    4. JavaScript
    5. Roborock Adapter tester gesucht
      DonToben @DonToben last edited by
      @dontoben said in Roborock Adapter tester gesucht:
      @copystring
      Hier ein aktueller Log mit der aktuellsten Version.
      Die Warnmeldungen sind nicht wirklich weniger geworden.
      2023-01-27 07:15:30.980 - info: roborock.0 (1849) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v14.18.1, js-controller: 4.0.24
      2023-01-27 07:15:31.179 - debug: roborock.0 (1849) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer B","8937854":"Kinderzimmer L","8937856":"Schlafzimmer","10093883":"Bad"}
      2023-01-27 07:15:31.259 - info: roborock.0 (1849) MQTT initialized
      2023-01-27 07:15:31.264 - debug: roborock.0 (1849) Robot key: roborock.vacuum.a62
      2023-01-27 07:15:31.686 - debug: roborock.0 (1849) Latest data requested
      2023-01-27 07:15:31.689 - debug: roborock.0 (1849) getParameter: get_mop_mode
      2023-01-27 07:15:31.694 - debug: roborock.0 (1849) getParameter: get_water_box_custom_mode
      2023-01-27 07:15:31.696 - debug: roborock.0 (1849) getParameter: get_status
      2023-01-27 07:15:31.697 - debug: roborock.0 (1849) getParameter: get_consumable
      2023-01-27 07:15:31.698 - debug: roborock.0 (1849) getParameter: get_network_info
      2023-01-27 07:15:31.701 - debug: roborock.0 (1849) getParameter: get_carpet_mode
      2023-01-27 07:15:31.702 - debug: roborock.0 (1849) getParameter: get_carpet_cleaning_mode
      2023-01-27 07:15:31.703 - debug: roborock.0 (1849) getParameter: get_fw_features
      2023-01-27 07:15:31.703 - debug: roborock.0 (1849) Firmware features request
      2023-01-27 07:15:31.704 - debug: roborock.0 (1849) getParameter: get_multi_maps_list
      2023-01-27 07:15:31.705 - debug: roborock.0 (1849) getParameter: get_room_mapping
      2023-01-27 07:15:31.706 - debug: roborock.0 (1849) get_room_mapping
      2023-01-27 07:15:31.785 - debug: roborock.0 (1849) dps debug: {"id":3,"result":{"water_box_mode":202}}
      2023-01-27 07:15:31.788 - debug: roborock.0 (1849) dps debug: {"id":5,"result":[{"main_brush_work_time":314911,"side_brush_work_time":314911,"filter_work_time":314911,"filter_element_work_time":0,"sensor_dirty_time":93051,"strainer_work_times":112,"dust_collection_work_times":172,"cleaning_brush_work_times":266}]}
      2023-01-27 07:15:31.791 - debug: roborock.0 (1849) dps debug: {"id":1,"result":[300]}
      2023-01-27 07:15:31.793 - debug: roborock.0 (1849) dps debug: {"id":9,"result":"unknown_method"}
      2023-01-27 07:15:31.794 - debug: roborock.0 (1849) Unknown parameter: "unknown_method"
      2023-01-27 07:15:31.800 - debug: roborock.0 (1849) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":498,"state":8,"battery":100,"clean_time":19,"clean_area":155000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}]}
      2023-01-27 07:15:31.814 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.815 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.817 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.818 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.819 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.820 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.821 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.822 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.823 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.823 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.824 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.825 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.826 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.827 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.back_type" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.828 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_phase" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.829 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_ready" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.830 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.831 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.831 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.832 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.833 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.834 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.835 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.836 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.837 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.838 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.839 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.839 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.840 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.841 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.switch_map_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.842 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.852 - debug: roborock.0 (1849) dps debug: {"id":6,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"cc:ce:1e:2b:39:8c","rssi":-75}}
      2023-01-27 07:15:31.866 - debug: roborock.0 (1849) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":499,"state":8,"battery":100,"clean_time":19,"clean_area":155000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1}]}
