    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      Eugene last edited by
      Hallo Leute,
      ich habe einen tolles neues TV, aber leider kann ich den LG WebOS Adapter nicht installieren. Da ich sonst keine Probleme mit dem IOBroker habe, liegt es wohl am Adapter. Mit Admin v6.3.5 und Node.js v16.15.0 und dazu passendem npm 8.5.5 lässt sich der Adapter nicht installieren. Folgende Fehlermeldung erscheint:
      Installing SebastianSchultz/ioBroker.lgtv... (System call)
      npm ERR! code 1
      npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@8.4.1
      npm ERR! gyp info using node@16.15.0 | linux | armnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python Python is not set from command line or npm configurationnpm ERR! gyp ERR! find Python Python is not set from environment variable PYTHONnpm ERR! gyp ERR! find Python checking if "python3" can be usednpm ERR! gyp ERR! find Python - executable path is "/usr/bin/python3"npm ERR! gyp ERR! find Python - version is "3.5.3"npm ERR! gyp ERR! find Python - version is 3.5.3 - should be >=3.6.0npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTEDnpm ERR! gyp ERR! find Python checking if "python" can be usednpm ERR! gyp ERR! find Python - executable path is "/usr/bin/python"npm ERR! gyp ERR! find Python - version is "2.7.13"npm ERR! gyp ERR! find Python - version is 2.7.13 - should be >=3.6.0npm ERR! gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTEDnpm ERR! gyp ERR! find Python npm ERR! gyp ERR! find Python **********************************************************npm ERR! gyp ERR! find Python You need to install the latest version of Python.npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,npm ERR! gyp ERR! find Python you can try one of the following options:npm ERR! gyp ERR! find Python - Use the switch --python="/path/to/pythonexecutable"npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)npm ERR! gyp ERR! find Python - Set the environment variable PYTHONnpm ERR! gyp ERR! find Python - Set the npm configuration variable python:npm ERR! gyp ERR! find Python npm config set python "/path/to/pythonexecutable"
      npm ERR! /home/iobroker/.npm/_logs/2022-12-15T14_38_49_292Z-debug-0.log
      host.ioBroker-Tinker Cannot install SebastianSchultz/ioBroker.lgtv: 1
      ERROR: Process exited with code 25
      Sollte jemand eine Idee haben, bin ich für einen Hinweis dankbar!
      Euch allen schöne Feiertage und Gruß aus der Eifel
      Eugen
      liv-in-sky D Thomas Braun 3 Replies Last reply Reply Quote 0
        liv-in-sky @Eugene last edited by liv-in-sky
        @Eugene
        sorry - hier stand dummes 😞
          dirkhe Developer @Eugene last edited by
          @eugene also irgendwas ist mit deiner python version schief, hast du vlt. 2 und 3 gleichzeitig installiert? In dem bereicn solltest du mal suchen
            Thomas Braun Most Active @Eugene last edited by Thomas Braun
            @eugene sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
            Vermutlich ein veraltetes Betriebssystem. Aktuelles Zeuch kommt mit passenden Versionen daher.
              Eugene @dirkhe last edited by
              @dirkhe
              Alte Duster Version auf dem Tinker Board. Hab's platt gemacht und ein sauberes neues Armbian installiert.
              Natürlich geht jetzt alles.....
              Danke für Euren Tipp und frohe Weihnachten
              Eugen
                Dado @Maschine20 last edited by
                @maschine20 Moin, sory für die Noob-Frage, aber wie genau hast Du das installiert? Ich kenne nur die Möglichkeit, aus dem Repo zu installieren. Danke
                Maschine20 1 Reply Last reply Reply Quote 0
                • Maschine20
                  Maschine20 @Dado last edited by Maschine20
                  @dado Hi, ich habe aus dem git https://github.com/SebastianSchultz/ioBroker.lgtv/tree/lgtv_test den link kopiert und dann im Expertenmodus den Adapter aus der github Quelle installiert.
                  Unter dem Button Code kann man den link kopieren für den Adapter.
                  • V
                    Vopi69 @Maschine20 last edited by Vopi69
                    Seit heute habe ich ein Update für meinen LG OLED55G29LA bekommen. Seitdem verbindet sich der Adapter nicht mehr mit dem Fernseher und ich habe beim Neustarten des Adapters:
                    2023-01-25 13:10:38.212 - info: host.iobroker stopInstance system.adapter.lgtv.0 (force=false, process=true)
                    2023-01-25 13:10:38.215 - info: lgtv.0 (14518) Got terminate signal TERMINATE_YOURSELF
                    2023-01-25 13:10:38.217 - info: lgtv.0 (14518) terminating
                    2023-01-25 13:10:38.218 - info: lgtv.0 (14518) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-01-25 13:10:38.257 - info: host.iobroker stopInstance system.adapter.lgtv.0 send kill signal
                    2023-01-25 13:10:38.772 - info: host.iobroker instance system.adapter.lgtv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-01-25 13:10:41.269 - info: host.iobroker instance system.adapter.lgtv.0 started with pid 15224
                    2023-01-25 13:10:41.815 - info: lgtv.0 (15224) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.19.0, js-controller: 4.0.24
                    2023-01-25 13:10:41.825 - info: lgtv.0 (15224) Ready. Configured WebOS TV IP: 192.168.0.80
                    Weiß jemand woran das liegt?
