    4. JavaScript
    5. Roborock Adapter tester gesucht
      DonToben @Hunter 0 last edited by DonToben
      @hunter-0 said in Roborock Adapter tester gesucht:
      @dontoben
      Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
      Gleiches Problem mit Node v16.19.0
      Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
      $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
      install copystring/ioBroker.roborock
      NPM version: 6.14.5
      Installing copystring/ioBroker.roborock... (System call)
      > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
      (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
      CXX(target) Release/obj.target/canvas/src/Backends.o
      CXX(target) Release/obj.target/canvas/src/Canvas.o
      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
      ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
      CXX(target) Release/obj.target/canvas/src/closure.o
      CXX(target) Release/obj.target/canvas/src/color.o
      CXX(target) Release/obj.target/canvas/src/Image.o
      CXX(target) Release/obj.target/canvas/src/ImageData.o
      CXX(target) Release/obj.target/canvas/src/init.o
      CXX(target) Release/obj.target/canvas/src/register_font.o
      SOLINK_MODULE(target) Release/obj.target/canvas.node
      COPY Release/canvas.node
      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
      npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
      48 packages are looking for funding run `npm fund` for details
      upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
      Process exited with code 0
      copystring 1 Reply Last reply Reply Quote 0
        DonToben last edited by
        Jemand zufällig noch einen S7 Pro Ultra?
        • wendy2702
          wendy2702 @DonToben last edited by
          @dontoben Das nicht. Aber bei Node 16 ist eigentlich NPM8 dabei.
          Du solltest mal deine Node/NPM installation checken.
          Wie das geht steht hier: https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          O D 2 Replies Last reply Reply Quote 0
          • O
            oxident @wendy2702 last edited by
            Hmm, bevor ich ein Issue aufmache würde ich gerne Eure Meinung hören:
            Wenn ich die Instanz aktiviere klappt erstmal alles (außer der paar Errors und Warnings, dass es unbekannte Attribute und nicht vorhandene DPs gibt).
            Komischerweise scheint jedoch iobroker alle 30-60min neuzustarten. Im Log habe ich bisher nichts dazu gefunden.
            Meint ihr, der Adapter könnte die Ursache sein?
            Wenn er angehalten ist passiert das definitiv nicht.
            • wendy2702
              wendy2702 @oxident last edited by
              @oxident sagte in Roborock Adapter tester gesucht:
              Kann nicht sein. Wenn iob neu startet steht das im log.
              Wie kommst du darauf das iob sich neu startet?
                DonToben @wendy2702 last edited by DonToben
                @wendy2702 said in Roborock Adapter tester gesucht:
                So ich habe jetzt alles auf den neuesten STand gebracht. Fehler ist immer noch da.
                Installationslog sieht jetzt so aus
                $ iobroker url https://github.com/copystring/ioBroker.roborock --host raspberrypi --debug
                install copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3
                Installing copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3... (System call)
                npm WARN skipping integrity check for git dependency ssh://git@github.com/copystring/ioBroker.roborock.git
                added 44 packages in 1m48 packages are looking for funding run `npm fund` for details
                upload [8] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                Und hier die aktuelle NPM Version:
                @copystring
                Eine Idee?
                • wendy2702
                  @dontoben Welcher Fehler?
                  Zumindest im Installations Log sieht man auf Anhieb keinen Fehler.
                  Was kommt denn wenn du die Instanz startest bzw neu startest?
                  Wie sieht denn die Ausgabe davon aus:
                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                  uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  • O
                    Sorry, ich habe mich blöd ausgedrückt. Bestimmt steht was im Log, jedoch für mich auf die Schnelle via Handy nicht mehr in der Admin-Oberfläche sichtbar (da die Fehlermeldung vom Roborock-Adapter ziemlich schnell alles geflutet hatten).
                    Ich sehe den Neustart an zwei Indikatoren: Zum einen habe ich ein Script welches beim Start eine Telegram-Nachricht schickt und zum anderen kommen plötzlich sämtliche Sendungsbenachrichtigungen vom Parcel-Adapter neu rein 😉
                    Bin aber gerade dabei, das System 24h ohne aktivierter Roborock-Instanz laufen zu lassen um auf Nummer sicher zu gehen. Dann aktivier ich sie wieder und versuche, entsprechende Log-Einträge zu finden.