      2023-01-27 07:15:31.870 - debug: roborock.0 (1849) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
      2023-01-27 07:15:31.872 - debug: roborock.0 (1849) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
      2023-01-27 07:15:31.875 - debug: roborock.0 (1849) dps debug: {"id":7,"result":{"clean_time":314911,"clean_area":5200022500,"clean_count":256,"dust_collection_count":172,"records":[1674754825,1674742452,1674729983,1674669094,1674664205,1674664145,1674663820,1674663752,1674663532,1674663218,1674662179,1674662106,1674661947,1674661250,1674587117,1674582931,1674582605,1674577286,1674558275,1674554746]}}
      2023-01-27 07:15:31.905 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.charge_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.912 - debug: roborock.0 (1849) dps debug: {"id":12,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
      2023-01-27 07:15:31.913 - debug: roborock.0 (1849) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
      2023-01-27 07:15:31.915 - debug: roborock.0 (1849) dps debug: {"id":11,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1674743903,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
      2023-01-27 07:15:31.924 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.927 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.929 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.929 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.930 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.931 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.932 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.945 - debug: roborock.0 (1849) dps debug: {"id":23,"result":[{"begin":1674662179,"end":1674662208,"duration":29,"area":410000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.950 - debug: roborock.0 (1849) dps debug: {"id":18,"result":[{"begin":1674664145,"end":1674664166,"duration":21,"area":452500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.953 - debug: roborock.0 (1849) dps debug: {"id":14,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:31.956 - debug: roborock.0 (1849) dps debug: {"id":13,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.958 - debug: roborock.0 (1849) dps debug: {"id":16,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
      2023-01-27 07:15:31.963 - debug: roborock.0 (1849) dps debug: {"id":20,"result":[{"begin":1674663752,"end":1674663777,"duration":25,"area":662500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.966 - debug: roborock.0 (1849) dps debug: {"id":17,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.968 - debug: roborock.0 (1849) dps debug: {"id":25,"result":[{"begin":1674661947,"end":1674661968,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.971 - debug: roborock.0 (1849) dps debug: {"id":24,"result":[{"begin":1674662106,"end":1674662127,"duration":21,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.973 - debug: roborock.0 (1849) dps debug: {"id":19,"result":[{"begin":1674663820,"end":1674663840,"duration":20,"area":467500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.976 - debug: roborock.0 (1849) dps debug: {"id":15,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:31.978 - debug: roborock.0 (1849) dps debug: {"id":21,"result":[{"begin":1674663532,"end":1674663569,"duration":37,"area":885000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:31.980 - debug: roborock.0 (1849) dps debug: {"id":22,"result":[{"begin":1674663218,"end":1674663240,"duration":22,"area":420000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:31.981 - debug: roborock.0 (1849) dps debug: {"id":27,"result":[{"begin":1674587117,"end":1674587629,"duration":512,"area":5695000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:31.987 - debug: roborock.0 (1849) dps debug: {"id":30,"result":[{"begin":1674577286,"end":1674577646,"duration":221,"area":3375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
      2023-01-27 07:15:31.989 - debug: roborock.0 (1849) dps debug: {"id":28,"result":[{"begin":1674582931,"end":1674584850,"duration":1919,"area":40270000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:31.992 - debug: roborock.0 (1849) dps debug: {"id":26,"result":[{"begin":1674661250,"end":1674661308,"duration":14,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0,"wash_count":1}]}
      2023-01-27 07:15:31.994 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.995 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.996 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.996 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.997 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.back_type" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.998 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_phase" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:31.999 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.wash_ready" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.000 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.001 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.002 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.003 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.004 