    4. Paradigma SystaService LAN ModBus Kommunikation?
      acidsubway last edited by
      doch noch was hinbekommen
      lobo 1 Reply Last reply Reply Quote 0
      • lobo
        lobo @acidsubway last edited by
        @acidsubway
        Hi, könntest du mal bitte deine modbus adapter einstellungen teilen?
        Ich seh bei mir im log nur:
        modbus.0	2021-02-03 23:54:44.937	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:54:44.937	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:54:36.144	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
        modbus.0	2021-02-03 23:53:44.900	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:53:44.900	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:52:44.865	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:52:44.865	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:51:44.830	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:51:44.829	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:50:44.794	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:50:44.793	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:49:44.760	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:49:44.759	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:48:53.966	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
        modbus.0	2021-02-03 23:48:44.724	info	(60626) Disconnected from slave 192.168.30.27
        modbus.0	2021-02-03 23:48:44.723	info	(60626) Connected to slave 192.168.30.27
        modbus.0	2021-02-03 23:48:09.537	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
        modbus.0	2021-02-03 23:48:00.814	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
        modbus.0	2021-02-03 23:47:44.688	info	(60626) Disconnected from slave 192.168.30.27
          acidsubway @lobo last edited by
          @lobo
          2021-02-07 19_53_29-instances - ioBroker.jpg 2021-02-07 19_53_20-instances - ioBroker.jpg 2021-02-07 19_53_10-instances - ioBroker.jpg
            MarcusF @acidsubway last edited by
            @acidsubway Hallo ich habe die gleiche Ausgangslage bekomme aber anscheinend keine Daten rein.
            gibt es noch was spezielles zu beachten? Danke und Gruß
              MarcusF @MarcusF last edited by
              @marcusf Ergänzung anscheinen verliert mein Adapter die Verbindung
                ReinWei @MarcusF last edited by
                @marcusf Ich bekomme den Systa_II Regler im Frühjahr geliefert und möchte diesen auch über ModBus an IOBroker anbinden. Gibt es zu Deinem Problem eine Lösung oder weitere Informationen? Danke und Gruß
                  MarcusF @ReinWei last edited by
                  @reinwei Hallo ReinWei, leider habe ich hier selbst noch keine Lösung gefunden. Und eine Antwort oder Hilfestellung bisher auch nicht. Gruß Marcus
                  wendy2702 R 2 Replies Last reply Reply Quote 0
                  • wendy2702
                    wendy2702 @MarcusF last edited by
                    @marcusf Ist das ein TCP Modbus device oder hängt da ein Adapter zwischen?
                    Stelle das Loggen mal auf Debug und poste die Ausgabe als Text in Code Tags </>
                      @marcusf Hast du dieses Dokument?TH-3000_V1.1_0321_SystaComfort_II_CompactC_Modbus_Informationen_B_Fhw.pdf
                        MarcusF @wendy2702 last edited by Homoran
                        @wendy2702 Vielen Dank für deine Antwort.
                        das Log findest du unten.
