    4. Linux/Debian - Grafana-Repo muss aktualisiert werden
      A Former User last edited by
      Moin,
      lasst doch gut sein, es geht hier nur darum Grafana und zwischendurch auch mal influxDB nach der Singnaturänderung wieder ans Laufen zu bringen, alles andere ist vergebene Liebesmüh und bring hier gar nichts 🙂
      VG
      Bernd
      M 1 Reply Last reply Reply Quote 3
        Marty56 @Guest last edited by
        @dp20eic ganz meiner Meinung. Sorry, dass ich vom Thema abgewichen bin.
          shellyrulestheworld @Thomas Braun last edited by
          Vielen Dank für deine Beiträge. Hab auch versucht influxdb umzustellen, wie von dir beschrieben.
          Err:7 https://repos.influxdata.com/debian bullseye InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          Fetched 7,022 B in 3s (2,530 B/s)
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          klappt aber leider nicht. Hab ich was vergessen?
          mein vorgehen war folgendes:
          apt-key list | grep -i influxdb | wc -l
          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
          0
          sudo rm influxdb.list
          wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
          export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
          echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
            Thomas Braun Most Active @shellyrulestheworld last edited by Thomas Braun
            ls -lA /etc/apt/sources.list.d/
            sudo apt update
            sagt? Vollständig posten, nix weg lassen. Auch nicht das login prompt.
              @thomas-braun said in Linux/Debian - Grafana-Repo muss aktualisiert werden:
              pi@raspberrypi:~ $ ls -lA /etc/apt/sources.list.d/
              total 24
              -rw-r--r-- 1 root root  60 Dec 23 10:10 deconz.list
              -rw-r--r-- 1 root root  84 Jan 30 14:21 grafana.list
              -rw-r--r-- 1 root root 101 Jan 30 15:05 influxdb.list
              -rw-r--r-- 1 root root 208 Dec 23 09:34 nodesource.list
              -rw-r--r-- 1 root root 398 Jan 11 16:11 ookla_speedtest-cli.list
              -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
              pi@raspberrypi:~ $ sudo apt update
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
              Hit:7 https://apt.grafana.com stable InRelease
              Get:8 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
              Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
              Err:8 https://repos.influxdata.com/debian bullseye InRelease
              Fetched 7,022 B in 2s (3,282 B/s)
              pi@raspberrypi:~ $
                sudo rm /etc/apt/sources.list.d/influxdb.list
                wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                sudo apt update
                sudo apt full-upgrade
                S H 2 Replies Last reply Reply Quote 3
                  ein großes Dankeschön, läuft perfekt durch 🙂
                  Ist wirklich ein klasse Support von dir
                    darkblu last edited by
                    und wieder eine Anfänger Frage, muss ich hier auch die beiden Schlüssel von influx löschen ?
                    pi@raspberrypi:~ $ apt-key list
                    pub   rsa2048 2012-04-01 [SC]
                          A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
                    uid        [ unbekannt ] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
                    sub   rsa2048 2012-04-01 [E]
                    pub   rsa2048 2012-06-17 [SC]
                          CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
                    uid        [ unbekannt ] Raspberry Pi Archive Signing Key
                    sub   rsa2048 2012-06-17 [E]
                    pub   rsa4096 2015-09-28 [SC]
                          05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
                    uid        [ unbekannt ] InfluxDB Packaging Service <support@influxdb.com>
                    sub   rsa4096 2015-09-28 [E]
                    pub   rsa4096 2023-01-18 [SC] [verfällt: 2026-01-17]
                          9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                    uid        [ unbekannt ] InfluxData Package Signing Key <support@influxdata.com>
                    pi@raspberrypi:~ $
                    und dann
                    sudo apt update
                    ausführen ?
                      Thomas Braun Most Active @darkblu last edited by
                      @darkblu
                      Ja, die Schlüssel sollten aus apt-key raus.
                      Ob du dann das Repo anlegen musst hängt vom jetzigen Setup ab.
                        darkblu @Thomas Braun last edited by
                        Wie finde ich denn raus, ob ich das Repo anlegen muss, bzw. welches Setup ich habe ?
                        Sorry für meine Unwissenheit.