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.004 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.005 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.006 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.007 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.008 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.008 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.009 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.010 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.011 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.switch_map_mode" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.011 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.012 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.charge_status" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.097 - debug: roborock.0 (1849) dps debug: {"id":32,"result":[{"begin":1674554746,"end":1674556140,"duration":1394,"area":20745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":1}]}
      2023-01-27 07:15:32.100 - debug: roborock.0 (1849) dps debug: {"id":31,"result":[{"begin":1674558275,"end":1674559264,"duration":989,"area":11415000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
      2023-01-27 07:15:32.102 - debug: roborock.0 (1849) dps debug: {"id":29,"result":[{"begin":1674582605,"end":1674582695,"duration":90,"area":3110000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1,"wash_count":0}]}
      2023-01-27 07:15:32.116 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.10.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.118 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.5.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.120 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.1.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.123 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.0.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.125 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.3.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.127 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.7.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.129 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.4.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.130 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.12.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.132 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.11.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.134 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.6.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.136 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.2.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.138 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.8.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.140 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.9.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.143 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.14.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.145 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.17.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.148 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.15.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.150 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.13.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.215 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.19.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.217 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.18.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.228 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.cleaningInfo.Records.16.wash_count" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.472 - debug: roborock.0 (1849) deviceStatus 120 set with value: 0
      2023-01-27 07:15:32.476 - debug: roborock.0 (1849) deviceStatus 121 set with value: 8
      2023-01-27 07:15:32.481 - debug: roborock.0 (1849) deviceStatus 122 set with value: 100
      2023-01-27 07:15:32.485 - debug: roborock.0 (1849) deviceStatus 123 set with value: 102
      2023-01-27 07:15:32.489 - debug: roborock.0 (1849) deviceStatus 124 set with value: 202
      2023-01-27 07:15:32.494 - debug: roborock.0 (1849) deviceStatus 125 set with value: 71
      2023-01-27 07:15:32.498 - debug: roborock.0 (1849) deviceStatus 126 set with value: 57
      2023-01-27 07:15:32.502 - debug: roborock.0 (1849) deviceStatus 127 set with value: 42
      2023-01-27 07:15:32.507 - debug: roborock.0 (1849) deviceStatus 128 set with value: 0
      2023-01-27 07:15:32.509 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.128" has no existing object, this might lead to an error in future versions
      2023-01-27 07:15:32.558 - debug: roborock.0 (1849) deviceStatus 133 set with value: 1
      2023-01-27 07:15:32.560 - warn: roborock.0 (1849) State "roborock.0.Devices.5Im6TX0cm6mgxaWxHaEos7.deviceStatus.133" has no existing object, this might lead to an error in future versions
      127 = Filter
      126 = Seitenbürste
      125 = Hauptbürste
      muss noch zugeordnet werden.
      Bei 120 bis 124 habe ich noch keine Ahnung, was das sein könnte.
