    4. [Neuer Adapter] radar-trap
    • Z
      Zelkin @carsten04 last edited by
      @carsten04
      Huhu, hier noch jemand aktiv?
      • O
        Oli @carsten04 last edited by
        Hallo @carsten04 ,
        ich habe mir die neuste Version deines Adapter von github gezogen und installiert, leider verbindet sich nach der Installation meine Vis nicht mehr.
        Ich verwende Google als Browser und bekomme folgende Meldungen:
        Warnungen in der Konsole
        DevTools failed to load source map: Could not load content for http://192.168.2.120:8082/vis/widgets/radar-trap/js/mapbox/mapbox-gl-csp.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        widgets.min.js:1 [waitForVisConnected] stop waiting for vis connection after 500 retries
        Fehler in der Konsole
        VM391:410 Uncaught (in promise) SyntaxError: Expected double-quoted property name in JSON at position 247968
            at JSON.parse (<anonymous>)
            at getTranslation (info.js:13:47)
        getTranslation @ info.js:13
        await in getTranslation (async)
        (anonymous) @ info.js:6
        jquery-1.11.2.min.js:4          GET http://192.168.2.120:8082/vis/adapter/rssfeed/words.js 404 (Not Found)
        send @ jquery-1.11.2.min.js:4
        ajax @ jquery-1.11.2.min.js:4
        m.<computed> @ jquery-1.11.2.min.js:4
        (anonymous) @ rssfeed.js:15
        index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=ODVzMMA 404 (Not Found)
        i.create @ index.js:83
        i @ index.js:83
        o.request @ index.js:83
        o.doPoll @ index.js:83
        r.poll @ index.js:83
        r.doOpen @ index.js:83
        r.open @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r.open.r.connect @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r @ index.js:83
        init @ conn.js:266
        main @ vis.js:3649
        (anonymous) @ vis.js:3935
        j @ jquery-1.11.2.min.js:2
        fireWith @ jquery-1.11.2.min.js:2
        ready @ jquery-1.11.2.min.js:2
        J @ jquery-1.11.2.min.js:2
        index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=ODVzOsI 404 (Not Found)
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        (anonymous) @ conn.js:158
        setInterval (async)
        reconnect @ conn.js:156
        (anonymous) @ conn.js:363
        r.emit @ index.js:83
        r.emitAll @ index.js:83
        (anonymous) @ index.js:83
        r.onError @ index.js:83
        i.onError @ index.js:83
        setTimeout (async)
        hasXDR.e.onreadystatechange @ index.js:83
        XMLHttpRequest.send (async)
        i @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r @ index.js:83
        r @ index.js:83
        init @ conn.js:266
        main @ vis.js:3649
        index.js:83          GET http://192.168.2.120:8082/socket.io/?key=nokey&EIO=3&transport=polling&t=ODVzRHk 404 (Not Found)
        Wenn ich deinen Adapter deinstalliere funktioniert wieder alles
        • Felix Simon
          Felix Simon last edited by
          Hi @sigi234 ich hab dein Github repo schon gefunden und finde deine Arbeit echt toll.
          Ich hab vor ein ähnliches Projekt zu erstellen aber in der Art eines Messenger Dienstes mit der Möglichkeit eine Postleitzahl einzugeben welche dann im Umkreis von 50km alle Blitzer, etc.. als Nachricht in einer WhatsApp - Gruppe verteilt.
          Meine Frage, welche Datenschnittstelle verwendest du? Die von Blitzer.de?
          Danke für deine Antwort.
          Liebe Grüße, Felix
            sigi234 Forum Testing Most Active @Felix Simon last edited by
            @felix-simon
            Ist nicht von mir 🙂
            Felix Simon 1 Reply Last reply Reply Quote 0
            • Felix Simon
              Felix Simon @sigi234 last edited by
              @sigi234 mein Fehler, ich bin da wohl etwas durcheinandergekommen 😄
              Die Frage war dementsprechend an @carsten04 gerichtet 🙂
              • carsten04
                carsten04 Developer last edited by carsten04
                @felix-simon ich nutze folgende api: https://cdn2.atudo.net/api/1.0/
                Felix Simon 1 Reply Last reply Reply Quote 1
                • Felix Simon
                  Felix Simon @carsten04 last edited by
                  @carsten04 Vielen Dank für die Antwort, darf ich fragen obs nen Grund gab wieso du dich nicht für die von Blitzer.de entschieden hast
                  carsten04 1 Reply Last reply Reply Quote 0
                  • carsten04
                    carsten04 Developer @Felix Simon last edited by
                    @felix-simon Die Datenbasis von biltzer.de und atudo ist identisch.
                    • Felix Simon
                      @carsten04 Perfekt, ich danke dir 😄
                      • carsten04
                        carsten04 Developer @Felix Simon last edited by carsten04
                        ich habe einen Nachfolger für den radar-trap Adapter entwickelt. Dieser wird jetzt sukzessive erweitert und mit neuen Funktionen ausgestattet. Alles Weitere gibt es hier zum nachlesen.
                        Carsten
                        222
                        24569
