    4. Server Cannot start inMem-objects on port 9001
      Doggie last edited by
      @thomas-braun o.k. Danke!
        Thomas Braun Most Active @Doggie last edited by
        @doggie
        Und was sagt
        iob diag
        nun in der Langfassung?
          Doggie @Thomas Braun last edited by Doggie
          o.k. das ist echt lang:
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Architecture:   armv7l
          Docker:         false
          Virtualization: none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           19:10:29 up 50 min,  1 user,  load average: 0.31, 0.37, 0.36
          CPU threads: 4
          *** Time and Time Zones ***
          Fri Jan 27 18:10:29 UTC 2023
          Fri Jan 27 19:10:29 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            3.8G        1.3G        2.2G        1.0M        334M        2.8G
          Swap:            99M          0B         99M
          Total:          3.9G        1.3G        2.3G
                   3838 M total memory
                   1280 M used memory
                    151 M active memory
                   1350 M inactive memory
                   2224 M free memory
                     53 M buffer memory
                    281 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /dev/root      ext4       59G  6.5G   50G  12% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     768M  1.2M  767M   1% /run
          /dev/sda1      exfat     7.5G  7.5G  8.1M 100% /mnt/usb0
          /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
          tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
          Messages in dmesg:
          [Fri Jan 27 18:20:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:B0:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4b9b7d8f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Fri Jan 27 18:20:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Jan 27 18:20:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Jan 27 18:20:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET      SOURCE         FSTYPE OPTIONS
          /           /dev/mmcblk0p2 ext4   rw,noatime
          |-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
          `-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.2G    /var/
          860M    /var/log
          841M    /var/log/journal/a67c6b0af55647aea7f6b6889796f9aa
          143M    /var/cache
          /opt/iobroker/backups:
          85M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          319M    /opt/iobroker/iobroker-data/
          269M    /opt/iobroker/iobroker-data/files
          72M     /opt/iobroker/iobroker-data/files/telegram.admin
          51M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js
          33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          12M     /opt/iobroker/iobroker-data/objects.jsonl
          9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.19.0
          /usr/bin/node           v16.19.0
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u3 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
          + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.41
            system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
          Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.5.10   , installed 2.5.10
          Adapter    "ble"          : 0.13.0   , installed 0.13.0
          Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
          Adapter    "cloud"        : 4.3.0    , installed 4.3.0
          Adapter    "devices"      : 1.1.2    , installed 1.1.2
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.14.2   , installed 1.14.2
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "shelly"       : 6.0.0    , installed 6.0.0
          Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "text2command" : 2.3.0    , installed 2.3.0
          Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
          Adapter    "tuya"         : 3.12.1   , installed 3.12.1
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Objects and States
          Objects:        2266
          States:         1820
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.178.41:1883     0.0.0.0:*               LISTEN      1001       17603      1166/io.mqtt.0
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18028      1411/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13055      555/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14282      520/cupsd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11055      522/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14329      522/iobroker.js-con
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13057      555/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17958      1351/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13237      685/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14281      520/cupsd
          udp        0      0 0.0.0.0:40825           0.0.0.0:*                           108        10701      347/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15752      1275/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15753      1275/io.tuya.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14914      1215/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13140      472/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13129      610/cups-browsed
          udp        0      0 192.168.178.29:123      0.0.0.0:*                           116        14608      554/ntpd
          udp        0      0 192.168.178.41:123      0.0.0.0:*                           116        14551      554/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          10981      554/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          10977      554/ntpd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15969      1381/io.chromecast.
          udp        0      0 192.168.178.29:5353     0.0.0.0:*                           1001       14748      1146/io.tr-064.0
          udp        0      0 192.168.178.41:5353     0.0.0.0:*                           1001       14747      1146/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10699      347/avahi-daemon: r
          udp6       0      0 :::50030                :::*                                108        10702      347/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          13153      472/dhcpcd
          udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14670      554/ntpd
          udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14649      554/ntpd
          udp6       0      0 fe80::4017:de71:8ff:123 :::*                                116        14502      554/ntpd
          udp6       0      0 fe80::cb6f:a96d:5ee:123 :::*                                116        11206      554/ntpd
          udp6       0      0 ::1:123                 :::*                                0          10983      554/ntpd
          udp6       0      0 :::123                  :::*                                0          10974      554/ntpd
          udp6       0      0 :::5353                 :::*                                108        10700      347/avahi-daemon: r
          2023-01-27 18:21:50.553  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.SET has no target 12
          2023-01-27 18:21:50.555  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.AVAILABLE has no target 12
          2023-01-27 18:21:52.523  - info: text2command.0 (1426) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.0, js-controller: 4.0.24
          2023-01-27 18:21:54.444  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1450
          2023-01-27 18:21:58.345  - info: host.raspberrypi instance system.adapter.iot.0 started with pid 1473
          2023-01-27 18:21:59.327  - info: info.0 (1450) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
          2023-01-27 18:21:59.498  - info: info.0 (1450) Reading/updating systemdata.