      • wendy2702
        @copystring sagte in Roborock Adapter tester gesucht:
        https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
        Habe auch gerade mal komplett gelöscht und neu installiert. So sieht das log aus:
        2023-01-27 09:11:45.094  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1075557
        2023-01-27 09:11:46.186  - debug: roborock.0 (1075557) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2023-01-27 09:11:46.247  - debug: roborock.0 (1075557) Objects client ready ... initialize now
        2023-01-27 09:11:46.252  - debug: roborock.0 (1075557) Objects create System PubSub Client
        2023-01-27 09:11:46.253  - debug: roborock.0 (1075557) Objects create User PubSub Client
        2023-01-27 09:11:46.331  - debug: roborock.0 (1075557) Objects client initialize lua scripts
        2023-01-27 09:11:46.334  - debug: roborock.0 (1075557) Objects connected to redis: 0.0.0.0:9001
        2023-01-27 09:11:46.369  - debug: roborock.0 (1075557) Redis States: Use Redis connection: 0.0.0.0:9000
        2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create System PubSub Client
        2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create User PubSub Client
        2023-01-27 09:11:46.493  - debug: roborock.0 (1075557) States connected to redis: 0.0.0.0:9000
        2023-01-27 09:11:46.769  - info: roborock.0 (1075557) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 09:11:46.912  - debug: roborock.0 (1075557) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
        2023-01-27 09:11:46.940  - info: roborock.0 (1075557) MQTT initialized
        2023-01-27 09:11:46.953  - debug: roborock.0 (1075557) Robot key: roborock.vacuum.a15
        2023-01-27 09:11:47.081  - debug: roborock.0 (1075557) Latest data requested
        2023-01-27 09:11:47.083  - debug: roborock.0 (1075557) getParameter: get_mop_mode
        2023-01-27 09:11:47.085  - debug: roborock.0 (1075557) getParameter: get_water_box_custom_mode
        2023-01-27 09:11:47.086  - debug: roborock.0 (1075557) getParameter: get_status
        2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_consumable
        2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_network_info
        2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_mode
        2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_cleaning_mode
        2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_fw_features
        2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) Firmware features request
        2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_multi_maps_list
        2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) getParameter: get_room_mapping
        2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) get_room_mapping
        2023-01-27 09:11:47.146  - debug: roborock.0 (1075557) dps debug: {"id":3,"result":[203]}
        2023-01-27 09:11:47.147  - debug: roborock.0 (1075557) dps debug: {"id":5,"result":[{"main_brush_work_time":581958,"side_brush_work_time":581958,"filter_work_time":36866,"filter_element_work_time":0,"sensor_dirty_time":50176,"dust_collection_work_times":26}]}
        2023-01-27 09:11:47.207  - debug: roborock.0 (1075557) dps debug: {"id":6,"result":{"ssid":"WXXXXXXXSOHO","ip":"192.168.178.73","mac":"b0XXX:72","bssid":"76:83:c2:9a:11:5d","rssi":-64}}
        2023-01-27 09:11:47.214  - debug: roborock.0 (1075557) dps debug: {"id":1,"result":[302]}
        2023-01-27 09:11:47.215  - debug: roborock.0 (1075557) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
        2023-01-27 09:11:47.216  - debug: roborock.0 (1075557) dps debug: {"id":7,"result":{"clean_time":581938,"clean_area":8566392500,"clean_count":355,"dust_collection_count":292,"records":[1674660336,1674660313,1674577216,1674310611,1673963198,1673962557,1673625667,1673624409,1673450020,1673279186,1673177137,1673177094,1672931751,1672839102,1672839052,1672676949,1672483666,1671550852,1671550717,1671292694]}}
        2023-01-27 09:11:47.223  - debug: roborock.0 (1075557) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1311,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
        2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) dps debug: {"id":12,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
        2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
        2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674662405,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
        2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":9,"result":"unknown_method"}
        2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) Unknown parameter: "unknown_method"
        2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
        2023-01-27 09:11:47.230  - debug: roborock.0 (1075557) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1312,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
        2023-01-27 09:11:47.233  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.250  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.262  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.267  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.268  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
