    4. JavaScript
    5. Roborock Adapter tester gesucht
    • wendy2702
      wendy2702 @oxident last edited by
      @oxident Schau doch in die gespeicherten Logs unter:
      /opt/iobroker/logs/
        DonToben @wendy2702 last edited by
        @wendy2702
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v16.19.0
        v16.19.0
        8.19.3
        8.19.3
        4.0.24
        pi
        pi adm tty dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        tty
        /home/pi
        OK:1 http://archive.raspberrypi.org/debian buster InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:3 https://deb.nodesource.com/node_16.x buster InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           16.19.0-deb-1nodesource1
          Installationskandidat: 16.19.0-deb-1nodesource1
          Versionstabelle:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u2 500
        pi@raspberrypi:~ $
        Hier der Log vom Adapter:
        2023-01-30 20:21:55.849 - info: host.raspberrypi "system.adapter.roborock.0" enabled
        2023-01-30 20:21:56.290 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5746
        2023-01-30 20:21:59.848 - debug: roborock.0 (5746) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-01-30 20:21:59.916 - debug: roborock.0 (5746) Objects client ready ... initialize now
        2023-01-30 20:21:59.919 - debug: roborock.0 (5746) Objects create System PubSub Client
        2023-01-30 20:21:59.923 - debug: roborock.0 (5746) Objects create User PubSub Client
        2023-01-30 20:21:59.992 - debug: roborock.0 (5746) Objects client initialize lua scripts
        2023-01-30 20:22:00.013 - debug: roborock.0 (5746) Objects connected to redis: 127.0.0.1:9001
        2023-01-30 20:22:00.055 - debug: roborock.0 (5746) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-01-30 20:22:00.095 - debug: roborock.0 (5746) States create System PubSub Client
        2023-01-30 20:22:00.097 - debug: roborock.0 (5746) States create User PubSub Client
        2023-01-30 20:22:00.144 - debug: roborock.0 (5746) States connected to redis: 127.0.0.1:9000
        2023-01-30 20:22:00.538 - info: roborock.0 (5746) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        2023-01-30 20:22:00.908 - debug: roborock.0 (5746) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
        2023-01-30 20:22:01.049 - info: roborock.0 (5746) MQTT initialized
        2023-01-30 20:22:01.059 - debug: roborock.0 (5746) Products: object
        2023-01-30 20:22:01.060 - debug: roborock.0 (5746) Products: object
        2023-01-30 20:22:01.063 - debug: roborock.0 (5746) Robot key: roborock.vacuum.a62
        2023-01-30 20:22:02.000 - debug: roborock.0 (5746) Latest data requested
        2023-01-30 20:22:02.003 - debug: roborock.0 (5746) getParameter: get_status
        2023-01-30 20:22:02.009 - debug: roborock.0 (5746) getParameter: get_water_box_custom_mode
        2023-01-30 20:22:02.012 - debug: roborock.0 (5746) getParameter: get_consumable
        2023-01-30 20:22:02.015 - debug: roborock.0 (5746) getParameter: get_network_info
        2023-01-30 20:22:02.018 - debug: roborock.0 (5746) getParameter: get_carpet_mode
        2023-01-30 20:22:02.020 - debug: roborock.0 (5746) getParameter: get_carpet_clean_mode
        2023-01-30 20:22:02.021 - debug: roborock.0 (5746) getParameter: get_fw_features
        2023-01-30 20:22:02.023 - debug: roborock.0 (5746) Firmware features request
        2023-01-30 20:22:02.025 - debug: roborock.0 (5746) getParameter: get_multi_maps_list
        2023-01-30 20:22:02.027 - debug: roborock.0 (5746) getParameter: get_room_mapping
        2023-01-30 20:22:02.028 - debug: roborock.0 (5746) get_room_mapping
        2023-01-30 20:22:02.149 - debug: roborock.0 (5746) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
        2023-01-30 20:22:02.151 - debug: roborock.0 (5746) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
        2023-01-30 20:22:02.160 - debug: roborock.0 (5746) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
        2023-01-30 20:22:02.178 - debug: roborock.0 (5746) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
        2023-01-30 20:22:02.179 - debug: roborock.0 (5746) get_status: {"msg_ver":2,"msg_seq":215,"state":18,"battery":69,"clean_time":2000,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