                    • wendy2702
                      @oxident Schau doch in die gespeicherten Logs unter:
                      /opt/iobroker/logs/
                        @wendy2702
                        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v16.19.0
                        v16.19.0
                        8.19.3
                        8.19.3
                        4.0.24
                        pi
                        pi adm tty dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        tty
                        /home/pi
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                        Alle Pakete sind aktuell.
                        nodejs:
                          Installiert:           16.19.0-deb-1nodesource1
                          Installationskandidat: 16.19.0-deb-1nodesource1
                          Versionstabelle:
                         *** 16.19.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.24.0~dfsg-1~deb10u2 500
                        pi@raspberrypi:~ $
                        Hier der Log vom Adapter:
                        2023-01-30 20:21:55.849 - info: host.raspberrypi "system.adapter.roborock.0" enabled
                        2023-01-30 20:21:56.290 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5746
                        2023-01-30 20:21:59.848 - debug: roborock.0 (5746) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-01-30 20:21:59.916 - debug: roborock.0 (5746) Objects client ready ... initialize now
                        2023-01-30 20:21:59.919 - debug: roborock.0 (5746) Objects create System PubSub Client
                        2023-01-30 20:21:59.923 - debug: roborock.0 (5746) Objects create User PubSub Client
                        2023-01-30 20:21:59.992 - debug: roborock.0 (5746) Objects client initialize lua scripts
                        2023-01-30 20:22:00.013 - debug: roborock.0 (5746) Objects connected to redis: 127.0.0.1:9001
                        2023-01-30 20:22:00.055 - debug: roborock.0 (5746) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-01-30 20:22:00.095 - debug: roborock.0 (5746) States create System PubSub Client
                        2023-01-30 20:22:00.097 - debug: roborock.0 (5746) States create User PubSub Client
                        2023-01-30 20:22:00.144 - debug: roborock.0 (5746) States connected to redis: 127.0.0.1:9000
                        2023-01-30 20:22:00.538 - info: roborock.0 (5746) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                        2023-01-30 20:22:00.908 - debug: roborock.0 (5746) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
                        2023-01-30 20:22:01.049 - info: roborock.0 (5746) MQTT initialized
                        2023-01-30 20:22:01.059 - debug: roborock.0 (5746) Products: object
                        2023-01-30 20:22:01.060 - debug: roborock.0 (5746) Products: object
                        2023-01-30 20:22:01.063 - debug: roborock.0 (5746) Robot key: roborock.vacuum.a62
                        2023-01-30 20:22:02.000 - debug: roborock.0 (5746) Latest data requested
                        2023-01-30 20:22:02.003 - debug: roborock.0 (5746) getParameter: get_status
                        2023-01-30 20:22:02.009 - debug: roborock.0 (5746) getParameter: get_water_box_custom_mode
                        2023-01-30 20:22:02.012 - debug: roborock.0 (5746) getParameter: get_consumable
                        2023-01-30 20:22:02.015 - debug: roborock.0 (5746) getParameter: get_network_info
                        2023-01-30 20:22:02.018 - debug: roborock.0 (5746) getParameter: get_carpet_mode
                        2023-01-30 20:22:02.020 - debug: roborock.0 (5746) getParameter: get_carpet_clean_mode
                        2023-01-30 20:22:02.021 - debug: roborock.0 (5746) getParameter: get_fw_features
                        2023-01-30 20:22:02.023 - debug: roborock.0 (5746) Firmware features request
                        2023-01-30 20:22:02.025 - debug: roborock.0 (5746) getParameter: get_multi_maps_list
                        2023-01-30 20:22:02.027 - debug: roborock.0 (5746) getParameter: get_room_mapping
                        2023-01-30 20:22:02.028 - debug: roborock.0 (5746) get_room_mapping
                        2023-01-30 20:22:02.149 - debug: roborock.0 (5746) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                        2023-01-30 20:22:02.151 - debug: roborock.0 (5746) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
                        2023-01-30 20:22:02.160 - debug: roborock.0 (5746) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
                        2023-01-30 20:22:02.178 - debug: roborock.0 (5746) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                        2023-01-30 20:22:02.179 - debug: roborock.0 (5746) get_status: {"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                        2023-01-30 20:22:02.184 - debug: roborock.0 (5746) dps debug: {"id":2,"result":{"water_box_mode":203}}
                        2023-01-30 20:22:02.234 - debug: roborock.0 (5746) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-61}}