                        • wendy2702
                          wendy2702 @darkblu last edited by
                          @darkblu Guckst du hier: https://forum.iobroker.net/post/937984
                            sodele,
                            sudo apt update
                            sagt:
                            pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                            OK
                            pi@raspberrypi:~ $ sudo apt-key del 9D539D90D3328DC7D6C8D3B9D8FF8E1F7DF8B07E
                            OK
                            insgesamt 12
                            -rw-r--r-- 1 root root  84 30. Jan 18:31 grafana.list
                            -rw-r--r-- 1 root root 208 26. Aug 15:09 nodesource.list
                            -rw-r--r-- 1 root root 191 30. Okt 2021  raspi.list
                            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                            OK:3 https://apt.grafana.com stable InRelease
                            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Paketlisten werden gelesen… Fertig
                            Abhängigkeitsbaum wird aufgebaut… Fertig
                            Statusinformationen werden eingelesen… Fertig
                            Alle Pakete sind aktuell.
                            wenn ich es richtig verstanden habe, bin ich dann endlich am Ziel und muss nix mehr machen 😧 ?
                            also das hier (nicht machen):
                            sudo apt update
                              @darkblu
                              Da ist kein Repo für influxdb angelegt.
                              Also wirst du das tun müssen, wenn influxdb verwendet werden soll.
                                ey ey Sir
                                hier die Ausgabe:
                                pi@raspberrypi:~ $ iob stop
                                pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
                                rm: das Entfernen von '/etc/apt/sources.list.d/influxdb.list' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                influxdata-archive_compat.key: OK
                                pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                Holen:2 https://repos.influxdata.com/debian stable InRelease [6.874 B]
                                OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                Holen:6 https://repos.influxdata.com/debian stable/main armhf Packages [1.669 B]
                                Es wurden 8.543 B in 1 s geholt (6.376 B/s).
                                pi@raspberrypi:~ $ sudo apt full-upgrade
                                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                pi@raspberrypi:~ $
                                jetzt bin ich aber durch ?
                                  @darkblu
                                  apt policy influxdb*
                                  sagt?
                                    sagt:
                                    pi@raspberrypi:~ $ apt policy influxdb*
                                    influxdb-client:
                                      Installiert:           (keine)
                                      Installationskandidat: 1.6.7~rc0-1
                                      Versionstabelle:
                                         1.6.7~rc0-1 500
                                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                    influxdb-dev:
                                      Installationskandidat: (keine)
                                      Versionstabelle:
                                    influxdb:
                                      Installiert:           1.8.10-1
                                      Installationskandidat: 1.8.10-1
                                      Versionstabelle:
                                     *** 1.8.10-1 500
                                            500 https://repos.influxdata.com/debian stable/main armhf Packages
                                            100 /var/lib/dpkg/status
                                         1.6.7~rc0-1 500
                                    pi@raspberrypi:~ $
                                      @darkblu
                                      Passt.
                                        @thomas-braun ,
                                        ich kann mich nur wiederholen
                                        vielen lieben Dank
                                          hotspot_2 @Thomas Braun last edited by
                                          sudo apt update
                                          Hallo zusammen, ich habe das oben stehende gemacht und der Fehler mit dem Key ist dann weg.
                                          Erhalte dann aber diesen Fehler:
                                          Fehl:1 https://packages.grafana.com/oss/deb stable/main amd64 grafana amd64 9.3.6
                                            404  Not Found [IP: 151.101.2.217 443]
                                          E: Fehlschlag beim Holen von https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_9.3.6_amd64.deb 404  Not Found [IP: 151.101.2.217 443]
                                          E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                                          apt-get update bringt auch keine Besserung.
                                          Hat mir jemand einen Tipp was ich da machen kann?
                                          Vielen Dank.
                                            Thomas Braun Most Active @hotspot_2 last edited by Thomas Braun
                                            @hotspot_2
                                            Bitte IMMER vollständige Ein- wie Ausgaben inkl. LogIn Prompt posten.
                                            ls -lA
                                            in dem Verzeichnis wo do da gerade drinstandst sagt?
                                            cat /etc/apt/sources.list.d/gra*
                                            sagt?
                                            146
                                            36861