        2023-01-30 20:22:02.184 - debug: roborock.0 (5746) dps debug: {"id":2,"result":{"water_box_mode":203}}
        2023-01-30 20:22:02.234 - debug: roborock.0 (5746) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-61}}
        2023-01-30 20:22:02.239 - debug: roborock.0 (5746) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
        2023-01-30 20:22:02.243 - debug: roborock.0 (5746) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
        2023-01-30 20:22:02.246 - debug: roborock.0 (5746) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
        2023-01-30 20:22:02.247 - debug: roborock.0 (5746) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
        2023-01-30 20:22:02.249 - debug: roborock.0 (5746) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.253 - debug: roborock.0 (5746) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
        2023-01-30 20:22:02.256 - debug: roborock.0 (5746) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.258 - debug: roborock.0 (5746) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.261 - debug: roborock.0 (5746) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
        2023-01-30 20:22:02.264 - debug: roborock.0 (5746) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.267 - debug: roborock.0 (5746) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.269 - debug: roborock.0 (5746) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.272 - debug: roborock.0 (5746) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.274 - debug: roborock.0 (5746) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.277 - debug: roborock.0 (5746) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.278 - debug: roborock.0 (5746) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:02.281 - debug: roborock.0 (5746) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.284 - debug: roborock.0 (5746) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:02.286 - debug: roborock.0 (5746) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.289 - debug: roborock.0 (5746) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
        2023-01-30 20:22:02.364 - debug: roborock.0 (5746) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.366 - debug: roborock.0 (5746) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:02.372 - debug: roborock.0 (5746) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:02.376 - debug: roborock.0 (5746) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:02.378 - debug: roborock.0 (5746) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
        2023-01-30 20:22:02.441 - debug: roborock.0 (5746) dps debug: {"id":11,"result":["ok"]}
        2023-01-30 20:22:03.208 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
        2023-01-30 20:22:03.209 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
        2023-01-30 20:22:03.209 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
        2023-01-30 20:22:33.345 - info: host.raspberrypi instance system.adapter.roborock.0 started with pid 5773
        2023-01-30 20:22:36.103 - debug: roborock.0 (5773) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-01-30 20:22:36.253 - debug: roborock.0 (5773) Objects client ready ... initialize now
        2023-01-30 20:22:36.257 - debug: roborock.0 (5773) Objects create System PubSub Client
        2023-01-30 20:22:36.259 - debug: roborock.0 (5773) Objects create User PubSub Client
        2023-01-30 20:22:36.338 - debug: roborock.0 (5773) Objects client initialize lua scripts
        2023-01-30 20:22:36.347 - debug: roborock.0 (5773) Objects connected to redis: 127.0.0.1:9001
        2023-01-30 20:22:36.386 - debug: roborock.0 (5773) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-01-30 20:22:36.413 - debug: roborock.0 (5773) States create System PubSub Client
        2023-01-30 20:22:36.415 - debug: roborock.0 (5773) States create User PubSub Client
        2023-01-30 20:22:36.458 - debug: roborock.0 (5773) States connected to redis: 127.0.0.1:9000
        2023-01-30 20:22:36.753 - info: roborock.0 (5773) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock#150a18a009f6fef4f1bd9e8172184412230a6ca3) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
        2023-01-30 20:22:37.022 - debug: roborock.0 (5773) RoomIDs debug: {"8917356":"Küche","8917361":"Esszimmer","8917365":"Wohnzimmer","8917371":"Toilette","8917375":"Hauswirtschaftsraum","8917377":"Gang","8937845":"Badezimmer","8937849":"Büro","8937851":"Bügelzimmer","8937852":"Kinderzimmer Bastian","8937854":"Kinderzimmer Lara","8937856":"Schlafzimmer","10093883":"Bad"}