                        Zur Info: Ich habe eine SystaComfort der ersten generation und das SystaService Lan Module am Bus der SystaComfort angeschlossen. Des weiteren hängt an dem Bus die SystaSolar (I) und ein SystaAqua II
                        Vielen Dank für die Unterstützung
                        Marcus
                        Mit der Software SystaService V. 1.60
                        SystaService 1.60 Log
                        11:59 4:08:400 - 0.000: 0F 04 01 00 00 E5
                        11:59 4:08:410 - 0.010: 10 02 05 00
                        11:59 4:08:490 - 0.080: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:08:510 - 0.020: 0F 04 01 00 00 E5
                        11:59 4:08:600 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:08:620 - 0.020: 0F 04 01 00 00 E5
                        11:59 4:08:710 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:08:730 - 0.020: 0F 04 01 00 00 E5
                        11:59 4:08:820 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:08:840 - 0.020: 0F 04 01 00 00 E5
                        11:59 4:08:850 - 0.010: 15 01 02
                        11:59 4:08:930 - 0.080: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:08:950 - 0.020: 0F 04 01 00 00 E5
                        11:59 4:08:970 - 0.020: 0B 10 10 12 08 29 01 02 07 02 58 01 FC 01 01 D5 02 06
                        11:59 4:09:000 - 0.030: 0B 11 10 00 01 A7 00 00 00 00 00 00 00 01 01 F2 02 02 02
                        11:59 4:09:050 - 0.050: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:060 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:070 - 0.010: 0B 01 13
                        11:59 4:09:120 - 0.050: FC 24 0B 01 01 A7 01 18 01 6C FE D9 00 00 02 00 02 0F 12 08 29 01 00 00 00 00 00 00 00 01 01 F2 22 00 00 00 00 00
                        11:59 4:09:210 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:220 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:230 - 0.010: 23 01 D0
                        11:59 4:09:320 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:330 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:430 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:440 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:450 - 0.010: 11 02 05 00
                        11:59 4:09:540 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:550 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:650 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:660 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:760 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:770 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:870 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:880 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:09:980 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        11:59 4:09:990 - 0.010: 0F 04 01 00 00 E5
                        11:59 4:10:010 - 0.020: 14 09 10 02 D8 20 ED 02 44 01 01
                        11:59 4:10:030 - 0.020: 14 08 10 00 01 02 58 02 00 04
                        11:59 4:10:090 - 0.060: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                        < **ioBroker Log mit Debug für Modbus**
                        2023-01-29 12:02:45.729 - info: host.buanet-iobroker stopInstance system.adapter.modbus.0 send kill signal
                        2023-01-29 12:02:46.279 - info: host.buanet-iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-01-29 12:02:46.802 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:47.219 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:02:48.769 - info: host.buanet-iobroker instance system.adapter.modbus.0 started with pid 20930
                        2023-01-29 12:02:48.990 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:49.121 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:02:50.099 - debug: modbus.0 (20930) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-01-29 12:02:50.151 - debug: modbus.0 (20930) Objects client ready ... initialize now
                        2023-01-29 12:02:50.154 - debug: modbus.0 (20930) Objects create System PubSub Client
                        2023-01-29 12:02:50.155 - debug: modbus.0 (20930) Objects create User PubSub Client
                        2023-01-29 12:02:50.184 - debug: modbus.0 (20930) Objects client initialize lua scripts
                        2023-01-29 12:02:50.191 - debug: modbus.0 (20930) Objects connected to redis: 127.0.0.1:9001
                        2023-01-29 12:02:50.217 - debug: modbus.0 (20930) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-01-29 12:02:50.226 - debug: modbus.0 (20930) States create System PubSub Client
                        2023-01-29 12:02:50.228 - debug: modbus.0 (20930) States create User PubSub Client
                        2023-01-29 12:02:50.240 - debug: modbus.0 (20930) States connected to redis: 127.0.0.1:9000
                        2023-01-29 12:02:50.278 - debug: modbus.0 (20930) Plugin sentry Initialize Plugin (enabled=true)
                        2023-01-29 12:02:50.606 - info: modbus.0 (20930) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
                        2023-01-29 12:02:50.891 - debug: modbus.0 (20930) Initialize Objects for disInputs: []
                        2023-01-29 12:02:50.892 - debug: modbus.0 (20930) Initialize Objects for coils: []
