    4. Linux/Debian - Grafana-Repo muss aktualisiert werden
      lessthanmore @Thomas Braun last edited by lessthanmore
      @Thomas-Braun
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 http://ftp.debian.org/debian bullseye-backports InRelease
      Get:7 http://security.debian.org/debian-security bullseye-security/main Sources [176 kB]
      Get:8 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [214 kB]
      Err:5 https://repos.influxdata.com/debian stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
      Fetched 438 kB in 1s (825 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
      W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 684A14CF2582E0C5
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hmm, irgendwas habe ich mir da gerade verbaut (main vs InRelease).
        Thomas Braun Most Active @lessthanmore last edited by Thomas Braun
        @lessthanmore
        echad@chet:~ $ cat /etc/apt/sources.list.d/influxdb.list
        deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
        Ist bei mir schon auf die neue Struktur umgestellt. Der Key ist auch nicht mehr im Schlüsselbund:
        echad@chet:~ $ apt-key list | grep influx | wc -l
        Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
        0
          @thomas-braun Bei mir heißt die influxdata.list.
          Gibt es da eine Anleitung?
          Hätte auch gedacht dass der key influxdb2.key ist.
          Welche influxdb Version hast du oder spielt das keine Rolle hier?
          Wie kann ich das bei mir korrigieren? Kannst du mir da bitte helfen?
            @lessthanmore
            Key löschen. Geht wie oben:
            sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
            Die /etc/apt/sources.list.d/influxdata.list löschen.
            Aktuelles Setup für influxdb:
            wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
            export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
            echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
            L A S 3 Replies Last reply Reply Quote 1
              @thomas-braun Lieben Dank, läuft wieder bzw. keine Fehler- bzw. Warnmeldungen mehr.
                A Former User @Naturfreund last edited by
                Hallo @naturfreund,
                ein Tipp am Rande, wenn Dir ein Befehl, den Du auf der Kommandozeile eingeben sollst, fremd ist oder dich die Neugierde umtreibt, dann kann Du auf der Kommandozeile ja mal folgendes eintippen 😉
                # man "befehl"   <- für befehl den einsetzen, den Du nicht kennst
                z.B.:
                # man wc
                NAME
                       wc - print newline, word, and byte counts for each file
                SYNOPSIS
                       wc [OPTION]... [FILE]...
                       wc [OPTION]... --files0-from=F
                DESCRIPTION
                       Print newline, word, and byte counts for each FILE, and a total line if more than one FILE is speci‐
                       fied.  A word is a non-zero-length sequence of printable characters delimited by white space.
                       With no FILE, or when FILE is -, read standard input.
                       The options below may be used to select which counts are printed, always  in  the  following  order:
                       newline, word, character, byte, maximum line length.
                       -c, --bytes
                              print the byte counts
                       -m, --chars
                              print the character counts
                       -l, --lines
                              print the newline counts
                       --files0-from=F
                              read  input  from  the files specified by NUL-terminated names in file F; If F is - then read
                              names from standard input
                       -L, --max-line-length
                              print the maximum display width
                       -w, --words
                              print the word counts
                       --help display this help and exit
                       --version
                              output version information and exit
                AUTHOR
                       Written by Paul Rubin and David MacKenzie.
                REPORTING BUGS
                       GNU coreutils online help: <https://www.gnu.org/software/coreutils/>
                       Report any translation bugs to <https://translationproject.org/team/>
                So kannst Du für fast jeden Konsolen Befehl eine kurze Beschreibung und eine Liste der Parameter, kompakter geht es mit,
                # wc --help
                1 dp20eic@yoga-3 ~ % wc --help
                Aufruf: wc [OPTION]... [DATEI]...
                  oder: wc [OPTION]... --files0-from=DL
                Zeilen‐, Wort‐ und Byteanzahl für jede DATEI ausgeben und eine Zeile mit der
                Gesamtsumme, wenn mehr als eine DATEI angegeben wurde. Ohne DATEI, oder wenn
                DATEI „-“ ist, wird von der Standardeingabe gelesen. Ein Wort ist eine nicht
                leere Folge von darstellbaren Zeichen, die durch Leerzeichen begrenzt wird.
