB ~]$ cat /etc/apt/sources.list.d/influxdata.list
                    Und dann verschiebe mal die die nicht mehr benötigte Datei influxdb.list nach /tmp und mach mal ein update
                    # sudo mv /etc/apt/sources.list.d/influxdb.list /tmp
                    # sudo apt-get update
                    VG
                    Bernd
                    Latzi 1 Reply Last reply Reply Quote 3
                    • Latzi
                      @dp20eic
                      das ist der Inhalt der beiden:
                      latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdata.list
                      latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdb.list
                      deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
                      latzi@influxDB:~$
                      wenn ich die influxdb.list verschiebe schaut das apt update so aus:
                      latzi@influxDB:/$ sudo apt update
                      Get:1 http://security.debian.org bullseye-security InRelease [48.4 kB]
                      Fetched 48.4 kB in 0s (116 kB/s)
                      latzi@influxDB:/$
                      Ich würde mal behaupten es passt (zumindest ist der Fehler weg), vielen herzlichen Dank! 👍 👏
                        @latzi
                        Moin,
                        wichtig ist, dass Du die zusammenhänge erkennst, zwischen dem Fehler von oben und der Lösung 😉
                        Und/oder auch erkennst was Du da mit dem Update des Keys gemacht hast.
                        Der Fehler von oben hing nur noch mit der alten Liste zusammen, einem
                        # sudo apt-get upgrade
                        hätte das nicht gestört, glaube ich :), wäre halt nur immer eine Fehlermeldung, die man nicht haben möchte.
                        VG
                        Bernd
                          Rushmed Most Active last edited by Rushmed
                          Was hat denn das zu bedeuten?
                          pi@Smartazamba:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                          pi@Smartazamba:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                          gpg: directory '/home/pi/.gnupg' created
                          gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
                          -bash: pub: command not found
                          -bash: 9D53: command not found
                          -bash: syntax error near unexpected token `newline'
                          EDIT: Hat doch geklappt.
                          Meister Mopper R 2 Replies Last reply Reply Quote 0
                          • Meister Mopper
                            Meister Mopper @Rushmed last edited by
                            Sehr gut Männer,
                            das Problem hat mich den ganzen Tag beschäftigt. Jetzt ist es keines mehr! 👍
                              cbrocker last edited by
                              @dp20eic sagte
                              kennst Du dich mit der InfluxDB Abfragesprache influxQL gut aus und Flux ist häh wasn das, dann bleib lieber bei der 1.8 Version und fang heute schon mal an Dich mit Flux zu beschäftigen
                              Wenn Du gerade erst beginnst, dann kannst Du auch gleich mit V2.x weitermachen, vorher natürlich gut einlesen, wegen Datenmigration 1.8 -> 2.x und wie immer Backups nicht vergessen
                              Hey dp20eic,
                              hast du selber mal InfluxDB Daten von 1.8.x auf 2.6 migriert?
                                A Former User @cbrocker last edited by
                                @cbrocker
                                Moin,
                                war im Urlaub, daher muss ich erst einiges durchlesen.
                                Ja, habe ich. Hier im Forum sollte es aber auch schon einige Beiträge zum Theme geben, schmeiß einfach mal die Suche an.
                                Ich bin eigentlich stur nach der influxDB Anleitung auf deren Seiten vorgegangen.
                                Wenn Du aber spezielle Fragen hast, dann stell sie mal, besser dafür einen eigenen Thread aufmachen oder einen noch offenen finden und sich dranhängen.
                                VG
                                Bernd
                                  Sushibomba last edited by Sushibomba
                                  pi@Pi4ioBroker128GB:~ $ sudo apt-get update
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Get:3 https://repos.influxdata.com/debian stable InRelease [6,883 B]
                                  Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
                                  Get:6 https://repos.influxdata.com/debian stretch InRelease [7,030 B]
                                  Get:7 https://repos.influxdata.com/debian stable/main armhf Packages [2,105 B]
                                  Err:5 https://packages.grafana.com/oss/deb stable InRelease
                                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  Get:8 https://repos.influxdata.com/debian stretch/stable armhf Packages [2,105 B]
                                  Fetched 18.1 kB in 2s (7,716 B/s)
                                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                                  Irgendwie komme ich nicht weiter. Bin nach der ANleitung von InfluxDB vorgegnagen aber bekomme immer noch die Meldung. Kann mir vielleicht jemand helfen und sagen warum?
                                  Gehe ich da einfach nach dieser Anleitung vor? https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                    A Former User @Sushibomba last edited by A Former User
                                    @sushibomba sagte in [Gelöst] InfluxDB Upgrade error:
                                    Moin,
                                    Du hast, zwar die Signaturen für influxDB erneuert, aber noch nicht für Grafana, auch dafür gibt es hier im Forum schon Anleitungen, wie das aktualisiert wird, oder schau
                                    hier
                                    Nach, wie Du das ändern musst.
                                    VG
                                    Bernd
                                      Thomas Braun Most Active @Guest last edited by Thomas Braun
                                      @dp20eic sagte in [Gelöst] InfluxDB Upgrade error:
                                      @Sushibomba
                                      Schau hier z. B. rein:
                                      ist auch falsch, statt stretch sollte da bullseye oder stable stehen. Also anpassen!
                                        Sushibomba @Thomas Braun last edited by
                                        Dankje Thomas aber wie ändere ich das. Sorry bin auf dem Gebiet leider noch nicht so fit 😕
                                          Thomas Braun Most Active @Sushibomba last edited by
                                          @sushibomba
                                          Im Verzeichnis /etc/apt/sources.list.d/
                                          muss es eine influxdb.list (oder ähnlich) geben. Da dann z. B. per Editor
                                          nano ändern.
                                            Moin,
                                            da Du ja schreibst, dass Du noch nicht so Fit bist und ich daraus schließe Du möchtest Fit werden, kann ich Dir das hier wärmstens empfehlen 🙂
                                            Debian-Paketmanagement
                                            Dort 3.3 ff und 8.46.3. Punkt 8 das interessante, Du musst das nur auf Deine Gegebenheit anpassen, da das Buch schon vor bullseye geschrieben wurde.
                                            Dann gibt es noch eine wie ich finde Erleichterung, in meinem Beispiel siehst Du, dass ich zwei Debian Releases buster und bullseye stehen habe, wobei buster durch # kommentiert ist, sodass es bei apt / apt-get nicht benutzt wird
                                            dp20eic@iobroker:~$ sudo apt edit-sources
                                            [sudo] password for dp20eic:
                                            #deb http://ftp.debian.org/debian buster main contrib
                                            #deb http://ftp.debian.org/debian buster-updates main contrib
                                            #deb http://security.debian.org buster/updates main contrib
                                            deb http://ftp.debian.org/debian bullseye main contrib
                                            deb http://ftp.debian.org/debian bullseye-updates main contrib
                                            deb http://security.debian.org bullseye-security main contrib
                                            Wie gesagt, das musst Du an Deine Installation anpassen.
                                            VG
                                            Bernd
                                            Edit:
                                            Gerade gesehen, dass es die Einträge zu influxDB betrifft, da kannst Du nicht mit den von mir vorgeschlagenen Weg arbeiten, dann doch lieber so wie @Thomas-Braun geschrieben hat.
                                            error influx upgrade
                                            13520
