    4. Linux/Debian - Grafana-Repo muss aktualisiert werden
    • N
      Naturfreund @Negalein last edited by
      @negalein 👍 😇
        lessthanmore @Thomas Braun last edited by
        @thomas-braun Danke!
        Gleiches gilt offensichtlich auch für influxdb.
          Thomas Braun Most Active @lessthanmore last edited by
          @lessthanmore sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
          Über solche Meldungen bin ich noch nicht gestolpert. Kann aber auch sein, dass mein influx-Repo schon länger umgestellt ist.
            lessthanmore @Thomas Braun last edited by lessthanmore
            @Thomas-Braun
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
            Hit:4 https://apt.grafana.com stable InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 http://ftp.debian.org/debian bullseye-backports InRelease
            Get:7 http://security.debian.org/debian-security bullseye-security/main Sources [176 kB]
            Get:8 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [214 kB]
            Err:5 https://repos.influxdata.com/debian stable InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
            Fetched 438 kB in 1s (825 kB/s)
            Reading package lists... Done
            Building dependency tree... Done
            All packages are up to date.
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
            W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            Hmm, irgendwas habe ich mir da gerade verbaut (main vs InRelease).
              Thomas Braun Most Active @lessthanmore last edited by Thomas Braun
              @lessthanmore
              echad@chet:~ $ cat /etc/apt/sources.list.d/influxdb.list
              deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
              Ist bei mir schon auf die neue Struktur umgestellt. Der Key ist auch nicht mehr im Schlüsselbund:
              echad@chet:~ $ apt-key list | grep influx | wc -l
              Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
              0
                @thomas-braun Bei mir heißt die influxdata.list.
                Gibt es da eine Anleitung?
                Hätte auch gedacht dass der key influxdb2.key ist.
                Welche influxdb Version hast du oder spielt das keine Rolle hier?
                Wie kann ich das bei mir korrigieren? Kannst du mir da bitte helfen?
                  @lessthanmore
                  Key löschen. Geht wie oben:
                  sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                  Die /etc/apt/sources.list.d/influxdata.list löschen.
                  Aktuelles Setup für influxdb:
                  wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
                  export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                  echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                  L A S 3 Replies Last reply Reply Quote 1
                    @thomas-braun Lieben Dank, läuft wieder bzw. keine Fehler- bzw. Warnmeldungen mehr.
                      A Former User @Naturfreund last edited by
                      Hallo @naturfreund,
                      ein Tipp am Rande, wenn Dir ein Befehl, den Du auf der Kommandozeile eingeben sollst, fremd ist oder dich die Neugierde umtreibt, dann kann Du auf der Kommandozeile ja mal folgendes eintippen 😉
                      # man "befehl"   <- für befehl den einsetzen, den Du nicht kennst
                      z.B.:
                      # man wc
                      NAME
                             wc - print newline, word, and byte counts for each file
                      SYNOPSIS
                             wc [OPTION]... [FILE]...
                             wc [OPTION]... --files0-from=F
                      DESCRIPTION
                             Print newline, word, and byte counts for each FILE, and a total line if more than one FILE is speci‐
                             fied.  A word is a non-zero-length sequence of printable characters delimited by white space.
                             With no FILE, or when FILE is -, read standard input.
                             The options below may be used to select which counts are printed, always  in  the  following  order:
                             newline, word, character, byte, maximum line length.
                             -c, --bytes
                                    print the byte counts
                             -m, --chars
                                    print the character counts
                             -l, --lines
                                    print the newline counts
                             --files0-from=F
                                    read  input  from  the files specified by NUL-terminated names in file F; If F is - then read
                                    names from standard input
                             -L, --max-line-length
                                    print the maximum display width
                             -w, --words
                                    print the word counts
                             --help display this help and exit
                             --version
                                    output version information and exit
                      AUTHOR
                             Written by Paul Rubin and David MacKenzie.