        2023-01-30 20:22:37.101 - info: roborock.0 (5773) MQTT initialized
        2023-01-30 20:22:37.109 - debug: roborock.0 (5773) Products: object
        2023-01-30 20:22:37.110 - debug: roborock.0 (5773) Products: object
        2023-01-30 20:22:37.111 - debug: roborock.0 (5773) Robot key: roborock.vacuum.a62
        2023-01-30 20:22:37.938 - debug: roborock.0 (5773) Latest data requested
        2023-01-30 20:22:37.940 - debug: roborock.0 (5773) getParameter: get_status
        2023-01-30 20:22:37.946 - debug: roborock.0 (5773) getParameter: get_water_box_custom_mode
        2023-01-30 20:22:37.948 - debug: roborock.0 (5773) getParameter: get_consumable
        2023-01-30 20:22:37.950 - debug: roborock.0 (5773) getParameter: get_network_info
        2023-01-30 20:22:37.953 - debug: roborock.0 (5773) getParameter: get_carpet_mode
        2023-01-30 20:22:37.955 - debug: roborock.0 (5773) getParameter: get_carpet_clean_mode
        2023-01-30 20:22:37.957 - debug: roborock.0 (5773) getParameter: get_fw_features
        2023-01-30 20:22:37.957 - debug: roborock.0 (5773) Firmware features request
        2023-01-30 20:22:37.959 - debug: roborock.0 (5773) getParameter: get_multi_maps_list
        2023-01-30 20:22:37.961 - debug: roborock.0 (5773) getParameter: get_room_mapping
        2023-01-30 20:22:37.962 - debug: roborock.0 (5773) get_room_mapping
        2023-01-30 20:22:38.133 - debug: roborock.0 (5773) dps debug: {"id":2,"result":{"water_box_mode":203}}
        2023-01-30 20:22:38.140 - debug: roborock.0 (5773) dps debug: {"id":10,"result":[[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]}
        2023-01-30 20:22:38.141 - debug: roborock.0 (5773) get_room_mapping: [[16,"8917365",6],[17,"8917361",13],[18,"8917356",14],[19,"8917377",12],[20,"8917375",12],[22,"8917371",12]]
        2023-01-30 20:22:38.143 - debug: roborock.0 (5773) dps debug: {"id":4,"result":{"ssid":"FRITZ!Box 7490","ip":"192.168.178.84","mac":"b0:4a:39:3e:2a:b2","bssid":"c8:0e:14:cf:75:9a","rssi":-62}}
        2023-01-30 20:22:38.147 - debug: roborock.0 (5773) dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
        2023-01-30 20:22:38.148 - debug: roborock.0 (5773) get_status: {"msg_ver":2,"msg_seq":217,"state":18,"battery":68,"clean_time":2030,"clean_area":40127500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
        2023-01-30 20:22:38.153 - debug: roborock.0 (5773) dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
        2023-01-30 20:22:38.156 - debug: roborock.0 (5773) dps debug: {"id":5,"result":{"clean_time":334535,"clean_area":5514490000,"clean_count":271,"dust_collection_count":183,"records":[1675101410,1674999168,1674997469,1674997396,1674996096,1674995173,1674992012,1674990549,1674988026,1674904255,1674902607,1674840930,1674839064,1674827084,1674805409,1674754825,1674742452,1674729983,1674669094,1674664205]}}
        2023-01-30 20:22:38.173 - debug: roborock.0 (5773) dps debug: {"id":3,"result":[{"main_brush_work_time":334535,"side_brush_work_time":334535,"filter_work_time":334535,"filter_element_work_time":0,"sensor_dirty_time":2086,"strainer_work_times":3,"dust_collection_work_times":183,"cleaning_brush_work_times":3}]}
        2023-01-30 20:22:38.176 - debug: roborock.0 (5773) dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
        2023-01-30 20:22:38.193 - debug: roborock.0 (5773) dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
        2023-01-30 20:22:38.196 - debug: roborock.0 (5773) dps debug: {"id":9,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1675103601,"length":11,"name":"Erdgeschoss","bak_maps":[{"mapFlag":4,"add_time":1675091976}]},{"mapFlag":1,"add_time":1672833022,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1675092000}]}]}]}