          2023-01-27 18:22:00.804  - info: info.0 (1450) cpu Temp res = {"main":39.92,"cores":[],"max":39.92,"socket":[],"chipset":null}
          2023-01-27 18:22:01.852  - info: iot.0 (1473) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
          2023-01-27 18:22:01.991  - info: iot.0 (1473) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2023-01-27 18:22:02.380  - info: host.raspberrypi instance system.adapter.smartthings.0 started with pid 1638
          2023-01-27 18:22:02.896  - info: iot.0 (1473) Connection changed: connect
          2023-01-27 18:22:05.379  - info: smartthings.0 (1638) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smartthings, node: v16.19.0, js-controller: 4.0.24
          2023-01-27 18:22:05.727  - error: smartthings.0 (1638) AxiosError: Request failed with status code 403
          2023-01-27 18:22:05.728  - error: smartthings.0 (1638) ""
          2023-01-27 18:22:06.333  - info: host.raspberrypi instance system.adapter.ble.0 started with pid 1657
          2023-01-27 18:22:08.944  - info: ble.0 (1657) starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.19.0, js-controller: 4.0.24
          2023-01-27 18:22:09.090  - info: ble.0 (1657) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
          2023-01-27 18:22:09.092  - info: ble.0 (1657) enabled plugins: _default
          2023-01-27 18:22:09.095  - info: ble.0 (1657) monitored services:
          2023-01-27 18:22:09.176  - info: ble.0 (1657) starting scanner process...
          2023-01-27 18:22:09.843  - info: ble.0 (1657) starting scan for services []
          2023-01-27 18:22:15.400  - info: cloud.0 (1396) Trying to connect as system.user.admin to cloud
          2023-01-27 18:22:15.605  - info: cloud.0 (1396) Connection changed: connect
          2023-01-27 18:52:54.695  - warn: zigbee.0 (1290) DeviceAvailability:Stopping to ping 0xf0d1b8be2408070d A60 DIM T after 4 ping attempts
          iob diag has finished.
          Das Update war ja sicher nötig.
          Das eigentliche Problem - die Nicht-Erreichbarkeit im Browser- besteht aber nach wie vor.
          Ich bin für weitere Vorschläge dankbar.
          Der ioBroker scheint aber zu funktionieren. Er hat die Leuchten, die er schalten soll angeschaltet.
          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Doggie last edited by Thomas Braun
            @doggie
            Deim Gerät /dev/sda1 ist rappelvoll.
            Und mit dem Netzwerk stimmt wohl auch irgendwie was nicht.
              @thomas-braun ups... das ist mir garnicht aufgefallen. Das ist der USB-Stick für die Backups.
              Dann werd ich mal schauen, wie ich die ältesten Backups lösche.
                @thomas-braun Tja das Netzwerk...ich frag mich, wie ich da weiter komme.
                  apollon77 @Doggie last edited by
                  @doggie na dann schau doch mal ins log. Dann scheint ja der Admin Adapter ein Problem beim
                  Starten zu haben - was aber dann jetzt ggf ein anderer Fehler ist als zu Beginn (oder du hast uns verwirrt in dem thread hier)
                    @apollon77 verwirrt habe ich bestimmt niemanden. Zumindest nicht absichtlich, höchstens aus Unwissenheit.