                        2023-01-29 12:02:50.892 - debug: modbus.0 (20930) Initialize Objects for inputRegs: [{"_address":77,"deviceId":1,"name":"Test","description":"Test","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":77,"id":"inputRegisters.1.77_Test"},{"_address":4002,"name":"SpeichertempOben","description":"Speicher oben TW","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":true,"isScale":false,"address":4002,"deviceId":1,"id":"inputRegisters.1.4002_SpeichertempOben"},{"_address":4003,"name":"","description":"Solar Vorlauf","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4003,"deviceId":1,"id":"inputRegisters.1.4003"},{"_address":4012,"name":"","description":"Volumenstrom VF","unit":"l/min","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4012,"deviceId":1,"id":"inputRegisters.1.4012"},{"_address":4013,"name":"","description":"Solar Rücklauf","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4013,"deviceId":1,"id":"inputRegisters.1.4013"},{"_address":4016,"name":"","description":"Außentemperatur Kollector","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4016,"deviceId":1,"id":"inputRegisters.1.4016"},{"_address":4018,"name":"","description":"Temperatur Kollerktor","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4018,"deviceId":1,"id":"inputRegisters.1.4018"},{"_address":4027,"name":"","description":"Kollektorleistung","unit":"KW","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4027,"deviceId":1,"id":"inputRegisters.1.4027"}]
                        2023-01-29 12:02:50.894 - debug: modbus.0 (20930) Add inputRegisters.1.77_Test: {"_id":"inputRegisters.1.77_Test","type":"state","common":{"name":"Test","role":"value","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":77,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.894 - debug: modbus.0 (20930) Add inputRegisters.1.4002_SpeichertempOben: {"_id":"inputRegisters.1.4002_SpeichertempOben","type":"state","common":{"name":"Speicher oben TW","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4002,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.895 - debug: modbus.0 (20930) Add inputRegisters.1.4003: {"_id":"inputRegisters.1.4003","type":"state","common":{"name":"Solar Vorlauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4003,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.895 - debug: modbus.0 (20930) Add inputRegisters.1.4012: {"_id":"inputRegisters.1.4012","type":"state","common":{"name":"Volumenstrom VF","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"l/min"},"native":{"regType":"inputRegs","address":4012,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.896 - debug: modbus.0 (20930) Add inputRegisters.1.4013: {"_id":"inputRegisters.1.4013","type":"state","common":{"name":"Solar Rücklauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4013,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.897 - debug: modbus.0 (20930) Add inputRegisters.1.4016: {"_id":"inputRegisters.1.4016","type":"state","common":{"name":"Außentemperatur Kollector","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4016,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.897 - debug: modbus.0 (20930) Add inputRegisters.1.4018: {"_id":"inputRegisters.1.4018","type":"state","common":{"name":"Temperatur Kollerktor","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4018,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.898 - debug: modbus.0 (20930) Add inputRegisters.1.4027: {"_id":"inputRegisters.1.4027","type":"state","common":{"name":"Kollektorleistung","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"KW"},"native":{"regType":"inputRegs","address":4027,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1}}
                        2023-01-29 12:02:50.899 - debug: modbus.0 (20930) Initialize Objects for holdingRegs: [{"_address":4004,"name":"","description":"Sollwert Einspeisen Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":false,"isScale":"","address":4004,"deviceId":1,"id":"holdingRegisters.1.4004"},{"_address":4006,"name":"","description":"Maximal Temperatur Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4006,"deviceId":1,"id":"holdingRegisters.1.4006"},{"_address":4010,"name":"","description":"Solargewinn Tag","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4010,"deviceId":1,"id":"holdingRegisters.1.4010"},{"_address":4012,"name":"","description":"Solargewinn Gesamt","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4012,"deviceId":1,"id":"holdingRegisters.1.4012"}]
                        2023-01-29 12:02:50.899 - debug: modbus.0 (20930) Add holdingRegisters.1.4004: {"_id":"holdingRegisters.1.4004","type":"state","common":{"name":"Sollwert Einspeisen Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4004,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                        2023-01-29 12:02:50.900 - debug: modbus.0 (20930) Add holdingRegisters.1.4006: {"_id":"holdingRegisters.1.4006","type":"state","common":{"name":"Maximal Temperatur Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4006,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                        2023-01-29 12:02:50.900 - debug: modbus.0 (20930) Add holdingRegisters.1.4010: {"_id":"holdingRegisters.1.4010","type":"state","common":{"name":"Solargewinn Tag","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4010,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                        2023-01-29 12:02:50.901 - debug: modbus.0 (20930) Add holdingRegisters.1.4012: {"_id":"holdingRegisters.1.4012","type":"state","common":{"name":"Solargewinn Gesamt","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4012,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                        2023-01-29 12:02:50.993 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:51.421 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:02:51.915 - info: modbus.0 (20930) Connected to slave 192.168.0.186
                        2023-01-29 12:02:51.916 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:02:51.918 - debug: modbus.0 (20930) Initialization of scale factors done!
