    5. Alexa erzählt etwas anderes als sie soll
      Flori @Thomas Braun last edited by
      Nein so wie ich das sehe ist der blaue Ordner leer wenn du diesen meinst.
        Thomas Braun Most Active @Flori last edited by
        @flori
        Nein, ich meine das Verzeichnis 'global'. Sieht man nur im Experten-Modus.
          Nein absolut leer
            Flori @DJMarc75 last edited by
            @djmarc75
            So jetzt noch einmal mit genau deinem Programm. Erst das davor vor den 100000 gleichen Einträgen
            2023-01-28 18:02:31.211 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
            2023-01-28 18:02:40.393 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
            2023-01-28 18:03:01.808 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
            2023-01-28 18:03:28.880 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 1
            2023-01-28 18:03:31.019 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
            2023-01-28 18:03:49.503 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.windowopenactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.504 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.boostactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.505 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950115643.endperiod" has to be type "number" but received type "string"
            2023-01-28 18:03:49.549 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.windowopenactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.551 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.boostactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.553 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116517.endperiod" has to be type "number" but received type "string"
            2023-01-28 18:03:49.628 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.windowopenactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.629 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.boostactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.629 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950116240.endperiod" has to be type "number" but received type "string"
            2023-01-28 18:03:49.669 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.windowopenactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.670 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.boostactiveendtime" has to be type "number" but received type "string"
            2023-01-28 18:03:49.685 - info: fritzdect.0 (492214) State value to set for "fritzdect.0.DECT_099950135395.endperiod" has to be type "number" but received type "string"
            2023-01-28 18:03:29.471 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 3
            2023-01-28 18:03:59.464 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
            2023-01-28 18:03:59.465 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
            2023-01-28 18:03:59.466 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
            2023-01-28 18:03:59.467 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
            2023-01-28 18:03:59.468 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
            2023-01-28 18:03:59.469 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
              @flori sagte in Alexa erzählt etwas anderes als sie soll:
              Poste doch mal das Skript
                @djmarc75
                Und noch einmal das danach. Mit den unzähligen Ansagen. Das berühmte Sätzchen kommt übrigens auch wieder auch ohne Sprachaktivierung. 😉
                2023-01-28 18:04:06.149 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.150 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.152 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.154 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.169 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.171 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.172 - warn: javascript.0 (243299) script.js.Alarmanlage.Alarmanlage_wurde_ausgeschaltet: Alarmanlage ausgeschaltet
                2023-01-28 18:04:06.562 - info: admin.0 (243242) ==> Connected system.user.admin from ::ffff:192.168.178.69
                2023-01-28 18:04:11.149 - info: tuya.0 (243444) 02654020840d8e804331: Error on Reconnect (5): connection timed out
                2023-01-28 18:04:48.208 - info: admin.0 (243242) <== Disconnect system.user.admin from ::ffff:192.168.178.69 javascript
                2023-01-28 18:04:23.541 - info: javascript.0 (243299) script.js.Alarmanlage.Neu_für_DJ: 1
                • DJMarc75
                  DJMarc75 @Flori last edited by
                  ja Du brauchst das nicht in jedem zweiten Beitrag unnötig hier posten, das nervt und ist nicht hilfreich.
                  Mach doch einfach mal was man Dir sagt wie z.B.
                  @thomas-braun sagte in Alexa erzählt etwas anderes als sie soll:
                    Dieses Skript läuft aber im Moment überhaupt nicht weil da noch die Sachen mit drinne sind die ich dann bei den neuen Script komplett heraus genommen habe. Sprich Trigger in Trigger so wie das mit der Zeit.
                    DJMarc75 paul53 Thomas Braun 3 Replies Last reply Reply Quote 0
                    • DJMarc75
                      den Adapter neu starten.
                        paul53 @Flori last edited by paul53
                        @flori sagte: Dieses Skript läuft aber im Moment überhaupt nicht
                        Es werden offenbar noch gepufferte Ereignisse ausgeführt. Starte ioBroker neu oder Reboot.
                          Hast du den ioBroker bzw. besser den ganzen Rechner mal neugestartet? Das hängt vermutlich noch was im Cache.
                            Mache ich mal alles, Rechner neu hochfahren und Raspi4 neu hochfahren.
                              Also den Rechner schalte ich ja zweischenzeitlich eh immer aus, aber der IObroker und Raspi Neustart scheinen etwas gebracht zu haben. Zumindest sagt sie die angegeben Texte nur noch einmal und der berühmte Satz sind bisher auch ausgeblieben.
                              Na dann erst einmal vielen Dank für Eure Gedult mit mir und vielen Lieben Dank für Eure Hilfe.
                              Hoffe einmal das es so bleibt. Wenn es wieder auftritt versuche ich es gleich einmal mit einem Raspi Neustart.
                              Es war mir eben unerklärlich wo sie das jedes mal hergeholt hat. Ist ja nicht mein erstes Blockly was ich geschrieben habe. Vielen lieben Dank an Euch ALLE 😉 😉
                                @flori sagte: Wenn es wieder auftritt
                                Wenn keine Trigger im Trigger und keine Endlosschleifen programmiert werden, sollte es nicht wieder auftreten.
                                  Flori @paul53 last edited by
                                  Ja manchmal sieht man eben den Wald vor lauter Bäumen nicht.
                                  Jeden sage ich ob Freund oder Frau wenn etwas mit dem Handy zum Beispiel nicht stimmt.
                                  Mal ausschalten und neu Starten und dann mal schauen, aber selber komme ich nicht mal auf die Idee den Raspi einmal neu zu starten. Das hätte mir wahrscheinlich einige Stunden erspart.
                                  Vielen Lieben Dank Euch allen. 😉 😉 😉
                                  2189