                        2023-01-30 20:22:02.239 - debug: roborock.0 (5746) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
                        2023-01-30 20:22:02.243 - debug: roborock.0 (5746) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
                        2023-01-30 20:22:02.246 - debug: roborock.0 (5746) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
                        2023-01-30 20:22:02.247 - debug: roborock.0 (5746) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
                        2023-01-30 20:22:02.249 - debug: roborock.0 (5746) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.253 - debug: roborock.0 (5746) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                        2023-01-30 20:22:02.256 - debug: roborock.0 (5746) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.258 - debug: roborock.0 (5746) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.261 - debug: roborock.0 (5746) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
                        2023-01-30 20:22:02.264 - debug: roborock.0 (5746) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.267 - debug: roborock.0 (5746) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.269 - debug: roborock.0 (5746) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.272 - debug: roborock.0 (5746) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.274 - debug: roborock.0 (5746) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.277 - debug: roborock.0 (5746) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.278 - debug: roborock.0 (5746) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:02.281 - debug: roborock.0 (5746) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.284 - debug: roborock.0 (5746) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:02.286 - debug: roborock.0 (5746) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.289 - debug: roborock.0 (5746) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
                        2023-01-30 20:22:02.364 - debug: roborock.0 (5746) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.366 - debug: roborock.0 (5746) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:02.372 - debug: roborock.0 (5746) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:02.376 - debug: roborock.0 (5746) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:02.378 - debug: roborock.0 (5746) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
                        2023-01-30 20:22:02.441 - debug: roborock.0 (5746) dps debug: {"id":11,"result":["ok"]}
                        2023-01-30 20:22:03.208 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
                        2023-01-30 20:22:03.209 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
                        2023-01-30 20:22:03.209 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                        2023-01-30 20:22:33.345 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5773
                        2023-01-30 20:22:36.103 - debug: roborock.0 (5773) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-01-30 20:22:36.253 - debug: roborock.0 (5773) Objects client ready ... initialize now
                        2023-01-30 20:22:36.257 - debug: roborock.0 (5773) Objects create System PubSub Client
                        2023-01-30 20:22:36.259 - debug: roborock.0 (5773) Objects create User PubSub Client
                        2023-01-30 20:22:36.338 - debug: roborock.0 (5773) Objects client initialize lua scripts
                        2023-01-30 20:22:36.347 - debug: roborock.0 (5773) Objects connected to redis: 127.0.0.1:9001
                        2023-01-30 20:22:36.386 - debug: roborock.0 (5773) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-01-30 20:22:36.413 - debug: roborock.0 (5773) States create System PubSub Client
                        2023-01-30 20:22:36.415 - debug: roborock.0 (5773) States create User PubSub Client
                        2023-01-30 20:22:36.458 - debug: roborock.0 (5773) States connected to redis: 127.0.0.1:9000
                        2023-01-30 20:22:36.753 - info: roborock.0 (5773) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                        2023-01-30 20:22:37.022 - debug: roborock.0 (5773) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
                        2023-01-30 20:22:37.101 - info: roborock.0 (5773) MQTT initialized
                        2023-01-30 20:22:37.109 - debug: roborock.0 (5773) Products: object
                        2023-01-30 20:22:37.110 - debug: roborock.0 (5773) Products: object
                        2023-01-30 20:22:37.111 - debug: roborock.0 (5773) Robot key: roborock.vacuum.a62
                        2023-01-30 20:22:37.938 - debug: roborock.0 (5773) Latest data requested
                        2023-01-30 20:22:37.940 - debug: roborock.0 (5773) getParameter: get_status
                        2023-01-30 20:22:37.946 - debug: roborock.0 (5773) getParameter: get_water_box_custom_mode
                        2023-01-30 20:22:37.948 - debug: roborock.0 (5773) getParameter: get_consumable
                        2023-01-30 20:22:37.950 - debug: roborock.0 (5773) getParameter: get_network_info