                      REPORTING BUGS
                             GNU coreutils online help: <https://www.gnu.org/software/coreutils/>
                             Report any translation bugs to <https://translationproject.org/team/>
                      So kannst Du für fast jeden Konsolen Befehl eine kurze Beschreibung und eine Liste der Parameter, kompakter geht es mit,
                      # wc --help
                      1 dp20eic@yoga-3 ~ % wc --help
                      Aufruf: wc [OPTION]... [DATEI]...
                        oder: wc [OPTION]... --files0-from=DL
                      Zeilen‐, Wort‐ und Byteanzahl für jede DATEI ausgeben und eine Zeile mit der
                      Gesamtsumme, wenn mehr als eine DATEI angegeben wurde. Ohne DATEI, oder wenn
                      DATEI „-“ ist, wird von der Standardeingabe gelesen. Ein Wort ist eine nicht
                      leere Folge von darstellbaren Zeichen, die durch Leerzeichen begrenzt wird.
                      Ohne DATEI oder wenn DATEI „-“ ist, Standardeingabe lesen.
                      Die unten angeführten Optionen erlauben es, die auszugebenden Zähler
                      auszuwählen, wobei sie immer in dieser Reihenfolge ausgegeben werden:
                      Zeilen, Wörter, Zeichen, Bytes, größte Zeilenlänge.
                        -c, --bytes            Byteanzahl ausgeben
                        -m, --chars            Zeichenanzahl ausgeben
                        -l, --lines            Zeilenanzahl ausgeben
                            --files0-from=D    Eingabe aus den Dateien lesen, die mit NULL
                                               terminiert in der Datei D stehen;
                                               ist D „-“, so wird aus der Standardeingabe gelesen
                        -L, --max-line-length  die Länge der längsten Zeile ausgeben
                        -w, --words            Wortanzahl ausgeben
                            --help        diese Hilfe anzeigen und beenden
                            --version     Versionsinformation anzeigen und beenden
                      Onlinehilfe für GNU coreutils: <https://www.gnu.org/software/coreutils/>
                      Melden Sie Übersetzungsfehler für %s an <translation-team-de@lists.sourceforge.net>
                      Die vollständige Dokumentation ist hier: <https://www.gnu.org/software/coreutils/wc>
                      oder auch lokal mittels „info '(coreutils) wc invocation'“
                      Somit lernt man Stück für Stück Linux und Tippt/Kopiert nicht nur blind Befehle ab 🙂
                      VG
                      Bernd
                        australien @Thomas Braun last edited by
                        Hi thomas
                        leider hat das bei mir nichts geholfen 😞
                        bekomme immer noch die Fehlermeldung
                        pi@raspberrypi:/ $ sudo apt update
                        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                        Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
                        Err:5 https://repos.influxdata.com/debian bullseye InRelease
                          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                        Fetched 7,022 B in 2s (4,068 B/s)
                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                        W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          Thomas Braun Most Active @australien last edited by
                          @australien
                          ls -lAh /etc/apt/sources.list.d/
                            pi@raspberrypi:/ $ ls -lAh /etc/apt/sources.list.d/
                            total 12K
                            -rw-r--r-- 1 root root 101 Jan 27 15:19 influxdb.list
                            -rw-r--r-- 1 root root 208 Nov 30 15:57 nodesource.list
                            -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
                              @australien
                              Da mal reingeschaut?
                              https://forum.iobroker.net/topic/62271/gelöst-influxdb-upgrade-error/17
                                australien @Thomas Braun last edited by australien
                                kannte ich nicht, bekomme aber schnell so etwas
                                pi@raspberrypi:/ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                pi@raspberrypi:/ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                                gpg: can't open './influxdata-archive_compat.key': No such file or directory
                                pi@raspberrypi:/
                                ich werde es morgen wieder versuchen
                                  A Former User @australien last edited by A Former User
                                  @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                                  pi@raspberrypi:/
                                  Moin,
                                  schau mal nach dem wget ob Du eine Datei im Verzeichnis liegen hast, wenn nicht, dann Netzwerk prüfen, denn ich kann es genau so wie offiziell von influxDB beschrieben updaten.