        2023-01-30 20:22:38.243 - debug: roborock.0 (5773) dps debug: {"id":13,"result":[{"begin":1674999168,"end":1675001120,"duration":1952,"area":30752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.251 - debug: roborock.0 (5773) dps debug: {"id":12,"result":[{"begin":1675101410,"end":1675103496,"duration":2086,"area":31040000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.255 - debug: roborock.0 (5773) dps debug: {"id":19,"result":[{"begin":1674990549,"end":1674991556,"duration":1006,"area":5840000,"error":0,"complete":1,"start_type":101,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.264 - debug: roborock.0 (5773) dps debug: {"id":15,"result":[{"begin":1674997396,"end":1674997429,"duration":33,"area":122500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.272 - debug: roborock.0 (5773) dps debug: {"id":24,"result":[{"begin":1674839064,"end":1674839751,"duration":551,"area":5740000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:38.274 - debug: roborock.0 (5773) dps debug: {"id":14,"result":[{"begin":1674997469,"end":1674997490,"duration":21,"area":417500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.277 - debug: roborock.0 (5773) dps debug: {"id":21,"result":[{"begin":1674904255,"end":1674909516,"duration":5261,"area":91615000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.282 - debug: roborock.0 (5773) dps debug: {"id":17,"result":[{"begin":1674995173,"end":1674995694,"duration":521,"area":12742500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.285 - debug: roborock.0 (5773) dps debug: {"id":25,"result":[{"begin":1674827084,"end":1674828836,"duration":1624,"area":24290000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:38.291 - debug: roborock.0 (5773) dps debug: {"id":26,"result":[{"begin":1674805409,"end":1674807918,"duration":2168,"area":31010000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
        2023-01-30 20:22:38.293 - debug: roborock.0 (5773) dps debug: {"id":20,"result":[{"begin":1674988026,"end":1674988721,"duration":695,"area":15525000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.297 - debug: roborock.0 (5773) dps debug: {"id":27,"result":[{"begin":1674754825,"end":1674754844,"duration":19,"area":155000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.303 - debug: roborock.0 (5773) dps debug: {"id":16,"result":[{"begin":1674996096,"end":1674997396,"duration":12,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":50,"dust_collection_status":0,"wash_count":1}]}
        2023-01-30 20:22:38.304 - debug: roborock.0 (5773) dps debug: {"id":18,"result":[{"begin":1674992012,"end":1674992855,"duration":843,"area":11485000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.310 - debug: roborock.0 (5773) dps debug: {"id":30,"result":[{"begin":1674669094,"end":1674671507,"duration":2094,"area":40292500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":3}]}
        2023-01-30 20:22:38.312 - debug: roborock.0 (5773) dps debug: {"id":29,"result":[{"begin":1674729983,"end":1674735263,"duration":4614,"area":81692500,"error":0,"complete":1,"start_type":101,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.345 - debug: roborock.0 (5773) dps debug: {"id":28,"result":[{"begin":1674742452,"end":1674743822,"duration":1370,"area":20887500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.369 - debug: roborock.0 (5773) dps debug: {"id":31,"result":[{"begin":1674664205,"end":1674664243,"duration":38,"area":860000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0,"wash_count":0}]}
        2023-01-30 20:22:38.423 - debug: roborock.0 (5773) dps debug: {"id":22,"result":[{"begin":1674902607,"end":1674903605,"duration":997,"area":11620000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":0}]}
        2023-01-30 20:22:38.425 - debug: roborock.0 (5773) dps debug: {"id":23,"result":[{"begin":1674840930,"end":1674842972,"duration":1854,"area":42267500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"wash_count":2}]}
        2023-01-30 20:22:38.428 - debug: roborock.0 (5773) dps debug: {"id":11,"result":["ok"]}
        2023-01-30 20:22:40.311 - debug: roborock.0 (5773) dps debug: {"id":32,"result":["ok"]}
        2023-01-30 20:22:41.122 - warn: host.raspberrypi instance system.adapter.roborock.0 terminated due to SIGSEGV
        2023-01-30 20:22:41.122 - info: host.raspberrypi instance system.adapter.roborock.0 terminated with code NaN ()
        2023-01-30 20:22:41.123 - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
        • wendy2702
          wendy2702 @DonToben last edited by
          @dontoben sagte in Roborock Adapter tester gesucht:
          SIGSEGV
          Was ist das fuer ein PI?
          Was sagt:
          free -ht
          sudo apt update
          Als erste Hilfe kannst du mal Instanz und Adapter komplett loeschen. Server neu starten und dann neu installieren.