                        2023-01-30 20:22:37.953 - debug: roborock.0 (5773) getParameter: get_carpet_mode
                        2023-01-30 20:22:37.955 - debug: roborock.0 (5773) getParameter: get_carpet_clean_mode
                        2023-01-30 20:22:37.957 - debug: roborock.0 (5773) getParameter: get_fw_features
                        2023-01-30 20:22:37.957 - debug: roborock.0 (5773) Firmware features request
                        2023-01-30 20:22:37.959 - debug: roborock.0 (5773) getParameter: get_multi_maps_list
                        2023-01-30 20:22:37.961 - debug: roborock.0 (5773) getParameter: get_room_mapping
                        2023-01-30 20:22:37.962 - debug: roborock.0 (5773) get_room_mapping
                        2023-01-30 20:22:38.133 - debug: roborock.0 (5773) dps debug: {"id":2,"result":{"water_box_mode":203}}
                        2023-01-30 20:22:38.140 - debug: roborock.0 (5773) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
                        2023-01-30 20:22:38.141 - debug: roborock.0 (5773) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
                        2023-01-30 20:22:38.143 - debug: roborock.0 (5773) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-62}}
                        2023-01-30 20:22:38.147 - debug: roborock.0 (5773) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
                        2023-01-30 20:22:38.148 - debug: roborock.0 (5773) get_status: {"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
                        2023-01-30 20:22:38.153 - debug: roborock.0 (5773) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                        2023-01-30 20:22:38.156 - debug: roborock.0 (5773) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
                        2023-01-30 20:22:38.173 - debug: roborock.0 (5773) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
                        2023-01-30 20:22:38.176 - debug: roborock.0 (5773) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
                        2023-01-30 20:22:38.193 - debug: roborock.0 (5773) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                        2023-01-30 20:22:38.196 - debug: roborock.0 (5773) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
                        2023-01-30 20:22:38.243 - debug: roborock.0 (5773) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.251 - debug: roborock.0 (5773) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.255 - debug: roborock.0 (5773) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.264 - debug: roborock.0 (5773) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.272 - debug: roborock.0 (5773) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:38.274 - debug: roborock.0 (5773) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.277 - debug: roborock.0 (5773) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.282 - debug: roborock.0 (5773) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.285 - debug: roborock.0 (5773) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:38.291 - debug: roborock.0 (5773) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
                        2023-01-30 20:22:38.293 - debug: roborock.0 (5773) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.297 - debug: roborock.0 (5773) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.303 - debug: roborock.0 (5773) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
                        2023-01-30 20:22:38.304 - debug: roborock.0 (5773) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.310 - debug: roborock.0 (5773) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
                        2023-01-30 20:22:38.312 - debug: roborock.0 (5773) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.345 - debug: roborock.0 (5773) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.369 - debug: roborock.0 (5773) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
                        2023-01-30 20:22:38.423 - debug: roborock.0 (5773) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
                        2023-01-30 20:22:38.425 - debug: roborock.0 (5773) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
                        2023-01-30 20:22:38.428 - debug: roborock.0 (5773) dps debug: {"id":11,"result":["ok"]}
                        2023-01-30 20:22:40.311 - debug: roborock.0 (5773) dps debug: {"id":32,"result":["ok"]}
                        2023-01-30 20:22:41.122 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
                        2023-01-30 20:22:41.122 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
                        2023-01-30 20:22:41.123 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                        • wendy2702
                          @dontoben sagte in Roborock Adapter tester gesucht:
                          SIGSEGV
                          Was ist das fuer ein PI?
                          Was sagt:
                          free -ht
                          sudo apt update
                          Als erste Hilfe kannst du mal Instanz und Adapter komplett loeschen. Server neu starten und dann neu installieren.
