    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
    • Damrak2022
      Damrak2022 @Thomas Braun last edited by Damrak2022
      @thomas-braun Jetzt scheint es zu gehen,, sind aber noch viele errors drin:
      (.venv) pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
      2022-04-23 00:14:07,252 - INFO: Done parsing config file
      2022-04-23 00:14:07,265 - INFO: Database <db> not found, trying to create it
      2022-04-23 00:14:07,276 - INFO: Connection to InfluxDB established and database present
      2022-04-23 00:14:08,899 - INFO: Successfully connected to FritzBox
      2022-04-23 00:14:08,900 - INFO: Starting main loop
      2022-04-23 00:14:09,201 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:09,212 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:09,313 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
      2022-04-23 00:14:09,314 - ERROR: Encountered problems while requesting data. Data might be incomplete.
      2022-04-23 00:14:18,832 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:18,844 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:18,943 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
      2022-04-23 00:14:18,943 - ERROR: Encountered problems while requesting data. Data might be incomplete.
      2022-04-23 00:14:28,634 - ERROR: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:28,679 - ERROR: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
      2022-04-23 00:14:28,777 - ERROR: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
      2022-04-23 00:14:28,777 - ERROR: Encountered problems while requesting data. Data might be incomplete.
      Ich habe in der .ini noch keinen Datenbanknamen vergeben.
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Damrak2022 last edited by
        @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
        Ich denke da muss jetzt der user und dessen Passwort auf der Fritzbox angegeben werden. Sonst kann der Kram nicht von dort ausgelesen werden.
        • Damrak2022
          @thomas-braun Der ist drin. Ich schaue mal was ich noch hinbekomme. Ansonsten frage ich heute nochmal bei Dir ich.
          Bis dann und Danke
            @damrak2022
            Ist das ein Kabelanschluss?
            WANDSLInterfaceConfig hört sich nach DSL an. Das dürfte auf einer FritzCable-Box nicht vorhanden sein.
            • Damrak2022
              @thomas-braun Jepp, da gibt es auch schon einiges bei Github, weil die Anleitung sich wohl mehr auf eine DSL Box bezieht, aber viele eine 6591 Cable, so wie ich haben.
              Ich habe da auch schon gepostet und hoffe, das sich irgendwann auch eine Cable Box vollständig abfragen lässt. Jetzt werde ich mal versuchen das Grafana Dashboard zu realisieren.
                A Former User @Damrak2022 last edited by
                @damrak2022 said in Fritzbox mit Grafana visualisieren [Version 2022]:
                2022-04-23 00:14:07,265 - INFO: Database <db> not found, trying to create it 2022-04-23 00:14:07,276 - INFO: Connection to InfluxDB established and database present
                doch Du hattest den Standard in der "fritzinfluxdb.ini", daher heißt Deine Datenbank in "influxdb" jetzt "db".
                VG
                Bernd
                • Damrak2022
                  Damrak2022 @Guest last edited by
                  @dp20eic Ich danke Dir, das klappt jetzt glücklicherweise alles
                  Rene R 1 Reply Last reply Reply Quote 0
                  • Rene R
                    Rene R @Damrak2022 last edited by Rene R
                    @damrak2022
                    Kannst du mir vielleicht helfen ich bekomme es nicht am laufen was hast du bei dir in der .ini alles drin???
                    Habe ne fritzbox 6490
                    So läuft aber bekomme keine daten..
