    4. Linux/Debian - Grafana-Repo muss aktualisiert werden
      shellyrulestheworld @Thomas Braun last edited by
      @thomas-braun said in Linux/Debian - Grafana-Repo muss aktualisiert werden:
      ls -lA /etc/apt/sources.list.d/
      pi@raspberrypi:~ $ ls -lA /etc/apt/sources.list.d/
      total 24
      -rw-r--r-- 1 root root  60 Dec 23 10:10 deconz.list
      -rw-r--r-- 1 root root  84 Jan 30 14:21 grafana.list
      -rw-r--r-- 1 root root 101 Jan 30 15:05 influxdb.list
      -rw-r--r-- 1 root root 208 Dec 23 09:34 nodesource.list
      -rw-r--r-- 1 root root 398 Jan 11 16:11 ookla_speedtest-cli.list
      -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Get:8 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
      Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Err:8 https://repos.influxdata.com/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Fetched 7,022 B in 2s (3,282 B/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      pi@raspberrypi:~ $
        Thomas Braun Most Active @shellyrulestheworld last edited by Thomas Braun
        sudo rm /etc/apt/sources.list.d/influxdb.list
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        sudo apt update
        sudo apt full-upgrade
        S H 2 Replies Last reply Reply Quote 3
          ein großes Dankeschön, läuft perfekt durch 🙂
          Ist wirklich ein klasse Support von dir
            darkblu last edited by
            und wieder eine Anfänger Frage, muss ich hier auch die beiden Schlüssel von influx löschen ?
            pi@raspberrypi:~ $ apt-key list
            Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
            pub   rsa2048 2012-04-01 [SC]
                  A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
            uid        [ unbekannt ] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
            sub   rsa2048 2012-04-01 [E]
            pub   rsa2048 2012-06-17 [SC]
                  CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
            uid        [ unbekannt ] Raspberry Pi Archive Signing Key
            sub   rsa2048 2012-06-17 [E]
            pub   rsa4096 2015-09-28 [SC]
                  05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
            uid        [ unbekannt ] InfluxDB Packaging Service <support@influxdb.com>
            sub   rsa4096 2015-09-28 [E]
            pub   rsa4096 2023-01-18 [SC] [verfällt: 2026-01-17]
                  9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
            uid        [ unbekannt ] InfluxData Package Signing Key <support@influxdata.com>
            pi@raspberrypi:~ $
            und dann
            sudo apt update
            ausführen ?
              Thomas Braun Most Active @darkblu last edited by
              @darkblu
              Ja, die Schlüssel sollten aus apt-key raus.
              Ob du dann das Repo anlegen musst hängt vom jetzigen Setup ab.
                darkblu @Thomas Braun last edited by
                Wie finde ich denn raus, ob ich das Repo anlegen muss, bzw. welches Setup ich habe ?
                Sorry für meine Unwissenheit.
                • wendy2702
                  wendy2702 @darkblu last edited by
                  @darkblu Guckst du hier: https://forum.iobroker.net/post/937984
                    sodele,
                    sudo apt update
                    sagt:
                    pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                    OK
                    pi@raspberrypi:~ $ sudo apt-key del 9D539D90D3328DC7D6C8D3B9D8FF8E1F7DF8B07E
                    OK
                    insgesamt 12
                    -rw-r--r-- 1 root root  84 30. Jan 18:31 grafana.list
                    -rw-r--r-- 1 root root 208 26. Aug 15:09 nodesource.list
                    -rw-r--r-- 1 root root 191 30. Okt 2021  raspi.list
                    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    OK:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                    OK:3 https://apt.grafana.com stable InRelease
                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Paketlisten werden gelesen… Fertig
                    Abhängigkeitsbaum wird aufgebaut… Fertig
                    Statusinformationen werden eingelesen… Fertig
                    Alle Pakete sind aktuell.
                    wenn ich es richtig verstanden habe, bin ich dann endlich am Ziel und muss nix mehr machen 😧 ?
                    also das hier (nicht machen):
                    sudo apt update
                      @darkblu
                      Da ist kein Repo für influxdb angelegt.
                      Also wirst du das tun müssen, wenn influxdb verwendet werden soll.
