    4. Tractive Adapter für Haustiere?
      Wildbill @Issi last edited by
      @issi Die Meldungen kommen im Minutentakt :
      2023-01-30 08:54:57.587
      warn
      State "tractive-gps.0.VGXXXKDJ.device_pos_report.course" has no existing object, this might lead to an error in future versions
      tractive-gps.0
      2023-01-30 08:54:57.577
      info
      State value to set for "tractive-gps.0.VGXXXKDJ.device_pos_report.pos_status" has to be type "string" but received type "object"
      tractive-gps.0
      2023-01-30 08:54:57.344
      warn
      State "tractive-gps.0.PBXXXSIX.tracker.hw_edition" has no existing object, this might lead to an error in future versions
      tractive-gps.0
      2023-01-30 08:54:57.181
      warn
      [Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
      tractive-gps.0
      2023-01-30 08:54:56.648
      warn
      [Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
      tractive-gps.0
      2023-01-30 08:53:55.642
      warn
      tractive-gps.0
      2023-01-30 08:53:55.581
      info
      tractive-gps.0
      2023-01-30 08:53:55.359
      warn
      tractive-gps.0
      2023-01-30 08:53:55.260
      warn
      tractive-gps.0
      2023-01-30 08:53:54.743
      warn
      tractive-gps.0
      2023-01-30 08:52:53.650
      warn
      tractive-gps.0
      2023-01-30 08:52:53.586
      info
      tractive-gps.0
      2023-01-30 08:52:53.283
      warn
      tractive-gps.0
      2023-01-30 08:52:53.150
      warn
      tractive-gps.0
      2023-01-30 08:52:52.553
      warn
      tractive-gps.0
      2023-01-30 08:51:51.360
      warn
      tractive-gps.0
      2023-01-30 08:51:51.344
      info
      tractive-gps.0
      2023-01-30 08:51:51.061
      warn
      tractive-gps.0
      2023-01-30 08:51:50.952
      warn
      tractive-gps.0
      2023-01-30 08:51:50.244
      warn
      tractive-gps.0
      2023-01-30 08:50:49.085
      warn
      tractive-gps.0
      2023-01-30 08:50:49.078
      info
      tractive-gps.0
      2023-01-30 08:50:48.875
      warn
      Die angemahnten Datenpunkte existieren auch nicht. Ich setze den Loglevel mal auf error, sonst ist ja ruck zuck das Log voll. 😊
      Was aber ankommt passt und deckt sich mit den Daten aus Homeassistant.
      Gruss, Jürgen
      Issi 1 Reply Last reply Reply Quote 0
      • Issi
        Issi Developer @Wildbill last edited by
        @wildbill
        ja, der state hw_edition war bei meinem Test Tracker nicht verfügbar, da es verschied Tracker gibt und da auch verschiedene daten zurückkommen, den werde ich heute noch einbauen.
        Und zu den anderen davon können noch mehr kommen, die muss ich alle nach einender fixen, das ist einfach nur eine Info, dass der state den falschen type hat, da von der API sehr viel mit null zurückkommt und ich nicht weiß was da für ein type eigentlich sein sollte, habe ich einfach ein Standard wert gesetzt, wenn solche Meldungen auftauchen, bitte melden.
          @issi Hier melden oder im Github-Issue mit dazu schreiben?
          Gruss, Jürgen
          Issi 2 Replies Last reply Reply Quote 0
          • Issi
            @wildbill
            GitHub bitte da sehe ich es immer hier im Forum kann, das schnell untergehen
            • Issi
              @wildbill
              kannst du mir bitte den Inhalt von der json per pm schicken? Ich will alle type der state sehen, die bei dir sind.
                @issi Meinst Du, wenn ich in iobroker unter Objekten den Baum vom Adapter im Expertenmodus exportiere und als json speichere?
                • Issi
                  @wildbill
                  W Negalein 2 Replies Last reply Reply Quote 0
                    @issi Hast PM.
                    Gruss, Jürgen
                    • Negalein
                      Negalein Global Moderator @Issi last edited by Negalein
                      @issi
                      ein paar States inkl. Beschreibung
                      tractive-gps.0.VSVLINVJ.tracker.state --> OPERATIONAL = eingeschaltet
                      tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used --> GPS = unterwegs
                      tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used --> KNOWN_WIFI = Energiesparzone
                      tractive-gps.0.VSVLINVJ.tracker.state_reason --> POWER_SAVING = Energiesparzone
                      tractive-gps.0.VSVLINVJ.tracker.power_saving_zone_id ändert sich nicht.
                      Man kann aber tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used verwenden, um zu sehen, ob Miezi oder Wufti Zuhause sind.
                      • Issi
                        Issi Developer @Negalein last edited by
                        @negalein sagte in Tractive Adapter für Haustiere?:
                        Die sollte ganz weg sein, wen das Tier aus der Energiesparzone raus ist, das hat jedenfalls der Test mit Flexer gezeigt.
                        Interessant ist es, ob sie sich bei einer anderen Energiesparzone ändert.
                        • Negalein
                          @issi sagte in Tractive Adapter für Haustiere?:
                          Ok, eventuell war es zu kurz wo er außerhalb der Zone war.
                          Ich logge mal den DP.
                          Werde zusätzlich die SSID vom Nachbarn verwenden. Kann das aber erst morgen machen.