                    (.venv) pi@raspberrypi:/opt/fritzinfluxdb $ python3 ./fritzinfluxdb.py
                    2022-09-02 23:07:51,955 - INFO: Starting fritzinfluxdb v1.0.1 (2022-08-22)
                    2022-09-02 23:07:51,957 - INFO: Done reading config files
                    2022-09-02 23:07:52,011 - INFO: Successfully parsed config
                    2022-09-02 23:07:52,024 - INFO: Connection to InfluxDB 1.8.10 established and database present
                    2022-09-02 23:07:53,656 - INFO: Successfully established FritzBox TR-069 session
                    2022-09-02 23:07:54,735 - INFO: Successfully established FritzBox Lua session
                    2022-09-02 23:07:54,735 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritzbox) Model: FRITZ!Box 6490 Cable - FW: 7.29
                    2022-09-02 23:07:54,741 - INFO: Starting main loop
                    2022-09-02 23:07:55,460 - INFO: Requested invalid action 'GetInfo' for service: WANDSLInterfaceConfig
                    2022-09-02 23:07:55,460 - INFO: Querying action 'GetInfo' will be disabled
                    2022-09-02 23:07:55,474 - INFO: Requested invalid action 'GetStatisticsTotal' for service: WANDSLInterfaceConfig
                    2022-09-02 23:07:55,475 - INFO: Querying action 'GetStatisticsTotal' will be disabled
                    2022-09-02 23:07:55,488 - INFO: Requested invalid action 'X_AVM-DE_GetDSLInfo' for service: WANDSLInterfaceConfig
                    2022-09-02 23:07:55,488 - INFO: Querying action 'X_AVM-DE_GetDSLInfo' will be disabled
                    2022-09-02 23:07:55,488 - INFO: All actions for service 'WANDSLInterfaceConfig' are unavailable. Disabling service.
                    2022-09-02 23:07:55,544 - INFO: Requested invalid action 'GetInfo' for service: WANPPPConnection:1
                    2022-09-02 23:07:55,544 - INFO: Querying action 'GetInfo' will be disabled
                    2022-09-02 23:07:55,545 - INFO: All actions for service 'WANPPPConnection:1' are unavailable. Disabling service.
                    2022-09-02 23:08:19,603 - INFO: Unable to request FritzBox Lua service 'DSL Info'
                    2022-09-02 23:08:19,603 - INFO: FritzBox Lua service 'DSL Info' will be disabled.
                    Rene
                    • framp
                      framp @crunchip last edited by framp
                      Unhandled python exception in init callback: OSError: fritzcollectd: Failed to connect to fritz.box", was mir sagt das mein FritzOS wohl zu neu ist.
                      Ich hatte das Problem auch. Allerdings liegt es nicht an einer zu neuen FB sondern daran, dass der Connect etwas laenger dauert und fritzcollectd keinen Connect Retry hat. Den habe ich eingebaut und schon ist die Fehlermeldung weg :-). Der Fix steht ich hier in meinem Fork zur allgemeinen Verfuegung.
                      Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                      Jan 28 23:53:22 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
                      Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                      Jan 28 23:53:25 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Retrying in 3 seconds ...
                      Jan 28 23:53:28 raspberrypi-bullseye-docker-64 collectd[547]: fritzcollectd: Connecting to FRITZ Box ...
                      Jan 28 23:53:33 raspberrypi-bullseye-docker-64 collectd[547]: Initialization complete, entering read-loop.
                      • I
                        iobroJB @crunchip last edited by iobroJB
                        @crunchip Hallo, ich antworte jetzt einfach mal Dir.
                        Ich habe noch wenig Erfahrung mit iobroker und grafana,
                        habe aber nach der obigen Anweisung hier und den weiteren Hilfen in diesem Beitrag, die Installationen denke ich richtig hinbekommen.
                        Da das BeispielDashboard in obigen Beitrag nicht mehr aufrufbar ist, habe ich aus einem anderen Beitrag hier (ganz am Ende des Textes) das Dashboard hier importiert.
                        Leider zeigt Grafana keine Werte an, obwohl ich die vorhandene influxdb zugewiesen habe und auch den Wert für die FritzBox entsprechend ausgewählt habe.
                        Habe ich noch etwas vergessen, übersehen oder falsch gemacht?
                        Ich bitte um Eure Hilfe, danke.
                        ? crunchip 2 Replies Last reply Reply Quote 0
                          A Former User @iobroJB last edited by
                          @iobrojb
                          Moin,
                          warum bist Du nicht nach dem offiziellen Installations Doku vorgegangen fritzinfluxdb?
                          Benutzt Du influxDB V. 1.8 oder influxDB V.2.x?