        2023-01-27 09:11:47.269  - debug: roborock.0 (1075557) dps debug: {"id":15,"result":[{"begin":1674577216,"end":1674583431,"duration":3658,"area":39990000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.271  - debug: roborock.0 (1075557) dps debug: {"id":13,"result":[{"begin":1674660336,"end":1674662311,"duration":1975,"area":30992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.272  - debug: roborock.0 (1075557) dps debug: {"id":14,"result":[{"begin":1674660313,"end":1674660315,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
        2023-01-27 09:11:47.273  - debug: roborock.0 (1075557) dps debug: {"id":18,"result":[{"begin":1673962557,"end":1673962598,"duration":15,"area":0,"error":0,"complete":0,"start_type":1,"clean_type":1,"finish_reason":21,"dust_collection_status":0}]}
        2023-01-27 09:11:47.274  - debug: roborock.0 (1075557) dps debug: {"id":17,"result":[{"begin":1673963198,"end":1673970437,"duration":2672,"area":37172500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":1}]}
        2023-01-27 09:11:47.293  - debug: roborock.0 (1075557) dps debug: {"id":19,"result":[{"begin":1673625667,"end":1673628366,"duration":2699,"area":39452500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":16,"result":[{"begin":1674310611,"end":1674311055,"duration":444,"area":6152500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":22,"result":[{"begin":1673279186,"end":1673280386,"duration":1200,"area":18042500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":23,"result":[{"begin":1673177137,"end":1673179722,"duration":2585,"area":36967500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":26,"result":[{"begin":1672839102,"end":1672847459,"duration":2861,"area":39335000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":28,"result":[{"begin":1672676949,"end":1672678212,"duration":1263,"area":17982500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":20,"result":[{"begin":1673624409,"end":1673624479,"duration":70,"area":1490000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
        2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":29,"result":[{"begin":1672483666,"end":1672484896,"duration":1230,"area":17945000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":21,"result":[{"begin":1673450020,"end":1673452606,"duration":2586,"area":39457500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":30,"result":[{"begin":1671550852,"end":1671553922,"duration":3062,"area":39902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.298  - debug: roborock.0 (1075557) dps debug: {"id":25,"result":[{"begin":1672931751,"end":1672934471,"duration":2720,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.301  - debug: roborock.0 (1075557) dps debug: {"id":27,"result":[{"begin":1672839052,"end":1672839065,"duration":13,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
        2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":32,"result":[{"begin":1671292694,"end":1671294598,"duration":1904,"area":27470000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
        2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":31,"result":[{"begin":1671550717,"end":1671550797,"duration":80,"area":1050000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
        2023-01-27 09:11:47.303  - debug: roborock.0 (1075557) dps debug: {"id":24,"result":[{"begin":1673177094,"end":1673177102,"duration":8,"area":0,"error":0,"complete":0,"start_type":4,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
        2023-01-27 09:11:48.417  - debug: roborock.0 (1075557) deviceStatus 120 set with value: 0
        2023-01-27 09:11:48.423  - debug: roborock.0 (1075557) deviceStatus 121 set with value: 8
        2023-01-27 09:11:48.426  - debug: roborock.0 (1075557) deviceStatus 122 set with value: 100
        2023-01-27 09:11:48.430  - debug: roborock.0 (1075557) deviceStatus 123 set with value: 104
        2023-01-27 09:11:48.433  - debug: roborock.0 (1075557) deviceStatus 124 set with value: 203
        2023-01-27 09:11:48.437  - debug: roborock.0 (1075557) deviceStatus 125 set with value: 47
        2023-01-27 09:11:48.440  - debug: roborock.0 (1075557) deviceStatus 126 set with value: 20
        2023-01-27 09:11:48.446  - debug: roborock.0 (1075557) deviceStatus 127 set with value: 94
        So die Objekte:
        Gibt es in der API eine Übersicht was die "8" bei Device State bedeutet? Bei Xiaomi war es "Lädt"
        • copystring
          copystring last edited by
          Danke für die vielen logs. Ich habe schon ein paar gute Ideen und werde die sehr wahrscheinlich am Wochenende umsetzen können.
          Black Thunder 1 Reply Last reply Reply Quote 0
          • Black Thunder
            Black Thunder Developer @copystring last edited by
            @copystring Weiß zwar nicht, ob du es vielleicht schon selbst rausgefunden hast, aber ich konnte mein Absturzproblem beim Absetzen von Kommandos lösen. Und zwar funktioniert die Art, wie du das Extrahieren der Device-ID aus dem State implementiert hast, in meinem Fall nicht sauber. Meine Device-ID ist 21 Stellen lang, dein Code geht aber fix von 22 Stellen aus. Deswegen kommt es zu der Exception beim Zugriff auf das "vacuums"-Array.
