    4. Linux/Debian - Grafana-Repo muss aktualisiert werden
      A Former User @australien last edited by
      @australien
      Moin,
      du stehst im völlig falschen Verzeichnis, Du must im Home des Privaten Users stehen.
      # cd
      # pwd
      A 2 Replies Last reply Reply Quote 0
        australien @Guest last edited by
        @dp20eic
        pi@raspberrypi:~ $ pwd
        /home/pi
        ich hab gerade gesehen, dass es bei den https://repos.influxdata.com eine influxdb2.key gibt. soll ich diese benutzen? hab ja auch influxdb2.
          @dp20eic
          ich dacht ich hab es, aber......
          pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
          pi@raspberrypi:~ $ ls
          Abfall.ics  influxdata-archive_compat.key  iobroker       log      node_modules  package-lock.json
          Calender    iob                            iobroker-data  nbsm.py  package.json  raspberrypi.gpg.key
          pi@raspberrypi:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
          pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
          uid                      InfluxData Package Signing Key <support@influxdata.com>
          pi@raspberrypi:~ $ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
          -bash: $: command not found
          gpg: no valid OpenPGP data found.
          pi@raspberrypi:~ $ cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
          pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
          pi@raspberrypi:~ $ sudo rm -f /etc/apt/trusted.gpg.d/influxdb.gpg
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Get:5 https://repos.influxdata.com/debian stable InRelease [6,874 B]
          Hit:6 https://deb.nodesource.com/node_17.x bullseye InRelease
          Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
          Get:8 https://repos.influxdata.com/debian stable/main arm64 Packages [3,275 B]
          Err:7 https://repos.influxdata.com/debian bullseye InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          Get:9 https://repos.influxdata.com/debian stable/main armhf Packages [1,669 B]
          Fetched 18.8 kB in 2s (9,253 B/s)
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          pi@raspberrypi:~ $
          ? 2 Replies Last reply Reply Quote 0
            @australien sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
            Moin,
            nein, wenn Du jetzt im richtigen Verzeichnis stehst, dann genau so wie influxDB das beschrieben hat. vorhin warst Du im / da darf man nicht schreiben, es sei denn Du hast root Rechte.
            VG
            Bernd
              Moin,
              das mir zwei $ $ geht nicht, Bash kennt kein $. Falsch kopiert 😉
              VG
              Bernd
                @dp20eic
                das ganze von vorne
                pi@raspberrypi:~ $ cd
                /home/pi
                Hit:1 https://repos.influxdata.com/debian stable InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:7 https://deb.nodesource.com/node_17.x bullseye InRelease
                Err:5 https://repos.influxdata.com/debian bullseye InRelease
                Fetched 7,022 B in 2s (3,881 B/s)
                pi@raspberrypi:~ $
                  Moin,
                  lies mal im Thread, den @Thomas-Braun verlinkt hat weiter, dann kommst Du auch auf die Lösung 🙂
                  Kleiner Tip,
                  # ls -la /etc/apt/sources.list.d/
                  Dann
                  VG
                  Bernd
                    @dp20eic
                    DANKE!!!!
                    jetzt hab ich es auch 🙂
                      das ganze von vorne
                      Moin,
                      warum so ungeduldig?
                      Erst lesen, dann Nachdenken 🙂
                      Du hast mit Sicherheit mehr Source List Files für influxDB im Verzeichnis, die werden beim apt-get update auch genommen, nur die alten List Files haben keine gültige Signatur mehr.
                      Also immer ganz ruhig junger Padawan 🙂
                      VG
                      Bernd
                        Marty56 @Guest last edited by Marty56
                        Danke an alle.
                        Warum muss Linux immer so eine fürchterlichere Frickelei sein?!
                        Ich verstehe das nicht.
                        Ich habe die Befehle vom ersten Post eingetippt.
                        Und bekomme jetzt folgenden Output.
                        Hit:1 http://security.debian.org bullseye-security InRelease
                        Hit:2 http://ftp.debian.org/debian bullseye InRelease
                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                        Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
                        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
                        Get:6 https://apt.grafana.com stable InRelease [5984 B]
                        Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Ign:8 https://apt.tvheadend.org/unstable bullseye InRelease
                        Hit:9 https://apt.tvheadend.org/unstable bullseye Release
                        Err:4 https://packages.grafana.com/oss/deb stable InRelease
                          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                        Get:11 https://apt.grafana.com stable/main amd64 Packages [105 kB]
                        Fetched 118 kB in 1s (80.5 kB/s)
                        4 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                        N: Skipping acquire of configured file 'main/binary-amd64/Packages' as repository 'https://apt.tvheadend.org/unstable bullseye InRelease' doesn't support architecture 'amd64'
                        W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                        apt-key list | grep -i grafana | wc -l
                        Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                        0
                        wendy2702 ? 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          wendy2702 @Marty56 last edited by wendy2702
                          @marty56 sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                          Verstehe nicht was daran Frickelei ist. Blos weil du bei WIndows nicht mitbekommst was die auf deinem Rechner veranstalten ist es nicht besser.