                          Welche Version setzt Du von fritzinfluxdb ein (Aktuell ist 1.2.1)
                          Ist influxDB auch der korrekte Name der Datenbank, Zeig mal die zu fitzinfluxdb passende Konfiguration /opt/fritzinfluxdb/fritzinfluxdb.ini
                          !!!Achtung!!! da können User und Passwort im Klartext stehen
                          Installations Beispiel für Ubuntu, sieh obigen link
                          sudo apt-get install python3-virtualenv
                          cd /opt
                          git clone https://github.com/bb-Ricardo/fritzinfluxdb.git
                          cd fritzinfluxdb
                          virtualenv -p python3 .venv
                          . .venv/bin/activate
                          pip3 install -r requirements.txt
                          modify your configuration and test it
                          ./fritzinfluxdb.py
                          Wenn Du das ganze über systemd startest, was sagt dir
                          # systemctl status fritzinfluxdb.service
                          Bei mir sieht das so aus:
                          [dp20eic@loki fritzinfluxdb]$ systemctl status fritzinfluxdb.service
                          * fritzinfluxdb.service - Fritz to InfluxDB daemon
                               Loaded: loaded (/usr/lib/systemd/system/fritzinfluxdb.service; enabled; preset: disabled)
                               Active: active (running) since Wed 2023-02-01 17:11:39 CET; 3min 5s ago
                             Main PID: 187969 (python)
                                Tasks: 1 (limit: 38366)
                               Memory: 34.4M
                               CGroup: /system.slice/fritzinfluxdb.service
                                       `-187969 /opt/fritzinfluxdb/.venv/bin/python /opt/fritzinfluxdb/fritzinfluxdb.py -d
                          Feb 01 17:11:40 loki fritzinfluxdb[187969]: INFO: Connection to InfluxDB 2.5.1 established and bucket is present
                          Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Unknown FritzBox link type 'Ethernet'. Please report this link type as issue to the gi>
                          Feb 01 17:11:45 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox TR-069 session
                          Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully established FritzBox Lua session
                          Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 (>
                          Feb 01 17:11:46 loki fritzinfluxdb[187969]: /opt/fritzinfluxdb/fritzinfluxdb.py:141: DeprecationWarning: There is no current event loop
                          Feb 01 17:11:46 loki fritzinfluxdb[187969]:   loop = asyncio.get_event_loop()
                          Feb 01 17:11:46 loki fritzinfluxdb[187969]: INFO: Starting main loop
                          Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'DSL Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Lin>
                          Feb 01 17:11:48 loki fritzinfluxdb[187969]: INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model L>
                          Die original Dashboards liegen, wenn Du alles richtig gemacht hast unter den jeweiligen Ordnern für influx1 / influx2
                          [dp20eic@loki ~]$ ls -la /opt/fritzinfluxdb/grafana/
                          total 555
                          drwxr-xr-x 4 root root      6 Jan 25 14:00 .
                          drwxr-xr-x 7 root root     18 Jan 25 14:03 ..
                          -rw-r--r-- 1 root root 356744 Jan 25 14:00 grafana_dashboard.png
                          -rw-r--r-- 1 root root 164338 Jan 25 14:00 grafana_home-automation_dashboard.png
                          drwxr-xr-x 2 root root      5 Jan 25 14:00 influx1_dashboards
                          drwxr-xr-x 2 root root      6 Jan 25 14:00 influx2_dashboards
                          !!!Achtung!!!
                          fritzinfluxdb für influxDb V. 1.8 wird vom Developer nicht mehr weiter entwickelt.
                          VG
                          Bernd
                            crunchip Forum Testing Most Active @iobroJB last edited by
                            @iobrojb sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                            Sind denn auch Daten in der Datenbank?
                            Ich hatte das wie weiter oben geschrieben, per upnp Adapter laufen, der die Daten holte und die query's im Dashboard entsprechend angepasst.
                            Nutze das allerdings seit rund 3 Jahren nicht mehr
                              Maxtor62 @Guest last edited by Maxtor62
                              @dp20eic
                              hi, ist ein alter Thread aber ich versuch es trotzdem.
                              Ich habe jetzt schon Proxmox LXC Container mit Debian 11 + 12, Ubuntu 22.04 + 23.04 versucht das Teil ans Laufen zu bringen.
                              Auch mit nem Docker auf dem Synology NAS hab ich es versucht. Was soll ich sagen? Es klappt einfach nicht. Kann das an meiner Fritte liegen. Das ist die 7590 AX. Wäre super, wenn mir jemand noch n Tipp geben könnte. Hier die Logs dazu.