                Ohne DATEI oder wenn DATEI „-“ ist, Standardeingabe lesen.
                Die unten angeführten Optionen erlauben es, die auszugebenden Zähler
                auszuwählen, wobei sie immer in dieser Reihenfolge ausgegeben werden:
                Zeilen, Wörter, Zeichen, Bytes, größte Zeilenlänge.
                  -c, --bytes            Byteanzahl ausgeben
                  -m, --chars            Zeichenanzahl ausgeben
                  -l, --lines            Zeilenanzahl ausgeben
                      --files0-from=D    Eingabe aus den Dateien lesen, die mit NULL
                                         terminiert in der Datei D stehen;
                                         ist D „-“, so wird aus der Standardeingabe gelesen
                  -L, --max-line-length  die Länge der längsten Zeile ausgeben
                  -w, --words            Wortanzahl ausgeben
                      --help        diese Hilfe anzeigen und beenden
                      --version     Versionsinformation anzeigen und beenden
                Onlinehilfe für GNU coreutils: <https://www.gnu.org/software/coreutils/>
                Melden Sie Übersetzungsfehler für %s an <translation-team-de@lists.sourceforge.net>
                Die vollständige Dokumentation ist hier: <https://www.gnu.org/software/coreutils/wc>
                oder auch lokal mittels „info '(coreutils) wc invocation'“
                Somit lernt man Stück für Stück Linux und Tippt/Kopiert nicht nur blind Befehle ab 🙂
                VG
                Bernd
                  australien @Thomas Braun last edited by
                  Hi thomas
                  leider hat das bei mir nichts geholfen 😞
                  bekomme immer noch die Fehlermeldung
                  pi@raspberrypi:/ $ sudo apt update
                  Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                  Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
                  Err:5 https://repos.influxdata.com/debian bullseye InRelease
                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  Fetched 7,022 B in 2s (4,068 B/s)
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                    Thomas Braun Most Active @australien last edited by
                    @australien
                    ls -lAh /etc/apt/sources.list.d/
                      pi@raspberrypi:/ $ ls -lAh /etc/apt/sources.list.d/
                      total 12K
                      -rw-r--r-- 1 root root 101 Jan 27 15:19 influxdb.list
                      -rw-r--r-- 1 root root 208 Nov 30 15:57 nodesource.list
                      -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
                        @australien
                        Da mal reingeschaut?
                        https://forum.iobroker.net/topic/62271/gelöst-influxdb-upgrade-error/17
                          australien @Thomas Braun last edited by australien
                          kannte ich nicht, bekomme aber schnell so etwas
                          pi@raspberrypi:/ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                          pi@raspberrypi:/ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                          gpg: can't open './influxdata-archive_compat.key': No such file or directory
                          pi@raspberrypi:/
                          ich werde es morgen wieder versuchen
                            A Former User @australien last edited by A Former User
                            @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                            pi@raspberrypi:/
                            Moin,
                            schau mal nach dem wget ob Du eine Datei im Verzeichnis liegen hast, wenn nicht, dann Netzwerk prüfen, denn ich kann es genau so wie offiziell von influxDB beschrieben updaten.
                            # wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                            # ls -la
                            # -rw-r--r-- 1 dp20eic dp20eic  1684 Jan 26 22:11 influxdata-archive_compat.key
                            VG
                            Bernd
                            P.S.: Du kannst auch auf die Seite Package Pepository gehen und dir die Datei herunterladen, dann auf dein Pi Kopieren und mit gpg weiter machen.
                              australien last edited by australien
                              @dp20eic
                              da ist viel, aber nicht die Datei.
                              alles im root, kein Unterverzeichnis
                              pi@raspberrypi:/ $ ls -la
                              total 68
                              drwxr-xr-x  18 root root  4096 Sep 22 05:06 .
                              drwxr-xr-x  18 root root  4096 Sep 22 05:06 ..