                      Doggie last edited by Doggie
                      @apollon77 das war mal das log, als der iobroker am 23.1.2023 zum erstenmal im Browser nicht mehr erreichbar war:
                      code_text
                      ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                      2023-01-26 20:18:32.217  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                      2023-01-26 20:18:32.226  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                      2023-01-26 20:18:32.228  - info: host.raspberrypi hostname: raspberrypi, node: v16.17.0
                      2023-01-26 20:18:32.230  - info: host.raspberrypi ip addresses: 192.168.178.41 2001:9e8:6256:ee00:2a69:6134:2330:b0b3 fe80::cb6f:a96d:5ee2:712a 192.168.178.29 2001:9e8:6256:ee00:20a0:2b27:ab07:1ca7 fe80::4017:de71:8ffb:880a
                      2023-01-26 20:18:34.348  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!```
                      code_text
                      was jetzt drinsteht, schau ich noch mal
                      Ergänzung: Nach den Updates steht noch der gleiche Fehler drin. Es hat sich also nichts geändert. Und das Sympton -keine Erreichbarkeit im Browser- ist auch das gleiche
                        @doggie also wenn es dieser Fehler ist der jetzt im log ist dann dürfte gar nichts funktionieren. Das passt nicht zusammen was du schreibst.
                        Reboote mal den Host und schau dann.
                          Doggie @apollon77 last edited by Doggie
                          @apollon77 Der angegebene Fehler steht ja nicht im "Allgemeinen Log", sondern erscheint nur nach Eingabe von
                          code_text
                          ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs```
                          code_text
                          Bis auf die Erreichbarkeit im Browser funktioniert der ioBrowser, wie ich schon schrieb. Er schaltet z.B. alles was er soll. Den o.a. Befehl habe ich von einer Seite in ioBroker.net (Thema "ioBoker läuft nicht mehr). Möglicherweise ist dieser Befehl nicht so zielführend, wie ich dachte.
                          Im allgemeinen Log sehe ich überhaupt keine Fehlermeldungen.
                          Auch wenn es erstmal nicht erklärbar ist: Es ist wie es ist.
                          Gibt es noch Ansätze oder Ideen?
                          Was mir noch aufgefallen ist:
                          code_text
                          ```system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled```
                          code_text
                          Thomas Braun F 2 Replies Last reply Reply Quote 0
                            @doggie sagte in Server Cannot start inMem-objects on port 9001:
                            Der Befehl ist soweit ich das sehe obsolet.
                              @thomas-braun Dann wäre es gut, wenn ein Admin den von der angegebenen ioBroker.net Seite
                              entfernen würde. Leute wie ich fallen nur darauf rein.
                              • wendy2702
                                wendy2702 @Doggie last edited by
                                wo genau steht der denn?
                                  Doggie @wendy2702 last edited by
                                  @wendy2702 Seite: https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de#installAdapter
                                  Thema "IoBroker läuft nicht mehr"
                                  "Falls immer noch nicht läuft oder es kommen Fehlermeldungen, dann kann man versuchen controller manuell zu starten...."
                                    fastfoot @Doggie last edited by
                                    ich sehe da 2 ip adressen, evtl ist der iobroke Admin unter der anderen Adresse erreichbar?
                                    192.168.178.41 und 192.168.178.29
                                      @fastfoot Nein, ist er leider nicht.
                                      Auch in der Fritzbox stehen merkwürdigerweise die beiden Adressen.
                                      Die 192.168.178.29 unter WLAN, aber auch unter LAN. Die 41 aber auch unter LAN.
                                        Wo genau? Die beiden Interfaces sollten nicht die gleiche IP haben.
                                          @thomas-braun Also der Raspberry hat unter WLAN die Adresse 29 und unter LAN die 41.
                                          War möglicherweise ein Fehler in der Fritzbox. In der Liste waren die Adressen gleich, aber bei den Einzelheiten erschienen die richtigen Adressen
                                            Nach einigem Probieren kann ich den ioBroker jetzt im Browser erreichen.
                                            Ich musste nach der Adresseingabe den Port 8081 angeben und das "https" löschen.
                                            Irgendwie hat der Browser die falsche Angabe automatisch eingetragen.
                                            schon komisch: Ich hatte es mit 3 verschiedenen Browsern versucht. Oder die gemachten Änderungen haben doch etwas behoben und ich habe es nicht bemerkt durch die Fehleingabe im Browser.
                                            Manchmal sieht man den Wald vor lauter Bäumen nicht.
                                            Danke an alle, die sich um mein Problem bemüht haben.
                                            429
                                            81552