                        2023-01-29 12:02:51.919 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:02:51.936 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:02:52.869 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:52.938 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:02:52.943 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:02:53.835 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:02:54.946 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:02:54.950 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:02:54.971 - info: smartmeter.0 (511) Received 7 values, 2 updated
                        2023-01-29 12:02:56.667 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:02:57.057 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:58.004 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:02:58.004 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:02:58.016 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:02:58.948 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:02:59.017 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:02:59.025 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:02:59.227 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:00.841 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:01.025 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:01.032 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:01.391 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:03.129 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:03.337 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:04.084 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:04.085 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:04.088 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:05.013 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:05.089 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:05.097 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:05.394 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:06.898 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:07.100 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:07.104 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:07.735 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:08.988 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:10.008 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:10.156 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:10.156 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:10.160 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:10.873 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:11.160 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:11.168 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:12.142 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:12.970 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:13.170 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:13.175 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:14.401 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:15.056 - info: smartmeter.0 (511) Received 7 values, 2 updated
                        2023-01-29 12:03:16.227 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:16.228 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:16.230 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:16.614 - info: smartmeter.1 (526) Received 10 values, 2 updated
                        2023-01-29 12:03:16.941 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:17.231 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:17.239 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:18.831 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:18.884 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:19.241 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:19.246 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:21.011 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:21.023 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:22.296 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:22.297 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:22.302 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:22.866 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:23.127 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:23.302 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:23.311 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:24.897 - info: smartmeter.0 (511) Received 7 values, 2 updated
                        2023-01-29 12:03:25.232 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:25.312 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:25.317 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:26.782 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:27.536 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:28.371 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:28.371 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:28.374 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:29.084 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:29.374 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:29.382 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:29.887 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:30.965 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:31.384 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:31.389 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        2023-01-29 12:03:32.208 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:32.848 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:34.442 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                        2023-01-29 12:03:34.442 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                        2023-01-29 12:03:34.446 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                        2023-01-29 12:03:34.572 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:35.151 - info: smartmeter.0 (511) Received 7 values, 2 updated
                        2023-01-29 12:03:35.446 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                        2023-01-29 12:03:35.454 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                        2023-01-29 12:03:36.866 - info: smartmeter.0 (511) Received 7 values, 3 updated
                        2023-01-29 12:03:36.877 - info: smartmeter.1 (526) Received 10 values, 3 updated
                        2023-01-29 12:03:37.457 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                        2023-01-29 12:03:37.462 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                        wendy2702 G 2 Replies Last reply Reply Quote 0
                          @reinwei Danke für das Dokument, schaue ich mir mal an, mal sehen ob ich damit weiter kommen. Habe allerdings eine SystaComfort der ersten generation in verbindung mit dem SysService LAN Interface welches ich über den modbus Adapter grundsätzlich verbinden kann.
                          Danke und Gruß
                          Marcus
                            MarcusF @wendy2702 last edited by wendy2702
                            @wendy2702
                            Hier nochmal das Log für den Modbus Adapter aus ioBroker irgendwie habe ich das mit den Tags im ersten Reply nicht rein bekommen.
                            modbus.0
                            2023-01-29 12:26:12.709	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                            modbus.0
                            2023-01-29 12:26:12.702	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                            modbus.0
                            2023-01-29 12:26:11.701	debug	[DevID_1/inputRegs] Poll address 77 DONE
                            modbus.0
                            2023-01-29 12:26:11.699	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                            modbus.0
                            2023-01-29 12:26:11.698	debug	[DevID_1] Poll start ---------------------
                            modbus.0
                            2023-01-29 12:26:08.644	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                            modbus.0
                            2023-01-29 12:26:08.639	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                            modbus.0
                            2023-01-29 12:26:06.637	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                            modbus.0
                            2023-01-29 12:26:06.629	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                            modbus.0
                            2023-01-29 12:26:05.628	debug	[DevID_1/inputRegs] Poll address 77 DONE
                            modbus.0
                            2023-01-29 12:26:05.616	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                            modbus.0
                            2023-01-29 12:26:05.614	debug	[DevID_1] Poll start ---------------------
                            modbus.0
                            2023-01-29 12:26:02.561	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                            modbus.0
                            2023-01-29 12:26:02.557	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                            modbus.0
                            2023-01-29 12:26:00.554	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                            modbus.0
                            2023-01-29 12:26:00.547	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                            modbus.0
                            2023-01-29 12:25:59.545	debug	[DevID_1/inputRegs] Poll address 77 DONE
                            modbus.0
                            2023-01-29 12:25:59.542	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                            modbus.0
                            2023-01-29 12:25:59.541	debug	[DevID_1] Poll start ---------------------
                            modbus.0
                            2023-01-29 12:25:56.489	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                            modbus.0
                            2023-01-29 12:25:56.483	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                            modbus.0
                            2023-01-29 12:25:54.482	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                            modbus.0
                            2023-01-29 12:25:54.474	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                            modbus.0
                            2023-01-29 12:25:53.473	debug	[DevID_1/inputRegs] Poll address 77 DONE
                            modbus.0
                            2023-01-29 12:25:53.461	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                            modbus.0
                            2023-01-29 12:25:53.461	debug	[DevID_1] Poll start ---------------------
                            modbus.0
                            2023-01-29 12:25:50.408	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                            modbus.0
                            2023-01-29 12:25:50.403	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                            modbus.0
                            2023-01-29 12:25:48.400	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                            modbus.0
                            2023-01-29 12:25:48.395	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                            modbus.0
                            2023-01-29 12:25:47.392	debug	[DevID_1/inputRegs] Poll address 77 DONE
                            modbus.0
                            2023-01-29 12:25:47.375	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                            modbus.0
                            2023-01-29 12:25:47.374	debug	Initialization of scale factors done!