                            @wendy2702
                            pi@raspberrypi:~ $ free -ht
                                          total        used        free      shared  buff/cache
                               available
                            Mem:          3,7Gi       606Mi        79Mi       200Mi       3,1Gi
                                   2,8Gi
                            Swap:          99Mi        13Mi        86Mi
                            Total:        3,8Gi       619Mi       166Mi
                            pi@raspberrypi:~ $ sudo apt update
                            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:2 https://deb.nodesource.com/node_16.x buster InRelease
                            OK:3 http://archive.raspberrypi.org/debian buster InRelease
                            pi@raspberrypi:~ $
                            Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM, WLAN-ac, Bluetooth 5, LAN, 4 x USB, 2 x Micro-HD
                            0.0.5 funktionierte noch einwandfrei.
                            Deinstallation, Server Neustart und Neuinstallation brachte keine Abhilfe
                            • wendy2702
                              wendy2702 @DonToben last edited by wendy2702
                              @dontoben OK. Buster solltest du mal bei Gelegenheit updaten. Bzw. besser was aktuelles neu installieren. Moeglich das es da haengt. Kommt halt drauf an was @copystring alles in seinem Adapter verwendet.
                              Sonst wuerde ich einmal wie geschrieben vorgehen.
                              EDIT: Hat sich mit deinem Edit ueberschnitten. Immer noch SIGSEGV als error?
                                Ja, SIGSEGV kommt noch als Fehler.
                                Ich warte jetzt mal, was @copystring sagt. Update des Betriebssystems würde ich nur zur Not machen, da ich das mühselige Neueinrichten vermeiden möchte.
                                Hoffentlich ist es nur ein Fehler im Adapter.
                                • wendy2702
                                  @dontoben Wieso muehselig bei einem PI?
                                  Kannst das Betriebssystem auch updaten:
                                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye?page=1
                                  Vorher natuerlich ein Backup machen.
                                  • copystring
                                    copystring last edited by
                                    SIGSEGV steht für Segmentation fault. Ein Programm stürzt also ab. Dass das von meinen Adapter direkt kommt ist eher unwahrscheinlich. Es wird wohl eher daher kommen, dass entweder eine Bibliothek (vielleicht canvas von npm) abstürzt oder ein RPi nicht damit klar kommt, dass die Karte jede Sekunde neu erstellt wird. Beim meinen Server lief das auch nicht richtig aber es kam nie ein Absturz. Daher hatte ich das bereits auf 2 Sekunden reduziert.
                                    • copystring
                                      copystring @DonToben last edited by copystring
                                      @dontoben said in Roborock Adapter tester gesucht:
                                      @dontoben
                                      NPM version: 6.14.5
                                      Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
                                      Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
                                      Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
                                      DonToben created this issue in copystring/ioBroker.roborock
                                      closed 0.0.6 Adapter startet ständig neu #40
                                      • wendy2702
                                        @DonToben
                                        mal versucht Canvas zu installieren:
                                        cd /opt/iobroker/
                                        npm install canvas
                                        • copystring
                                          copystring last edited by wendy2702
                                          Vergiss was ich gesagt habe. canvas wurde anschließend erfolgreich kompiliert.
                                          Der eigentliche Fehler ist bei:
                                          • wendy2702
                                            @copystring sagte in Roborock Adapter tester gesucht:
                                            buffer@>=6.0.3
                                            Da habe ich ja Glueck gehabt das es die bei mir gibt:
                                             npm ls buffer
                                            [sudo] password for mi:
                                            iobroker.inst@2.0.3 /opt/iobroker
                                            +-- iobroker.modbus@5.0.11
                                            | `-- crc@4.1.1
                                            |   `-- buffer@6.0.3
                                            +-- iobroker.mqtt@4.0.7
                                            | `-- mqtt-connection@4.1.0
                                            |   `-- mqtt-packet@6.10.0
                                            |     `-- bl@4.1.0
                                            |       `-- buffer@5.7.1
                                            +-- iobroker.sayit@1.12.6
                                            | `-- aws-sdk@2.1071.0
                                            |   `-- buffer@4.9.2
                                            `-- iobroker.shelly@6.3.1
                                              `-- shelly-iot@1.1.2
                                                `-- coap@0.26.0
                                                  `-- bl@5.1.0
                                                    `-- buffer@6.0.3 deduped
                                            766
                                            242542