                    Gruß Stefan
                      dirkhe Developer last edited by
                      @vopi69 ohne debug log sieht man gar nichts
                        Denzel1994 last edited by Denzel1994
                        Adapter verbindet sich mit meinem CS9 seit Firmware 03.30.16 nicht mehr:
                        lgtv.0 2023-01-27 22:37:11.349	debug	Error on connecting or sending command to WebOS TV: Error: socket hang up
                        lgtv.0 2023-01-27 22:37:11.340	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                        lgtv.0 2023-01-27 22:37:11.298	debug	TV is off
                        lgtv.0 2023-01-27 22:37:06.338	debug	Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
                        lgtv.0 2023-01-27 22:37:06.325	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                        lgtv.0 2023-01-27 22:37:01.323	debug	Error on connecting or sending command to WebOS TV: Error: socket hang up
                        lgtv.0 2023-01-27 22:37:01.293	debug	Connecting to WebOS TV: ws://192.168.XX.XX:3000
                          sigi234 Forum Testing Most Active @Denzel1994 last edited by
                          @denzel1994
                          Ist eine Verbindungsanfrage am TV gekommen?
                            roesthod @sigi234 last edited by
                            @sigi234 Hallo, Ich habe genau das gleich Problem. Das Errorlog sieht wie folgt aus:
                            2023-01-28 13:56:39.791 - debug: lgtv.0 (1414) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-01-28 13:56:39.841 - debug: lgtv.0 (1414) Objects client ready ... initialize now
                            2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create System PubSub Client
                            2023-01-28 13:56:39.842 - debug: lgtv.0 (1414) Objects create User PubSub Client
                            2023-01-28 13:56:39.958 - debug: lgtv.0 (1414) Objects client initialize lua scripts
                            2023-01-28 13:56:39.963 - debug: lgtv.0 (1414) Objects connected to redis: 127.0.0.1:9001
                            2023-01-28 13:56:39.964 - silly: lgtv.0 (1414) redis psubscribe cfg.o.system.user.*
                            2023-01-28 13:56:40.001 - silly: lgtv.0 (1414) redis psubscribe cfg.o.enum.*
                            2023-01-28 13:56:40.004 - silly: lgtv.0 (1414) objectDB connected
                            2023-01-28 13:56:40.005 - debug: lgtv.0 (1414) Redis States: Use Redis connection: 127.0.0.1:9000
                            2023-01-28 13:56:40.033 - debug: lgtv.0 (1414) States create System PubSub Client
                            2023-01-28 13:56:40.034 - debug: lgtv.0 (1414) States create User PubSub Client
                            2023-01-28 13:56:40.090 - debug: lgtv.0 (1414) States connected to redis: 127.0.0.1:9000
                            2023-01-28 13:56:40.090 - silly: lgtv.0 (1414) statesDB connected
                            2023-01-28 13:56:40.474 - info: lgtv.0 (1414) starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.lgtv, node: v16.14.0, js-controller: 4.0.23
                            2023-01-28 13:56:40.496 - info: lgtv.0 (1414) Ready. Configured WebOS TV IP: 192.168.1.236
                            2023-01-28 13:56:40.497 - debug: lgtv.0 (1414) adapter.config = {"ip":"192.168.1.236","mac":"XX:XX:XX:XX:37:6B","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
                            2023-01-28 13:56:40.508 - silly: lgtv.0 (1414) States system redis pmessage system.adapter.lgtv.0.logLevel/system.adapter.lgtv.0.logLevel:{"val":"silly","ack":true,"ts":1674910600499,"q":0,"from":"system.adapter.lgtv.0","lc":1674910600499}
                            2023-01-28 13:56:40.516 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
                            2023-01-28 13:56:40.523 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: socket hang up
                            2023-01-28 13:56:45.523 - debug: lgtv.0 (1414) Connecting to WebOS TV: ws://192.168.1.236:3000
                            2023-01-28 13:56:45.526 - debug: lgtv.0 (1414) Error on connecting or sending command to WebOS TV: Error: read ECONNRESET
                            Thomas Braun sigi234 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @roesthod last edited by
                              @roesthod sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                              Vom konkreten Problem abgesehen:
                              Halt die Kiste auf Stand.
                                sigi234 Forum Testing Most Active @roesthod last edited by
                                @roesthod
                                IP Richtig? Kannst du den TV via Ping erreichen?
                                  @sigi234 IP ist richtig und ich habe das System jetzt auf den aktuellen Stand gebracht.
                                    roesthod @roesthod last edited by
                                    @roesthod Ich habe übrigends zwei von den LG's und beide mit dem identischen Fehlerbild...
                                      sigi234 Forum Testing Most Active @roesthod last edited by sigi234
                                      Alle mit WLAN verbunden?
                                      Hatte auch Probleme, mit LAN hat es dann mal nach 20 versuchen funktioniert.
                                      https://github.com/SebastianSchultz/ioBroker.lgtv/issues/123
                                      Dany53 created this issue in SebastianSchultz/ioBroker.lgtv
                                      closed Nach TV update keine Verbindung mehr #123
                                        dirkhe Developer @sigi234 last edited by
                                        @sigi234 Da s sieht wirklich so aus, als wenn der Adapter angepasst werden muss. Ist halt auch schwierig rauszubekommen, welcher TV dann ws und welcher wss braucht. Zur Not müsste man es einstellbar machen..
                                          roesthod @dirkhe last edited by
                                          @dirkhe TV's sind über LAN eingebunden...
                                            dirkhe Developer @roesthod last edited by
                                            @roesthod das hat mit wlan und lan wahrscheinlich nicht viel zu tun, eher das die mi der neueren firmware ein anderen websocket nutzen, wie in dem issue auf github beschrieben
                                            lgtv
                                            113
                                            861
                                            312095