            DonToben @wendy2702 last edited by DonToben
            @wendy2702
            pi@raspberrypi:~ $ free -ht
                          total        used        free      shared  buff/cache
               available
            Mem:          3,7Gi       606Mi        79Mi       200Mi       3,1Gi
                   2,8Gi
            Swap:          99Mi        13Mi        86Mi
            Total:        3,8Gi       619Mi       166Mi
            pi@raspberrypi:~ $ sudo apt update
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 https://deb.nodesource.com/node_16.x buster InRelease
            OK:3 http://archive.raspberrypi.org/debian buster InRelease
            pi@raspberrypi:~ $
            Raspberry Pi 4 Modell B; 4 GB, ARM-Cortex-A72 4 x, 1,50 GHz, 4 GB RAM, WLAN-ac, Bluetooth 5, LAN, 4 x USB, 2 x Micro-HD
            0.0.5 funktionierte noch einwandfrei.
            Deinstallation, Server Neustart und Neuinstallation brachte keine Abhilfe
            • wendy2702
              wendy2702 @DonToben last edited by wendy2702
              @dontoben OK. Buster solltest du mal bei Gelegenheit updaten. Bzw. besser was aktuelles neu installieren. Moeglich das es da haengt. Kommt halt drauf an was @copystring alles in seinem Adapter verwendet.
              Sonst wuerde ich einmal wie geschrieben vorgehen.
              EDIT: Hat sich mit deinem Edit ueberschnitten. Immer noch SIGSEGV als error?
                @wendy2702 said in Roborock Adapter tester gesucht:
                Ja, SIGSEGV kommt noch als Fehler.
                Ich warte jetzt mal, was @copystring sagt. Update des Betriebssystems würde ich nur zur Not machen, da ich das mühselige Neueinrichten vermeiden möchte.
                Hoffentlich ist es nur ein Fehler im Adapter.
                • wendy2702
                  @dontoben Wieso muehselig bei einem PI?
                  Kannst das Betriebssystem auch updaten:
                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye?page=1
                  Vorher natuerlich ein Backup machen.
                  • copystring
                    copystring last edited by
                    SIGSEGV steht für Segmentation fault. Ein Programm stürzt also ab. Dass das von meinen Adapter direkt kommt ist eher unwahrscheinlich. Es wird wohl eher daher kommen, dass entweder eine Bibliothek (vielleicht canvas von npm) abstürzt oder ein RPi nicht damit klar kommt, dass die Karte jede Sekunde neu erstellt wird. Beim meinen Server lief das auch nicht richtig aber es kam nie ein Absturz. Daher hatte ich das bereits auf 2 Sekunden reduziert.
                    • copystring
                      copystring @DonToben last edited by copystring
                      @dontoben said in Roborock Adapter tester gesucht:
                      @hunter-0 said in Roborock Adapter tester gesucht:
                      @dontoben
                      Ist Node v16 nicht voraussetzen? Du hast: (node: v14.18.1)
                      Gleiches Problem mit Node v16.19.0
                      Hier mal der Log vom installieren des Adapters. Waren das schon immer so viele Meldungen?
                      $ iobroker url copystring/ioBroker.roborock --host raspberrypi --debug
                      install copystring/ioBroker.roborock
                      NPM version: 6.14.5
                      Installing copystring/ioBroker.roborock... (System call)
                      > canvas@2.11.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build --update-binary
                      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
                      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.19.0 (node-v93 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-glibc-arm.tar.gz
                      (node:4471) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                      (Use `node --trace-deprecation ...` to show where the warning was created)
                      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~
                      CXX(target) Release/obj.target/canvas/src/Backends.o
                      CXX(target) Release/obj.target/canvas/src/Canvas.o
                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                      ../src/CanvasRenderingContext2d.cc: In member function ‘void Context2d::setTextPath(double, double)’:../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_LEFT’ not handled in switch [-Wswitch] switch (state->textAlignment) { ^../src/CanvasRenderingContext2d.cc:2494:10: warning: enumeration value ‘TEXT_ALIGNMENT_START’ not handled in switch [-Wswitch]
                      CXX(target) Release/obj.target/canvas/src/closure.o
                      CXX(target) Release/obj.target/canvas/src/color.o
                      CXX(target) Release/obj.target/canvas/src/Image.o
                      CXX(target) Release/obj.target/canvas/src/ImageData.o
                      CXX(target) Release/obj.target/canvas/src/init.o
                      CXX(target) Release/obj.target/canvas/src/register_font.o
                      SOLINK_MODULE(target) Release/obj.target/canvas.node
                      COPY Release/canvas.node
                      make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                      npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      + iobroker.roborock@0.0.6-alpha.0added 45 packages from 35 contributors and updated 1 package in 346.618s
                      48 packages are looking for funding run `npm fund` for details
                      upload [11] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [5] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [4] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
                      Process exited with code 0
                      Ist dies das selbe Problem https://github.com/copystring/ioBroker.roborock/issues/40?