            Hab dir gerade mal auf GitHub einen PR als Vorschlag geschickt, wie man das lösen könnte, ohne eine fixe Länge zu erwarten. Kannst dir ja mal bei Gelegenheit angucken. 😉
            • O
              oxident @Black Thunder last edited by
              @black-thunder @copystring Ich habe mal den Branch nach dem Merge des PR getestet und leider mit meinen S7 Max ProV keinen Erfolg gehabt:
              host.iobroker
              2023-01-28 12:39:50.439	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              roborock.0
              2023-01-28 12:39:50.000	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.924	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.923	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.923	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.921	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.920	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.919	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.918	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.917	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.916	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.915	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.886	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.884	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.881	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.878	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.877	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.875	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.872	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.869	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.861	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.847	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
              roborock.0
              2023-01-28 12:39:49.846	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
              roborock.0
              2023-01-28 12:39:49.844	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
              roborock.0
              2023-01-28 12:39:49.819	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
              roborock.0
              2023-01-28 12:39:49.817	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-01-28 12:39:49.816	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-01-28 12:39:49.807	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-61}}
              roborock.0
              2023-01-28 12:39:49.804	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
              roborock.0
              2023-01-28 12:39:49.794	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
              roborock.0
              2023-01-28 12:39:49.791	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
              roborock.0
              2023-01-28 12:39:49.789	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
              roborock.0
              2023-01-28 12:39:49.774	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
              roborock.0
              2023-01-28 12:39:49.765	error	Cannot read properties of undefined (reading 'divider')
              roborock.0
              2023-01-28 12:39:49.764	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
              roborock.0
              2023-01-28 12:39:49.764	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
              roborock.0
              2023-01-28 12:39:49.763	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-01-28 12:39:49.759	debug	get_status: {"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
              roborock.0
              2023-01-28 12:39:49.757	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
              roborock.0
              2023-01-28 12:39:49.691	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-01-28 12:39:49.690	info	terminating
              roborock.0
              2023-01-28 12:39:49.683	error	Cannot read properties of undefined (reading 'model')
              roborock.0
              2023-01-28 12:39:49.682	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
              roborock.0
              2023-01-28 12:39:49.681	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
              roborock.0
              2023-01-28 12:39:49.680	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-01-28 12:39:49.676	debug	get_room_mapping
              roborock.0
              2023-01-28 12:39:49.675	debug	getParameter: get_room_mapping
              roborock.0
              2023-01-28 12:39:49.673	debug	getParameter: get_multi_maps_list
              roborock.0
              2023-01-28 12:39:49.672	debug	Firmware features request
              roborock.0
              2023-01-28 12:39:49.672	debug	getParameter: get_fw_features
              roborock.0
              2023-01-28 12:39:49.670	debug	getParameter: get_carpet_clean_mode
              roborock.0
              2023-01-28 12:39:49.668	debug	getParameter: get_carpet_mode
              roborock.0
              2023-01-28 12:39:49.666	debug	getParameter: get_network_info
              roborock.0
              2023-01-28 12:39:49.664	debug	getParameter: get_consumable
              roborock.0
              2023-01-28 12:39:49.663	debug	getParameter: get_water_box_custom_mode
              roborock.0
              2023-01-28 12:39:49.657	debug	getParameter: get_status
              roborock.0
              2023-01-28 12:39:49.655	debug	Latest data requested
              roborock.0
              2023-01-28 12:39:49.227	debug	Robot key: roborock.vacuum.a27
              roborock.0
              2023-01-28 12:39:49.222	info	MQTT initialized
              roborock.0
              2023-01-28 12:39:49.135	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              2023-01-28 12:39:48.829	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
              roborock.0
              2023-01-28 12:39:48.544	debug	States connected to redis: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:48.532	debug	States create User PubSub Client
              roborock.0
              2023-01-28 12:39:48.530	debug	States create System PubSub Client
              roborock.0
              2023-01-28 12:39:48.514	debug	Redis States: Use Redis connection: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:48.481	debug	Objects connected to redis: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:48.474	debug	Objects client initialize lua scripts
              roborock.0
              2023-01-28 12:39:48.034	debug	Objects create User PubSub Client
              roborock.0
              2023-01-28 12:39:48.033	debug	Objects create System PubSub Client
              roborock.0
              2023-01-28 12:39:48.031	debug	Objects client ready ... initialize now
              roborock.0
              2023-01-28 12:39:47.999	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
              host.iobroker