                          Poste doch bitte mal die vollständige Ausgabe der Eingabe der Befehle aus dem ersten Post.
                            A Former User @Marty56 last edited by
                            Moin,
                            Zu 1: Das hat nichts mit Linux zu tun, sondern mit der Distribution und den 3rd. Party Software Hersteller, die versuchen zu verhinder, das schlechte Menschen, verseuchte Pakete auf Deinen PC installieren können. Jede Distribution kocht da leider ihr eigenes Süppchen.
                            Zu 2. Dann musst Du dir mal ein gutes Buch zu Linux kaufen und lesen, dann wird vieles klar 🙂
                            Zu 3. immer nur Befehle, die ein anderer hier eintippt blindlings zu kopieren und sich dann zu wundern wieso geht das bei mir nicht, ist auch nicht so klug.
                            Hatte ich ja schon weiter oben geschrieben, Lesen (Bildet) dann nachdenken, dann handeln.
                            Wenn Du auf die Seite von Grafana gehst, steht genau beschrieben was zu tun ist, um die neuen Signaturen in sein System zu bekommen.
                            VG
                            Bernd
                              @dp20eic Sehr hilfreich. Leider habe ich überhaupt keinen Bock, Bücher über Linux zu lesen und Frickelkönig zu werden.
                              ? Thomas Braun Chaot 3 Replies Last reply Reply Quote -4
                                Moin,
                                ist doch eine Aussage, kann ich mit leben, ob Du damit leben kannst und ob Du mit dieser Einstellung Hilfe bekommst, kann ich Dir nur wünschen. Ich bin dann mal weg.
                                VG
                                Bernd
                                  Thomas Braun Most Active @Marty56 last edited by Thomas Braun
                                  Dann lass es bleiben und nerv andere nicht mit deinem Unwillen dich damit zu beschäftigen.
                                  Ich z.B. habe überhaupt keinen Bock so triviales Zeug Leuten zu erklären die es nicht wissen wollen. Setz besser ein Windows ein.
                                  Das Repo ist nach der obigen Anleitung und mit ein wenig Nachdenken in Nullkommanix richtig umgestellt. Hat gestern bei mir keine 10 Sekunden gedauert. Da war nix 'zu frickeln'.
                                  • Chaot
                                    Chaot @Marty56 last edited by
                                    @marty56 Ich verstehe dein Problem nicht.
                                    Ich musste mich beim Übergang von win 3.1 auf Win 95 komplett neu damit befassen. Dann kam Win2000 was auch viele Eigenheiten hatte und dann die Umstellung auf Win7. Auch hier musste einiges komplett neu erlernt werden.
                                    Warum ist das bei Windows ok, aber bei Linux plötzlich böse?
                                    Wenn ich eine Software nutze muss ich mich halt damit beschäftigen damit ich sie richtig einsetzen kann. Das war schon bei PC-DOS so und wird auch bei Win 25 irgendwann so bleiben.
                                    Und Frickelkönig? Dann hast du noch nie einen Windows Server bearbeitet.
                                      A Former User last edited by
                                      Moin,
                                      lasst doch gut sein, es geht hier nur darum Grafana und zwischendurch auch mal influxDB nach der Singnaturänderung wieder ans Laufen zu bringen, alles andere ist vergebene Liebesmüh und bring hier gar nichts 🙂
                                      VG
                                      Bernd
                                      M 1 Reply Last reply Reply Quote 3
                                        @dp20eic ganz meiner Meinung. Sorry, dass ich vom Thema abgewichen bin.
                                          shellyrulestheworld @Thomas Braun last edited by
                                          Vielen Dank für deine Beiträge. Hab auch versucht influxdb umzustellen, wie von dir beschrieben.
                                          Fetched 7,022 B in 3s (2,530 B/s)
                                          klappt aber leider nicht. Hab ich was vergessen?
                                          mein vorgehen war folgendes:
                                          apt-key list | grep -i influxdb | wc -l
                                          0
                                          sudo rm influxdb.list
                                          wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
                                          export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                                          echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                                            Thomas Braun Most Active @shellyrulestheworld last edited by Thomas Braun
                                            ls -lA /etc/apt/sources.list.d/
                                            sudo apt update
                                            sagt? Vollständig posten, nix weg lassen. Auch nicht das login prompt.
                                            146
                                            36841