                              (.venv) stefan@helper:/opt/fritzinfluxdb$ ./fritzinfluxdb.py
                              2023-10-31 18:15:40,918 - INFO: Starting fritzinfluxdb v1.2.1 (2023-01-26)
                              2023-10-31 18:15:40,918 - INFO: Done reading config files
                              2023-10-31 18:15:40,938 - INFO: Successfully parsed config
                              2023-10-31 18:15:40,940 - INFO: Connection to InfluxDB 2 established
                              2023-10-31 18:15:46,412 - INFO: Successfully established FritzBox TR-069 session
                              2023-10-31 18:15:47,135 - INFO: Successfully established FritzBox Lua session
                              2023-10-31 18:15:47,136 - INFO: Successfully connected to FritzBox '192.168.178.1' (fritz.box) Model: FRITZ!Box 7590 AX (DSL) - FW: 7.                                     57
                              2023-10-31 18:15:47,136 - INFO: Starting main loop
                              2023-10-31 18:15:59,125 - INFO: Service 'Cable Info (Fritz!OS 7.29 - latest)' not applicable for this FritzBox Model Link type 'DSL'
                              2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:16:00,134 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:16:24,525 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:16:30,738 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:16:30,767 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:35,802 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:40,870 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:45,920 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:50,991 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:16:56,016 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:17:02,085 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:17:03,083 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:08,623 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:14,134 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:19,203 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:24,889 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:30,976 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:33,338 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:17:33,339 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:17:36,381 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:41,420 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:46,463 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:51,571 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:17:56,971 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:02,262 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:18:05,602 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:18:07,437 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:17,150 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:22,474 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:29,000 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:35,006 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-673710080' for 'ha_alert' to '<class 'int'>': invalid literal                                      for int() with base 10: '0-673710080'
                              2023-10-31 18:18:36,383 - ERROR: Unable to convert FritzBox Lua value '0-1865154560' for 'ha_alert' to '<class 'int'>': invalid litera                                     l for int() with base 10: '0-1865154560'
                              2023-10-31 18:18:40,422 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:45,471 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:51,073 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              2023-10-31 18:18:56,581 - ERROR: Failed to write to InfluxDB '192.168.178.139': 422: failure writing points to database: partial write                                     : field type conflict: input field "ha_alert" on measurement "fritzbox" is type string, already exists as type integer dropped=2
                              ^C2023-10-31 18:19:01,953 - INFO: Received exit signal SIGINT...
                              2023-10-31 18:19:01,954 - INFO: Cancelling 4 outstanding tasks
                              2023-10-31 18:19:01,955 - INFO: Closed FritzBox TR-069 connection
                              2023-10-31 18:19:01,955 - INFO: Closed FritzBox Lua connection
                              2023-10-31 18:19:01,955 - INFO: Closed InfluxDB session
                              2023-10-31 18:19:01,955 - INFO: Successfully shutdown fritzinfluxdb
                              Die Datenbank wird kurz mit Daten gefüttert, die ich auch mit Grafana darstellen sehe, aber nach ca. einer Minute sind die Daten wieder weg, N/A.
                                A Former User @Maxtor62 last edited by
                                @maxtor62 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                                Moin,
                                wie ist die FritzBox eingerichtet, welchen User nutzt Du zum Login?
                                Die Einrichtung im LX Container hast Du nach Vorgabe wie auf der Github Seite gemacht, also auch fritzconnection und alle Python Module installiert?
                                Zeig mal die fritzinfluxdb.ini aber nimm vorher den User und das Passwort raus, oder x es aus
                                VG
                                Bernd
                                  @dp20eic
                                  hi sorry für meine Ungeduld. Hab halt schon so viel probiert.
                                  Auf der Fritte hab ich extra ein User eingerichtet den ich dafür nehme. Hat alle Rechte.
                                  Die Einrichtung habe ich jedes Mal genau so wie Du oder auf Github beschrieben, gemacht.
                                  Fritzconnection und alle Python Module installiert.