                              lrwxrwxrwx   1 root root     7 Sep 22 04:49 bin -> usr/bin
                              drwxr-xr-x   4 root root  4096 Jan  1  1970 boot
                              drwxr-xr-x  17 root root  3940 Jan 27 11:31 dev
                              drwxr-xr-x  89 root root  4096 Jan 27 14:51 etc
                              drwxr-xr-x   4 root root  4096 Nov 15 20:50 home
                              lrwxrwxrwx   1 root root     7 Sep 22 04:49 lib -> usr/lib
                              drwx------   2 root root 16384 Sep 22 05:05 lost+found
                              drwxr-xr-x   2 root root  4096 Sep 22 04:49 media
                              drwxr-xr-x   2 root root  4096 Sep 22 04:49 mnt
                              drwxr-xr-x   3 root root  4096 Nov 15 20:50 opt
                              dr-xr-xr-x 228 root root     0 Jan  1  1970 proc
                              drwx------   5 root root  4096 Nov 30 15:18 root
                              drwxr-xr-x  26 root root   780 Jan 27 16:27 run
                              lrwxrwxrwx   1 root root     8 Sep 22 04:49 sbin -> usr/sbin
                              drwxr-xr-x   2 root root  4096 Sep 22 04:49 srv
                              dr-xr-xr-x  12 root root     0 Jan  1  1970 sys
                              drwxrwxrwt  10 root root  4096 Jan 27 16:07 tmp
                              drwxr-xr-x  11 root root  4096 Sep 22 04:49 usr
                              drwxr-xr-x  11 root root  4096 Sep 22 05:06 var
                              pi@raspberrypi:/ $
                              wo soll die datei gespeichert sein?
                              Am PC wird die datei geladen.
                                @australien
                                Moin,
                                du stehst im völlig falschen Verzeichnis, Du must im Home des Privaten Users stehen.
                                # cd
                                # pwd
                                A 2 Replies Last reply Reply Quote 0
                                  australien @Guest last edited by
                                  @dp20eic
                                  pi@raspberrypi:~ $ pwd
                                  /home/pi
                                  ich hab gerade gesehen, dass es bei den https://repos.influxdata.com eine influxdb2.key gibt. soll ich diese benutzen? hab ja auch influxdb2.
                                    @dp20eic
                                    ich dacht ich hab es, aber......
                                    pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                    pi@raspberrypi:~ $ ls
                                    Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
                                    Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
                                    pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
                                    pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                                          9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                                    uid                      InfluxData Package Signing Key <support@influxdata.com>
                                    pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                    -bash: $: command not found
                                    gpg: no valid OpenPGP data found.
                                    pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                    pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                    pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
                                    pi@raspberrypi:~ $ sudo apt update
                                    Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
                                    Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                                    Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
                                    Err:7 https://repos.influxdata.com/debian bullseye InRelease
                                    Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
                                    Fetched 18.8 kB in 2s (9,253 B/s)
                                    pi@raspberrypi:~ $
                                    ? 2 Replies Last reply Reply Quote 0
                                      Moin,
                                      nein, wenn Du jetzt im richtigen Verzeichnis stehst, dann genau so wie influxDB das beschrieben hat. vorhin warst Du im / da darf man nicht schreiben, es sei denn Du hast root Rechte.
                                      VG
                                      Bernd
                                        Moin,
                                        das mir zwei $ $ geht nicht, Bash kennt kein $. Falsch kopiert 😉
                                        VG
                                        Bernd
                                          @dp20eic
                                          das ganze von vorne
                                          pi@raspberrypi:~ $ cd
                                          /home/pi
                                          Hit:1 https://repos.influxdata.com/debian stable InRelease
                                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:7 https://deb.nodesource.com/node_17.x bullseye InRelease
                                          Fetched 7,022 B in 2s (3,881 B/s)
                                          pi@raspberrypi:~ $
                                            Moin,
                                            lies mal im Thread, den @Thomas-Braun verlinkt hat weiter, dann kommst Du auch auf die Lösung 🙂
                                            Kleiner Tip,
                                            # ls -la /etc/apt/sources.list.d/
                                            Dann
                                            VG
                                            Bernd
                                            146
                                            36826