                          • Issi
                            Issi Developer @Negalein last edited by Issi
                            @negalein
                            kein Stress bin ohnehin gerade etwas angeschlagen (Corona) und kann nicht so viel daran arbeiten
                            W Negalein H 3 Replies Last reply Reply Quote 0
                              @issi Gute Besserung. 👍
                              • Negalein
                                @issi
                                Gute Besserung. 👍
                                  homecineplexx @Issi last edited by
                                  @issi zuerst mal, super und großes danke für deine arbeit....und baldige gute besserung
                                  ich hab den adapter ebenfalls gerade zuerst installiert und da kommt einige warnings
                                  tractive-gps.0
                                  2023-01-30 10:37:45.677	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:37:45.514	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:37:45.471	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:37:45.287	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:37:44.978	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:37:44.906	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:36:44.100	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:36:43.932	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:36:43.903	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:36:43.726	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:36:43.291	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:36:43.223	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:35:42.279	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:35:42.057	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:35:41.996	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:35:41.771	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:35:41.307	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:35:41.257	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:34:40.407	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:34:40.213	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:34:40.171	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:34:39.937	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:34:39.475	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:34:39.397	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:33:38.274	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:33:38.065	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:33:38.021	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:33:37.796	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:33:37.356	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:33:37.309	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:32:36.441	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:32:36.213	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:32:36.178	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:32:36.012	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:32:35.664	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:32:35.590	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:31:34.567	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:31:34.341	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:31:34.290	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:31:33.994	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:31:33.598	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:31:33.533	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  host.ioBroker
                                  2023-01-30 10:30:38.559	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  tractive-gps.0
                                  2023-01-30 10:30:32.231	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:30:31.979	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:30:31.923	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:30:31.585	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:30:30.892	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:30:30.745	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  host.ioBroker
                                  2023-01-30 10:30:12.519	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.ioBroker
                                  2023-01-30 10:30:08.264	info	instance system.adapter.yr.0 started with pid 24261
                                  host.ioBroker
                                  2023-01-30 10:30:05.708	info	instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.ioBroker
                                  2023-01-30 10:30:04.174	info	instance system.adapter.daswetter.0 started with pid 24250
                                  host.ioBroker
                                  2023-01-30 10:30:00.116	info	instance system.adapter.meteoalarm.0 started with pid 24233
                                  tractive-gps.0
                                  2023-01-30 10:29:29.435	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:29:29.290	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:29:29.245	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:29:28.981	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:29:28.675	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:29:28.628	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:28:27.764	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:28:27.537	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:28:27.498	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:28:26.904	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:28:23.637	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:28:23.279	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:27:22.398	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:27:22.200	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:27:22.157	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:27:21.851	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:27:21.374	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:27:21.259	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:26:20.266	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:26:20.020	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:26:19.968	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:26:19.675	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:26:19.206	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:26:19.146	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:25:18.148	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:25:17.938	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:25:17.899	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:25:17.526	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:25:17.117	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:25:17.050	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:24:16.142	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:24:16.015	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:24:15.993	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:24:15.803	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:24:15.415	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:24:15.360	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:23:14.398	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:23:14.133	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:23:14.105	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:23:13.934	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:23:13.636	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:23:13.580	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:22:12.727	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:22:12.407	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:22:12.376	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:22:12.146	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:22:11.638	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:22:11.580	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  tractive-gps.0
                                  2023-01-30 10:21:10.695	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:21:10.482	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:21:10.416	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:21:10.147	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:21:09.616	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:21:09.565	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  host.ioBroker
                                  2023-01-30 10:20:47.589	info	instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                                  host.ioBroker
                                  2023-01-30 10:20:25.315	info	instance system.adapter.fuelpricemonitor.0 started with pid 24160
                                  tractive-gps.0
                                  2023-01-30 10:20:08.704	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:20:08.567	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:20:08.543	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                  tractive-gps.0
                                  2023-01-30 10:20:08.433	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                  tractive-gps.0
                                  2023-01-30 10:20:08.041	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                  tractive-gps.0
                                  2023-01-30 10:20:07.978	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                  • Issi
                                    Issi Developer @homecineplexx last edited by
                                    @homecineplexx sagte in Tractive Adapter für Haustiere?:
                                    read_only_since
                                    Schicke mir bitte entweder die json per PM oder den Inhalt von read_only_since den musst du in der json suchen den state hatte bisher noch niemand gehabt.
                                      @issi said in Tractive Adapter für Haustiere?:
                                      read_only_since
                                      ok, super schick ich dir, aber wie gesagt, es ist überhaupt nicht wichtig, schau lieber dass du gesund wirst
                                      • Issi
                                        Issi Developer last edited by
                                        Installiert bitte alle von GitHub hab ein Fix für die fehler gemacht
                                        W Negalein 2 Replies Last reply Reply Quote 1
                                          @issi Log ist gleich viel ruhiger, hab natürlich wieder auf Info gestellt. Für einen meiner zwei Tracker bekomme ich noch folgende Meldung im Log:
                                          Im Datenpunkt steht als Wert (dauerhaft, wie es scheint)
                                          ["LAST_VALID_FIX"]
                                          Beim zweiten Tracker kommt keine Meldung diesbezüglich. Der Datenpunkt existiert, enthält aber
                                          (null)
                                          Das scheint irgendwas zu sein, was der ältere der beiden Tracker gar nicht kennt.
                                          Gruss, Jürgen
                                          • Negalein
                                            0.0.1 bleibt aber gleich?
                                            Meldungen im Log sind nun viel weniger. 🙂
                                            162
                                            15069