                                  # wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                  # ls -la
                                  # -rw-r--r-- 1 dp20eic dp20eic  1684 Jan 26 22:11 influxdata-archive_compat.key
                                  VG
                                  Bernd
                                  P.S.: Du kannst auch auf die Seite Package Pepository gehen und dir die Datei herunterladen, dann auf dein Pi Kopieren und mit gpg weiter machen.
                                    australien last edited by australien
                                    @dp20eic
                                    da ist viel, aber nicht die Datei.
                                    alles im root, kein Unterverzeichnis
                                    pi@raspberrypi:/ $ ls -la
                                    total 68
                                    drwxr-xr-x  18 root root  4096 Sep 22 05:06 .
                                    drwxr-xr-x  18 root root  4096 Sep 22 05:06 ..
                                    lrwxrwxrwx   1 root root     7 Sep 22 04:49 bin -> usr/bin
                                    drwxr-xr-x   4 root root  4096 Jan  1  1970 boot
                                    drwxr-xr-x  17 root root  3940 Jan 27 11:31 dev
                                    drwxr-xr-x  89 root root  4096 Jan 27 14:51 etc
                                    drwxr-xr-x   4 root root  4096 Nov 15 20:50 home
                                    lrwxrwxrwx   1 root root     7 Sep 22 04:49 lib -> usr/lib
                                    drwx------   2 root root 16384 Sep 22 05:05 lost+found
                                    drwxr-xr-x   2 root root  4096 Sep 22 04:49 media
                                    drwxr-xr-x   2 root root  4096 Sep 22 04:49 mnt
                                    drwxr-xr-x   3 root root  4096 Nov 15 20:50 opt
                                    dr-xr-xr-x 228 root root     0 Jan  1  1970 proc
                                    drwx------   5 root root  4096 Nov 30 15:18 root
                                    drwxr-xr-x  26 root root   780 Jan 27 16:27 run
                                    lrwxrwxrwx   1 root root     8 Sep 22 04:49 sbin -> usr/sbin
                                    drwxr-xr-x   2 root root  4096 Sep 22 04:49 srv
                                    dr-xr-xr-x  12 root root     0 Jan  1  1970 sys
                                    drwxrwxrwt  10 root root  4096 Jan 27 16:07 tmp
                                    drwxr-xr-x  11 root root  4096 Sep 22 04:49 usr
                                    drwxr-xr-x  11 root root  4096 Sep 22 05:06 var
                                    pi@raspberrypi:/ $
                                    wo soll die datei gespeichert sein?
                                    Am PC wird die datei geladen.
                                      @australien
                                      Moin,
                                      du stehst im völlig falschen Verzeichnis, Du must im Home des Privaten Users stehen.
                                      # cd
                                      # pwd
                                      A 2 Replies Last reply Reply Quote 0
                                        australien @Guest last edited by
                                        @dp20eic
                                        pi@raspberrypi:~ $ pwd
                                        /home/pi
                                        ich hab gerade gesehen, dass es bei den https://repos.influxdata.com eine influxdb2.key gibt. soll ich diese benutzen? hab ja auch influxdb2.
                                          @dp20eic
                                          ich dacht ich hab es, aber......
                                          pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                          pi@raspberrypi:~ $ ls
                                          Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
                                          Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
                                          pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                                          pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                                                9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                                          uid                      InfluxData Package Signing Key <support@influxdata.com>
                                          pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                          -bash: $: command not found
                                          gpg: no valid OpenPGP data found.
                                          pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                          pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                          pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
                                          pi@raspberrypi:~ $ sudo apt update
                                          Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
                                          Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                                          Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
                                          Err:7 https://repos.influxdata.com/debian bullseye InRelease
                                          Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
                                          Fetched 18.8 kB in 2s (9,253 B/s)
                                          pi@raspberrypi:~ $
                                          ? 2 Replies Last reply Reply Quote 0
                                            Moin,
                                            nein, wenn Du jetzt im richtigen Verzeichnis stehst, dann genau so wie influxDB das beschrieben hat. vorhin warst Du im / da darf man nicht schreiben, es sei denn Du hast root Rechte.
                                            VG
                                            Bernd
                                            146
                                            36826