                      Für die Karte wird canvas benötigt und canvas scheint es für RPi (bzw. für arm) nicht zu geben... Daher 404 beim Herunterladen von canvas. Es scheint auch keine ältere Version von canvas für den RPi (arm) zu geben.
                      Vielleicht gibt es eine alternative, welche auch auf dem RPi läuft...
                      DonToben created this issue in copystring/ioBroker.roborock
                      closed 0.0.6 Adapter startet ständig neu #40
                      • wendy2702
                        @DonToben
                        mal versucht Canvas zu installieren:
                        cd /opt/iobroker/
                        npm install canvas
                        • copystring
                          copystring last edited by wendy2702
                          Vergiss was ich gesagt habe. canvas wurde anschließend erfolgreich kompiliert.
                          Der eigentliche Fehler ist bei:
                          • wendy2702
                            @copystring sagte in Roborock Adapter tester gesucht:
                            buffer@>=6.0.3
                            Da habe ich ja Glueck gehabt das es die bei mir gibt:
                             npm ls buffer
                            [sudo] password for mi:
                            iobroker.inst@2.0.3 /opt/iobroker
                            +-- iobroker.modbus@5.0.11
                            | `-- crc@4.1.1
                            |   `-- buffer@6.0.3
                            +-- iobroker.mqtt@4.0.7
                            | `-- mqtt-connection@4.1.0
                            |   `-- mqtt-packet@6.10.0
                            |     `-- bl@4.1.0
                            |       `-- buffer@5.7.1
                            +-- iobroker.sayit@1.12.6
                            | `-- aws-sdk@2.1071.0
                            |   `-- buffer@4.9.2
                            `-- iobroker.shelly@6.3.1
                              `-- shelly-iot@1.1.2
                                `-- coap@0.26.0
                                  `-- bl@5.1.0
                                    `-- buffer@6.0.3 deduped
                              DonToben @copystring last edited by DonToben
                              @copystring said in Roborock Adapter tester gesucht:
                              @dontoben
                              NPM version: 6.14.5
                              @copystring
                              Ja das ist issue 40.
                              Ich mache dann heute mit deinen Anweisungen aus issue 40 weiter. Oder soll ich noch etwas anderes installieren?
                              copystring 1 Reply Last reply Reply Quote 0
                              • copystring
                                @dontoben Siehe github.
                                  Hunter 0 last edited by
                                  Da es noch keine neue Version ist, weiß ich nicht ob es ein Issue für Github ist. Main Branch stand jetzt:
                                  • wendy2702
                                    wendy2702 @Hunter 0 last edited by wendy2702
                                    @hunter-0 Bitte vollständiges Log als text in Code Tags </> posten.
                                    Und vielleicht noch mitteilen was für ein System das ist.
                                    • wendy2702
                                      aktualisieren sich bei euch die Objekte noch?
                                      Unser Sauger ist eben gefahren und ich kann keine Änderung in den Objekten feststellen.
                                      Batterie z.B.
                                      Nach knapp 45 minuten Arbeit unverändert.
                                      Bisschen was RAM belegt er auch:
                                      Und im Log passiert zum Adapter nichts mehr.
                                      Erst nach restart kommen die neuen Werte aber beim RAM hochzählen kann ich zugucken:
                                      Restart log ohne Debug:
                                      mirko@iobroker:~$ tail -f /opt/iobroker/log/iobroker.current.log |grep roborock
                                      2023-02-02 15:50:38.847  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                      2023-02-02 15:50:38.851  - info: roborock.0 (77838) Got terminate signal TERMINATE_YOURSELF
                                      2023-02-02 15:50:38.853  - info: roborock.0 (77838) terminating
                                      2023-02-02 15:50:38.854  - info: roborock.0 (77838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-02-02 15:50:39.007  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                      2023-02-02 15:50:40.012  - info: host.iobroker stopInstance system.adapter.roborock.0 killing pid 77838
                                      2023-02-02 15:50:40.323  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-02-02 15:50:42.148  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89295
                                      2023-02-02 15:50:43.974  - info: roborock.0 (89295) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                      2023-02-02 15:50:44.177  - info: roborock.0 (89295) MQTT initialized
                                      2023-02-02 15:51:23.345  - info: host.iobroker "system.adapter.roborock.0" disabled
                                      2023-02-02 15:51:23.346  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                      2023-02-02 15:51:23.360  - info: roborock.0 (89295) Got terminate signal TERMINATE_YOURSELF
                                      2023-02-02 15:51:23.364  - info: roborock.0 (89295) terminating
                                      2023-02-02 15:51:23.365  - info: roborock.0 (89295) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-02-02 15:51:23.392  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                      2023-02-02 15:51:23.954  - warn: roborock.0 (89295) get state error: Connection is closed.