                        ey ey Sir
                        hier die Ausgabe:
                        pi@raspberrypi:~ $ iob stop
                        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
                        rm: das Entfernen von '/etc/apt/sources.list.d/influxdb.list' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                        pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                        pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                        influxdata-archive_compat.key: OK
                        pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                        Holen:2 https://repos.influxdata.com/debian stable InRelease [6.874 B]
                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        Holen:6 https://repos.influxdata.com/debian stable/main armhf Packages [1.669 B]
                        Es wurden 8.543 B in 1 s geholt (6.376 B/s).
                        pi@raspberrypi:~ $ sudo apt full-upgrade
                        Paketaktualisierung (Upgrade) wird berechnet… Fertig
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        pi@raspberrypi:~ $
                        jetzt bin ich aber durch ?
                          @darkblu
                          apt policy influxdb*
                          sagt?
                            sagt:
                            pi@raspberrypi:~ $ apt policy influxdb*
                            influxdb-client:
                              Installiert:           (keine)
                              Installationskandidat: 1.6.7~rc0-1
                              Versionstabelle:
                                 1.6.7~rc0-1 500
                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                            influxdb-dev:
                              Installationskandidat: (keine)
                              Versionstabelle:
                            influxdb:
                              Installiert:           1.8.10-1
                              Installationskandidat: 1.8.10-1
                              Versionstabelle:
                             *** 1.8.10-1 500
                                    500 https://repos.influxdata.com/debian stable/main armhf Packages
                                    100 /var/lib/dpkg/status
                                 1.6.7~rc0-1 500
                            pi@raspberrypi:~ $
                              @darkblu
                              Passt.
                                @thomas-braun ,
                                ich kann mich nur wiederholen
                                vielen lieben Dank
                                  hotspot_2 @Thomas Braun last edited by
                                  sudo apt update
                                  Hallo zusammen, ich habe das oben stehende gemacht und der Fehler mit dem Key ist dann weg.
                                  Erhalte dann aber diesen Fehler:
                                  Fehl:1 https://packages.grafana.com/oss/deb stable/main amd64 grafana amd64 9.3.6
                                    404  Not Found [IP: 151.101.2.217 443]
                                  E: Fehlschlag beim Holen von https://packages.grafana.com/oss/deb/pool/main/g/grafana/grafana_9.3.6_amd64.deb 404  Not Found [IP: 151.101.2.217 443]
                                  E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                                  apt-get update bringt auch keine Besserung.
                                  Hat mir jemand einen Tipp was ich da machen kann?
                                  Vielen Dank.
                                    Thomas Braun Most Active @hotspot_2 last edited by Thomas Braun
                                    @hotspot_2
                                    Bitte IMMER vollständige Ein- wie Ausgaben inkl. LogIn Prompt posten.
                                    ls -lA
                                    in dem Verzeichnis wo do da gerade drinstandst sagt?
                                    cat /etc/apt/sources.list.d/gra*
                                    sagt?
                                      @thomas-braun sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                                      @hotspot_2
                                      Alles klar! Danke für den Hinweis.
                                      ls -lA
                                      marcus@iobroker:~$ sudo ls -lA
                                      [sudo] Passwort für marcus:
                                      Das hat nicht funktioniert, bitte nochmal probieren.
                                      insgesamt 28
                                      -rw------- 1 marcus marcus 4908 31. Jan 10:55 .bash_history
                                      -rw-r--r-- 1 marcus marcus  220  6. Sep 11:02 .bash_logout
                                      -rw-r--r-- 1 marcus marcus 3526  6. Sep 11:02 .bashrc
                                      -rw-r--r-- 1 marcus marcus 1684 26. Jan 22:11 influxdata-archive_compat.key
                                      -rw------- 1 marcus marcus    0  2. Jan 21:47 .node_repl_history
                                      drwxr-xr-x 3 marcus marcus 4096  2. Jan 21:10 .npm
                                      -rw-r--r-- 1 marcus marcus  807  6. Sep 11:02 .profile
                                      sagt?
                                      marcus@iobroker:~$ cat /etc/apt/sources.list.d/gra*
                                      deb https://packages.grafana.com/oss/deb stable main
                                        @hotspot_2 sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                                        sudo ls -lA
                                        Wer hat denn gesagt, dass du da root-Rechte benötigst?
                                        Das Grafana-Repository nochmal neuanlegen, da fehlen Einträge in der *.list-Datei.
                                          Hier nochmal ohne "sudo":
                                          marcus@iobroker:~$ ls -lA
                                          insgesamt 28
                                          Wie lege ich den das grafana repository neu an?
                                            @hotspot_2
                                            https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                            1.0k
                                            146
                                            36847