                                  Hier die fritzinfluxdb.ini
                                  [influxdb]
                                  # requires a hostname or IP which points to your InfluxDB instance
                                  hostname = 192.168.178.139
                                  # define the port your InfluxDB instance is listening on
                                  port = 8086
                                  # weather TLS encryption is enabled or disabled
                                  #tls_enabled = false
                                  # set this to 'true' to enforces TLS certificate validation
                                  #verify_tls = false
                                  # set a measurement name which is used to write the data to InfluxDB
                                  # If this is changed from the default then it also has to be changed
                                  # from the default value during the Grafana dashboard installation
                                  measurement_name = fritzbox
                                  # The amount of days the data should be stored in InfluxDB.
                                  # Older data will be deleted.
                                  # Attention: THIS IS ONLY CONFIGURED ON NEW DB/BUCKET CREATION!
                                  data_retention_days = 365
                                  # define which InfluxDB version you are using
                                  version = 2
                                  ##### InfluxDB version 1.x options
                                  # username and password to use to write data to InfluxDB
                                  username =
                                  password =
                                  # defines the InfluxDB database to write the data to
                                  # if the credentials permit to create databases then this
                                  # will be created automatically
                                  database =
                                  ##### InfluxDB version 2.x options
                                  # requires an InfluxDB API token with permissions to write to the desired bucket
                                  token = RRoG5NJBBUqnql1OKaHuxo3d2xqz0YpA-2AOO-fviu1Ft5mpafJizebVkpiQdGxwdtQvDv3AUJvXWLMreSQ1NA==
                                  # a valid InfluxDB organisation needs to be defined which is used during login
                                  organisation = home
                                  # defines the InfluxDB bucket to write the data to
                                  # if the credentials permit to create buckets then this
                                  bucket = fritzbox
                                  ### [fritzbox]
                                  ### Controls the parameters for connecting to your InfluxDB instance.
                                  [fritzbox]
                                  # changes the default FritzBox IP
                                  # username and password to connect to the FritzBox
                                  username = XXXX
                                  password = XXXX
                                  # Define the port the FritzBox is listening on
                                  # change to 49443 if you use ssl
                                  port = 49000
                                  # weather TLS encryption is enabled or disabled (will set port to 49443 if port is undefined)
                                  # set this to 'true' to enforces TLS certificate validation (only affects Lua sessions)
                                  #verify_tls = false
                                  # defines the InfluxDB measurement tag which is used
                                  # to tag data from this FritzBox
                                  #box_tag = fritz.box
                                  # Define the FritzBox time zone. Used to convert dates/times from FritzBox to correct UTC Timestamp
                                  timezone = Europe/Berlin
                                  # the maximum of time in seconds which a connection to the FritzBox is allowed to take
                                  connect_timeout = 30
                                  # interval to request data from FritzBox in seconds
                                  # the value CAN'T be lower then 10 seconds
                                  request_interval = 30
                                  # EOF
                                  Danke und Grüße
                                    Moin,
                                    also da sehe ich erst einmal keine Klinke.
                                    Ich habe mal nach dem im Log aufgeführten Fehler ha_alert im Source auf Github gesucht, das kommt wohl aus dem Bereich homeauto.py, jetzt kann ich damit aber auch nicht mehr anfangen, ob das jetzt an der FritzBox liegt, oder ob die Version 7.57 da für die AX eine Macke hat oder ob Du da vielleicht Geräte in Samrt Home eingerichtet hast und deswegen der Fehler kommt.
                                    Warte einfach mal ab, was bb-Ricardo zu dem Fehler sagt.
                                    VG
                                    Bernd
                                      @dp20eic
                                      ok, danke für Deine Mühe. Im SmatHome hab ich nur Fritz Geräte über DECT eingerichtet, außer die drei Rollladen Motoren. Die sind von BoxControl, was auch über DECT läuft. Da sollte die Fritte ja kein Problem haben.
                                      Ich werde mich in Geduld üben.
                                      Stefan
                                        Moin,
                                        na dann kann es ja doch sein, dass da etwas nicht korrekt eingerichtet oder installiert ist. Du solltest mal gleich dein issuse auf Github mit allen Informationen erweitern, damit bb-Ricardo nicht erst noch nachfragen muss, verzögert dann ja nur zusätzlich.
                                        VG
                                        Bernd
                                          @dp20eic
                                          es ist unglaublich.
                                          FritzBox boot tut gut.
                                          Jetzt funktioniert alles.
                                          Danke Dir noch mal.
                                          Stefan
                                            Danke Dir noch mal.
                                            Moin,
                                            bidde schön, ist aber nicht meine Verdienst, Du kannst Dich bei bb-Ricardo bedanken.
                                            Und ja, mach mal, tut ein Boot gut 🙂
                                            VG
                                            Bernd
                                            1.5k
                                            144
                                            20482