                                      2023-02-02 15:51:23.956  - error: roborock.0 (89295) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2023-02-02 15:51:23.956  - error: roborock.0 (89295) unhandled promise rejection: DB closed
                                      2023-02-02 15:51:23.956  - error: roborock.0 (89295) Error: DB closed
                                      2023-02-02 15:51:23.956  - error: roborock.0 (89295) DB closed
                                      2023-02-02 15:51:24.059  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-02-02 15:52:43.193  - info: host.iobroker "system.adapter.roborock.0" enabled
                                      2023-02-02 15:52:43.422  - info: host.iobroker instance system.adapter.roborock.0 started with pid 89332
                                      2023-02-02 15:52:44.603  - info: roborock.0 (89332) starting. Version 0.0.6-alpha.0 (non-npm: copystring/ioBroker.roborock) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                      2023-02-02 15:52:44.827  - info: roborock.0 (89332) MQTT initialized
                                      2023-02-02 15:54:25.755  - info: host.iobroker "system.adapter.roborock.0" disabled
                                      2023-02-02 15:54:25.756  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                                      2023-02-02 15:54:25.769  - info: roborock.0 (89332) Got terminate signal TERMINATE_YOURSELF
                                      2023-02-02 15:54:25.772  - info: roborock.0 (89332) terminating
                                      2023-02-02 15:54:25.772  - info: roborock.0 (89332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-02-02 15:54:25.800  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                                      2023-02-02 15:54:26.440  - warn: roborock.0 (89332) get state error: Connection is closed.
                                      2023-02-02 15:54:26.441  - error: roborock.0 (89332) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2023-02-02 15:54:26.441  - error: roborock.0 (89332) unhandled promise rejection: DB closed
                                      2023-02-02 15:54:26.442  - error: roborock.0 (89332) Error: DB closed
                                      2023-02-02 15:54:26.442  - error: roborock.0 (89332) DB closed
                                      2023-02-02 15:54:26.533  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      @copystring : soll ich ein Issue aufmachen?
                                      Desweiteren, kann man es vielleicht so machen das die Karte nur aktualisiert wird wenn das Kerlchen fährt?
                                      • copystring
                                        copystring @wendy2702 last edited by copystring
                                        @wendy2702 Ja bitte ein Issue öffnen. Es scheint so zu sein, dass viel RAM belegt wird wenn unbekannte Befehle oder Statusnachrichten vorliegen. Siehe https://github.com/copystring/ioBroker.roborock/issues/34 und https://github.com/copystring/ioBroker.roborock/issues/49
                                        Für solche Probleme brauche ich Tester da ich den passenden Saugroboter nicht habe. Hier z.B. den Roborock S7 MaxV (Ultra). Für den Roboter kann https://github.com/copystring/ioBroker.roborock/compare/update_robot_attributes getestet werden.
                                        mproper23 created this issue in copystring/ioBroker.roborock
                                        closed Unsupported attribute #34
                                        closed extreme RAM Usage #49
                                        • wendy2702
                                          wendy2702 @copystring last edited by
                                          Ich habe mich an das Issue dran gehangen, oder wolltest du zwingend ein neues?
                                          Für das Map Update neues Issue:
                                          https://github.com/copystring/ioBroker.roborock/issues/50
                                          wendy2702 created this issue in copystring/ioBroker.roborock
                                          closed Anpassung Kartenupdate #50
                                          • copystring
                                            @wendy2702 Ist schon ok so.
                                            M-A Hueb 1 Reply Last reply Reply Quote 0
                                            766
                                            242580