              2023-01-28 12:39:40.788	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              roborock.0
              2023-01-28 12:39:40.407	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.406	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.404	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.402	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.346	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.343	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.342	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.339	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.336	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.335	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.333	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.330	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.329	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.325	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.324	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.322	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.320	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.317	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.302	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.298	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.263	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-01-28 12:39:40.262	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
              roborock.0
              2023-01-28 12:39:40.255	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
              roborock.0
              2023-01-28 12:39:40.253	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
              roborock.0
              2023-01-28 12:39:40.252	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
              roborock.0
              2023-01-28 12:39:40.241	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
              roborock.0
              2023-01-28 12:39:40.239	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-62}}
              roborock.0
              2023-01-28 12:39:40.237	error	Cannot read properties of undefined (reading 'divider')
              roborock.0
              2023-01-28 12:39:40.236	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
              roborock.0
              2023-01-28 12:39:40.236	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
              roborock.0
              2023-01-28 12:39:40.235	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-01-28 12:39:40.232	debug	get_status: {"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
              roborock.0
              2023-01-28 12:39:40.231	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
              roborock.0
              2023-01-28 12:39:40.229	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
              roborock.0
              2023-01-28 12:39:40.227	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
              roborock.0
              2023-01-28 12:39:40.225	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
              roborock.0
              2023-01-28 12:39:40.221	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
              roborock.0
              2023-01-28 12:39:40.199	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
              roborock.0
              2023-01-28 12:39:40.096	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2023-01-28 12:39:40.095	info	terminating
              roborock.0
              2023-01-28 12:39:40.091	error	Cannot read properties of undefined (reading 'model')
              roborock.0
              2023-01-28 12:39:40.091	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
              roborock.0
              2023-01-28 12:39:40.091	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
              roborock.0
              2023-01-28 12:39:40.090	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              roborock.0
              2023-01-28 12:39:40.088	debug	get_room_mapping
              roborock.0
              2023-01-28 12:39:40.088	debug	getParameter: get_room_mapping
              roborock.0
              2023-01-28 12:39:40.087	debug	getParameter: get_multi_maps_list
              roborock.0
              2023-01-28 12:39:40.087	debug	Firmware features request
              roborock.0
              2023-01-28 12:39:40.086	debug	getParameter: get_fw_features
              roborock.0
              2023-01-28 12:39:40.086	debug	getParameter: get_carpet_clean_mode
              roborock.0
              2023-01-28 12:39:40.085	debug	getParameter: get_carpet_mode
              roborock.0
              2023-01-28 12:39:40.084	debug	getParameter: get_network_info
              roborock.0
              2023-01-28 12:39:40.083	debug	getParameter: get_consumable
              roborock.0
              2023-01-28 12:39:40.082	debug	getParameter: get_water_box_custom_mode
              roborock.0
              2023-01-28 12:39:40.079	debug	getParameter: get_status
              roborock.0
              2023-01-28 12:39:40.078	debug	Latest data requested
              roborock.0
              2023-01-28 12:39:39.756	debug	Robot key: roborock.vacuum.a27
              roborock.0
              2023-01-28 12:39:39.752	info	MQTT initialized
              roborock.0
              2023-01-28 12:39:39.655	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
              roborock.0
              2023-01-28 12:39:39.390	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
              roborock.0
              2023-01-28 12:39:39.036	debug	States connected to redis: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:39.025	debug	States create User PubSub Client
              roborock.0
              2023-01-28 12:39:39.023	debug	States create System PubSub Client
              roborock.0
              2023-01-28 12:39:39.011	debug	Redis States: Use Redis connection: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:38.983	debug	Objects connected to redis: 127.0.0.1:6379
              roborock.0
              2023-01-28 12:39:38.976	debug	Objects client initialize lua scripts
              roborock.0
              2023-01-28 12:39:38.572	debug	Objects create User PubSub Client
              roborock.0
              2023-01-28 12:39:38.571	debug	Objects create System PubSub Client
              roborock.0
              2023-01-28 12:39:38.570	debug	Objects client ready ... initialize now
              • copystring
                copystring last edited by copystring
                Ich bedanke mich für das fleißige Testen! Dadurch konnte ich einen ersten alpha release erstellen.
                https://github.com/copystring/ioBroker.roborock hat jetzt einen alpha (v0.0.2-alpha.0) release. Bitte testen und bei Fehlern mit entsprechenden Log ein Issue auf Github öffnen. Die ganzen Protokolle sind mir hier zu viel geworden ich und weiß gar nicht mehr welche tatsächlich noch relevant sind.