                            modbus.0
                            2023-01-29 12:25:47.372	debug	[DevID_1] Poll start ---------------------
                            modbus.0
                            2023-01-29 12:25:47.371	info	Connected to slave 192.168.0.186
                            modbus.0
                            2023-01-29 12:25:47.012	debug	Add holdingRegisters.1.4012: {"_id":"holdingRegisters.1.4012","type":"state","common":{"name":"Solargewinn Gesamt","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4012,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                            modbus.0
                            2023-01-29 12:25:47.012	debug	Add holdingRegisters.1.4010: {"_id":"holdingRegisters.1.4010","type":"state","common":{"name":"Solargewinn Tag","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4010,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                            modbus.0
                            2023-01-29 12:25:47.011	debug	Add holdingRegisters.1.4006: {"_id":"holdingRegisters.1.4006","type":"state","common":{"name":"Maximal Temperatur Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4006,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                            modbus.0
                            2023-01-29 12:25:47.011	debug	Add holdingRegisters.1.4004: {"_id":"holdingRegisters.1.4004","type":"state","common":{"name":"Sollwert Einspeisen Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4004,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                            modbus.0
                            2023-01-29 12:25:47.010	debug	Initialize Objects for holdingRegs: [{"_address":4004,"name":"","description":"Sollwert Einspeisen Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":false,"isScale":"","address":4004,"deviceId":1,"id":"holdingRegisters.1.4004"},{"_address":4006,"name":"","description":"Maximal Temperatur Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4006,"deviceId":1,"id":"holdingRegisters.1.4006"},{"_address":4010,"name":"","description":"Solargewinn Tag","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4010,"deviceId":1,"id":"holdingRegisters.1.4010"},{"_address":4012,"name":"","description":"Solargewinn Gesamt","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4012,"deviceId":1,"id":"holdingRegisters.1.4012"}]
                            modbus.0
                            2023-01-29 12:25:47.010	debug	Add inputRegisters.1.4027: {"_id":"inputRegisters.1.4027","type":"state","common":{"name":"Kollektorleistung","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"KW"},"native":{"regType":"inputRegs","address":4027,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.009	debug	Add inputRegisters.1.4018: {"_id":"inputRegisters.1.4018","type":"state","common":{"name":"Temperatur Kollerktor","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4018,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.008	debug	Add inputRegisters.1.4016: {"_id":"inputRegisters.1.4016","type":"state","common":{"name":"Außentemperatur Kollector","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4016,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.007	debug	Add inputRegisters.1.4013: {"_id":"inputRegisters.1.4013","type":"state","common":{"name":"Solar Rücklauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4013,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.007	debug	Add inputRegisters.1.4012: {"_id":"inputRegisters.1.4012","type":"state","common":{"name":"Volumenstrom VF","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"l/min"},"native":{"regType":"inputRegs","address":4012,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.006	debug	Add inputRegisters.1.4003: {"_id":"inputRegisters.1.4003","type":"state","common":{"name":"Solar Vorlauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4003,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.005	debug	Add inputRegisters.1.4002_SpeichertempOben: {"_id":"inputRegisters.1.4002_SpeichertempOben","type":"state","common":{"name":"Speicher oben TW","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4002,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.005	debug	Add inputRegisters.1.77_Test: {"_id":"inputRegisters.1.77_Test","type":"state","common":{"name":"Test","role":"value","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":77,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-01-29 12:25:47.003	debug	Initialize Objects for inputRegs: [{"_address":77,"deviceId":1,"name":"Test","description":"Test","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":77,"id":"inputRegisters.1.77_Test"},{"_address":4002,"name":"SpeichertempOben","description":"Speicher oben TW","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":true,"isScale":false,"address":4002,"deviceId":1,"id":"inputRegisters.1.4002_SpeichertempOben"},{"_address":4003,"name":"","description":"Solar Vorlauf","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4003,"deviceId":1,"id":"inputRegisters.1.4003"},{"_address":4012,"name":"","description":"Volumenstrom VF","unit":"l/min","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4012,"deviceId":1,"id":"inputRegisters.1.4012"},{"_address":4013,"name":"","description":"Solar Rücklauf","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4013,"deviceId":1,"id":"inputRegisters.1.4013"},{"_address":4016,"name":"","description":"Außentemperatur Kollector","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4016,"deviceId":1,"id":"inputRegisters.1.4016"},{"_address":4018,"name":"","description":"Temperatur Kollerktor","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4018,"deviceId":1,"id":"inputRegisters.1.4018"},{"_address":4027,"name":"","description":"Kollektorleistung","unit":"KW","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4027,"deviceId":1,"id":"inputRegisters.1.4027"}]
                            modbus.0
                            2023-01-29 12:25:47.003	debug	Initialize Objects for coils: []
                            MOD EDIT: LOG IN CODE TAGS </> GESETZT
                              Thomas Braun Most Active last edited by Thomas Braun
                              @marcusf sagte in Paradigma SystaService LAN ModBus Kommunikation?:
                              Dann schau dir im vom Mod für dich editierten Beitrag an wie es richtig gemacht wird. Tipp: Die Steuerzeichen bekommst du mit dem </> Icon serviert.
                              • wendy2702
                                IOB läuft im Container ?
                                Ist der Port 502 durchgereicht nach aussen?
                                  MarcusF @Thomas Braun last edited by
                                  @thomas-braun Vielen Dank hatte ich versucht doch das Log wurde im ersten Post nicht gespeichert. Versuche es beim nächsten mal. Gruß Marcus
                                    IUwendy2702 Hallo Wendy2702, ja läuft im Container auf meiner Synology. Ich habe den Port jetzt nochmal durchgereicht, doch das bringt keine Veränderung. Der Verbindungstatus war vorher auch wie im Bild.
                                    In den Objectdaten wir die Verbindung auch ausgegebenScreenshot 2023-01-30 084156.jpg
                                    info/connection = true
                                    Danke für die Unterstützung
                                    Marcus
                                    • wendy2702
                                      @marcusf Mal was ganz triviales, hast du mal anderen Browser versucht oder den Cache gelöscht bzw. Forced Reload?
                                      Welchen Zeitstempel haben die Objekte?
                                        @wendy2702 Hallo Wendy2702, auch mit anderen Browsern oder force Reload gibt es keinen Unterschied. Ich habe den Objectbaum mal gelöscht und nach neustart des Adapters wurden alle neu angelegt. Einen Zeitstemple habe ich nicht direkt gefunden, kann nur vermuten, dass er sich im TS Json des objects verbirgt.
                                        Gruß Marcus
                                        • wendy2702
                                          wendy2702 @MarcusF last edited by wendy2702
                                          @marcusf Zeitstempel sieht man wenn man mit der Maus langsam ueber das Objekt faehrt.
                                          Kannst du mal alle bis auf einen Register loeschen.
                                          Und zeig doch mal deine Register als Screenshot.
                                          Und beantworte mal diese Frage: https://forum.iobroker.net/post/930606
                                            glitzi @MarcusF last edited by
                                            @marcusf
                                            kannst du mir die Software in Version 1.6 bereitstellen? ich haben noch Version 1,56
                                            modbus paradigma systaservice lan
                                            2461