                Es kann dadurch vorkommen, dass ihr den gleiche Fehler (@oxident) nochmal posten müsst aber nur dadurch kann ich die Fehler sauber im Blick behalten.
                wendy2702 1 Reply Last reply Reply Quote 1
                • wendy2702
                  wendy2702 @copystring last edited by
                  Danke für deine Arbeit!
                  Installiert und Issue angelegt.
                  https://github.com/copystring/ioBroker.roborock/issues/14
                  wendy2702 created this issue in copystring/ioBroker.roborock
                  closed Alpha 0.0.2 Some states are not showing data S7+ #14
                    DonToben last edited by
                    Aktuelle 0.0.5 Alpha funktioniert bei mir überhaupt nicht. Adapter startet ständig neu.
                    Wie kommt man auf einen älteren Stand? Mir wird in iobroker keine andere Version angezeigt ...
                    • wendy2702
                      wendy2702 @DonToben last edited by
                      @dontoben sagte in Roborock Adapter tester gesucht:
                      Ist 0.0.5 ein Tippfehler?
                      Vielleicht macht es Sinn wenn du @copystring das Logfile mit dem Fehler in Github zukommen lässt damit er sich das anschauen kann. Sonst wird der Fehler ja nicht behoben.
                        DonToben @wendy2702 last edited by
                        @wendy2702
                        nein ist kein Tippfehler. Ich bin gerade unterwegs. Evtl. könnte das kurz jemand anderes testen. Danke
                        wendy2702 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          @dontoben Gar nicht mitbekommen das wir schon bei 0.0.5 sind.
                          Mal testen
                          • wendy2702
                            @wendy2702
                            Version 0.0.5 läuft bei mir
                              DonToben last edited by DonToben
                              Issue zur 0.0.5 alpha auf github angelegt
                              https://github.com/copystring/ioBroker.roborock/issues/27
                              DonToben created this issue in copystring/ioBroker.roborock
                              closed 0.0.5 Adapter startet ständig neu #27
                              • wendy2702
                                @dontoben Mal Instanz und Adapter gelöscht und komplett neu installiert?
                                  simplyclever @wendy2702 last edited by
                                  @copystring Super Arbeit!
                                  Der Test Branch aus issue https://github.com/copystring/ioBroker.roborock/issues/26 funktioniert soweit, nur noch 1 Warning.
                                  Kannst Du in GitHub auflisten, welche Commands schon funktionieren?
                                  Ich kann den Roboter starten, aber stoppen oder aufladen funktioniert wohl noch nicht, oder?
                                  mbefore305 created this issue in copystring/ioBroker.roborock
                                  closed Adapter throws DB errors; terminates itself (loop); does not show rooms #26
                                  copystring 1 Reply Last reply Reply Quote 0
                                  • copystring
                                    copystring @simplyclever last edited by
                                    @simplyclever mit https://github.com/copystring/ioBroker.roborock/tree/report_unknown_attributes sollte alles laufen. Habe gerad eben noch einen Fehler behoben. Dadurch laufen jetzt wieder alle commands.
                                    S wendy2702 2 Replies Last reply Reply Quote 0
                                      simplyclever @copystring last edited by
                                      @copystring Ja, funktioniert.
                                      • wendy2702
                                        @copystring machst du das wieder in eine Alpha?
                                        • copystring
                                          copystring @wendy2702 last edited by
                                          @wendy2702 ja heute Abend. Ein Ticket ist noch offen. Wenn keine weiteren Fehler auftreten mache ich heute Abend 0.0.6 daraus.
                                          O wendy2702 2 Replies Last reply Reply Quote 0
                                          • O
                                            oxident @copystring last edited by
                                            @copystring
                                            https://github.com/copystring/ioBroker.roborock/issues/21
                                            Das war mein's ... und ist erledigt!
                                            Danke 😉
                                            kopierschnitte created this issue in copystring/ioBroker.roborock
                                            closed Adapter crash with two S7 MaxV devices #21
                                            766
                                            242405
